[Mapbender-commits] r5850 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Mon Mar 29 04:04:43 EDT 2010
Author: christoph
Date: 2010-03-29 04:04:20 -0400 (Mon, 29 Mar 2010)
New Revision: 5850
trunk/mapbender/http/plugins/jq_upload.js
trunk/mapbender/http/plugins/jq_upload.php
added configuration options
Modified: trunk/mapbender/http/plugins/jq_upload.js
--- trunk/mapbender/http/plugins/jq_upload.js 2010-03-29 08:03:10 UTC (rev 5849)
+++ trunk/mapbender/http/plugins/jq_upload.js 2010-03-29 08:04:20 UTC (rev 5850)
@@ -24,7 +24,7 @@
time = 0;
var returnValueArray = returnValue.split("_");
- var filename = returnValueArray[returnValueArray.length - 2];
+ var filename = returnValueArray[returnValueArray.length - 3];
var origFilename = window.frames[id+"_target"].filename;
var msg = "";
var success = false;
Modified: trunk/mapbender/http/plugins/jq_upload.php
--- trunk/mapbender/http/plugins/jq_upload.php 2010-03-29 08:03:10 UTC (rev 5849)
+++ trunk/mapbender/http/plugins/jq_upload.php 2010-03-29 08:04:20 UTC (rev 5850)
@@ -11,7 +11,7 @@
$uploadedFile = $_FILES['myfile']['tmp_name'];
$clientFilename = $_FILES['myfile']['name'];
- $serverFilename = Mapbender::session()->get("mb_user_id") . "_" . uniqid(true);
+ $serverFilename = Mapbender::session()->get("mb_user_id") . "-" . uniqid(true);
$uploadDir = TMPDIR;
if (defined("UPLOAD_DIR")) {
@@ -22,6 +22,8 @@
$allowedFileTypes = explode(",", UPLOAD_WHITELIST_FILE_TYPES);
+ new mb_exception(1);
// check if file type is valid
foreach ($allowedFileTypes as $item) {
$cancel = true;
@@ -31,6 +33,7 @@
break;
+ new mb_exception(2);
$disallowedFileTypes = array("PHP", "PHP3", "PHP4", "PHTML", "PHP5", "PHP6");
if (defined("UPLOAD_BLACKLIST_FILE_TYPES")) {
@@ -39,7 +42,8 @@
+ new mb_exception(3);
foreach ($disallowedFileTypes as $item) {
if(preg_match("/\.$item\$/i", $clientFilename)) {
@@ -48,6 +52,7 @@
break;
+ new mb_exception(4);
$maxSize = intval(ini_get("upload_max_filesize"))*1024;
if (defined("UPLOAD_MAX_SIZE_KB") && UPLOAD_MAX_SIZE_KB < $maxSize) {
$maxSize = UPLOAD_MAX_SIZE_KB;
@@ -62,7 +67,8 @@
if ($pos !== false) {
$extension = substr($clientFilename, $pos);
- $serverFullFilename = $uploadDir . "/" . $serverFilename . $extension;
+ $serverFilename .= $extension;
+ $serverFullFilename = $uploadDir . "/" . $serverFilename;
if (!$cancel) {
if (!copy($uploadedFile, $serverFullFilename)) {
$status = "cancelled";
@@ -82,7 +88,7 @@
<head>
<script type="text/javascript">
window.id = "<?php
- echo $id . "_" . $serverFilename . "_" . $status . "_" . $message;
+ echo $id . "_" . $serverFullFilename . "_" . $status . "_" . $message;
window.filename = "<?php echo $clientFilename; ?>";
</script>
More information about the Mapbender_commits
