[Mapbender-commits] r6055 - in trunk/mapbender: http/javascripts
resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Mon May 3 04:40:01 EDT 2010
Author: verenadiewald
Date: 2010-05-03 04:40:00 -0400 (Mon, 03 May 2010)
New Revision: 6055
trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
added possibility to remove spatialRequestHighlight in gazetteerWFS when firing search as element var for gazetteerWFS
Modified: trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
--- trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php 2010-04-30 14:29:21 UTC (rev 6054)
+++ trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php 2010-05-03 08:40:00 UTC (rev 6055)
@@ -77,6 +77,10 @@
* > 'enableSearchWithoutParams', '0',
* > 'define that search can be started without any search params' ,
* > 'var');
+ * > INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES('<appId>', 'gazetteerWFS',
+ * > 'removeSpatialRequestHighlight', '0', 'remove spatialrequest highlighting when firing search' ,'var');
* Help:
* http://www.mapbender.org/GazetteerWFS
@@ -91,6 +95,7 @@
* initializeOnLoad - start gazetteer onload
* enableSearchWithoutParams - define that search can be started without any
* search params
+ * removeSpatialRequestHighlight - remove spatialrequest highlighting when firing search
* License:
* Copyright (c) 2009, Open Source Geospatial Foundation
@@ -126,6 +131,9 @@
// Element var to allow search without any search params
try {if(enableSearchWithoutParams){}}catch(e) {enableSearchWithoutParams = 0;}
+//Element var to remove spatialrequest highlighting when firing search
+try {if(removeSpatialRequestHighlight){}}catch(e) {removeSpatialRequestHighlight = 0;}
var targetArray = targetString.split(",");
var global_wfsConfObj;
var global_selectedWfsConfId;
@@ -969,6 +977,11 @@
//close old dialogs
parent.$('.resultList').dialog('close');
parent.$('.infoPopup').dialog('close');
+ if(removeSpatialRequestHighlight == 1) {
+ requestGeometryHighlight.clean();
+ requestGeometryHighlight.paint();
var filterParameterCount = getNumberOfFilterParameters();
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-04-30 14:29:21 UTC (rev 6054)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-05-03 08:40:00 UTC (rev 6055)
@@ -2373,6 +2373,6 @@
INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','deleteWFSConf',2,1,'delete wfs conf','','a','','href = "../javascripts/mod_deleteWfsConf_client.html" target="AdminFrame"',10,1204,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WFS CONF','a','','','','AdminFrame','');
+-- element var removeSpatialRequestHighlight for gazetteerWFS
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'removeSpatialRequestHighlight', '0', 'remove spatialrequest highlighting when firing search' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'removeSpatialRequestHighlight' AND fkey_e_id = 'gazetteerWFS');
More information about the Mapbender_commits
