[Mapbender-commits] r6064 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Mon May 3 10:20:41 EDT 2010
Author: christoph
Date: 2010-05-03 10:20:41 -0400 (Mon, 03 May 2010)
New Revision: 6064
trunk/mapbender/http/plugins/mb_metadata_server.php
categories
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php 2010-05-03 14:20:18 UTC (rev 6063)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php 2010-05-03 14:20:41 UTC (rev 6064)
@@ -85,7 +85,8 @@
$resultObj = array();
while ($row = db_fetch_assoc($res)) {
foreach ($row as $key => $value) {
- $resultObj["wms:".$key] = $value;
+// $resultObj["wms:".$key] = $value;
+ $resultObj[$key] = $value;
$ajaxResponse->setResult($resultObj);
@@ -96,22 +97,23 @@
case "getCategories":
$resultObj = array(
- "inspire" => array(),
- "custom" => array()
+ "categories" => array(
+ "fkey_inspire_category_id" => array(),
+ "fkey_custom_category_id" => array()
$sql = "SELECT inspire_category_id, inspire_category_code_en FROM inspire_category";
$res = db_query($sql);
while ($row = db_fetch_row($res)) {
- $resultObj["inspire"][]= $row;
+ $resultObj["categories"]["fkey_inspire_category_id"][]= $row;
$sql = "SELECT custom_category_id, custom_category_code_en FROM custom_category";
- $resultObj = array();
- $resultObj["custom"][]= $row;
+ $resultObj["categories"]["fkey_custom_category_id"][]= $row;
$ajaxResponse->setSuccess(true);
More information about the Mapbender_commits
