[Mapbender-commits] r6066 - in trunk/mapbender: conf
http/javascripts http/php
svn_mapbender at osgeo.org
Tue May 4 03:55:37 EDT 2010
Author: verenadiewald
Date: 2010-05-04 03:55:36 -0400 (Tue, 04 May 2010)
New Revision: 6066
Added:
trunk/mapbender/http/php/mod_digitize_mergeLines.php
trunk/mapbender/conf/digitize_default.conf
trunk/mapbender/http/javascripts/mod_digitize_tab.php
trunk/mapbender/http/php/mod_digitize_messages.php
new digitize functionality to merge 2 lines into a single line
Modified: trunk/mapbender/conf/digitize_default.conf
--- trunk/mapbender/conf/digitize_default.conf 2010-05-03 14:21:18 UTC (rev 6065)
+++ trunk/mapbender/conf/digitize_default.conf 2010-05-04 07:55:36 UTC (rev 6066)
@@ -14,6 +14,7 @@
addButtonDig("digitizeDifference", 1, "punchPolygon_off.png", "", "", 28, 28);
addButtonDig("digitizeMerge", 1, "mergePolygons_off.png", "", "", 56, 28);
addButtonDig("lineContinue", 1, "line_continue_off.png", "", "", 85, 28);
+addButtonDig("mergeLine", 1, "mergeLines_off.png", "", "", 114, 28);
//definition of directory of digitize buttons
buttonDig_imgdir = "../img/button_digitize/";
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php 2010-05-03 14:21:18 UTC (rev 6065)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php 2010-05-04 07:55:36 UTC (rev 6066)
@@ -307,6 +307,7 @@
var button_split = "digitizeSplit";
var button_merge = "digitizeMerge";
var button_difference = "digitizeDifference";
+var button_line_merge = "mergeLine";
var _currentGeomIndex = -1;
var digitizeDivTag;
@@ -1165,6 +1166,14 @@
currentTitle = msgObj.buttonLabelDifferenceOff;
break;
+ case "mergeLine":
+ if (currentStatus == 1) {
+ currentTitle = msgObj.buttonLabelMergeLineOn;
+ else {
+ currentTitle = msgObj.buttonLabelMergeLineOff;
+ break;
currentButton.title = currentTitle;
@@ -1193,7 +1202,8 @@
else if (obj.id == button_point || obj.id == button_line ||
obj.id == button_polygon || obj.id == button_clear ||
obj.id == button_split || obj.id == button_merge ||
- obj.id == button_difference || obj.id == button_line_continue){
+ obj.id == button_difference || obj.id == button_line_continue ||
+ obj.id == button_line_merge){
var el = mapDomElement;
$(el).mousemove(function (e) {
@@ -1407,6 +1417,59 @@
parent.mb_disableThisButton(mod_digitizeEvent);
+ else if (obj.id == button_line_merge) {
+ //var applicable = (d.count() > 1);
+/* var lineTextArray = [];
+ for (var i = 0; i < d.count(); i++) {
+ if (d.get(i).geomType != parent.geomType.line) {
+ applicable = false;
+ lineTextArray = [];
+ break;
+ lineTextArray.push(d.get(i).toText());
+ var applicable = (d.count() == 2) &&
+ (d.get(0).geomType == parent.geomType.line) &&
+ (d.get(1).geomType == parent.geomType.line);
+ if (!applicable) {
+ alert(msgObj.messageErrorMergeLineNotApplicable);
+ parent.mb_disableThisButton(mod_digitizeEvent);
+ return false;
+ var line1Text = d.get(0).toText();
+ var line2Text = d.get(1).toText();
+ parent.mb_ajax_post("../php/mod_digitize_mergeLines.php", {line1: line1Text, line2: line2Text}, function(json, status) {
+ var response = eval('(' + json + ')');
+ var line = response.line;
+ if(line == "") {
+ alert(msgObj.errorMessageInvalidLineGeometries);
+ return false;
+ var wfsConfId = d.get(0).wfs_conf;
+ var wfsProperties = d.get(0).e;
+ var mapIndex = parent.getMapObjIndexByName(mod_digitize_target);
+ d.importGeometryFromText(line, parent.mb_mapObj[mapIndex].epsg);
+ d.get(-1).wfs_conf = wfsConfId;
+ for (var i = 0; i < wfsProperties.count(); i++) {
+ d.get(-1).e.setElement(wfsProperties.getName(i), wfsProperties.getValue(i));
+ // remove the original lines
+ var len = d.count();
+ for (var i = 0; i < len-1; i++) {
+ d.del(0);
else {
alert("unknown type: " + obj.id);
Added: trunk/mapbender/http/php/mod_digitize_mergeLines.php
--- trunk/mapbender/http/php/mod_digitize_mergeLines.php (rev 0)
+++ trunk/mapbender/http/php/mod_digitize_mergeLines.php 2010-05-04 07:55:36 UTC (rev 6066)
@@ -0,0 +1,92 @@
+<?php
+# $Id: mod_digitize_mergePolygon.php 4691 2009-09-25 10:39:48Z christoph $
+# http://www.mapbender.org/index.php/DeleteWMS
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
+$json = new Mapbender_JSON();
+$line1 = $_REQUEST["line1"];
+$line2 = $_REQUEST["line2"];
+#$lineList = $_REQUEST["lines"];
+$floatPattern = "-?\d+(\.\d+)?";
+$pointPattern = $floatPattern . " " . $floatPattern;
+$linePattern = "LINESTRING \(" . $pointPattern . ",( )*" . $pointPattern . "(,( )*" . $pointPattern . ")*\)";
+$pattern = "/" . $linePattern . "/";
+#if (!preg_match($pattern, $lineList)) {
+# echo "not a line.";
+# die();
+if (!preg_match($pattern, $line1)) {
+ echo "Line 1 not a line.";
+ die();
+if (!preg_match($pattern, $line2)) {
+ echo "Line 2 not a line.";
+ die();
+#$lineArray = explode(";", $lineList);
+//check for valid lines for merging (2 lines)
+$sql = "SELECT ";
+$sql .= "ST_StartPoint(ST_GeomFromText('" . $line1 . "')) = ST_StartPoint(ST_GeomFromText('" . $line2 . "')) as a, ";
+$sql .= "ST_StartPoint(ST_GeomFromText('" . $line1 . "')) = ST_EndPoint(ST_GeomFromText('" . $line2 . "')) as b, ";
+$sql .= "ST_EndPoint(ST_GeomFromText('" . $line1 . "')) = ST_StartPoint(ST_GeomFromText('" . $line2 . "')) as c, ";
+$sql .= "ST_EndPoint(ST_GeomFromText('" . $line1 . "')) = ST_EndPoint(ST_GeomFromText('" . $line2 . "')) as d";
+$res = db_query($sql);
+$row = db_fetch_array($res);
+if($row['a'] == 't' || $row['b'] == 't' || $row['c'] == 't' || $row['d'] == 't') {
+ $sql = "SELECT ST_AsText(multi(st_linemerge(st_collect_garray(ARRAY[";
+ $sql .= "ST_GeomFromText('" . $line1 . "'), ST_GeomFromText('" . $line2 . "')";
+/* for ($i = 0; $i < count($lineArray); $i++) {
+ if ($i > 0) {
+ $sql .= ", ";
+ $sql .= "ST_GeomFromText('" . $lineArray[$i] . "')";
+ $sql .= "])))) as a";
+ #echo $sql;
+ $res = db_query($sql);
+ $lineArray = array();
+ $row = db_fetch_array($res);
+ $data = array("line" => $row[0]);
+else {
+ $data = array("line" => "");
+$output = $json->encode($data);
+header("Content-type:application/x-json; charset=utf-8");
+echo $output;
\ No newline at end of file
Modified: trunk/mapbender/http/php/mod_digitize_messages.php
--- trunk/mapbender/http/php/mod_digitize_messages.php 2010-05-03 14:21:18 UTC (rev 6065)
+++ trunk/mapbender/http/php/mod_digitize_messages.php 2010-05-04 07:55:36 UTC (rev 6066)
@@ -26,6 +26,7 @@
$msg_obj["messageErrorMergeNotApplicable"] = _mb("At least two geometries must be available. Only polygons are allowed in the geometry list.");
$msg_obj["messageErrorSplitNotApplicable"] = _mb("Exactly two geometries must be available. The first geometry shall be a polygon or a line, the second geometry shall be a line.");
$msg_obj["messageErrorDifferenceNotApplicable"] = _mb("Exactly two polygons must be available.");
+$msg_obj["messageErrorMergeLineNotApplicable"] = _mb("Exactly two lines must be available.");
$msg_obj["messageSuccessWfsWrite"] = _mb("Success.");
$msg_obj["messageConfirmDeleteGeomFromDb"] = _mb("Delete geometry from database?");
$msg_obj["messageConfirmDeleteAllGeomFromList"] = _mb("Clear list of geometries?");
@@ -36,6 +37,7 @@
$msg_obj["buttonLabelAbort"] = _mb("Abort");
$msg_obj["errorMessageEpsgMismatch"] = _mb("Fatal error: EPSG mismatch. ");
$msg_obj["errorMessageNoGeometrySelected"] = _mb("No geometry selected!");
+$msg_obj["errorMessageInvalidLineGeometries"] = _mb("No valid line geometries for merging! Please check start and end points of your lines.");
$msg_obj["buttonLabelPointOff"] = _mb("add point");
$msg_obj["buttonLabelPointOn"] = _mb("cancel editing");
$msg_obj["buttonLabelLineOff"] = _mb("add line");
@@ -58,6 +60,8 @@
$msg_obj["buttonLabelSplitOn"] = _mb("Split a polygon/line by a line (the new polygons/lines will be added to the geometry list)");
$msg_obj["buttonLabelDifferenceOff"] = _mb("Combine two polygons (to create en- and exclave or to compute the difference)");
$msg_obj["buttonLabelDifferenceOn"] = _mb("Split geometries");
+$msg_obj["buttonLabelMergeLineOff"] = _mb("Merge two lines into a single line");
+$msg_obj["buttonLabelMergeLineOn"] = _mb("Merge two lines into a single line");
$msg_obj["buttonDig_wfs_title"] = _mb("save / update / delete");
$msg_obj["buttonDig_remove_title"] = _mb("remove from workspace");
$msg_obj["buttonDig_removeDb_title"] = _mb("remove from database");
More information about the Mapbender_commits
