[Mapbender-commits] r6073 - in trunk/mapbender/http:
extensions/jsTree.v.0.9.9a2 plugins
svn_mapbender at osgeo.org
Tue May 4 07:51:11 EDT 2010
Author: christoph
Date: 2010-05-04 07:51:10 -0400 (Tue, 04 May 2010)
New Revision: 6073
trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/jquery.tree.js
trunk/mapbender/http/plugins/mb_metadata_layer.js
trunk/mapbender/http/plugins/mb_metadata_layerTree.js
trunk/mapbender/http/plugins/mb_metadata_select.js
trunk/mapbender/http/plugins/mb_metadata_server.php
Modified: trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/jquery.tree.js
--- trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/jquery.tree.js 2010-05-04 11:39:59 UTC (rev 6072)
+++ trunk/mapbender/http/extensions/jsTree.v.0.9.9a2/jquery.tree.js 2010-05-04 11:51:10 UTC (rev 6073)
@@ -1971,7 +1971,7 @@
str += "' ";
cls = true;
- else str += " " + i + "='" + data.attributes[i] + "' ";
+ else str += " " + i + "='" + data.attributes[i].replace(/[']/g, ''') + "' ";
if(!cls && (data.state == "closed" || data.state == "open")) str += " class='" + data.state + "' ";
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.js
--- trunk/mapbender/http/plugins/mb_metadata_layer.js 2010-05-04 11:39:59 UTC (rev 6072)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.js 2010-05-04 11:51:10 UTC (rev 6073)
@@ -50,7 +50,52 @@
that.events.initialized.done = true;
+ this.fillForm = function (obj) {
+ // layer data
+ console.log(obj);
+ for (var i in obj) {
+ $("#" + i).val(obj[i]);
+ // layer keywords
+ var req = new Mapbender.Ajax.Request({
+ url: "../plugins/mb_metadata_server.php",
+ method: "getCategories",
+ parameters: {
+ "id": obj
+ callback: function(o, r, m) {
+ if (!r) {
+ return;
+ initialized($.extend({
+ wmsId: obj
+ }, o));
+ req.send();
+ // layer categories
+ parameters: {
+ "id": obj
+ if (!r) {
+ return;
+ wmsId: obj
+ }, o));
+ req.send();
this.init = function (obj) {
if (!that.events.initialized.done) {
$metadataForm.load("../plugins/mb_metadata_layer.html", function () {
Modified: trunk/mapbender/http/plugins/mb_metadata_layerTree.js
--- trunk/mapbender/http/plugins/mb_metadata_layerTree.js 2010-05-04 11:39:59 UTC (rev 6072)
+++ trunk/mapbender/http/plugins/mb_metadata_layerTree.js 2010-05-04 11:51:10 UTC (rev 6073)
@@ -31,7 +31,7 @@
attributes: {
data: $.toJSON(set.attr)
- data: set.attr.title,
+ data: set.attr.layer_title,
state: "closed",
children: []
@@ -43,7 +43,7 @@
data: {
- title: set.attr.title
+ title: set.attr.layer_title
@@ -116,7 +116,9 @@
type: "attr",
- that.events.selected.trigger(data);
+ that.events.selected.trigger({
+ "layer": data
Modified: trunk/mapbender/http/plugins/mb_metadata_select.js
--- trunk/mapbender/http/plugins/mb_metadata_select.js 2010-05-04 11:39:59 UTC (rev 6072)
+++ trunk/mapbender/http/plugins/mb_metadata_select.js 2010-05-04 11:51:10 UTC (rev 6073)
@@ -20,6 +20,7 @@
var $metadataSelect = $(this);
+$metadataSelect.prepend("<img src='../img/indicator_wheel.gif'>");
var MetadataSelectApi = function (o) {
var table = null;
@@ -47,6 +48,8 @@
if (!result) {
return;
+ $metadataSelect.find("img").remove();
var aoColumns = [];
for (var i in obj.header) {
if (obj.header[i] === "WMS ID") {
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php 2010-05-04 11:39:59 UTC (rev 6072)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php 2010-05-04 11:51:10 UTC (rev 6073)
@@ -98,11 +98,18 @@
case "getCategories":
$resultObj = array(
"categories" => array(
+ "fkey_md_topic_category_id" => array(),
"fkey_inspire_category_id" => array(),
"fkey_custom_category_id" => array()
+ $sql = "SELECT md_topic_category_id, md_topic_category_code_en FROM md_topic_category";
+ $res = db_query($sql);
+ while ($row = db_fetch_row($res)) {
+ $resultObj["categories"]["fkey_md_topic_category_id"][]= $row;
$sql = "SELECT inspire_category_id, inspire_category_code_en FROM inspire_category";
@@ -160,6 +167,49 @@
$ajaxResponse->setResult($resultObj);
$ajaxResponse->setSuccess(true);
break;
+ case "getLayerCategories" :
+ $layerId = $ajaxResponse->getParameter("id");
+ getLayer($layerId);
+ $resultObj = array(
+ "fkey_inspire_category_id" => array(),
+ "fkey_custom_category_id" => array(),
+ $sql = <<<SQL
+SELECT fkey_md_topic_category_id
+FROM layer_md_topic_category
+WHERE fkey_layer_id = $layerId
+SQL;
+ while ($row = db_fetch_assoc($res)) {
+ $resultObj["fkey_md_topic_category_id"][]= $row;
+ $sql = <<<SQL
+SELECT fkey_inspire_category_id
+FROM layer_inspire_category
+SQL;
+ $resultObj["fkey_inspire_category_id"][]= $row;
+ $sql = <<<SQL
+SELECT fkey_custom_category_id
+FROM layer_custom_category
+SQL;
+ $resultObj["fkey_custom_category_id"][]= $row;
+ $ajaxResponse->setResult($resultObj);
+ $ajaxResponse->setSuccess(true);
+ break;
case "getLayerByWms" :
$wmsId = $ajaxResponse->getParameter("id");
// getWms($wmsId);
@@ -185,9 +235,10 @@
"parent" => $row["layer_parent"] !== "" ? intval($row["layer_parent"]) : null,
"pos" => intval($row["layer_pos"]),
"attr" => array (
- "id" => intval($row["layer_id"]),
- "name" => $row["layer_name"],
- "title" => $row["layer_title"]
+ "layer_id" => intval($row["layer_id"]),
+ "layer_name" => $row["layer_name"],
+ "layer_title" => $row["layer_title"],
+ "layer_abstract" => $row["layer_abstract"]
More information about the Mapbender_commits
