[Mapbender-commits] r6088 - in trunk/mapbender/http: javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 6 09:30:51 EDT 2010
Author: christoph
Date: 2010-05-06 09:30:51 -0400 (Thu, 06 May 2010)
New Revision: 6088
   trunk/mapbender/http/javascripts/mod_changeEPSG.js
   trunk/mapbender/http/php/mod_changeEPSG_server.php
added ajaxChange
removed MySQL
improved error handling
Modified: trunk/mapbender/http/javascripts/mod_changeEPSG.js
--- trunk/mapbender/http/javascripts/mod_changeEPSG.js	2010-05-06 10:19:45 UTC (rev 6087)
+++ trunk/mapbender/http/javascripts/mod_changeEPSG.js	2010-05-06 13:30:51 UTC (rev 6088)
@@ -37,11 +37,76 @@
  * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+(function ($) {
+	$.fn.ajaxChange = function () {
+		var args = arguments;
+		this.each(function () {
+			if (this.tagName.toUpperCase() !== "SELECT") return;
+			var $this = $(this);
+			// initialization
+			if (args.length >= 1 && typeof args[0] === "function") {
+				var f = args[0];
+				var options = {};
+				if (args.length >= 2 && typeof args[1] === "object") {
+					options = args[1];
+				options = $.extend({
+					disable: true,
+					undo: true
+				}, options);
+				$this
+					.data("ajaxChangeDisable", options.disable)
+					.data("ajaxChangeUndo", options.undo)
+					.data("ajaxChangeSelectedIndex", null)
+					.change(function () {
+						if ($this.data("ajaxChangeDisable") === true) {
+							$this.attr("disabled", "disabled");
+						f.apply(this, arguments);
+					.mousedown(function () {
+						if ($this.data("ajaxChangeSelectedIndex") === null
+							&& $this.data("ajaxChangeUndo")
+							$this.data("ajaxChangeSelectedIndex", this.selectedIndex);
+			// control
+			else if (args.length >= 1 && typeof args[0] === "string") {
+				var command = args[0];
+				switch (command) {
+					case "abort":
+							$this.removeAttr("disabled");
+						if ($this.data("ajaxChangeUndo")) {
+							this.selectedIndex = $this.data("ajaxChangeSelectedIndex");
+							$this.data("ajaxChangeSelectedIndex", null);
+						break;
+					case "done":
+						break;
+}(jQuery));
 var $changeEpsg = $(this);
-$changeEpsg.change(function () {
+$changeEpsg.ajaxChange(function () {
 	var srsValue = this.value;
 	if (srsValue === "") {
+		$(this).ajaxChange("abort");
 		return;
 	$changeEpsg.mapbender(function () {
@@ -96,9 +161,11 @@
 	var setSrsCallback = function (obj, success, message) {
 		if (!success) {
+			$changeEpsg.ajaxChange("abort");
 			new Mapbender.Exception(message);
 			return;
+		$changeEpsg.ajaxChange("done");
 		var newExtent = obj;
 		var mapObjNames = [];
Modified: trunk/mapbender/http/php/mod_changeEPSG_server.php
--- trunk/mapbender/http/php/mod_changeEPSG_server.php	2010-05-06 10:19:45 UTC (rev 6087)
+++ trunk/mapbender/http/php/mod_changeEPSG_server.php	2010-05-06 13:30:51 UTC (rev 6088)
@@ -48,43 +48,29 @@
 				is_numeric($oldEPSG) && is_numeric($newEPSG)) {
-				if(SYS_DBTYPE=='pgsql'){
-					$con = db_connect($DBSERVER,$OWNER,$PW);
-					$sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$extArray[0]." ".$extArray[1].")',".$oldEPSG."),".$newEPSG.")) as minx";
-					$resMinx = db_query($sqlMinx);
-					$minx = floatval(db_result($resMinx,0,"minx"));
-					$sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$extArray[0]." ".$extArray[1].")',".$oldEPSG."),".$newEPSG.")) as miny";
-					$resMiny = db_query($sqlMiny);
-					$miny = floatval(db_result($resMiny,0,"miny"));
-					$sqlMaxx = "SELECT X(transform(GeometryFromText('POINT(".$extArray[2]." ".$extArray[3].")',".$oldEPSG."),".$newEPSG.")) as maxx";
-					$resMaxx = db_query($sqlMaxx);
-					$maxx = floatval(db_result($resMaxx,0,"maxx"));
-					$sqlMaxy = "SELECT Y(transform(GeometryFromText('POINT(".$extArray[2]." ".$extArray[3].")',".$oldEPSG."),".$newEPSG.")) as maxy";
-					$resMaxy = db_query($sqlMaxy);
-					$maxy = floatval(db_result($resMaxy,0,"maxy"));
-				}else{
-					$con_string = "host=$GEOS_DBSERVER port=$GEOS_PORT dbname=$GEOS_DB user=$GEOS_OWNER password=$GEOS_PW";
-					$con = pg_connect($con_string) or die ("Error while connecting database");
-					$resMinx = pg_query($con,$sqlMinx);
-					$minx = floatval(pg_fetch_result($resMinx,0,"minx"));
-					$resMiny = pg_query($con,$sqlMiny);
-					$miny = floatval(pg_fetch_result($resMiny,0,"miny"));
-					$resMaxx = pg_query($con,$sqlMaxx);
-					$maxx = floatval(pg_fetch_result($resMaxx,0,"maxx"));
-					$resMaxy = pg_query($con,$sqlMaxy);
-					$maxy = floatval(pg_fetch_result($resMaxy,0,"maxy"));
+				$con = db_connect($DBSERVER,$OWNER,$PW);
+				$sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$extArray[0]." ".$extArray[1].")',".$oldEPSG."),".$newEPSG.")) as minx";
+				$resMinx = db_query($sqlMinx);
+				$minx = floatval(db_result($resMinx,0,"minx"));
+				$sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$extArray[0]." ".$extArray[1].")',".$oldEPSG."),".$newEPSG.")) as miny";
+				$resMiny = db_query($sqlMiny);
+				$miny = floatval(db_result($resMiny,0,"miny"));
+				$sqlMaxx = "SELECT X(transform(GeometryFromText('POINT(".$extArray[2]." ".$extArray[3].")',".$oldEPSG."),".$newEPSG.")) as maxx";
+				$resMaxx = db_query($sqlMaxx);
+				$maxx = floatval(db_result($resMaxx,0,"maxx"));
+				$sqlMaxy = "SELECT Y(transform(GeometryFromText('POINT(".$extArray[2]." ".$extArray[3].")',".$oldEPSG."),".$newEPSG.")) as maxy";
+				$resMaxy = db_query($sqlMaxy);
+				$maxy = floatval(db_result($resMaxy,0,"maxy"));
+				if (!$resMinx || !$resMiny || !$resMaxx || !$resMaxy) {
+					$ajaxResponse->setSuccess(false);
+					$ajaxResponse->setMessage(_mb("The coordinates could not be projected."));
+					$ajaxResponse->send();
 				$extenty = $maxy - $miny;
 				$extentx = $maxx - $minx;
 				$relation_px_x = $currentEpsg->width / $currentEpsg->height;
More information about the Mapbender_commits mailing list
