[Mapbender-commits] r6092 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Thu May 6 09:35:02 EDT 2010
Author: christoph
Date: 2010-05-06 09:35:02 -0400 (Thu, 06 May 2010)
New Revision: 6092
trunk/mapbender/resources/db/metadataGui.sql
metadata application
Modified: trunk/mapbender/resources/db/metadataGui.sql
--- trunk/mapbender/resources/db/metadataGui.sql 2010-05-06 13:33:15 UTC (rev 6091)
+++ trunk/mapbender/resources/db/metadataGui.sql 2010-05-06 13:35:02 UTC (rev 6092)
@@ -1,12 +1,20 @@
-DELETE FROM gui_element WHERE fkey_gui_id = 'admin_wms_metadata';
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_wms_metadata','admin_wms_metadata','GUI with tab, search modules',1);
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_wms_metadata','admin_wms_metadata','GUI with tab, search modules',1);
+-- give root access to admin_wms_metadata
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_wms_metadata', 1, 'owner');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','Change Projection','select','','',432,25,107,24,1,'','<option value="">undefined</option>
+<option value="EPSG:4326">EPSG:4326</option>
+<option value="EPSG:31466">EPSG:31466</option>
+<option value="EPSG:31467">EPSG:31467</option>
+<option value="EPSG:31468">EPSG:31468</option>
+<option value="EPSG:31469">EPSG:31469</option>','select','mod_changeEPSG.js','','overview','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
$(selector).datatables(options)','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree',1,1,'jsTree','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/jquery.tree.min.js','','','http://www.jstree.com/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree_checkbox',1,1,'jsTree checkbox plugin','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.js','','','http://www.jstree.com/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree',1,1,'jsTree','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/jquery.tree.js','','','http://www.jstree.com/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree_checkbox',1,0,'jsTree checkbox plugin','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.js','','','http://www.jstree.com/');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_layout',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','','');
@@ -14,15 +22,99 @@
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js','','jq_ui','http://jqueryui.com/demos/draggable/');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js','','jq_ui','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_edit',2,1,'Edit WMS metadata','Edit WMS metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_edit.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mapframe1',1,1,'frame for a map','','div','','',230,55,200,200,3,'border:1px solid black;overflow:hidden;background-color:#ffffff;display:none;','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_edit',2,1,'Edit WMS metadata','Edit WMS metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'overflow:auto','','div','../plugins/mb_metadata_edit.js','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer',3,1,'Edit layer metadata','Edit layer metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_layer.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview',2,1,'Allows selection of a preview image of a Map','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_layerPreview.js','mod_addWMSgeneralFunctions.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview_save',2,1,'','','img','../img/button_gray/wmc_save_off.png','',NULL ,NULL ,NULL ,NULL ,NULL ,'display: none;','','','../plugins/mb_metadata_saveLayerPreview.js','','mapframe1','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_tree',2,1,'Select a layer from a layer tree','Select a layer from a layer tree','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_layerTree.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_linkage',2,1,'','Metadata linkage','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_linkage.js','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_select',2,1,'Select a WMS','Select WMS','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<table class=''display''></table>','div','../plugins/mb_metadata_select.js','','','jq_datatables','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<ul></ul>','div','../plugins/mb_tabs_horizontal.js','','mb_md_select,mb_md_edit,mb_md_layer,mb_md_linkage','jq_ui_tabs','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_submit',1,1,'','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<input type=''button'' value=''Preview metadata''><input type=''button'' value=''Save metadata''>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_select,mb_md_edit,mb_md_layer','jq_ui_tabs','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','',270,10,24,24,1,'','','','mod_pan.js','','mapframe1','','http://www.mapbender.org/index.php/Pan');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,NULL ,NULL ,NULL ,'','','div','mod_sandclock.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','scaleSelect',2,1,'Scale-Selectbox','Scale Select','select','','',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','',295,10,24,24,3,'display: none;','','','mod_selArea.js','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','',320,10,24,24,2,'display: none;','','','mod_zoomFull.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,'','','','mod_zoomIn1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','',245,10,24,24,1,'','','','mod_zoomOut1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'css_class_bg', 'body{ background-color: #ffffff; margin: 5 5 5 5 }
+ font-family: Verdana;
+ font-size: 96%;
+label {
+ width: 250px;
+ height: 40px;
+ float: left;
+p {
+ clear: both;
+input {
+ font-weight: bold;
+ vertical-align: top;
+ width: 250px;
+ height: 25px;
+.metadata_span {
+ padding-right: 30px;
+.metadata_img {
+ width: 25px;
+ height: 25px;
+.metadata_selectbox {
+ height: 130px;
+ width: 250px;
+div#choose {
+ float: left;
+ width: 25em;
+div#layer {
+ margin-left: 25em;
+div#map {
+ float: left;
+ width: 45em;
+div#classification {
+ margin-left: 45em;
+div#save {
+div#buttons {
+ float: left;
+ width: 250px;
+fieldset {
+ display:inline
+div#selectbox {
+ margin-left: 312px;
+ padding-top: 20px;
+}', 'to define the color of the body', 'text/css');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'favicon', '../img/favicon.png', 'favicon', 'php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'includeWhileLoading', '', 'show splash screen while the application is loading', 'php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'jq_datatables_css', '../extensions/dataTables-1.5/media/css/site_jui.ccss.css', 'css-file for jQuery datatables', 'file/css');
@@ -32,6 +124,8 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '', 'file/css');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '', 'file/css');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_validate', 'css', 'label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }', '', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mapframe1', 'slippy', '0', '1 = Activates an animated, pseudo slippy map', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_edit', 'inputs', '[
"method": "init",
@@ -48,7 +142,7 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer', 'inputs', '[
"method": "init",
- "title": "initialize",
+ "title": "initialize wms data",
"linkedTo": [
"id": "mb_md_select",
@@ -56,8 +150,63 @@
"attr": "wmsId"
+ "method": "fillForm",
+ "title": "initialize layer data",
+ "linkedTo": [
+ "id": "mb_md_layer_tree",
+ "event": "selected",
+ "attr": "layer"
] ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer_preview', 'buttons', '[''zoomFull'',''zoomOut1'',''zoomIn1'',''selArea1'',''pan1'',''mb_md_layer_preview_save'',''changeEPSG'',''scaleSelect'']', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer_preview', 'inputs', '[
+ "method": "init",
+ "title": "initialize",
+ "linkedTo": [
+ "id": "mb_md_layer",
+ "event": "initialized",
+ "attr": "wmsId"
+ "method":"layer",
+ "title":"set the current Layer",
+ "linkedTo": [
+ "id":"mb_md_layer_tree",
+ "event":"selected",
+ "attr":"layer"
+]', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer_preview', 'map', 'mapframe1', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer_preview_save', 'inputs', '[
+ "method":"setLayer",
+ "linkedTo": [
+ "attr":"layer"
+]', '', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer_tree', 'inputs', '[
"method": "init",
@@ -71,6 +220,8 @@
] ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_pane', 'center', 'mb_tabs_horizontal', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_pane', 'south', 'mb_md_submit', '', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_tabs_horizontal', 'inputs', '[
"type": "id",
@@ -87,4 +238,3 @@
] ', '', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,hu,it,fr,es,pt', '', 'var');
More information about the Mapbender_commits
