[Mapbender-commits] r6115 - branches/3_dev/http/plugins
svn_mapbender at osgeo.org
Sun May 9 11:55:42 EDT 2010
Author: astrid_emde
Date: 2010-05-09 11:55:42 -0400 (Sun, 09 May 2010)
New Revision: 6115
Added:
branches/3_dev/http/plugins/mb_map.js
from trunk
Added: branches/3_dev/http/plugins/mb_map.js
--- branches/3_dev/http/plugins/mb_map.js (rev 0)
+++ branches/3_dev/http/plugins/mb_map.js 2010-05-09 15:55:42 UTC (rev 6115)
@@ -0,0 +1,94 @@
+ * Package: mapframe1
+ * Description:
+ * The main map in Mapbender
+ * Files:
+ * - http/plugins/mb_map.js
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<appId>','mapframe1',
+ * > 1,1,'The main map in Mapbender','','div','','',220,105,625,400,2,
+ * > 'overflow:hidden;background-color:#ffffff','','div',
+ * > '../plugins/mb_map.js',
+ * > '../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php',
+ * > '','','http://www.mapbender.org/index.php/Mapframe');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES('<appId>', 'mapframe1',
+ * > 'skipWmsIfSrsNotSupported', '0',
+ * > 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility',
+ * > 'var');
+ * > var_value, context, var_type) VALUES('<appId>', 'mapframe1', 'slippy',
+ * > '0', 'Activates an animated, pseudo slippy map' ,'var');
+ * Help:
+ * http://www.mapbender.org/Mapframe
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * Parameters:
+ * skipWmsIfSrsNotSupported - if set to 1, it skips the WMS request
+ * if the current SRS is not supported by
+ * the WMS; if set to 0, the WMS is always
+ * queried.
+ * Default is 0, because of backwards
+ * compatibility
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var $this = $(this);
+Mapbender.events.initMaps.register(function () {
+ $this.data("isMap", true);
+ $this.html('<div id="' + options.id + '_maps" name="maps" ' +
+ 'style="width: 0px; height: 0px; z-index:2;"></div>');
+ $this.mapbender(new Mapbender.Map (
+ options.id,
+ options.width,
+ options.height,
+ null
+ $this.bind("mousedown", function (e) {
+ e.preventDefault();
+ }).bind("mouseover", function (e) {
+ }).bind("mousemove", function (e) {
+ var mapObject = Mapbender.modules[options.id];
+ // set restricted extent
+ mapObject.skipWmsIfSrsNotSupported =
+ options.skipWmsIfSrsNotSupported === 1 ? true : false;
+ // pseudo slippy map
+ mapObject.slippy =
+ options.slippy === 1 ? true : false;
+ if (typeof options.restrictedExtent !== "undefined") {
+ mapObject.setRestrictedExtent(options.restrictedExtent);
+ else {
+ new Mapbender.Notice("Restricted extent not set via element variable.");
More information about the Mapbender_commits
