[Mapbender-commits] r6120 - branches/3_dev/core/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sun May 9 12:02:50 EDT 2010
Author: astrid_emde
Date: 2010-05-09 12:02:50 -0400 (Sun, 09 May 2010)
New Revision: 6120
Added:
   branches/3_dev/core/lib/class_Connector.php
   branches/3_dev/core/lib/class_Wms.php
   branches/3_dev/core/lib/class_bbox.php
   branches/3_dev/core/lib/class_georss.php
   branches/3_dev/core/lib/class_georss_factory.php
   branches/3_dev/core/lib/class_georss_geometry.php
   branches/3_dev/core/lib/class_georss_item.php
   branches/3_dev/core/lib/class_gml2.php
   branches/3_dev/core/lib/class_point.php
   branches/3_dev/core/lib/class_rss.php
   branches/3_dev/core/lib/class_rss_factory.php
   branches/3_dev/core/lib/class_rss_item.php
   branches/3_dev/core/lib/initWms.php
   branches/3_dev/core/lib/mod_map_messages.php
   branches/3_dev/core/lib/class_Mapbender.php
for template-basic from trunk,merges classes from trunk, class names not modified yet
Added: branches/3_dev/core/lib/class_Connector.php
--- branches/3_dev/core/lib/class_Connector.php	                        (rev 0)
+++ branches/3_dev/core/lib/class_Connector.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,326 @@
+<?php
+# $Id: class_connector.php 5707 2010-03-02 13:10:41Z armin11 $
+# http://www.mapbender.org/index.php/class_connector
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+ * Establishes a connection to a given URL (and loads the content).
+ * Supports HTTP (GET and POST), cURL and socket connections.
+ * @class
+class connector {
+	var $file;
+	private $connectionType;
+	private $httpType = "get";
+	private $httpVersion = "1.0";
+	private $httpPostData;
+	private $httpContentType = "text/html";
+	 * @constructor
+	 * @param String url the URL that will be loaded (optional)
+	public function __construct() {
+		$this->set("connectionType", CONNECTION);
+		if (func_num_args() == 1) {
+			$url = func_get_arg(0);
+			if ($url) {
+				$this->load($url);
+		else if (func_num_args() == 2) {
+       		$auth = func_get_arg(1);
+			if ($url) {
+				$this->load($url,$auth);
+	 * Loads content from the given URL.
+	public function load($url) {
+		if (!$url) {
+			$e = new mb_exception("connector: no URL given");
+			return false;
+		switch ($this->connectionType) {
+			case "curl":
+			    if (func_num_args() == 2) {
+						if (isset($auth)) {
+							$this->file = $this->getCURL($url,$auth);
+				else {
+					$this->file = $this->getCURL($url);
+				break;
+			case "http":
+				$this->file = $this->getHTTP($url);
+				break;
+			case "socket":
+				$this->file = $this->getSOCKET($url);
+				break;
+		if(!$this->file){
+			$e = new mb_exception("connector: unable to load: ".$url);
+			return false;
+		return $this->file;
+	 * Sets the environment variables. The following can be set:
+	 * - connectionType ("http", "curl", "socket")
+	 * - httpType ("get", "post")
+	 * - etc.
+	public function set ($key, $value) {
+		switch ($key) {
+			case "connectionType":
+				if ($this->isValidConnectionType($value)) {
+					$this->connectionType = $value;
+				break;
+			case "httpVersion":
+				if (in_array($value, array("1.0", "1.1"))) {
+					$this->httpVersion = $value;
+				else {
+					$e = new mb_exception("class_connector.php: invalid http type '" . $value . "'");
+				break;
+			case "httpType":
+				if (in_array(mb_strtoupper($value), array("POST", "GET"))) {
+					$this->httpType = $value;
+				else {
+				break;
+			case "httpPostData":
+				$this->httpPostData = $value;
+				break;
+			case "httpContentType":
+				if ($this->isValidHttpContentType($value)) {
+					$this->httpContentType = $value;
+				break;
+	private function isValidConnectionType ($value) {
+		if (in_array(mb_strtoupper($value), array("HTTP", "CURL", "SOCKET"))) {
+			return true;
+		else {
+			$e = new mb_exception("class_connector.php: invalid connection type '" . $value . "'");
+			return false;
+	private function isValidHttpContentType ($value) {
+		$validHttpContentTypeArray = array("XML","TEXT/XML");
+		if (in_array(mb_strtoupper($value), $validHttpContentTypeArray)) {
+			switch (mb_strtoupper($value)) {
+				case "XML":
+					$this->httpContentType = "application/xml";
+					break;
+			return true;
+		else {
+			$e = new mb_exception("class_connector.php: invalid HTTP content type '" . $value . "'");
+			return false;
+	private function getCURL($url){
+		$url=Str_replace(" ","+",$url); //to have no problems with image/png; mode=24bit!
+		$url=str_replace(";","%3B",$url);
+		} //auth should be an array of ['username', 'realm', 'password', 'auth_type'] - or false - problem would be, that these are stored without hashing them!
+		$ch = curl_init ($url);
+//		curl_setopt($ch, CURLOPT_BINARYTRANSFER, 1);
+		curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
+		//allow https connections and handle certificates quite simply ;-)
+		curl_setopt($ch,CURLOPT_SSL_VERIFYHOST,0);
+		curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0);
+		//get hostname/ip out of url
+		//$host = parse_url($url,PHP_URL_HOST);
+		$arURL = parse_url($url);
+		$host = $arURL["host"];
+		$port = $arURL["port"];
+		if($port == ''){
+			$port = 80;
+		$path = $arURL["path"];
+		// fill array (HOSTs not for Proxy)
+ 	    $NOT_PROXY_HOSTS_array = explode(",", NOT_PROXY_HOSTS);
+		if(CONNECTION_PROXY != "" AND (in_array($host, $NOT_PROXY_HOSTS_array)!= true)){
+			curl_setopt($ch, CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
+		if(CONNECTION_PASSWORD != ""){
+			curl_setopt ($ch, CURLOPT_PROXYUSERPWD, CONNECTION_USER.':'.CONNECTION_PASSWORD);
+		//TODO maybe allow basic authentication for client, but this will store the passwords in plain text
+		//TODO: store the  passwords as digest hash. Therefor we have to handle the realm which is defined in the 401 header and return it back to the scripts like mod_loadwms.php to store the digest into the database - problem: curl cannot handle digest connection without clear username and password - we have to send our own headers
+		if(isset($auth) && $auth != false) {
+			curl_setopt($ch, CURLOPT_USERPWD, $auth['username'].':'.$auth['password']);
+			if ($auth['auth_type'] == 'digest') {
+				curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_DIGEST);
+			if ($auth['auth_type'] == 'basic') {
+				curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_BASIC);
+		curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
+		//if httpType is POST, set CURLOPT_POST and CURLOPT_POSTFIELDS
+		//and set a usefull http header
+		if(strtoupper($this->httpType) == 'POST'){
+			$headers = array(
+					 "POST ".$path." HTTP/1.1",
+            		 "Content-type: ".$this->httpContentType."; charset=".CHARSET,
+           			 "Cache-Control: no-cache",
+	           		 "Pragma: no-cache",
+	           		 "Content-length: ".strlen($this->httpPostData)
+			$e = new mb_exception("connector: CURL POST: ".$this->httpPostData);
+			#$e = new mb_exception("connector: CURL POST HEADER: ".print_r($headers));
+			curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
+			curl_setopt($ch, CURLOPT_POST, 1);
+			curl_setopt($ch, CURLOPT_POSTFIELDS, $this->httpPostData);
+		$useragent=CONNECTION_USERAGENT;
+		$e = new mb_notice("connector: CURL connect to: ".$url);
+		curl_setopt ($ch,CURLOPT_USERAGENT,$useragent);
+		$file = curl_exec ($ch);
+		//handle http authentication
+		$info = curl_getinfo($ch);
+		if ($info['http_code'] == '401') {
+			curl_close ($ch);
+			return $info['http_code'];
+		curl_close ($ch);
+		return $file;
+	private function getHTTP($url){
+		if ($this->httpType == "get") {
+			return @file_get_contents($url);
+		else {
+			$errno = 0;
+			$errstr = "";
+			$urlComponentArray = parse_url($url);
+			$scheme = $urlComponentArray["scheme"];
+			$host = $urlComponentArray["host"];
+			$port = $urlComponentArray["port"];
+			if ($port == "") {
+				if ($scheme == "https") {
+					$port = 443;
+				else {
+					$port = 80;
+			$path = $urlComponentArray["path"];
+			$query = $urlComponentArray["query"];
+			$buf = '';
+				$fp = fsockopen("ssl://". $host, $port, $errno, $errstr);
+			else {
+			    $fp = fsockopen($host, $port);
+			$postStr = "";
+			$postPath = "POST " . $path . "?" . $query . " HTTP/".$this->httpVersion . "\r\n";
+			$postStr .= $postPath;
+		    fputs($fp, $postPath);
+			$postHost = "Host: " . $host . "\r\n";
+			$postStr .= $postHost;
+		    fputs($fp, $postHost);
+		    if ($this->isValidHttpContentType($this->httpContentType)) {
+				$postContentType = "Content-type: " . $this->httpContentType . "\r\n";
+				$postStr .= $postContentType;
+		    	fputs($fp, $postContentType);
+			$postContentLength = "Content-length: " . strlen($this->httpPostData) . "\r\n";
+			$postStr .= $postContentLength;
+		    fputs($fp, $postContentLength);
+			$postClose = "Connection: close\r\n\r\n";
+			$postStr .= $postClose;
+		    fputs($fp, $postClose);
+		    $postStr .= $this->httpPostData;
+			fputs($fp, $this->httpPostData);
+			new mb_notice("connector.http.postData: ".$this->httpPostData);
+		    $xmlstr = false;
+		    while (!feof($fp)) {
+		    	$content = fgets($fp,4096);
+//		    	if( strpos($content, '<?xml') === 0){
+		    	if( strpos($content, '<') === 0){
+		    		$xmlstr = true;
+		    	if($xmlstr == true){
+		    		$buf .= $content;
+		    fclose($fp);
+//		    new mb_notice("connector.http.response: ".$buf);
+		    return $buf;
+	private function getSOCKET($url){
+		$r = "";
+		$fp = fsockopen (CONNECTION_PROXY, CONNECTION_PORT, $errno, $errstr, 30);
+		if (!$fp) {
+			echo "$errstr ($errno)<br />\n";
+		else {
+			fputs ($fp, "GET ".$url." HTTP/1.0\r\n\r\n");
+				$r .= fgets($fp,4096);
+			fclose($fp);
+			return $r;
Modified: branches/3_dev/core/lib/class_Mapbender.php
--- branches/3_dev/core/lib/class_Mapbender.php	2010-05-09 16:00:07 UTC (rev 6119)
+++ branches/3_dev/core/lib/class_Mapbender.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -53,6 +53,7 @@
 			"languageId" => Mapbender::session()->get("mb_lang"),
 			"publicUser" => PUBLIC_USER,
 			"login" => LOGIN,
+			"resolution" => MB_RESOLUTION,
 			"log" => array(
 				"js" => LOG_JS,
 				"level" => LOG_LEVEL,
Added: branches/3_dev/core/lib/class_Wms.php
--- branches/3_dev/core/lib/class_Wms.php	                        (rev 0)
+++ branches/3_dev/core/lib/class_Wms.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,2641 @@
+<?php
+# $Id: class_wms.php 6058 2010-05-03 10:28:08Z christoph $
+# http://www.mapbender.org/index.php/class_wms
+require_once(dirname(__FILE__)."/class_Connector.php");
+require_once(dirname(__FILE__)."/class_User.php");
+require_once(dirname(__FILE__)."/class_Administration.php");
+require_once(dirname(__FILE__)."/class_georss_factory.php");
+class wms {
+	var $lastURL;
+	var $wms_id;
+	var $wms_status;
+	var $wms_version;
+	var $wms_title;
+	var $wms_abstract;
+	var $wms_getcapabilities;
+	var $wms_getcapabilities_doc;
+	var $wms_getmap;
+	var $wms_getfeatureinfo;
+	var $wms_getlegendurl;
+	var $wms_upload_url;
+	var $wms_srs = array();
+	var $fees;
+	var $accessconstraints;
+	var $contactperson;
+	var $contactposition;
+	var $contactorganization;
+	var $address;
+	var $city;
+	var $stateorprovince;
+	var $postcode;
+	var $country;
+	var $contactvoicetelephone;
+	var $contactfacsimiletelephone;
+	var $contactelectronicmailaddress;
+	var $wms_keyword = array();
+	var $data_type = array();
+	var $data_format = array();
+	var $objLayer = array();
+	var $wms_supportsld;
+	var $wms_userlayer;
+	var $wms_userstyle;
+	var $wms_remotewfs;
+	var $gui_wms_mapformat;
+	var $gui_wms_featureinfoformat;
+	var $gui_wms_exceptionformat;
+	var $gui_wms_epsg;
+	var $gui_wms_sldurl;
+	var $default_epsg = 0;
+	var $overwrite = true;
+	// write a GeoRSS feed?
+	const GEORSS = true;
+	// append items to the feed when a new WMS is inserted?
+	const GEORSS_APPEND_ON_INSERT = true;
+	// append items to the feed when an existing WMS is updated?
+	const GEORSS_APPEND_ON_UPDATE = true;
+	// append items to the feed only when an existing WMS is updated
+	// and new layers have been added?
+	const GEORSS_APPEND_ON_UPDATE_NEWLAYERS = true;
+	function wms() {
+	public static function getWmsMetadataUrl ($wmsId) {
+		return preg_replace(
+			"/(.*)frames\/login.php/",
+			"$1php/mod_layerMetadata.php?id=",
+			LOGIN
+		) . $wmsId;
+	public static function isOwsProxyUrl ($getmap) {
+//		$e = new mb_notice("isOwsProxyUrl? " . $getmap);
+		$result = preg_match("/^.*owsproxy.([^i][\w\d]+)\/([\w\d]{32})\/?.*$/", $getmap);
+//		$e = new mb_notice("result: " . $result);
+		return $result;
+	private function replaceSessionIdInOwsProxyUrl ($getMap) {
+//		$e = new mb_notice("replaceSessionIdInOwsProxyUrl: ");
+		$e = new mb_notice("before: " . $getMap);
+		$pattern = '/(^.*owsproxy.)([^i][\w\d]+)(\/)([\w\d]{32})(\/?.*)$/';
+		$getMap1= preg_replace($pattern, "$1",$getMap);
+		$getMap2=  preg_replace($pattern, "$3$4$5",$getMap);
+		$getMap = $getMap1.session_id().$getMap2;
+		$e = new mb_notice("after: " . $getMap);
+		return $getMap;
+	public static function getHashFromOwsProxyUrl ($getMap) {
+//		$e = new mb_notice("replaceSessionIdInOwsProxyUrl: " . $getMap);
+		$result = preg_replace("/^.*owsproxy.([^i][\w\d]+)\/([\w\d]{32})\/?.*$/", "$2", $getMap);
+		return $result;
+	private function getWmsIdByOwsProxyHash($md5) {
+		$sql = "SELECT wms_id FROM wms WHERE wms_owsproxy = $1";
+		$v = array($md5);
+		$t = array("s");
+		$res = db_prep_query($sql, $v, $t);
+		$row = db_fetch_row($res);
+		if ($row["wms_id"]) {
+			return $row["wms_id"];
+		return null;
+	private function updateOwsProxyUrl ($url) {
+		// is OWS proxy URL?
+		if (wms::isOwsProxyUrl($url)) {
+			// No WMS id could be found
+			if (!$this->wms_id) {
+				$e = new mb_notice("No WMS id could be found!");
+				return $url;
+			// Update session id in OWS proxy URL
+			$new_proxy_url = $this->replaceSessionIdInOwsProxyUrl($url);
+			// If new url is a valid proxy URL, return true
+			if ($this->isOwsProxyUrl($new_proxy_url)) {
+				return $new_proxy_url;
+			else {
+//				$e = new mb_notice("new URL is not an OWS proxy URL!");
+			// new URL is not an OWS proxy URL;
+			// some error must have occured.
+			// no update
+			return $url;
+		// no OWS proxy URL, no update necessary
+//		$e = new mb_notice("URL is not an OWS proxy URL!");
+		return $url;
+	function updateAllOwsProxyUrls () {
+		$wmsId = $this->wms_id;
+		// if WMS id is unknown, try to
+		// find it via OWS proxy entry
+		//FIXME -Funktion berichtigen
+		if (!$wmsId) {
+			$md5 = wms::getHashFromOwsProxyUrl($url);
+			if ($md5) {
+				$wmsId = $this->getWmsIdByOwsProxyHash($md5);
+				if (!is_null($wmsId)) {
+					$this->wms_id = $wmsId;
+		$this->wms_getmap =
+			$this->updateOwsProxyUrl($this->wms_getmap);
+		$this->wms_getfeatureinfo =
+			$this->updateOwsProxyUrl($this->wms_getfeatureinfo);
+		$this->wms_getlegendurl =
+			$this->updateOwsProxyUrl($this->wms_getlegendurl);
+		for ($i = 0; $i < count($this->objLayer); $i++) {
+			for ($j = 0; $j < count($this->objLayer[$i]->layer_style); $j++) {
+				$this->objLayer[$i]->layer_style[$j]["legendurl"] =
+					$this->updateOwsProxyUrl($this->objLayer[$i]->layer_style[$j]["legendurl"]);
+	public static function getConjunctionCharacter ($url) {
+		if (mb_strpos($url, "?") !== false) {
+			if (mb_substr($url, mb_strlen($url)-1, 1) == "?") {
+				return "";
+			else if (mb_substr($url, mb_strlen($url)-1, 1) == "&"){
+				return "";
+			else {
+				return "&";
+		else {
+			return "?";
+		return "";
+	function createOlObjFromWMS($base){
+	 	if(!$this->wms_title || $this->wms_title == ""){
+			echo "alert('Error: no valid capabilities-document !!');";
+			die; exit;
+		// wms_title and abstract have previously been urlencoded
+		// this solution may not yet be the ultimate one
+		$add_wms_string  = "var wms_".$this->wms_id." = new OpenLayers.Layer.WMS(";
+		// WMS-title
+		$add_wms_string .= "'" . addslashes($this->wms_title) . "',";
+		// Base-URL of service
+		$add_wms_string .= "'" . $this->wms_getmap ."',";
+		// Additional URL params
+		$add_wms_string .= "{layers:'";
+		for($i=1;$i<count($this->objLayer);$i++){
+			$add_wms_string .= addslashes($this->objLayer[$i]->layer_name);
+			if($i!=count($this->objLayer)-1) {
+				$add_wms_string .= ",";
+		$add_wms_string .= "',";
+		// This is hardcoded, exactly as for Mapbender WMS
+		$add_wms_string .= "transparent: 'true',";
+		$add_wms_string .= "format: '".$this->gui_wms_mapformat."'},";
+		// OpenLayers-Layer options
+		$add_wms_string .= "{";
+		$add_wms_string .= 	"transitionEffect:'resize',";
+		$add_wms_string .= 	"buffer:1.3,";
+		$add_wms_string .= 	"singleTile:true,";
+		// baselayer?
+		if($base) {
+			$add_wms_string .= 	"isBaseLayer:true,";
+		} else {
+			$add_wms_string .= 	"isBaseLayer:false,";
+		// visible or not?
+		if($this->gui_wms_visible=="1") {
+			$add_wms_string .= 	"visibility:true,";
+		} else {
+			$add_wms_string .= 	"visibility:false,";
+		// initial transparency
+		$add_wms_string .= 	"opacity:" . strval(round($this->gui_wms_opacity/100, 2));
+		$add_wms_string .= "}";
+		$add_wms_string .= ");";
+		// TODO why ol_map
+		$add_wms_string .= "ol_map.addLayer(wms_".$this->wms_id.");";
+		echo $add_wms_string;
+	 * Compares this WMS to another WMS.
+	 * @return boolean false, if
+	 * 					- the capabilities URLs don't match
+	 * 					- the layer count is different
+	 * 					- the layer names are different
+	 * @param $anotherWms wms this is just another WMS object
+	public function equals ($anotherWms) {
+		// If the getMap URLs are not equal, the WMS are not equal.
+		if ($this->wms_getmap != $anotherWms->wms_getmap) {
+//			$e = new mb_notice($this . " != " . $anotherWms . " (getMap URL)");
+			return false;
+		// If the layer count is different, the WMS are not equal.
+		if (count($this->objLayer) != count($anotherWms->objLayer)) {
+//			$e = new mb_notice($this . " != " . $anotherWms . " (layer count: " . count($this->objLayer) . ":" . count($anotherWms->objLayer). ")");
+			return false;
+		// If the layer names are different, the WMS are not equal.
+			$name1 = $this->objLayer[$i]->layer_name;
+			$name2 = $anotherWms->objLayer[$i]->layer_name;
+			if ($name1 != $name2) {
+//				$e = new mb_notice($this . " != " . $anotherWms . " (layer names, " . $name1 . " vs. " . $name2 . ")");
+				return false;
+//		$e = new mb_notice($this . " == " . $anotherWms);
+		return true;
+	 * The other WMS must be the same as this WMS, but with different
+	 * application settings. These application settings are copied,
+	 * the local settings are overwritten.
+	 * @return boolean true if the settings could be copied; false
+	 * 					when an error occured.
+	 * @param $anotherWms wms The same WMS with possibly other settings
+	public function copyConfiguration ($anotherWms) {
+		if (!$this->equals($anotherWms)) {
+			$e = new mb_exception("class_wms.php: copyConfiguration(): parameters cannot be copied, it's a different WMS.");
+			return false;
+			$myCurrentLayer = $this->objLayer[$i];
+			$theirCurrentLayer = $anotherWms->objLayer[$i];
+			$myCurrentLayer->gui_layer_selectable = $theirCurrentLayer->gui_layer_selectable;
+			$myCurrentLayer->gui_layer_visible    = $theirCurrentLayer->gui_layer_visible;
+			$myCurrentLayer->gui_layer_queryable  = $theirCurrentLayer->gui_layer_queryable;
+			$myCurrentLayer->gui_layer_querylayer = $theirCurrentLayer->gui_layer_querylayer;
+			$myCurrentLayer->gui_layer_style      = $theirCurrentLayer->gui_layer_style;
+	 * Removes duplicate WMS from an array of WMS. To find duplicates,
+	 * two WMS are compared via equals().
+	 * @return wms[]
+	 * @param $wmsArray wms[]
+	public static function merge ($wmsArray) {
+		$e = new mb_notice("before: " . implode(", ", $wmsArray));
+		if (!is_array($wmsArray)) {
+			$e = new mb_exception("class_wms.php: merge(): parameter is NOT an array.");
+			return array();
+		if (count($wmsArray) == 0) {
+			$e = new mb_exception("class_wms.php: merge(): parameter is an EMPTY array.");
+			return array();
+		$newWmsArray = array();
+		while (count($wmsArray) > 0) {
+			$currentWms = array_pop($wmsArray);
+			$isNewWms = true;
+			if (get_class($currentWms) != "wms") {
+				$e = new mb_exception("class_wms.php: merge(): current WMS is not a WMS object, but a " . get_class($currentWms));
+			else {
+				for ($i = 0; $i < count($newWmsArray) && $isNewWms; $i++) {
+					if ($currentWms->equals($newWmsArray[$i])) {
+						$isNewWms = false;
+				if ($isNewWms) {
+//					$e = new mb_notice("adding WMS " . $currentWms);
+					array_push($newWmsArray, $currentWms);
+		// reversal of the array, because the elements were popped
+		// from another array before.
+//		$e = new mb_notice("after: " . implode(", ", array_reverse($newWmsArray)));
+		return array_reverse($newWmsArray);
+	private function formatExists ($type, $format) {
+		for ($i = 0; $i < count($this->data_type); $i++) {
+			if ($type == $this->data_type[$i] && $format == $this->data_format[$i]) {
+				$e = new mb_warning("WMS format already exists ($type, $format). Violation of WMS spec. Ignoring this WMS format.");
+				return true;
+		return false;
+	public function __toString () {
+		return $this->wms_title;
+	function createObjFromXML($url){
+		if (func_num_args() == 2) { //new for HTTP Authentication
+			$x = new connector($url,$auth);
+		else {
+			$x = new connector($url);
+		$data = $x->file;
+		if ($data=='401') {
+			echo "<br>HTTP Error:<b>".$data." - Authorization required. This seems to be a service which needs HTTP Authentication!</b><br>";
+		if(!$data){
+			$this->wms_status = false;
+			return false;
+		else {
+			$this->wms_status = true;
+		$values = null;
+		$tags = null;
+		$admin = new administration();
+		$this->wms_getcapabilities_doc = $data;
+		$this->wms_upload_url = $url;
+		$this->wms_id = "";
+		$parser = xml_parser_create("");
+		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
+		xml_parse_into_struct($parser,$data,$values,$tags);
+		$code = xml_get_error_code($parser);
+		if ($code) {
+			$line = xml_get_current_line_number($parser);
+			$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
+		xml_parser_free($parser);
+		$section = null;
+		$format = null;
+		$cnt_format = 0;
+		$parent = array();
+		$myParent = array();
+		$cnt_layer = -1;
+		$request = null;
+		$layer_style = array();
+		$cnt_styles = -1;
+		$this->wms_getfeatureinfo = "";
+		$this->gui_wms_featureinfoformat = "";
+		foreach ($values as $element) {
+			if(mb_strtoupper($element[tag]) == "WMT_MS_CAPABILITIES" && $element[type] == "open"){
+				$this->wms_version = $element[attributes][version];
+			if(mb_strtoupper($element[tag]) == "TITLE" && $element[level] == '3'){
+				$this->wms_title = $this->stripEndlineAndCarriageReturn($element[value]);
+			if(mb_strtoupper($element[tag]) == "ABSTRACT" && $element[level] == '3'){
+				$this->wms_abstract = $this->stripEndlineAndCarriageReturn($element[value]);
+			if(mb_strtolower($element[tag]) == "fees"){
+				$this->fees = $element[value];
+			if(mb_strtolower($element[tag]) == "accessconstraints"){
+				$this->accessconstraints = $element[value];
+			if(mb_strtolower($element[tag]) == "contactperson"){
+				$this->contactperson = $element[value];
+			if(mb_strtolower($element[tag]) == "contactposition"){
+				$this->contactposition = $element[value];
+			if(mb_strtolower($element[tag]) == "contactorganization"){
+				$this->contactorganization = $element[value];
+			if(mb_strtolower($element[tag]) == "address"){
+				$this->address = $element[value];
+			if(mb_strtolower($element[tag]) == "city"){
+				$this->city = $element[value];
+			if(mb_strtolower($element[tag]) == "stateorprovince"){
+				$this->stateorprovince = $element[value];
+			if(mb_strtolower($element[tag]) == "postcode"){
+				$this->postcode = $element[value];
+			if(mb_strtolower($element[tag]) == "country"){
+				$this->country = $element[value];
+			if(mb_strtolower($element[tag]) == "contactvoicetelephone"){
+				$this->contactvoicetelephone = $element[value];
+			if(mb_strtolower($element[tag]) == "contactfacsimiletelephone"){
+				$this->contactfacsimiletelephone = $element[value];
+			if(mb_strtolower($element[tag]) == "contactelectronicmailaddress"){
+				$this->contactelectronicmailaddress = $element[value];
+	  		if(mb_strtolower($element[tag]) == "keyword" && $section != 'layer'){
+				$this->wms_keyword[count($this->wms_keyword)] = $element[value];
+			/*map section*/
+			if($this->wms_version == "1.0.0"){
+		 		if(mb_strtoupper($element[tag]) == "MAP" && $element[type] == "open"){
+					$section = "map";
+				if($section == "map" && mb_strtoupper($element[tag]) == "GET"){
+					$this->wms_getmap = $element[attributes][onlineResource];
+				if($section == "map" && mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
+					$format = "map";
+				if(mb_strtoupper($element[tag]) != "FORMAT" && $section == "map" && $format == "map"){
+					if (!$this->formatExists("map", trim($element[tag]))) {
+						$this->data_type[$cnt_format] = "map";
+						$this->data_format[$cnt_format] = trim($element[tag]);
+						$cnt_format++;
+				if(mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "close"){
+					$format = "";
+				if(mb_strtoupper($element[tag]) == "MAP" && $element[type] == "close"){
+					$section = "";
+			else{
+				if(mb_strtoupper($element[tag]) == "GETMAP" && $element[type] == "open"){
+					$section = "map";
+				if($section == "map" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "open"){
+					$request = "get";
+				if($section == "map" && $request == "get" && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
+					$this->wms_getmap = $element[attributes]["xlink:href"];
+				if($section == "map" && mb_strtoupper($element[tag]) == "FORMAT"){
+					if (!$this->formatExists("map", trim($element[value]))) {
+						$this->data_format[$cnt_format] = trim($element[value]);
+						$cnt_format++;
+				if($section == "map" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "close"){
+					$request = "";
+				if(mb_strtoupper($element[tag]) == "GETMAP" && $element[type] == "close"){
+					$section = "";
+			/*capabilities section*/
+				if(mb_strtoupper($element[tag]) == "CAPABILITIES" && $element[type] == "open"){
+					$section = "capabilities";
+				if($section == "capabilities" && mb_strtoupper($element[tag]) == "GET"){
+					$this->wms_getcapabilities = $element[attributes][onlineResource];
+				if(mb_strtoupper($element[tag]) == "CAPABILITIES" && $element[type] == "close"){
+					$section = "";
+			else{
+				if(mb_strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "open"){
+				if($section == "capabilities" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "open"){
+					$request = "get";
+				if($section == "capabilities" && $request == "get" && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
+					$this->wms_getcapabilities = $element[attributes]["xlink:href"];
+				if($section == "capabilities" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "close"){
+					$request = "";
+				if(mb_strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "close"){
+					$section = "";
+			/*featureInfo section*/
+				if(mb_strtoupper($element[tag]) == "FEATUREINFO" && $element[type] == "open"){
+					$section = "featureinfo";
+				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "GET"){
+					$this->wms_getfeatureinfo = $element[attributes][onlineResource];
+				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
+					$format = "featureinfo";
+				if(mb_strtoupper($element[tag]) != "FORMAT" && $section == "featureinfo" && $format == "featureinfo"){
+					if (!$this->formatExists("featureinfo", trim($element[tag]))) {
+						$this->data_type[$cnt_format] = "featureinfo";
+						$cnt_format++;
+					$format = "";
+				if(mb_strtoupper($element[tag]) == "FEATUREINFO" && $element[type] == "close"){
+					$section = "";
+			else{
+				if(mb_strtoupper($element[tag]) == "GETFEATUREINFO" && $element[type] == "open"){
+				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "open"){
+					$request = "get";
+				if($section == "featureinfo" && $request == "get" && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
+					$this->wms_getfeatureinfo = $element[attributes]["xlink:href"];
+				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "FORMAT"){
+					if (!$this->formatExists("featureinfo", trim($element[value]))) {
+						$cnt_format++;
+				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "close"){
+					$request = "";
+				if(mb_strtoupper($element[tag]) == "GETFEATUREINFO" && $element[type] == "close"){
+					$section = "";
+			/*exception section*/
+				if(mb_strtoupper($element[tag]) == "EXCEPTION" && $element[type] == "open"){
+					$section = "exception";
+				if($section == "exception" && mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
+					$format = "exception";
+				if(mb_strtoupper($element[tag]) != "FORMAT" && $section == "exception" && $format == "exception"){
+					$this->data_type[$cnt_format] = "exception";
+					$cnt_format++;
+				if($section == "exception" && mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "close"){
+					$format = "";
+				if(mb_strtoupper($element[tag]) == "EXCEPTION" && $element[type] == "close"){
+					$section = "";
+			else{
+				if($section == "exception" && mb_strtoupper($element[tag]) == "FORMAT"){
+					$cnt_format++;
+					$section = "";
+	      /*legend section*/
+	      else{
+	        if(mb_strtoupper($element[tag]) == "GETLEGENDGRAPHIC" && $element[type] == "open"){
+				$section = "legend";
+	        if($section == "legend" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "open"){
+				$request = "get";
+			if($section == "legend" && $request == "get" && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
+				$this->wms_getlegendurl = $element[attributes]["xlink:href"];
+	        if($section == "legend" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "close"){
+				$request = "";
+			if(mb_strtoupper($element[tag]) == "GETLEGENDGRAPHIC" && $element[type] == "close"){
+				$section = "";
+			/* sld section */
+			if(mb_strtoupper($element[tag]) == "USERDEFINEDSYMBOLIZATION" && $element[type] == "complete"){
+				$this->wms_supportsld = $element[attributes]["SupportSLD"];
+				$this->wms_userlayer = $element[attributes]["UserLayer"];
+				$this->wms_userstyle = $element[attributes]["UserStyle"];
+				$this->wms_remotewfs = $element[attributes]["RemoteWFS"];
+			/*layer section*/
+			if(mb_strtoupper($element[tag]) == "LAYER"){
+				$section = "layer";
+				if ($element[type] == "open") {
+					$cnt_epsg = -1;
+					$cnt_layer++;
+					$parent[$element[level]+1] = $cnt_layer;
+					$myParent[$cnt_layer]= $parent[$element[level]];
+					$this->addLayer($cnt_layer,$myParent[$cnt_layer]);
+					$this->objLayer[$cnt_layer]->layer_queryable = $element[attributes][queryable];
+				if ($element[type] == "close") {
+			/* attribution */
+			if(mb_strtoupper($element[tag]) == "ATTRIBUTION"){
+					$section = "attribution";
+			/* styles */
+			if(mb_strtoupper($element[tag]) == "STYLE"){
+				$section = "style";
+				if($cnt_layer != $layer_style){
+					$layer_style = $cnt_layer;
+					$cnt_styles = -1;
+					$cnt_styles++;
+			if($section == "style"){
+				if(mb_strtoupper($element[tag]) == "NAME"){
+					$this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["name"] = ($element[value] ? $element[value] : 'default');
+				if(mb_strtoupper($element[tag]) == "TITLE"){
+					$this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["title"] = ($element[value] ? $element[value] : '');
+	      		if(mb_strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "open"){
+					$legendurl = true;
+				if($legendurl && mb_strtoupper($element[tag]) == "FORMAT"){
+					$this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["legendurlformat"] = $element[value];
+				if($legendurl && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
+					$this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["legendurl"] = $element[attributes]["xlink:href"];
+			    if(mb_strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "close"){
+					$legendurl = false;
+			/* end of styles */
+			if($section == "layer"){
+					$this->objLayer[$cnt_layer]->layer_name = $element[value];
+					$this->objLayer[$cnt_layer]->layer_title = $this->stripEndlineAndCarriageReturn($element[value]);
+				if(mb_strtoupper($element[tag]) == "ABSTRACT"){
+					$this->objLayer[$cnt_layer]->layer_abstract = $this->stripEndlineAndCarriageReturn($element[value]);
+				if(mb_strtoupper($element[tag]) == "KEYWORD"){
+					array_push($this->objLayer[$cnt_layer]->layer_keyword, trim($element[value]));
+	      		if(mb_strtoupper($element[tag]) == "DATAURL" && $element[type] == "open"){
+					$dataurl = true;
+				if($dataurl && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
+					$this->objLayer[$cnt_layer]->layer_dataurl_href = $element[attributes]["xlink:href"];
+			    if(mb_strtoupper($element[tag]) == "DATAURL" && $element[type] == "close"){
+					$dataurl = false;
+				if(mb_strtoupper($element[tag]) == "METADATAURL" && $element[type] == "open"){
+					$metadataurl = true;
+				if($metadataurl && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
+					$this->objLayer[$cnt_layer]->layer_metadataurl = $element[attributes]["xlink:href"];
+			    if(mb_strtoupper($element[tag]) == "METADATAURL" && $element[type] == "close"){
+					$metadataurl = false;
+				if(mb_strtoupper($element[tag]) == "SRS"){
+					// unique srs only, see http://www.mapbender.org/index.php/Arrays_with_unique_entries
+					$this->wms_srs = array_keys(array_flip(array_merge($this->wms_srs, explode(" ", strtoupper($element[value])))));
+				if(mb_strtoupper($element[tag]) == "LATLONBOUNDINGBOX"){
+					$cnt_epsg++;
+					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["epsg"] = "EPSG:4326";
+					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["minx"] = $element[attributes][minx];
+					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["miny"] = $element[attributes][miny];
+					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["maxx"] = $element[attributes][maxx];
+					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["maxy"] = $element[attributes][maxy];
+				if(mb_strtoupper($element[tag]) == "BOUNDINGBOX" && $element[attributes][SRS] != "EPSG:4326"){
+					$cnt_epsg++;
+					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["epsg"] = $element[attributes][SRS];
+					// a default epsg for mapbender
+					if($cnt_layer == 0 && $this->default_epsg == 0 && mb_strlen(trim($element[attributes][SRS]))>= 10){
+						$this->default_epsg = $cnt_epsg;
+				if(mb_strtoupper($element[tag]) == "SCALEHINT"){
+					if($element[attributes][max]>1000) $max = 0; else $max = $element[attributes][max];
+					if($element[attributes][min]>1000) $min = 0; else $min = $element[attributes][min];
+					$this->objLayer[$cnt_layer]->layer_minscale = round(($min * 2004.3976484406788493955738891127));
+					$this->objLayer[$cnt_layer]->layer_maxscale = round(($max * 2004.3976484406788493955738891127));
+			else {
+				continue;
+		if(!$this->wms_title || $this->wms_title == "" || !$this->wms_getmap || $this->wms_getmap == ""){
+			$this->optimizeWMS();
+			$e = new mb_exception("class_wms: createObjFromXML: WMS " . $url . " could not be loaded.");
+			return false;
+		else{
+			$e = new mb_notice("class_wms: createObjFromXML: WMS " . $url . " has been loaded successfully.");
+			return true;
+	 * private function
+	function optimizeWMS() {
+		/*define defaults for wms-version 1.0.0*/
+		$map_default_ok = false;
+		$featureinfo_default_ok = false;
+		$exception_default_ok = false;
+			$map_default = "PNG";
+			$featureinfo_default = "MIME";
+			$exception_default = "INIMAGE";
+		/*define defaults for wms-version 1.1.0 and 1.1.1*/
+		else{
+			$map_default = "image/png";
+			$featureinfo_default = "text/html";
+			$exception_default = "application/vnd.ogc.se_inimage";
+		#some default
+		$this->gui_wms_visible = 1;
+		$this->gui_wms_opacity = 100;
+		/*if the rootlayer has no epsg...*/
+		if($this->objLayer[0]->layer_epsg[0]["epsg"] == ""){
+			$this->objLayer[0]->layer_epsg = $this->objLayer[1]->layer_epsg;
+			for($i=0;$i<count($this->objLayer[0]->layer_epsg);$i++){
+				for($j=1; $j<count($this->objLayer); $j++){
+					if($this->objLayer[0]->layer_epsg[$i]["epsg"] == $this->objLayer[$j]->layer_epsg[$i]["epsg"]){
+						if($this->objLayer[$j]->layer_epsg[$i]["minx"]<$this->objLayer[0]->layer_epsg[$i]["minx"]){
+							$this->objLayer[0]->layer_epsg[$i]["minx"] = $this->objLayer[$j]->layer_epsg[$i]["minx"];
+						if($this->objLayer[$j]->layer_epsg[$i]["miny"]<$this->objLayer[0]->layer_epsg[$i]["miny"]){
+							$this->objLayer[0]->layer_epsg[$i]["miny"] = $this->objLayer[$j]->layer_epsg[$i]["miny"];
+						if($this->objLayer[$j]->layer_epsg[$i]["maxx"]>$this->objLayer[0]->layer_epsg[$i]["maxx"]){
+							$this->objLayer[0]->layer_epsg[$i]["maxx"] = $this->objLayer[$j]->layer_epsg[$i]["maxx"];
+						if($this->objLayer[$j]->layer_epsg[$i]["maxy"]>$this->objLayer[0]->layer_epsg[$i]["maxy"]){
+							$this->objLayer[0]->layer_epsg[$i]["maxy"] = $this->objLayer[$j]->layer_epsg[$i]["maxy"];
+		for($i=0;$i<count($this->objLayer);$i++){
+			if(count($this->objLayer[$i]->layer_epsg) == 0 && count($this->objLayer[0]->layer_epsg) > 0){
+				$this->objLayer[$i]->layer_epsg = $this->objLayer[0]->layer_epsg;
+			if(!is_int($this->objLayer[$i]->layer_parent)){
+				$this->objLayer[$i]->layer_abstract = $this->wms_abstract;
+				for ($r = 0; $r < count($this->wms_keyword); $r++) {
+					array_push($this->objLayer[$i]->layer_keyword, trim($this->wms_keyword[$r]));
+			if($this->objLayer[$i]->layer_name == ""){
+				$this->objLayer[$i]->layer_name = $this->objLayer[$i]->layer_title;
+			if($this->objLayer[$i]->layer_minscale == ""){
+				$this->objLayer[$i]->layer_minscale = 0;
+			if($this->objLayer[$i]->layer_maxscale == ""){
+				$this->objLayer[$i]->layer_maxscale = 0;
+			if($this->objLayer[$i]->layer_queryable == ""){
+				$this->objLayer[$i]->layer_queryable = 0;
+			$this->objLayer[$i]->gui_layer_minscale = $this->objLayer[$i]->layer_minscale;
+			$this->objLayer[$i]->gui_layer_maxscale = $this->objLayer[$i]->layer_maxscale;
+		for($i=0;$i<count($this->data_format);$i++){
+			if(mb_strtolower($this->data_type[$i]) == 'map' && mb_strtoupper($this->data_format[$i]) == mb_strtoupper($map_default)){
+				$this->gui_wms_mapformat = mb_strtolower($map_default);
+				$map_default_ok = true;
+			if(mb_strtolower($this->data_type[$i]) == 'featureinfo' && mb_strtoupper($this->data_format[$i]) == mb_strtoupper($featureinfo_default)){
+				$this->gui_wms_featureinfoformat = mb_strtolower($featureinfo_default);
+				$featureinfo_default_ok = true;
+			if(mb_strtolower($this->data_type[$i]) == 'exception' && mb_strtolower($this->data_format[$i]) == mb_strtolower($exception_default)){
+				$this->gui_wms_exceptionformat = mb_strtolower($exception_default);
+				$exception_default_ok = true;
+		if($map_default_ok == false){
+				if(mb_strtolower($this->data_type[$i]) == "map" ){$this->gui_wms_mapformat = $this->data_format[$i]; break;}
+		if($featureinfo_default_ok == false){
+				if(mb_strtolower($this->data_type[$i]) == "featureinfo" ){$this->gui_wms_featureinfoformat = $this->data_format[$i]; break;}
+		if($exception_default_ok == false){
+				if(mb_strtolower($this->data_type[$i]) == "exception" ){$this->gui_wms_exceptionformat = $this->data_format[$i]; break;}
+		if(count($this->objLayer[0]->layer_epsg)>1){
+			$this->gui_wms_epsg = $this->objLayer[0]->layer_epsg[$this->default_epsg][epsg];
+		else{
+			$this->gui_wms_epsg = $this->objLayer[0]->layer_epsg[0][epsg];
+		/*the queryable layers*/
+		for($i=0; $i<count($this->objLayer); $i++){
+			if($this->objLayer[$i]->layer_queryable == 1){
+				$this->objLayer[$i]->gui_layer_queryable = 1;
+			else{
+				$this->objLayer[$i]->gui_layer_queryable = 0;
+				$this->objLayer[$i]->layer_pos=$i;
+		/* fill sld variables when empty */
+		if($this->wms_supportsld == ""){
+				$this->wms_supportsld = 0;
+		if($this->wms_userlayer == ""){
+				$this->wms_userlayer = 0;
+		if($this->wms_userstyle == ""){
+				$this->wms_userstyle = 0;
+		if($this->wms_remotewfs == ""){
+				$this->wms_remotewfs = 0;
+	function displayWMS(){
+		echo "<br>id: " . $this->wms_id . " <br>";
+		echo "version: " . $this->wms_version . " <br>";
+		echo "title: " . $this->wms_title . " <br>";
+		echo "abstract: " . $this->wms_abstract . " <br>";
+		echo "maprequest: " . $this->wms_getmap . " <br>";
+		echo "capabilitiesrequest: " . $this->wms_getcapabilities . " <br>";
+		echo "featureinforequest: " . $this->wms_getfeatureinfo . " <br>";
+		echo "gui_wms_mapformat: " . $this->gui_wms_mapformat . " <br>";
+		echo "gui_wms_featureinfoformat: " . $this->gui_wms_featureinfoformat . " <br>";
+		echo "gui_wms_exceptionformat: " . $this->gui_wms_exceptionformat . " <br>";
+		echo "gui_wms_epsg: " . $this->gui_wms_epsg . " <br>";
+		echo "wms_srs: " . implode(", ", $this->wms_srs) . " <br>";
+		echo "gui_wms_visible: " . $this->gui_wms_visible . " <br>";
+		echo "gui_wms_opacity: " . $this->gui_wms_opacity . " <br>";
+		echo "support_sld: " . $this->wms_supportsld . " <br>";
+		for($i=0; $i<count($this->data_type);$i++){
+			echo $this->data_type[$i]. " -> ".$this->data_format[$i]. "<br>";
+			echo "<hr>";
+			echo "id: <b>".$this->objLayer[$i]->layer_id ."</b> parent: <b>".$this->objLayer[$i]->layer_parent."</b> name: <b>".$this->objLayer[$i]->layer_name;
+			echo "</b> title: <b>".$this->objLayer[$i]->layer_title. "</b> queryable: <b>".$this->objLayer[$i]->layer_queryable."</b> minScale: <b>". $this->objLayer[$i]->layer_minscale."</b> maxScale: <b>".$this->objLayer[$i]->layer_maxscale."</b>";
+			echo "<br>dataurl: <b>".$this->objLayer[$i]->layer_dataurl_href. "</b>";
+			echo "<br>metadataurl: <b>".$this->objLayer[$i]->layer_metadataurl. "</b>";
+			echo "<table border='1'>";
+			for($j=0; $j<count($this->objLayer[$i]->layer_epsg);$j++){
+				echo "<tr><td>".$this->objLayer[$i]->layer_epsg[$j][epsg]."</td><td>".$this->objLayer[$i]->layer_epsg[$j][minx]."</td>";
+				echo "<td>".$this->objLayer[$i]->layer_epsg[$j][miny]."</td><td>".$this->objLayer[$i]->layer_epsg[$j][maxx]."</td>";
+				echo "<td>".$this->objLayer[$i]->layer_epsg[$j][maxy]."</td></tr>";
+			echo "</table>";
+			echo "layerstyle:";
+			echo "<tr><td>name</td><td>title</td><td>legendurl</td><td>legendurlformat</td></tr>";
+			for($j=0; $j<count($this->objLayer[$i]->layer_style);$j++){
+				echo "<tr><td>".$this->objLayer[$i]->layer_style[$j][name]."</td><td>".$this->objLayer[$i]->layer_style[$j][title]."</td><td>".$this->objLayer[$i]->layer_style[$j][legendurl]."</td><td>".$this->objLayer[$i]->layer_style[$j][legendurlformat]."</td></tr>";
+			echo "</table>";
+	        echo "<hr>";
+	        echo "<hr>";
+	  function addLayer($id,$parent){
+		$this->objLayer[count($this->objLayer)] = new layer($id,$parent);
+	  function stripEndlineAndCarriageReturn($string) {
+	  	return preg_replace("/\n/", "", preg_replace("/\r/", " ", $string));
+		function createJsObjFromWMS($parent=0){
+			echo $this->createJsObjFromWMS_($parent);
+	function newLayer ($currentLayer, $currentExtent) {
+		$pos = $currentLayer["extension"]["LAYER_POS"];
+		$parent = $currentLayer["extension"]["LAYER_PARENT"];
+		$this->addLayer($pos, $parent);
+		// set layer data
+		$layerIndex = count($this->objLayer) - 1;
+		$newLayer = $this->objLayer[$layerIndex];
+		$newLayer->layer_uid = $currentLayer["extension"]["LAYER_ID"];
+		$newLayer->layer_name = $currentLayer["name"];
+		$newLayer->layer_title = $currentLayer["title"];
+		$newLayer->layer_dataurl_href = $currentLayer["dataurl"];
+		$newLayer->layer_pos = $currentLayer["extension"]["LAYER_POS"];
+		$newLayer->layer_queryable = $currentLayer["queryable"];
+		$newLayer->layer_minscale = $currentLayer["extension"]["MINSCALE"];
+		$newLayer->layer_maxscale = $currentLayer["extension"]["MAXSCALE"];
+		$newLayer->layer_metadataurl = $currentLayer["metadataurl"];
+		$newLayer->gui_layer_wms_id = $currentLayer["extension"]["WMS_ID"];
+		$newLayer->gui_layer_status = $currentLayer["extension"]["GUI_STATUS"];
+		$newLayer->gui_layer_style = ""; // TODO: Add correct data
+		$newLayer->gui_layer_selectable = $currentLayer["extension"]["GUI_SELECTABLE"];
+		if (isset($currentLayer["extension"]["OVERVIEWHIDDEN"])) {
+			$newLayer->gui_layer_visible = ($currentLayer["extension"]["OVERVIEWHIDDEN"] === "1") ? false : true;
+		else {
+			$newLayer->gui_layer_visible = $currentLayer["visible"];
+		if (isset($currentLayer["extension"]["WFSFEATURETYPE"])) {
+			$newLayer->gui_layer_wfs_featuretype = strval($currentLayer["extension"]["WFSFEATURETYPE"]);
+		else {
+			$newLayer->gui_layer_wfs_featuretype = "";
+		$newLayer->gui_layer_queryable = $currentLayer["extension"]["GUI_QUERYABLE"];
+		$newLayer->gui_layer_querylayer = $currentLayer["extension"]["QUERYLAYER"];
+		$newLayer->gui_layer_minscale = $currentLayer["extension"]["GUI_MINSCALE"];
+		$newLayer->gui_layer_maxscale = $currentLayer["extension"]["GUI_MAXSCALE"];
+		$newLayer->layer_abstract = $currentLayer["abstract"];
+		// set layer epsg
+		$tmpEpsgArray= array();
+		$newLayer->layer_epsg = array();
+		if ($currentLayer["extension"]["EPSG"]) {
+			$layerEpsgArray = array();
+			$layerMinXArray = array();
+			$layerMinYArray = array();
+			$layerMaxXArray = array();
+			$layerMaxYArray = array();
+			if (!is_array($currentLayer["extension"]["EPSG"])) {
+				$layerEpsgArray[0] = $currentLayer["extension"]["EPSG"];
+				$layerMinXArray[0] = $currentLayer["extension"]["MINX"];
+				$layerMinYArray[0] = $currentLayer["extension"]["MINY"];
+				$layerMaxXArray[0] = $currentLayer["extension"]["MAXX"];
+				$layerMaxYArray[0] = $currentLayer["extension"]["MAXY"];
+			else {
+				$layerEpsgArray = $currentLayer["extension"]["EPSG"];
+				$layerMinXArray = $currentLayer["extension"]["MINX"];
+				$layerMinYArray = $currentLayer["extension"]["MINY"];
+				$layerMaxXArray = $currentLayer["extension"]["MAXX"];
+				$layerMaxYArray = $currentLayer["extension"]["MAXY"];
+			for ($i=0; $i < count($layerEpsgArray); $i++) {
+				$currentLayerEpsg = array();
+				$currentLayerEpsg["epsg"] = $layerEpsgArray[$i];
+				$tmpEpsgArray[]= $layerEpsgArray[$i];
+				if ($layerMinXArray[$i] == 0
+					&& $layerMinYArray[$i] == 0
+					&& $layerMaxXArray[$i] == 0
+					&& $layerMaxYArray[$i] == 0
+					$currentLayerEpsg["minx"] = null;
+					$currentLayerEpsg["miny"] = null;
+					$currentLayerEpsg["maxx"] = null;
+					$currentLayerEpsg["maxy"] = null;
+				else {
+					$currentLayerEpsg["minx"] = floatval($layerMinXArray[$i]);
+					$currentLayerEpsg["miny"] = floatval($layerMinYArray[$i]);
+					$currentLayerEpsg["maxx"] = floatval($layerMaxXArray[$i]);
+					$currentLayerEpsg["maxy"] = floatval($layerMaxYArray[$i]);
+				array_push($newLayer->layer_epsg, $currentLayerEpsg);
+		for ($i = 0; $i < count($currentLayer["epsg"]); $i++) {
+			if (!in_array($currentLayer["epsg"][$i], $tmpEpsgArray)) {
+				$newLayer->layer_epsg[]= array(
+					"epsg" => $currentLayer["epsg"][$i],
+					"minx" => null,
+					"miny" => null,
+					"maxx" => null,
+					"maxy" => null
+		// set layer style
+		for ($i = 0; $i < count($currentLayer["style"]); $i++) {
+			$layerStyleIndex = count($newLayer->gui_layer_style) - 1;
+			$newLayer->layer_style[$layerStyleIndex] = array();
+			$newLayer->layer_style[$layerStyleIndex]["name"] = $currentLayer["style"][$i]["name"];
+			$newLayer->layer_style[$layerStyleIndex]["title"] = $currentLayer["style"][$i]["title"];
+			$newLayer->layer_style[$layerStyleIndex]["legendurl"] = $currentLayer["style"][$i]["legendurl"];
+			$newLayer->layer_style[$layerStyleIndex]["legendurl_format"] = $currentLayer["style"][$i]["legendurl_type"];
+	  function createJsObjFromWMS_($parent=0){
+		$str = "";
+			$str .= "alert('Error: no valid capabilities-document !!');";
+			die; exit;
+			if($parent){
+				$str .=  "parent.";
+			$add_wms_string = "add_wms(" .
+					"'" . $this->wms_id ."'," .
+					"'" . $this->wms_version ."'," .
+					"'" . addslashes($this->wms_title) . "'," .
+					"'" . addslashes($this->wms_abstract) ."'," .
+					"'" . $this->wms_getmap ."'," .
+					"'" . $this->wms_getfeatureinfo ."'," .
+					"'" . $this->wms_getlegendurl ."'," .
+					"'" . $this->wms_filter ."'," .
+					"'" . $this->gui_wms_mapformat . "'," .
+					"'" . $this->gui_wms_featureinfoformat . "'," .
+					"'" . $this->gui_wms_exceptionformat . "'," .
+					"'" . $this->gui_wms_epsg ."'," .
+					"'" . $this->gui_wms_visible ."'," .
+					"'" . $this->gui_wms_opacity ."'," .
+					"'" . $this->gui_wms_sldurl ."" .
+			$str .=  $add_wms_string;
+			if($parent){
+			$str .= "wms_add_data_type_format('". $this->data_type[$i] ."','". $this->data_format[$i] ."');";
+			if($parent){
+			$str .=  "wms_add_layer('".
+				$this->objLayer[$i]->layer_parent ."','".
+				$this->objLayer[$i]->layer_uid ."','".
+				addslashes($this->objLayer[$i]->layer_name) . "','".
+				addslashes($this->objLayer[$i]->layer_title) ."','".
+				$this->objLayer[$i]->layer_dataurl_href ."','".
+				$this->objLayer[$i]->layer_pos ."','".
+				$this->objLayer[$i]->layer_queryable ."','".
+				$this->objLayer[$i]->layer_minscale . "','".
+				$this->objLayer[$i]->layer_maxscale ."','".
+				$this->objLayer[$i]->layer_metadataurl ."','".
+				$this->objLayer[$i]->gui_layer_wms_id ."','".
+				$this->objLayer[$i]->gui_layer_status ."','".
+				$this->objLayer[$i]->gui_layer_style ."','".
+				$this->objLayer[$i]->gui_layer_selectable ."','".
+				$this->objLayer[$i]->gui_layer_visible ."','".
+				$this->objLayer[$i]->gui_layer_queryable ."','".
+				$this->objLayer[$i]->gui_layer_querylayer ."','".
+				$this->objLayer[$i]->gui_layer_minscale ."','".
+				$this->objLayer[$i]->gui_layer_maxscale ."','".
+				$this->objLayer[$i]->gui_layer_wfs_featuretype ."');";
+				$currentEpsg = $this->objLayer[$i]->layer_epsg[$j];
+				if($i==0){
+					if($parent){
+					$str .= "wms_addSRS('".
+						$currentEpsg["epsg"] ."',".
+						(is_null($currentEpsg["minx"]) ? "null" : $currentEpsg["minx"]) .",".
+						(is_null($currentEpsg["miny"]) ? "null" : $currentEpsg["miny"]) .",".
+						(is_null($currentEpsg["maxx"]) ? "null" : $currentEpsg["maxx"]) .",".
+						(is_null($currentEpsg["maxy"]) ? "null" : $currentEpsg["maxy"]) .");";
+				if (!is_null($currentEpsg["epsg"])) {
+					if($parent){
+					$str .= "layer_addEpsg('".
+			for($j=0; $i==0 && $j<count($this->wms_srs);$j++){
+				$found = false;
+				for ($k = 0; $k < count($this->objLayer[$i]->layer_epsg); $k++){
+					if ($this->objLayer[$i]->layer_epsg[$k]["epsg"] === $this->wms_srs[$j]) {
+						$found = true;
+						break;
+				if ($found) {
+					continue;
+				if($parent){
+				$this->wms_srs[$j] ."', null, null, null, null);\n";
+				if($parent){
+				$str .= "wms_addLayerStyle('".$this->objLayer[$i]->layer_style[$j]["name"].
+					"', '".$this->objLayer[$i]->layer_style[$j]["title"].
+					"', ".$j.
+					",".$i.
+					",'".$this->objLayer[$i]->layer_style[$j]["legendurl"].
+					"', '".$this->objLayer[$i]->layer_style[$j]["legendurlformat"]."');";
+		return $str;
+	  function createJsLayerObjFromWMS($parent=0, $layer_name){
+			echo " alert('Error: no valid capabilities-document !!');";
+			die; exit;
+			if($parent){
+				echo "parent.";
+			print("add_wms('".
+			$this->wms_id ."','".
+			$this->wms_version ."','".
+			preg_replace("/'/", "", $this->wms_title) ."','".
+			preg_replace("/'/", "", $this->wms_abstract) ."','".
+			$this->wms_getmap ."','" .
+			$this->wms_getfeatureinfo ."','".
+			$this->wms_getlegendurl ."','".
+			$this->wms_filter ."','".
+			$this->gui_wms_mapformat ."','".
+			$this->gui_wms_featureinfoformat ."','".
+			$this->gui_wms_exceptionformat . "','".
+			$this->gui_wms_epsg ."','".
+			$this->gui_wms_visible ."','".
+			$this->gui_wms_opacity ."','".
+			$this->gui_wms_sldurl ."');");
+			if($parent){
+				echo "parent.";
+			echo "wms_add_data_type_format('". $this->data_type[$i] ."','". $this->data_format[$i] ."');";
+			if($this->objLayer[$i]->layer_name == $layer_name|| $this->objLayer[$i]->layer_pos == 0){
+				if($parent){
+					echo "parent.";
+			 print ("wms_add_layer('".
+				$this->objLayer[$i]->layer_name . "','".
+				$this->objLayer[$i]->gui_layer_wfs_featuretype ."');");
+				if($i==0){
+					if($parent){
+					echo "parent.";
+					print("wms_addSRS('".
+						$this->objLayer[$i]->layer_epsg[$j]["epsg"] ."','".
+						$this->objLayer[$i]->layer_epsg[$j]["minx"] ."','".
+						$this->objLayer[$i]->layer_epsg[$j]["miny"] ."','".
+						$this->objLayer[$i]->layer_epsg[$j]["maxx"] ."','".
+						$this->objLayer[$i]->layer_epsg[$j]["maxy"] ."');");
+				if($parent){
+				echo "parent.";
+				print("layer_addEpsg('".
+				if($parent){
+				echo "parent.";
+				print("wms_addLayerStyle('".$this->objLayer[$i]->layer_style[$j]["name"]."', '".$this->objLayer[$i]->layer_style[$j]["title"]."', ".$j.",".$i.",'".$this->objLayer[$i]->layer_style[$j]["legendurl"]."', '".$this->objLayer[$i]->layer_style[$j]["legendurlformat"]."');");
+	* writeObjInDB
+	* this function exports the information from the xml to the mapbender database
+	function writeObjInDB($gui_id){
+		global $con;
+			$username = $auth['username'];
+			$password = $auth['password'];
+			$authType = $auth['auth_type'];
+		else {
+			$username = '';
+			$password = '';
+			$authType = '';
+		$this->checkObj();
+		db_begin();
+		# TABLE wms
+		$sql = "INSERT INTO wms (wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, ";
+		$sql.= "wms_getfeatureinfo, wms_getlegendurl, wms_getcapabilities_doc, wms_upload_url, fees, ";
+		$sql .= "accessconstraints, contactperson, contactposition, contactorganization, address, city, ";
+		$sql .= "stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, ";
+		$sql .= "wms_owner,wms_timestamp,wms_username,wms_password,wms_auth_type,";
+		$sql .= "wms_supportsld, wms_userlayer, wms_userstyle, wms_remotewfs) ";
+		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24,$25,$26,$27,$28,$29,$30,$31)";
+		$v = array(
+			$this->wms_version,
+			$this->wms_title,
+			$this->wms_abstract,
+			$this->wms_getcapabilities,
+			$this->wms_getmap,
+			$this->wms_getfeatureinfo,
+			$this->wms_getlegendurl,
+			$admin->char_encode($this->wms_getcapabilities_doc),
+			$this->wms_upload_url,
+			$this->fees,
+			$this->accessconstraints,
+			$this->contactperson,
+			$this->contactposition,
+			$this->contactorganization,
+			$this->address,
+			$this->city,
+			$this->stateorprovince,
+			$this->postcode,
+			$this->country,
+			$this->contactvoicetelephone,
+			$this->contactfacsimiletelephone,
+			$this->contactelectronicmailaddress,
+			Mapbender::session()->get('mb_user_id'),
+			strtotime("now"),
+			$username,
+			$password,
+			$authType,
+			$this->wms_supportsld,
+			$this->wms_userlayer,
+			$this->wms_userstyle,
+		$t = array(
+			's','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s',
+			's','s','s','s','s','s','i','i','s','s','s','s','s','s','s'
+		$res = db_prep_query($sql,$v,$t);
+		if(!$res){
+			db_rollback();
+			return null;
+		$myWMS = db_insert_id($con,'wms', 'wms_id');
+		if ($authType != '') { //some authentication is needed!
+			echo "WMS ID: ".$myWMS;
+			$admin->setWMSOWSstring($myWMS, 1);
+		# TABLE layer and gui_layer
+			$this->insertLayer($i,$myWMS,$gui_id);
+			$this->insertGuiLayer($i,$myWMS,$gui_id);
+		#TABLE wms_srs
+		$this->insertSRS($myWMS);
+		# TABLE wms_format
+		$this->insertFormat($myWMS);
+		# TABLE gui_wms
+		$sql ="SELECT MAX(gui_wms_position) AS pos FROM gui_wms WHERE fkey_gui_id = $1";
+		$v = array($gui_id);
+		$t = array('s');
+		if (db_result($res, 0,"pos") > -1) {
+			$position = db_result($res, 0,"pos") + 1;
+		else {
+			$position = 0;
+		$sql ="INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, ";
+		$sql .= "gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg)";
+		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7)";
+		$v = array(
+			$gui_id,
+			$myWMS,
+			$position,
+			$this->gui_wms_mapformat,
+			$this->gui_wms_featureinfoformat,
+			$this->gui_wms_exceptionformat,
+		$t = array('s','i','i','s','s','s','s');
+		if(!$res){
+			db_rollback();
+			return null;
+		db_commit();
+		// update GeoRSS feed
+		$geoRssFactory = new GeoRssFactory();
+		$geoRss = $geoRssFactory->loadOrCreate(GEO_RSS_FILE);
+		if (!is_null($geoRss)) {
+			$geoRssItem = new GeoRssItem();
+			$geoRssItem->setTitle("NEW: " . $this->wms_title);
+			$geoRssItem->setDescription($this->wms_abstract);
+			$geoRssItem->setUrl(self::getWmsMetadataUrl($myWMS));
+			for ($j = 0; $j < count($this->objLayer[0]->layer_epsg); $j++) {
+				$currentEpsg = $this->objLayer[0]->layer_epsg[$j];
+				if ($currentEpsg["epsg"] === "EPSG:4326") {
+					$currentBbox = new Mapbender_bbox(
+						$currentEpsg["minx"],
+						$currentEpsg["miny"],
+						$currentEpsg["maxx"],
+						$currentEpsg["maxy"],
+					$geoRssItem->setBbox($currentBbox);
+					break;
+			$geoRss->append($geoRssItem);
+			$geoRss->saveAsFile();
+	    #Changes JW
+	    $this->wms_id = $myWMS;
+	function insertLayer($i,$myWMS){
+		global $con;
+		$sql = "INSERT INTO layer(fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, ";
+		$sql .= " layer_queryable, layer_minscale, layer_maxscale,layer_dataurl,layer_metadataurl,layer_abstract) ";
+		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11)";
+		if($this->objLayer[$i]->layer_id != null){
+			$tmpPos =  $this->objLayer[$i]->layer_id;
+		else {
+			$tmpPos .= 0;
+		if($this->objLayer[$i]->layer_parent == '' && $this->objLayer[$i]->layer_parent != '0'){
+			$this->objLayer[$i]->layer_parent = '';
+		$v = array($myWMS,$tmpPos,$this->objLayer[$i]->layer_parent,$this->objLayer[$i]->layer_name,
+				$this->objLayer[$i]->layer_title,
+				$this->objLayer[$i]->layer_queryable,$this->objLayer[$i]->layer_minscale,
+				$this->objLayer[$i]->layer_maxscale,$this->objLayer[$i]->layer_dataurl_href,
+				$this->objLayer[$i]->layer_metadataurl,$this->objLayer[$i]->layer_abstract);
+		$t = array('i','i','s','s','s','i','i','i','s','s','s');
+		if(!$res){
+			db_rollback();
+		else {
+			# save the id of each layer: set param2 true
+			$this->objLayer[$i]->db_id = db_insert_id($con, 'layer','layer_id');
+			$this->insertLayerEPSG($i);
+			# TABLE layer_style for each layer
+			$this->insertLayerStyle($i);
+			# insert Keywords
+			$this->insertLayerKeyword($i);
+	function updateLayer($i,$myWMS){
+		$sql = "SELECT layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_name = $2";
+		$v = array($myWMS,$this->objLayer[$i]->layer_name);
+		$t = array('i','s');
+		if($row = db_fetch_array($res)){
+			$l_id = $row['layer_id'];
+		else{
+			db_rollback();
+			$e = new mb_exception("Not found: ".$this->objLayer[$i]->layer_name);
+			return;
+		$sql = "UPDATE layer SET ";
+		$sql .= "layer_pos = $1, ";
+		$sql .= "layer_parent = $2, ";
+		$sql .= "layer_title = $3, ";
+		$sql .= "layer_queryable = $4, ";
+		$sql .= "layer_minscale = $5, ";
+		$sql .= "layer_maxscale = $6, ";
+		$sql .= "layer_dataurl = $7, ";
+		$sql .= "layer_metadataurl = $8, ";
+		$sql .= "layer_abstract = $9 ";
+		$sql .= "WHERE layer_id = $10";
+		else {
+			$tmpPos .= 0;
+		$v = array($tmpPos,$this->objLayer[$i]->layer_parent,
+				$this->objLayer[$i]->layer_metadataurl,$this->objLayer[$i]->layer_abstract, $l_id
+		$t = array('i','s','s','i','i','i','s','s','s','i');
+		if($this->overwrite == true){
+			$sql .= "layer_title = $1, ";
+			$sql .= "layer_abstract = $2 ";
+			$sql .= "WHERE layer_id = $3";
+			$v = array($this->objLayer[$i]->layer_title,$this->objLayer[$i]->layer_abstract, $l_id);
+			$t = array('s','s','i');
+		if(!$res){
+			db_rollback();
+		else {
+			$this->objLayer[$i]->db_id = $l_id;
+	function insertGuiLayer($i,$myWMS,$gui_id){
+		# table gui_layer
+		$sql = "INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, ";
+		$sql .= "gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, ";
+		$sql .= "gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale, gui_layer_priority, gui_layer_style) ";
+		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12)";
+		if(count($this->objLayer[$i]->layer_style)>0){
+			$layer_style_name = $this->objLayer[$i]->layer_style[0]["name"];
+		else{
+			$layer_style_name = NULL;
+		$v = array($gui_id,$this->objLayer[$i]->db_id,$myWMS,1,1,1,$this->objLayer[$i]->layer_queryable,
+			$this->objLayer[$i]->layer_queryable,$this->objLayer[$i]->layer_minscale,$this->objLayer[$i]->layer_maxscale,$i,$layer_style_name);
+		$t = array('s','i','i','i','i','i','i','i','i','i','i','s');
+		#$e = new mb_exception("name des insert styles und fkey_layer_id: ".$layer_style_name." --- ".$this->objLayer[$i]->db_id);
+		if(!$res){
+			db_rollback();
+	function appendGuiLayer($i,$myWMS,$gui_id){
+		# table gui_layer
+		else{
+		$v = array($gui_id,$this->objLayer[$i]->db_id,$myWMS,0,0,0,$this->objLayer[$i]->layer_queryable,
+		if(!$res){
+			db_rollback();
+	function insertSRS($myWMS){
+		for($i=0; $i<count($this->wms_srs);$i++){
+			$sql ="INSERT INTO wms_srs (fkey_wms_id, wms_srs) values($1,$2)";
+			$v = array($myWMS,mb_strtoupper($this->wms_srs[$i]));
+			if(!$res){
+				db_rollback();
+	function insertFormat($myWMS){
+			$sql ="INSERT INTO wms_format (fkey_wms_id, data_type, data_format) ";
+			$sql .= " VALUES($1,$2,$3)";
+			$v = array($myWMS,$this->data_type[$i],$this->data_format[$i]);
+			$t = array('i','s','s');
+			if(!$res){
+				db_rollback();
+	function insertLayerEPSG($i){
+		$sql = "DELETE FROM layer_epsg WHERE fkey_layer_id = $1";
+		$v = array($this->objLayer[$i]->db_id);
+		$t = array('i');
+			$sql = "INSERT INTO layer_epsg (fkey_layer_id, epsg, minx, miny, maxx, maxy) ";
+			$sql .= "VALUES($1,$2,$3,$4,$5,$6)";
+			$v = array($this->objLayer[$i]->db_id,$this->objLayer[$i]->layer_epsg[$j][epsg],
+				$this->objLayer[$i]->layer_epsg[$j][minx],$this->objLayer[$i]->layer_epsg[$j][miny],
+				$this->objLayer[$i]->layer_epsg[$j][maxx],$this->objLayer[$i]->layer_epsg[$j][maxy]
+			$t = array('i','s','d','d','d','d');
+			if(!$res){
+				db_rollback();
+	function insertLayerStyle($i){
+		$sql = "DELETE FROM layer_style WHERE fkey_layer_id = $1";
+		$t = array('i');
+			$sql = "INSERT INTO layer_style (fkey_layer_id, name, title, legendurl, legendurlformat) ";
+			$sql .= "VALUES($1,$2,$3,$4,$5)";
+			$v = array($this->objLayer[$i]->db_id,$this->objLayer[$i]->layer_style[$j]["name"],
+					$this->objLayer[$i]->layer_style[$j]["title"],$this->objLayer[$i]->layer_style[$j]["legendurl"],
+					$this->objLayer[$i]->layer_style[$j]["legendurlformat"]
+			$t = array('i','s','s','s','s');
+			if(!$res){
+				db_rollback();
+	function insertLayerKeyword($i){
+		global $con;
+		$sql = "DELETE FROM layer_keyword WHERE fkey_layer_id = $1";
+		$t = array('i');
+//		var_dump($this);
+		$k = $this->objLayer[$i]->layer_keyword;
+//		var_dump($k);
+		for($j=0; $j<count($k); $j++){
+			$keyword_id = "";
+			while ($keyword_id == "") {
+				$sql = "SELECT keyword_id FROM keyword WHERE UPPER(keyword) = UPPER($1)";
+				$v = array($k[$j]);
+				$t = array('s');
+				$row = db_fetch_array($res);
+			//print_r($row);
+				if ($row) {
+					$keyword_id = $row["keyword_id"];
+				else {
+					$sql_insertKeyword = "INSERT INTO keyword (keyword)";
+					$sql_insertKeyword .= "VALUES ($1)";
+					$v1 = array($k[$j]);
+					$t1 = array('s');
+					$res_insertKeyword = db_prep_query($sql_insertKeyword,$v1,$t1);
+					if(!$res_insertKeyword){
+						db_rollback();
+			// check if layer/keyword combination already exists
+			$sql_layerKeywordExists = "SELECT * FROM layer_keyword WHERE fkey_layer_id = $1 AND fkey_keyword_id = $2";
+			$v = array($this->objLayer[$i]->db_id, $keyword_id);
+			$t = array('i', 'i');
+			$res_layerKeywordExists = db_prep_query($sql_layerKeywordExists, $v, $t);
+			$row = db_fetch_array($res_layerKeywordExists);
+			//print_r($row);
+			if (!$row) {
+				$sql1 = "INSERT INTO layer_keyword (fkey_keyword_id,fkey_layer_id)";
+				$sql1 .= "VALUES ($1,$2)";
+				$v1 = array($keyword_id,$this->objLayer[$i]->db_id);
+				$t1 = array('i','i');
+				$res1 = db_prep_query($sql1,$v1,$t1);
+				if(!$res1){
+					db_rollback();
+	function updateObjInDB($myWMS){
+		db_begin();
+		$sql = "UPDATE wms SET ";
+		$sql .= "wms_version = $1 ,";
+		$sql .= "wms_getcapabilities  = $2 ,";
+		$sql .= "wms_getmap  = $3 ,";
+		$sql .= "wms_getfeatureinfo  = $4 ,";
+		$sql .= "wms_getlegendurl  = $5 ,";
+		$sql .= "wms_getcapabilities_doc = $6 ,";
+		$sql .= "wms_upload_url = $7,  ";
+		$sql .= "wms_owner = $8, ";
+		$sql .= "wms_timestamp = $9, ";
+		$sql .= "wms_supportsld = $10, ";
+		$sql .= "wms_userlayer = $11, ";
+		$sql .= "wms_userstyle = $12, ";
+		$sql .= "wms_remotewfs = $13 ";
+		$sql .= " WHERE wms_id = $14";
+		$v = array($this->wms_version,$this->wms_getcapabilities,
+			$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,
+			$admin->char_encode($this->wms_getcapabilities_doc),$this->wms_upload_url,Mapbender::session()->get("mb_user_id"),strtotime("now"),
+			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs,$myWMS);
+		$t = array('s','s','s','s','s','s','s','i','i','s','s','s','s','i');
+		if(!$res){
+			db_rollback();
+			$sql .= "wms_title  = $1 ,";
+			$sql .= "wms_abstract  = $2 ,";
+			$sql .= "fees = $3, ";
+			$sql .= "accessconstraints = $4, ";
+			$sql .= "contactperson = $5, ";
+			$sql .= "contactposition = $6, ";
+			$sql .= "contactorganization = $7, ";
+			$sql .= "address = $8, ";
+			$sql .= "city = $9, ";
+			$sql .= "stateorprovince = $10, ";
+			$sql .= "postcode = $11, ";
+			$sql .= "country = $12, ";
+			$sql .= "contactvoicetelephone = $13, ";
+			$sql .= "contactfacsimiletelephone = $14, ";
+			$sql .= "contactelectronicmailaddress = $15 ";
+			$sql .= " WHERE wms_id = $16";
+			$v = array($this->wms_title,$this->wms_abstract,$this->fees,$this->accessconstraints,
+				$this->contactperson,$this->contactposition,$this->contactorganization,$this->address,
+				$this->city,$this->stateorprovince,$this->postcode,$this->country,$this->contactvoicetelephone,
+				$this->contactfacsimiletelephone,$this->contactelectronicmailaddress,$myWMS);
+			$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i');
+			if(!$res){
+				db_rollback();
+		# delete and refill srs and formats
+		$sql = "DELETE FROM wms_srs WHERE fkey_wms_id = $1 ";
+		$v = array($myWMS);
+		$t = array('i');
+		if(!$res){
+			db_rollback();
+		$sql = "DELETE FROM wms_format WHERE fkey_wms_id = $1 ";
+		$t = array('i');
+		if(!$res){
+			db_rollback();
+		# update gui_wms
+		$this->update_gui_wms($myWMS);
+		# update TABLE layer
+		$oldLayerNameArray = array();
+		$t = array('i');
+		$c = 2;
+		$sql = "SELECT layer_name, layer_title, layer_abstract FROM layer WHERE fkey_wms_id = $1 AND NOT layer_name IN(";
+			if($i>0){$sql .= ',';}
+			$sql .= "$".$c;
+			array_push($v,$this->objLayer[$i]->layer_name);
+			array_push($t,'s');
+			$c++;
+		$sql .= ")";
+		while ($row = db_fetch_array($res)) {
+			$oldLayerNameArray[]= array(
+				"name" => $row["layer_name"],
+				"title" => $row["layer_title"],
+				"abstract" => $row["layer_abstract"]
+		# delete all layer which are outdated
+		$t = array('i');
+		$c = 2;
+		$sql = "DELETE FROM layer WHERE fkey_wms_id = $1 AND NOT layer_name IN(";
+			$sql .= "$".$c;
+			$c++;
+		$sql .= ")";
+		if(!$res){
+			db_rollback();
+		# update or insert?
+		$sql = "SELECT layer_name FROM layer WHERE fkey_wms_id = $1";
+		$t = array('i');
+		$exLayer = array();
+		while($row = db_fetch_array($res)){
+			array_push($exLayer,$row["layer_name"]);
+		$sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = $1";
+		$t = array('i');
+		$exGui = array();
+			array_push($exGui,$row["fkey_gui_id"]);
+		$newLayerArray = array();
+			if(in_array($this->objLayer[$i]->layer_name,$exLayer)){
+				//echo "<br>update: ".$this->objLayer[$i]->layer_name;
+				$this->updateLayer($i,$myWMS);
+				for($j=0; $j<count($exGui); $j++){
+					$this->updateGuiLayer($i,$myWMS,$exGui[$j]);
+			else{
+				//echo "<br>append: ".$this->objLayer[$i]->layer_name;
+				$this->insertLayer($i,$myWMS);
+				$newLayerArray[]= $i;
+					$this->appendGuiLayer($i,$myWMS,$exGui[$j]);
+		db_commit();
+			$geoRssItem->setTitle("UPDATED WMS: " . $this->wms_title);
+					break;
+			foreach ($newLayerArray as $newLayer) {
+				$currentLayer = $this->objLayer[$newLayer];
+				$geoRssItem->setTitle("ADDED LAYER: " . $currentLayer->layer_title);
+				$geoRssItem->setDescription($currentLayer->layer_abstract);
+				$geoRssItem->setUrl(layer::getLayerMetadataUrl($currentLayer->layer_id));
+				for ($j = 0; $j < count($currentLayer->layer_epsg); $j++) {
+					$currentEpsg = $currentLayer->layer_epsg[$j];
+						break;
+			foreach ($oldLayerNameArray as $oldLayer) {
+				$geoRssItem->setTitle("DELETED LAYER: " . $oldLayer["title"]);
+				$geoRssItem->setDescription($oldLayer["abstract"]);
+//				$geoRssItem->setUrl();
+		return;
+	function updateGuiLayer($i,$myWMS,$gui_id){
+		else{
+			db_rollback();
+			$e = new mb_exception("Not found: ".$this->objLayer[$i]->layer_name. " in gui: ".$gui_id);
+			return;
+		$sql = "SELECT * FROM gui_layer WHERE fkey_layer_id = $1 and fkey_gui_id = $2";
+		$v = array($l_id,$gui_id);
+			if($this->objLayer[$i]->layer_queryable == 0){
+				$sql1 = "UPDATE gui_layer set gui_layer_queryable = 0, gui_layer_querylayer = 0 ";
+				$sql1 .= "WHERE fkey_layer_id = $1 and fkey_gui_id = $2";
+				$res1 = db_prep_query($sql1,$v,$t);
+				if(!$res1){
+				db_rollback();
+				$sql1 = "UPDATE gui_layer set gui_layer_queryable = 1 ";
+				if(!$res1){
+					db_rollback();
+			if($row["gui_layer_minscale"] < $this->objLayer[$i]->layer_minscale){
+				$sql1 = "UPDATE gui_layer set gui_layer_minscale = $1 ";
+				$sql1 .= "WHERE fkey_layer_id = $2 and fkey_gui_id = $3";
+				$v = array($this->objLayer[$i]->layer_minscale,$l_id,$gui_id);
+				$t = array('i','i','s');
+				if(!$res1){db_rollback();
+			if($row["gui_layer_maxscale"] > $this->objLayer[$i]->layer_maxscale){
+				$sql1 = "UPDATE gui_layer set gui_layer_maxscale = $1 ";
+				$v = array($this->objLayer[$i]->layer_maxscale,$l_id,$gui_id);
+	function update_gui_wms($myWMS){
+		$mySubmit = null;
+		$sql = "SELECT * FROM gui_wms where fkey_wms_id = $1";
+		$t = array('i');
+		$cnt = 0;
+			unset($mySubmit);
+			$myGUI[$cnt] = $row["fkey_gui_id"];
+			$sql = "UPDATE gui_wms SET ";
+			$v = array();
+			$t = array();
+			$paramCount = 0;
+			for($i=0; $i<count($this->data_type); $i++){
+				# gui_wms_mapformat
+				if(mb_strtolower($this->data_type[$i]) == "map" && mb_strtolower($this->data_format[$i]) == mb_strtolower($row["gui_wms_mapformat"])){
+					$myMapFormat = true;
+				# gui_wms_featureinfoformat
+				if(mb_strtolower($this->data_type[$i]) == "featureinfo" && mb_strtolower($this->data_format[$i]) == mb_strtolower($row["gui_wms_featureinfoformat"])){
+					$myFeatureInfoFormat = true;
+				# gui_wms_exceptionformat
+				if(mb_strtolower($this->data_type[$i]) == "exception" && mb_strtolower($this->data_format[$i]) == mb_strtolower($row["gui_wms_exceptionformat"])){
+					$myExceptionFormat = true;
+			if(!$myMapFormat){
+				$paramCount++;
+				$sql .= "gui_wms_mapformat = $" . $paramCount . " ";
+				$mySubmit = true;
+				array_push($v, $this->gui_wms_mapformat);
+				array_push($t, "s");
+			if(!$myFeatureInfoFormat){
+				if($mySubmit){ $sql .= ",";}
+				$paramCount++;
+				$sql .= "gui_wms_featureinfoformat = $" . $paramCount . " ";
+				array_push($v, $this->gui_wms_featureinfoformat);
+				$mySubmit = true;
+			if(!$myExceptionFormat){
+				$paramCount++;
+				$sql .= "gui_wms_exceptionformat = $" . $paramCount ." ";
+				array_push($v, $this->gui_wms_exceptionformat);
+				$mySubmit = true;
+			# gui_wms_epsg
+			for($j=0; $j<count($this->objLayer[0]->layer_epsg);$j++){
+				if($this->objLayer[0]->layer_epsg[$j][epsg] == mb_strtoupper($row["gui_wms_epsg"])){
+					$myGUI_EPSG = true;
+			if(!$myGUI_EPSG){
+				$paramCount++;
+				$sql .= "gui_wms_epsg = $" . $paramCount . " ";
+				array_push($v, $this->gui_wms_epsg);
+				$mySubmit = true;
+			$paramCount++;
+			$sql .= " WHERE fkey_gui_id = $" . $paramCount . " ";
+			array_push($v, $row["fkey_gui_id"]);
+			$paramCount++;
+			$sql .= "AND fkey_wms_id = $" . $paramCount;
+			array_push($v, $myWMS);
+			array_push($t, "i");
+			if($mySubmit){
+				if(!$res){
+					db_rollback();
+					echo "<pre>".$sql."</pre><br> <br><p>";
+				 	echo db_error();
+				 	echo "<br /> UPDATE ERROR -> KILL PROCESS AND ROLLBACK....................no update<br><br>";
+					$e = new mb_exception("class_wms.php: transaction: Transaction aborted, rollback.");
+			$cnt++;
+	function getVersion() {
+		return $this->wms_version;
+	function getCapabilities() {
+		return $this->wms_getcapabilities;
+	function getCapabilitiesDoc() {
+		return $this->wms_getcapabilities_doc;
+	* creatObjfromDB
+	  function createObjFromDB($gui_id,$wms_id){
+		$sql = "Select * from gui_wms where fkey_wms_id = $1 AND fkey_gui_id = $2";
+		$v = array($wms_id,$gui_id);
+		$count=0;
+		#$res_count=db_num_rows($res);
+			$this->gui_wms_mapformat=$row["gui_wms_mapformat"];
+			$this->gui_wms_featureinfoformat=$row["gui_wms_featureinfoformat"];
+			$this->gui_wms_exceptionformat=$row["gui_wms_exceptionformat"];
+			$this->gui_wms_epsg=$row["gui_wms_epsg"];
+			$this->gui_wms_visible = $row["gui_wms_visible"];
+			$this->gui_wms_opacity = $row["gui_wms_opacity"];
+			$this->gui_wms_sldurl = $row["gui_wms_sldurl"];
+			$sql = "Select * from wms where wms_id = $1 ";
+			$v = array($wms_id);
+			$t = array('i');
+			$res_wms = db_prep_query($sql,$v,$t);
+			$count_wms=0;
+			while($row2 = db_fetch_array($res_wms)){
+				$this->wms_id = $row2["wms_id"];
+				$this->wms_version = $row2["wms_version"];
+				$this->wms_title = administration::convertIncomingString($this->stripEndlineAndCarriageReturn($row2["wms_title"]));
+				$this->wms_abstract = administration::convertIncomingString($this->stripEndlineAndCarriageReturn($row2["wms_abstract"]));
+				$wmsowsproxy = $row2["wms_owsproxy"];
+				#$wmsowsproxy = "test";
+				if($wmsowsproxy != ""){
+					$owsproxyurl = OWSPROXY."/".session_id()."/".$wmsowsproxy."?";
+					$this->wms_getmap = $owsproxyurl;
+					$this->wms_getcapabilities =  $owsproxyurl;
+					$this->wms_getfeatureinfo = $owsproxyurl;
+					$this->wms_getlegendurl = $owsproxyurl;
+				else{
+					$this->wms_getmap =  $row2["wms_getmap"];
+					$this->wms_getcapabilities =  $row2["wms_getcapabilities"];
+					$this->wms_getfeatureinfo = $row2["wms_getfeatureinfo"];
+					$this->wms_getlegendurl = $row2["wms_getlegendurl"];
+				// TO DO: Capabilities document needs to
+				// be encoded to the original encoding
+				// if different from the database encoding
+				$this->wms_getcapabilities_doc = $row2["wms_getcapabilities_doc"];
+				$this->wms_filter = $row2["wms_filter"];
+				$this->wms_supportsld = $row2["wms_supportsld"];
+				$this->wms_userlayer = $row2["wms_userlayer"];
+				$this->wms_userstyle = $row2["wms_userstyle"];
+				$this->wms_remotewfs = $row2["wms_remotewfs"];
+				$count_wms++;
+			### srs
+			$srs_sql = "SELECT * FROM wms_srs WHERE fkey_wms_id = $1 ";
+			$srs_v = array($wms_id);
+			$srs_t = array('i');
+			$srs_res = db_prep_query($srs_sql, $srs_v, $srs_t);
+			$this->wms_srs = array();
+			while($srs_row = db_fetch_array($srs_res)) {
+				$this->wms_srs[]= $srs_row["wms_srs"];
+			### formats
+			$sql = "SELECT * FROM wms_format WHERE fkey_wms_id = $1 ";
+			$t = array('i');
+			$count_format=0;
+			while($row3 = db_fetch_array($res_wms)){
+				$this->data_type[$count_format] = $row3["data_type"];
+				$this->data_format[$count_format] = $row3["data_format"];
+				$count_format++;
+			$count++;
+		#layer
+		$sql = "Select * from gui_layer where gui_layer_wms_id = $1 AND fkey_gui_id = $2 ";
+		$sql .= " AND gui_layer_status = 1 ORDER BY gui_layer_priority;";
+		$count=0;
+			$layer_id = $row["fkey_layer_id"];
+			$sql = "Select * from layer where layer_id = $1";
+			$v = array($layer_id);
+			$t = array('i');
+			$res_layer = db_prep_query($sql,$v,$t);
+			$count_layer=0;
+			while($row2 = db_fetch_array($res_layer)){
+				$this->addLayer($row2["layer_pos"],$row2["layer_parent"]);
+				$layer_cnt=count($this->objLayer)-1;
+				$this->objLayer[$layer_cnt]->layer_uid = $layer_id;
+				$this->objLayer[$layer_cnt]->layer_name = administration::convertIncomingString($row2["layer_name"]);
+				$this->objLayer[$layer_cnt]->layer_title = administration::convertIncomingString($row2["layer_title"]);
+				$this->objLayer[$layer_cnt]->layer_dataurl_href =$row2["layer_dataurl"];
+				$this->objLayer[$layer_cnt]->layer_metadataurl =$row2["layer_metadataurl"];
+				$this->objLayer[$layer_cnt]->layer_pos =$row2["layer_pos"];
+				$this->objLayer[$layer_cnt]->layer_queryable =$row2["layer_pos"];
+				$this->objLayer[$layer_cnt]->layer_queryable =$row2["layer_queryable"];
+				$this->objLayer[$layer_cnt]->layer_minscale =$row2["layer_minscale"];
+				$this->objLayer[$layer_cnt]->layer_maxscale = $row2["layer_maxscale"];
+				$count_layer++;
+			$this->objLayer[$layer_cnt]->gui_layer_wms_id = $row["gui_layer_wms_id"];
+			$this->objLayer[$layer_cnt]->gui_layer_selectable = $row["gui_layer_selectable"];
+			$this->objLayer[$layer_cnt]->gui_layer_visible = $row["gui_layer_visible"];
+			$this->objLayer[$layer_cnt]->gui_layer_queryable = $row["gui_layer_queryable"];
+			$this->objLayer[$layer_cnt]->gui_layer_querylayer = $row["gui_layer_querylayer"];
+			$this->objLayer[$layer_cnt]->gui_layer_minscale = $row["gui_layer_minscale"];
+			$this->objLayer[$layer_cnt]->gui_layer_maxscale = $row["gui_layer_maxscale"];
+			$this->objLayer[$layer_cnt]->gui_layer_style = $row["gui_layer_style"];
+			$this->objLayer[$layer_cnt]->gui_layer_wfs_featuretype = $row["gui_layer_wfs_featuretype"];
+			$sql = "Select * from layer_epsg where fkey_layer_id = $1 ORDER BY fkey_layer_id";
+			$t = array('i');
+			$res_layer_epsg = db_prep_query($sql,$v,$t);
+			$count_layer_epsg=0;
+			while($row2 = db_fetch_array($res_layer_epsg)){
+				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["epsg"]=$row2["epsg"];
+				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["minx"]=$row2["minx"];
+				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["miny"]=$row2["miny"];
+				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["maxx"]=$row2["maxx"];
+				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["maxy"]=$row2["maxy"];
+				$count_layer_epsg++;
+			### handle styles
+			$sql = "SELECT * FROM layer_style WHERE fkey_layer_id = $1 ";
+			$t = array('i');
+			$res_style = db_prep_query($sql,$v,$t);
+			$count_layer_style = 0;
+			while($row2 = db_fetch_array($res_style)){
+				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["name"] = $row2["name"] ? $row2["name"] : "default";
+				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["title"]=$row2["title"];
+					if($row2["legendurl"]!=''){
+						$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]=$owsproxyurl.
+						"REQUEST=getlegendgraphic&VERSION=".$this->wms_version."&LAYER=".$this->objLayer[$layer_cnt]->layer_name."&FORMAT=".$row2["legendurlformat"].
+						"&STYLE=".$row2["name"];
+				else{
+						$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]=$row2["legendurl"];
+						#$e = new mb_exception("legendurl = ".$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]);
+				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurlformat"]=$row2["legendurlformat"];
+				$count_layer_style++;
+			$count++;
+	/** end createObjfromDB **/
+	* creatObjfromDBNoGui
+	  function createObjFromDBNoGui($wms_id){
+		$t = array('i');
+		$count_wms=0;
+			$this->wms_title = $this->stripEndlineAndCarriageReturn($row2["wms_title"]);
+			$this->wms_abstract = $this->stripEndlineAndCarriageReturn($row2["wms_abstract"]);
+			else{
+			#some default
+                    $this->gui_wms_mapformat = "PNG";
+                    $this->gui_wms_featureinfoformat = "MIME";
+                    $this->gui_wms_exceptionformat = "INIMAGE";
+            else{
+                    $this->gui_wms_mapformat = "image/png";
+                    $this->gui_wms_featureinfoformat = "text/html";
+                    $this->gui_wms_exceptionformat = "application/vnd.ogc.se_inimage";
+			$count_wms++;
+		### formats
+		$t = array('i');
+		$count_format=0;
+			$count_format++;
+		$sql = "Select * from layer where fkey_wms_id = $1";
+		$t = array('i');
+		$count_layer=0;
+			$this->objLayer[$layer_cnt]->layer_uid = $row2["layer_id"];
+			$this->objLayer[$layer_cnt]->layer_name =$row2["layer_name"];
+			$this->objLayer[$layer_cnt]->layer_title =$row2["layer_title"];
+			if($this->objLayer[$layer_cnt]->layer_minscale == ""){
+				$this->objLayer[$layer_cnt]->layer_minscale = 0;
+			if($this->objLayer[$layer_cnt]->layer_maxscale == ""){
+				$this->objLayer[$layer_cnt]->layer_maxscale = 0;
+			$this->objLayer[$layer_cnt]->gui_layer_minscale = $this->objLayer[$layer_cnt]->layer_minscale;
+			$this->objLayer[$layer_cnt]->gui_layer_maxscale = $this->objLayer[$layer_cnt]->layer_maxscale;
+			$v = array($this->objLayer[$layer_cnt]->layer_uid);
+			$t = array('i');
+			### handle styles
+			$t = array('i');
+				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["name"]=$row2["name"];
+				else{
+			$count_layer++;
+	/** end createObjfromDBNoGui **/
+	* function checkObjExistsInDB()
+	* this function checks wether the onlineresource already exists in the database.
+	function checkObjExistsInDB(){
+		$sql = "Select * from wms where wms_getcapabilities = $1";
+		$v = array($this->wms_getcapabilities);
+		$t = array('s');
+		$res_count= db_num_rows($res);
+		$wms_id=0;
+		if($res_count>0){
+			$count=0;
+				$wms_id=$row["wms_id"];
+				$count++;
+		return $wms_id;
+	function displayDBInformation(){
+		echo $this->wms_getcapabilities;
+		$sql="Select * from wms where wms_getcapabilities = $1";
+		$t = array('s');
+		$count=0;
+		echo "count: ".$count."<br>";
+			echo "version: " .$wms_id." <br>";
+			echo "title: " .$row["wms_version"]. " <br>";
+			echo "abstract: " . $row["wms_title"] . " <br>";
+			echo "maprequest: " .$row["wms_abstract"] . " <br>";
+			echo "capabilitiesrequest: " . $row["wms_getcapabilities"] . " <br>";
+			echo "featureinforequest: " . $row["wms_getmap"]. " <br>";
+			echo "gui_wms_mapformat: " . $row["wms_getfeatureinfo"] . " <br>---------<br>";
+			$count++;
+	   echo "----<br> wms_id: ".$wms_id."<br>";
+	   $sql = "Select * from gui_wms where fkey_wms_id = $1";
+	   $t = array('i');
+	   echo "sql: ".$sql." <br>---------<br>";
+	   echo "result count: ".$res_count." <br>---------<br>";
+	   $count=0;
+	    	echo "gui_wms_featureinfoformat: " . $row["gui_wms_featureinfoformat"]." <br>";
+	    	echo "gui_wms_exceptionformat: " .  $row["gui_wms_exceptionformat"]. " <br>";
+	    	echo "gui_wms_epsg: " .  $row["gui_wms_epsg"]. " <br>";
+	      $count++;
+	   #db_close($connect);
+	function checkObj(){
+		if($this->wms_getcapabilities == '' || $this->wms_getmap == '' ){
+			echo "<br>Missing parameters: <br>";
+			$this->displayWMS();
+			print_r($this);
+			echo "<br> Data not committed<br>";
+			die();
+	public static function getWmsIdByLayerId ($id) {
+		$sql = "SELECT DISTINCT fkey_wms_id FROM layer WHERE layer_id = $1";
+		$res = db_prep_query($sql, array($id), array("i"));
+		$row = db_fetch_assoc($res);
+		if ($row) {
+			return $row["fkey_wms_id"];
+		return null;
+	 * Selects all WMS of the current user from the database.
+	 * Then it creates the corresponding WMS object and returns
+	 * these objects as an array.
+	 * @return wms[]
+	 * @param $appId String
+	public static function selectMyWmsByApplication ($appId) {
+		// check if user is permitted to access the application
+		$currentUser = new User(Mapbender::session()->get("mb_user_id"));
+		$appArray = $currentUser->getApplicationsByPermission(false);
+		if (!in_array($appId, $appArray)) {
+			$e = new mb_warning("class_wms.php: selectMyWmsByApplication(): User '" . $currentUser . "' is not allowed to acces application '" . $appId . "'.");
+			return array();
+		// get WMS of this application
+		$sql = "SELECT fkey_wms_id FROM gui_wms WHERE " .
+				"fkey_gui_id = $1 ORDER BY gui_wms_position";
+		$v = array($appId);
+		$t = array('s');
+		// instantiate PHP objects and store in array
+		$wmsArray = array();
+			$currentWms = new wms();
+			$currentWms->createObjFromDB($appId, $row["fkey_wms_id"]);
+			array_push($wmsArray, $currentWms);
+		return $wmsArray;
+class layer extends wms {
+	var $layer_id;
+	var $layer_parent;
+	var $layer_name;
+	var $layer_title;
+	var $layer_abstract;
+	var $layer_pos;
+	var $layer_queryable;
+	var $layer_minscale;
+	var $layer_maxscale;
+    var $layer_dataurl_href;
+    var $layer_metadataurl;
+    var $layer_keyword = array();
+	var $layer_epsg = array();
+	var $layer_style = array();
+	var $gui_layer_wms_id;
+	var $gui_layer_status = 1;
+	var $gui_layer_selectable = 1;
+	var $gui_layer_visible = 0;
+	var $gui_layer_queryable = 0;
+	var $gui_layer_querylayer = 0;
+	var $gui_layer_style = NULL;
+	function layer($id,$parent){
+		$this->layer_id = $id;
+		$this->layer_parent = $parent;
+		//var_dump($this);
+	public static function getLayerMetadataUrl ($layerId) {
+			"/(.*)frames\/login.php/",
+			"$1php/mod_layerMetadata.php?id=",
+			LOGIN
+		) . $layerId;
+	public function __toString () {
+		$e = new mb_exception("TITLE: " . $this->layer_title);
+		return $this->layer_title;
Added: branches/3_dev/core/lib/class_bbox.php
--- branches/3_dev/core/lib/class_bbox.php	                        (rev 0)
+++ branches/3_dev/core/lib/class_bbox.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,171 @@
+<?php
+# $Id: class_bbox.php 3402 2009-01-05 10:30:08Z christoph $
+# http://www.mapbender.org/index.php/
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/class_point.php");
+ * A bounding box consisting of an lower left and an upper right point, and an EPSG.
+class Mapbender_bbox {
+	var $min;
+	var $max;
+	var $epsg;
+	 * @constructor
+	function __construct() {
+		if (func_num_args() == 5) {
+			$param0 = func_get_arg(0);
+			$param1 = func_get_arg(1);
+			$param2 = func_get_arg(2);
+			$param3 = func_get_arg(3);
+			$param4 = func_get_arg(4);
+		else if (func_num_args() == 3) {
+		else {
+			return;
+		// params are point, point, epsg
+		if (is_a($param0, "Mapbender_point") && is_a($param1, "Mapbender_point") && !$param3 && !$param4) {
+			$e = new mb_notice("Mapbender_bbox: constructor: point1, point2, epsg");
+			$min = $param0; // is a Mapbender_point
+			$max = $param1; // is a Mapbender_point
+			$epsg = $param2; // is an EPSG code like "EPSG:4326"
+			if ($min->isWestOf($max) && $min->isSouthOf($max)) {
+				if ($min->epsg == $max->epsg && $min->epsg == $epsg) {
+					$this->min = $min;
+					$this->max = $max;
+					$this->epsg = $epsg;
+				else {
+					$e = new mb_exception("Mapbender_bbox: constructor: EPSG mismatch!");
+			else {
+				$e = new mb_exception("Mapbender_bbox: constructor: min (".$this->min.") is not southwest of max (".$this->max.")!");
+		// params are x1, y1, x2, xy, epsg
+		else {
+			$e = new mb_notice("Mapbender_bbox: constructor: x1, y1, x2, y2, epsg");
+			$min = new Mapbender_point($param0, $param1, $param4);
+			$max = new Mapbender_point($param2, $param3, $param4);
+			$epsg = $param4; // is an EPSG code like "EPSG:4326"
+				else {
+			else {
+	 * Computes a new bounding box, bbox1 UNION bbox2
+	static function union ($bboxArray) {
+		if (count($bboxArray) == 1) {
+			return array_pop($bboxArray);
+		elseif (count($bboxArray) >= 2) {
+			$bbox1 = array_pop($bboxArray);
+			$bbox2 = Mapbender_bbox::union($bboxArray);
+			if (!($bbox1 != null && $bbox1->isValid()) && !($bbox2 != null && $bbox2->isValid())) {
+				$e = new mb_exception("Mapbender_bbox: union: both parameters invalid!");
+				return null;
+			elseif (!($bbox1 != null && $bbox1->isValid()) && ($bbox2 != null && $bbox2->isValid())) {
+				$e = new mb_exception("Mapbender_bbox: union: first parameter invalid!");
+				return $bbox2;
+			elseif (($bbox1 != null && $bbox1->isValid()) && !($bbox2 != null && $bbox2->isValid())) {
+				$e = new mb_exception("Mapbender_bbox: union: second parameter invalid!");
+				return $bbox1;
+			else {
+				if ($bbox1->epsg == $bbox2->epsg) {
+					$e = new mb_notice("Mapbender_bbox: union: bbox1 is: " . $bbox1);
+					$e = new mb_notice("Mapbender_bbox: union: bbox2 is: " . $bbox2);
+					$e = new mb_notice("Mapbender_bbox: union: merging bbox1 and bbox2...");
+					return new Mapbender_bbox(Mapbender_point::min($bbox1->min, $bbox2->min), Mapbender_point::max($bbox1->max, $bbox2->max), $bbox1->epsg);
+				else {
+					$e = new mb_exception("Mapbender_bbox: cannot process union with different EPSG codes");
+		else {
+			$e = new mb_exception("Mapbender_bbox: Invalid parameter (Not an array)!");
+		return null;
+	 * transforms this bbox in another EPSG
+	 * @param toEpsg transform the bbox to this EPSG code, example: "EPSG:4326"
+	function transform($toEpsg) {
+		if ($this->isValid()) {
+			$this->epsg = $toEpsg;
+			$this->min->transform($toEpsg);
+			$this->max->transform($toEpsg);
+			return true;
+		return false;
+	 * checks if lower left and upper right coordinate are set, as well as EPSG
+	function isValid() {
+		if ($this->min != null && $this->max != null && $this->epsg != null) {
+			return true;
+		$e = new mb_exception("Mapbender_bbox: this is not a valid bbox!");
+		return false;
+	function toHtml () {
+		return (string) $this->min->toHtml() . " | " . $this->max->toHtml();
+	function __toString() {
+		return (string) "[" . $this->min . $this->max . " " . $this->epsg . "]";
Added: branches/3_dev/core/lib/class_georss.php
--- branches/3_dev/core/lib/class_georss.php	                        (rev 0)
+++ branches/3_dev/core/lib/class_georss.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,26 @@
+<?php
+# License:
+# Copyright (c) 2009, Open Source Geospatial Foundation
+# This program is dual licensed under the GNU General Public License
+# and Simplified BSD license.
+# http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+require_once(dirname(__FILE__)."/class_rss.php");
+require_once(dirname(__FILE__)."/class_georss_item.php");
+ * Creates an RSS Feed.
+class GeoRss extends Rss {
+	protected function createItem () {
+		return new GeoRssItem();
+	protected function getNamespaceString () {
+		return parent::getNamespaceString() .
+			' xmlns:georss="http://www.georss.org/georss"';
Added: branches/3_dev/core/lib/class_georss_factory.php
--- branches/3_dev/core/lib/class_georss_factory.php	                        (rev 0)
+++ branches/3_dev/core/lib/class_georss_factory.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,51 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+require_once dirname(__FILE__) . "/class_rss_factory.php";
+require_once dirname(__FILE__) . "/class_georss.php";
+class GeoRssFactory extends RssFactory {
+	protected function createRss () {
+		$rss = new GeoRss();
+		return $rss;
+	protected function createRssItem () {
+		$rssItem = new GeoRssItem();
+		return $rssItem;
+	protected function parseItem ($node, $item) {
+		$item = parent::parseItem($node, $item);
+		foreach ($node->childNodes as $childNode) {
+			switch ($childNode->tagName) {
+				case "georss:box":
+					$coordinateString = trim($childNode->nodeValue);
+					$coordinateArray = explode(" ", $coordinateString);
+					if (count($coordinateArray) === 4) {
+						$bbox = new Mapbender_bbox(
+							floatval($coordinateArray[0]),
+							floatval($coordinateArray[1]),
+							floatval($coordinateArray[2]),
+							floatval($coordinateArray[3]),
+							"EPSG:4326"
+						$item->setBbox($bbox);
+					break;
+		return $item;
Added: branches/3_dev/core/lib/class_georss_geometry.php
--- branches/3_dev/core/lib/class_georss_geometry.php	                        (rev 0)
+++ branches/3_dev/core/lib/class_georss_geometry.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,337 @@
+<?php
+# http://www.mapbender.org/index.php/class_gml2.php
+#TODO:Check if the following line is enough:
+#require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_Json.php");
+require_once(dirname(__FILE__)."/class_gml2.php");
+class geoRSS {
+	var $doc;
+	var $importItems = array("title","link","description");
+	var $targetEPSG;
+	function parseFile($req){
+		#$data = implode("",file($req));
+		$x = new connector($req);
+		$data = $x->file;
+		$data = $this->removeWhiteSpace($data);
+		if($data=="")
+			return false;
+		return $this->parseXML($data);
+		#$e = new mb_exception("data = ".$data);
+	 * Set the Rss Elements that should go to the property tags of geoJSON
+	 * default is "title","link" and "description"
+	public function setImportTags($tags){
+		$this->importItems = $tags;
+	function parseXML($data) {
+		$this->doc = $data;
+		return $this->toGeoJSON();
+	function removeWhiteSpace ($string) {
+		return preg_replace("/\>(\s)+\</", "><", trim($string));
+	function toGeoJSON () {
+		$rssDoc = new SimpleXMLElement($this->doc);
+		$rssDoc->registerXPathNamespace('xls', 'http://www.opengis.net/xls');
+		$rssDoc->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
+		$rssDoc->registerXPathNamespace('georss', 'http://www.georss.org/georss');
+		#for ingrid - portalu georss
+		$rssDoc->registerXPathNamespace('ingrid', 'http://www.portalu.de/opensearch/extension/1.0');
+		// build feature collection
+		$featureCollection = new FeatureCollection();
+		// elements of rss document
+		$rssItems = $rssDoc->xpath("//item");
+		if(count($rssItems)>0){
+			foreach($rssItems as $item){
+				$rssItem_dom = dom_import_simplexml($item);
+				$feature = new geoRSSItem();
+				$feature->targetEPSG = $this->targetEPSG;
+				$feature->parse($rssItem_dom, $this->importItems);
+				if (isset($feature->geometry) && $feature->geometry!==false) {
+					$featureCollection->addFeature($feature);
+			return $featureCollection->toGeoJSON();
+		else{
+			return "{'errorMessage':'Kein Ergebnis'}";
+class geoRSSItem extends Feature{
+	var $targetEPSG;
+	#$this->targetEPSG='4326';
+	public function parse($domNode, $importItems) {
+		$currentSibling = $domNode->firstChild;
+		while ($currentSibling) {
+			$tag = $currentSibling->nodeName;
+			if(in_array($tag, $importItems)){
+				$this->properties[$tag] = $currentSibling->nodeValue;
+			else{
+				switch ($tag) {
+				case "georss:where":
+					$this->parseGML($currentSibling);
+					break;
+				case "georss:point":
+					$this->geometry = new geoRSSPoint();
+					$this->geometry->targetEPSG = $this->targetEPSG;
+					$this->geometry->parsePoint($currentSibling);
+					break;
+				case "georss:line":
+					$this->geometry = new geoRSSLine();
+					$this->geometry->parseLine($currentSibling);
+					break;
+					$this->geometry = new geoRSSBox();
+					$this->geometry->parseBox($currentSibling);
+					break;
+				case "georss:polygon":
+					$this->geometry = new geoRSSPolygon();
+					$this->geometry->parsePolygon($currentSibling);
+					break;
+				case "geo:point":
+					$this->geometry = new geoPoint();
+					break;
+				case "geo:lat":
+					if(!$this->geometry)
+					$this->geometry->parseLat($currentSibling);
+					break;
+				case "geo:long":
+					$this->geometry->parseLong($currentSibling);
+					break;
+				default:
+					break;
+			$currentSibling = $currentSibling->nextSibling;
+	function parseGML($domNode){
+			$geomType = $currentSibling->nodeName;
+			switch ($geomType) {
+				case "gml:Polygon" :
+					$this->geometry = new GMLPolygon();
+					break;
+				case "gml:LineString" :
+					$this->geometry = new GMLLine();
+					break;
+				case "gml:Point" :
+					$this->geometry = new GMLPoint();
+					break;
+				case "gml:MultiLineString" :
+					$this->geometry = new GMLMultiLine();
+					$this->geometry->parseMultiLine($currentSibling);
+					break;
+				case "gml:MultiPolygon" :
+					$this->geometry = new GMLMultiPolygon();
+					$this->geometry->parseMultiPolygon($currentSibling);
+					break;
+				case "gml:Envelope" :
+					$this->geometry = new GMLEnvelope();
+					$this->geometry->parseEnvelope($currentSibling);
+				default:
+					break;
+class geoRSSPoint extends GMLPoint{
+	var $targetEPSG;
+	public function parsePoint($domNode){
+		list($y, $x) = explode(" ", $domNode->nodeValue);
+		if ($this->targetEPSG != '4326') {
+			$tCoords = transform($x, $y,'4326', $this->targetEPSG);
+			$x = $tCoords["x"];
+			$y = $tCoords["y"];
+			$this->setPoint($x, $y);
+		else {
+class geoPoint extends GMLPoint{
+	var $targetEPSG;
+			switch ($currentSibling->nodeName){
+			case "geo:lat":
+				$this->parseLat($currentSibling);
+				break;
+			case "geo:lon":
+				$this->parseLon($currentSibling);
+				break;
+	public function parseLat($node){
+		if(!$this->point)
+			$this->point=array();
+			$tCoords = transform(0, $node->nodeValue,'4326', $this->targetEPSG);
+			$this->point["y"] = $tCoords["y"];
+		else {
+			$this->point["y"] = $node->nodeValue;
+	public function parseLong($node){
+		if(!$this->point)
+			$tCoords = transform($node->nodeValue, 0, '4326', $this->targetEPSG);
+			$this->point["x"] = $tCoords["x"];
+		else {
+			$this->point["x"] = $node->nodeValue;
+class geoRSSLine extends GMLLine{
+	var $targetEPSG;
+	public function parseLine ($domNode) {
+		$cnt = 0;
+		$y = 0;
+		foreach(explode(' ',$domNode->nodeValue) as $cord){
+			if($cnt % 2)
+				$this->addPoint($cord, $y);
+			$y = $cord;
+			$cnt++;
+class geoRSSPolygon extends GMLPolygon{
+	var $targetEPSG;
+	public function parsePolygon ($domNode) {
+		$cnt = 0;
+		$y = 0;
+			if($cnt % 2)
+			$y = $cord;
+			$cnt++;
+class geoRSSBox extends GMLPolygon{
+	var $targetEPSG;
+	public function parseBox ($domNode) {
+		list($x1,$y1,$x2,$y2) = explode(' ',$domNode->nodeValue);
+			$tCoords = transform($x1, $y1,'4326', $this->targetEPSG);
+			$x1 = $tCoords["x"];
+			$y1 = $tCoords["y"];
+			$tCoords = transform($x2, $y2,'4326', $this->targetEPSG);
+			$x2 = $tCoords["x"];
+			$y2 = $tCoords["y"];
+		$this->addPoint($x1, $y1);
+		$this->addPoint($x1, $y2);
+		$this->addPoint($x2, $y2);
+		$this->addPoint($x2, $y1);
+function transform ($x, $y, $oldEPSG, $newEPSG) {
+    if (is_null($x) || !is_numeric($x) ||
+        is_null($y) || !is_numeric($y) ||
+        is_null($oldEPSG) || !is_numeric($oldEPSG) ||
+        is_null($newEPSG) || !is_numeric($newEPSG)) {
+        return null;
+    if(SYS_DBTYPE=='pgsql'){
+        $con = db_connect(DBSERVER, OWNER, PW);
+        $sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$x."
+".$y.")',".$oldEPSG."),".$newEPSG.")) as minx";
+        $resMinx = db_query($sqlMinx);
+        $minx = floatval(db_result($resMinx,0,"minx"));
+        $sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$x."
+".$y.")',".$oldEPSG."),".$newEPSG.")) as miny";
+        $resMiny = db_query($sqlMiny);
+        $miny = floatval(db_result($resMiny,0,"miny"));
+    }else{
+        $con_string = "host=" . GEOS_DBSERVER . " port=" . GEOS_PORT .
+            " dbname=" . GEOS_DB . "user=" . GEOS_OWNER .
+            "password=" . GEOS_PW;
+        $con = pg_connect($con_string) or die ("Error while connecting
+database");
+        $resMinx = pg_query($con,$sqlMinx);
+        $minx = floatval(pg_fetch_result($resMinx,0,"minx"));
+        $resMiny = pg_query($con,$sqlMiny);
+        $miny = floatval(pg_fetch_result($resMiny,0,"miny"));
+    return array("x" => $minx, "y" => $miny);
Added: branches/3_dev/core/lib/class_georss_item.php
--- branches/3_dev/core/lib/class_georss_item.php	                        (rev 0)
+++ branches/3_dev/core/lib/class_georss_item.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,42 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/class_bbox.php";
+class GeoRssItem extends RssItem {
+	private $bbox;
+	public function setBbox ($bbox) {
+		if (is_a($bbox, "Mapbender_bbox")) {
+			$this->bbox = $bbox;
+			return true;
+		new mb_exception(__FILE__ .
+			": setBbox(): parameter not a Mapbender_bbox!");
+		return false;
+	public function getBbox () {
+		return $this->bbox;
+	protected function getItemString () {
+		$str = parent::getItemString();
+		if (is_a($this->bbox, "Mapbender_bbox")) {
+			$str .= "<georss:box>" .
+					$this->bbox->min->x . " " .
+					$this->bbox->min->y . " " .
+					$this->bbox->max->x . " " .
+					$this->bbox->max->y .
+	            "</georss:box>\n";
+		return $str;
Added: branches/3_dev/core/lib/class_gml2.php
--- branches/3_dev/core/lib/class_gml2.php	                        (rev 0)
+++ branches/3_dev/core/lib/class_gml2.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,994 @@
+<?php
+# $Id: class_gml2.php 3099 2008-10-02 15:29:23Z nimix $
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+class gml2 {
+	var $geomtype_point = 'Point';
+	var $geomtype_polygon = 'Polygon';
+	var $geomtype_line = 'LineString';
+	var $geomtype_multipolygon = 'MultiPolygon';
+	var $geomtype_multiline = 'MultiLine';
+	var $geometries = array();
+	var $member = -1;
+	var $geomtype = array();
+	var $keys = array();
+	var $values = array();
+	var $geometry = array();
+	var $bbox = array();
+	var $doc;
+	var $geomFeaturetypeElement = null;
+	function gml2(){
+		$this->geometries = array($this->geomtype_point, $this->geomtype_polygon, $this->geomtype_line, $this->geomtype_multipolygon, $this->geomtype_multiline);
+	function getGml($req){
+		return $x->file;
+		$data = $x->file;
+		$this->parseXML($data);
+		if (func_num_args() == 2) {
+			$this->geomFeaturetypeElement = func_get_arg(1);
+		$this->doc = $this->removeWhiteSpace($data);
+	function sepNameSpace($s){
+		$c = mb_strpos($s,":");
+		if($c>0){
+			return mb_substr($s,$c+1);
+		else{
+			return $s;
+		$gmlDoc = new SimpleXMLElement($this->doc);
+		$gmlDoc->registerXPathNamespace('xls', 'http://www.opengis.net/xls');
+		$gmlDoc->registerXPathNamespace('wfs', 'http://www.opengis.net/wfs');
+		$gmlDoc->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
+		// segments of the featzreCollection
+		$gmlFeatureMembers = $gmlDoc->xpath("//gml:featureMember");
+		if(count($gmlFeatureMembers)>0){
+			$cnt=0;
+			foreach ($gmlFeatureMembers as $gmlFeatureMember) {
+				$featureMember_dom = dom_import_simplexml($gmlFeatureMember);
+				$feature = new Feature();
+				if ($this->geomFeaturetypeElement != null) {
+					$feature->parse($featureMember_dom, $this->geomFeaturetypeElement);
+				else {
+					$feature->parse($featureMember_dom);
+				if (isset($feature->geometry)) {
+				$cnt++;
+		else{
+			return "{}";
+	 * Exports the file to SHP.
+	 * @param string $filenamePrefix the filename without an ending like .shp
+	function toShape ($filenamePrefix) {
+		$unique = TMPDIR . "/" . $filenamePrefix;
+		$fShape = $unique.".shp";
+		$fGml = $unique.".gml";
+//		$pathOgr = '/appserver/postgresql/templates/postgresql824/bin/ogr2ogr';
+		$pathOgr = '/usr/bin/ogr2ogr';
+//		$pathOgr = OGR2OGR_PATH;
+		$w = $this->toFile($fGml);
+		// - get EPSC-Code from GML-File--
+		$data = file_get_contents($fGml);//
+		$gmlDoc = new SimpleXMLElement($data);
+		$gmlBboxes = $gmlDoc->xpath("//gml:Box");	//<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
+		if(count($gmlBboxes)>0){
+			$bbox_str = $gmlBboxes[0]['srsName'];
+			$pos_raute = strpos($bbox_str, '#');
+			$epsg = substr($bbox_str, $pos_raute+1);
+		} else {
+			$e = new mb_exception("class_gml2.php:toShape() => no EPSG in GML(" . $fGml . ").");
+		$str_ogr = $pathOgr.' -a_srs EPSG:'.$epsg.' -f "ESRI Shapefile" "'.$fShape.'" '.$fGml;
+		$e = new mb_exception("ogr-Befehl:".$str_ogr);
+ 		$exec = $pathOgr.' -a_srs EPSG:'.$epsg.' -f "ESRI Shapefile" "'.$fShape.'" '.$fGml;
+ 		//$exec = $pathOgr.' -f "ESRI Shapefile" "'.$fShape.'" '.$fGml;
+ 		exec($exec);
+ 		$exec = 'zip -j '.$unique.' '.$unique.'.shp '.$unique.'.dbf '.$unique.'.shx '.$unique.'.gfs '.$unique.'.gml '.$unique.'.prj ';
+ 		exec($exec);
+		$exec = 'rm -f '.$unique.' '.$unique.'.shp '.$unique.'.dbf '.$unique.'.shx '.$unique.'.gfs '.$unique.'.gml '.$unique.'.prj ';
+		exec($exec);
+		$exec = 'chmod 777 '.$unique.'.*';
+		exec($exec);
+		//echo "<a href='../tmp/".$unique.".zip'>Download ".$prefix."<a>";
+	 * Writes a file containing the GML.
+	 * @param string $path the path to the file.
+	 * @return bool true if the file could be saved; else false.
+	function toFile ($file) {
+		$handle = fopen($file, "w");
+		if (!$handle) {
+			$e = new mb_exception("class_gml2.php: Filehandler error (" . $file . ").");
+			return false;
+		if (!fwrite($handle,$this->__toString())) {
+			$e = new mb_exception("class_gml2.php: Could not write file (" . $file . ").");
+			fclose($handle);
+			return false;
+		fclose($handle);
+		return true;
+	function __toString () {
+		return $this->doc;
+	 * @deprecated
+	function parsegml($req){
+		$this->parse_xml($x->file);
+	 * @deprecated
+	function parse_xml($data){
+		$section = false;
+		$geom = false;
+		$boundedBy = false;
+		$coordinates = false;
+		$el = -1;
+		$parser = xml_parser_create(CHARSET);
+		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
+		xml_parse_into_struct($parser,$data,$values,$tags);
+		$code = xml_get_error_code ($parser);
+		if ($code) {
+			$line = xml_get_current_line_number($parser);
+			$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
+		xml_parser_free($parser);
+		foreach ($values as $element) {
+			#$e = new mb_exception($element[tag]);
+			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("boundedBy") && $element[type] == "open"){
+				$boundedBy = true;
+			if ($boundedBy) {
+				if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("coordinates")){
+					$this->bbox = explode(",", str_replace(",,","",str_replace(" ",",",trim($element[value]))));
+					$boundedBy=false;
+			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("featureMember") && $element[type] == "open"){
+				$this->member++;
+				$this->keys[$this->member] = array();
+				$this->value[$this->member] = array();
+				$this->geometry[$this->member] = array();
+				$section = true;
+				$cnt_geom = 0;
+			if($section == true){
+				if( in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "open"){
+					$geom = true;
+					$this->geomtype[$this->member] = $this->sepNameSpace($element[tag]);
+				else if(in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "close"){
+					$cnt_geom++;
+					$geom = false;
+				if($geom == true){
+					if (strtoupper($this->sepNameSpace($element[tag])) == strtoupper("coordinates")) {
+						$this->geometry[$this->member][$cnt_geom] =  str_replace(",,","",str_replace(" ",",",trim($element[value])));
+						$coordinates = true;
+						// XXX: Increment counter to get all geometries of a feature member,
+						// comment it out to only show first geometry of featuremember
+						$cnt_geom++;
+					else if (!$coordinates && trim($element[value])) {
+						$coords = str_replace(",,","",str_replace(" ",",",trim($element[value])));
+						$tmp_array = explode(",", $coords);
+						if (count($tmp_array > 1)) {
+							$this->geometry[$this->member][$cnt_geom] =  $coords;
+							$cnt_geom++;
+				else if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("featureMember") && $element[type] == "close"){
+					$section = false;
+					$el = -1;
+				else{
+					$el++;
+					$this->values[$this->member][$el] = $element[value];
+					$this->keys[$this->member][$el] = $element[tag];
+	 * @deprecated
+	function getMemberCount(){
+		return ($this->member+1);
+	 * @deprecated
+	function getValueBySeparatedKey($memberCount,$keyName){
+		for($i=0; $i<count($this->keys[$memberCount]); $i++){
+			if($this->sepNameSpace($this->keys[$memberCount][$i]) == $keyName){
+				return $this->values[$memberCount][$i];
+	 * @deprecated
+	function getValueByKey($memberCount,$keyName){
+			if($this->keys[$memberCount][$i] == $keyName){
+	 * @deprecated
+	function getXfromMemberAsString($memberCount,$geomCount){
+		$t = explode(",",$this->geometry[$memberCount][$geomCount]);
+		$x = array();
+		for($i=0; $i<(count($t)-1); $i=$i+2){
+			array_push($x,$t[$i]);
+		return implode(",",$x);
+	 * @deprecated
+	function getYfromMemberAsString($memberCount,$geomCount){
+		$y = array();
+		for($i=1; $i<=(count($t)-1); $i=$i+2){
+			array_push($y,$t[$i]);
+		return implode(",",$y);
+	 * @deprecated
+	function getGeometriesFromMember($memberCount){
+		return $this->geometry[$memberCount];
+	 * @deprecated
+	function getGeometryTypeFromMember($memberCount){
+		return 	$this->geomtype[$memberCount];
+	 * @deprecated
+	function exportGeometriesToJS ($isInFrame) {
+		$prefix = "";
+		if ($isInFrame == true) {
+			$prefix = "parent.";
+		$js = "";
+		$js .= "var geom = new ".$prefix."GeometryArray();\n";
+		for ($i=0; $i<count($this->geometry); $i++) {
+			$js .= $this->exportMemberToJS($i, $isInFrame);
+			$js .= "geom.addCopy(q);\n";
+		return $js;
+	 * @deprecated
+	function exportMemberToJS ($i, $isInFrame) {
+		$prefix = "";
+		$js = "";
+		if ($this->getGeometryTypeFromMember($i) == $this->geomtype_point) {
+			$js .= "var current_geomtype = ".$prefix."geomType.point;\n";
+		elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_line || $this->getGeometryTypeFromMember($i) == $this->geomtype_multiline) {
+			$js .= "var current_geomtype = ".$prefix."geomType.line;\n";
+		elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_polygon || $this->getGeometryTypeFromMember($i) == $this->geomtype_multipolygon) {
+			$js .= "var current_geomtype = ".$prefix."geomType.polygon;\n";
+		else {
+			$e = new mb_notice("unknown geometry type: '".$this->getGeometryTypeFromMember($i)."' or no geometry existing");
+			return "";
+		$js .= "var q = new ".$prefix."MultiGeometry(current_geomtype);\n";
+		for ($j=0; $j<count($this->geometry[$i]); $j++) {
+			$js .= "q.addGeometry(current_geomtype);\n";
+			$x_array = explode(",", $this->getXfromMemberAsString($i, $j));
+			$y_array = explode(",", $this->getYfromMemberAsString($i, $j));
+			for ($k=0; $k<count($x_array); $k++) {
+				$js .= "q.get(-1).addPointByCoordinates(parseFloat(".$x_array[$k]."), parseFloat(".$y_array[$k]."));\n";
+				//$js .= "alert(parseFloat(".$x_array[$k]."), parseFloat(".$y_array[$k]."));";
+			$js .= "q.get(-1).close();\n";
+//		$js .= "alert(q);\n";
+		return $js;
+class FeatureCollection {
+	var $type = "FeatureCollection";
+	var $featureArray = array();
+	public function __construct() {
+	public function addFeature ($aFeature) {
+		array_push($this->featureArray, $aFeature);
+	public function toGeoJSON () {
+		$str = "";
+		$len = count($this->featureArray);
+		if ($len > 0) {
+			$str .= "{\"type\": \"FeatureCollection\", \"features\": [";
+			for ($i=0; $i < $len; $i++) {
+				if ($i > 0) {
+					$str .= ",";
+				$str .= $this->featureArray[$i]->toGeoJSON();
+			$str .= "]}";
+		return $str;
+class Feature {
+	var $type = "Feature";
+	var $fid;
+	var $geometry = false;
+	var $properties = array();
+		list($ns,$FeaturePropertyName) = split(":",$s);
+		$nodeName = array('ns' => $ns, 'value' => $FeaturePropertyName);
+		return $nodeName;
+	 * Parses the feature segment of a GML and stores the geometry in the
+	 * $geometry variable of the class.
+	 * Example of a feature segment of a GML.
+	 * 	<gml:featureMember>
+	 * 		<ms:ROUTE fid="ROUTE.228168">
+	 * 			<gml:boundedBy>
+	 * 				<gml:Box srsName="EPSG:31466">
+	 * 					<gml:coordinates>2557381.0,5562371.1 2557653.7,5562526.0</gml:coordinates>
+	 * 				</gml:Box>
+	 * 			</gml:boundedBy>
+	 * 			<ms:geometry>
+	 * 				<gml:LineString>
+	 * 						2557380.97,5562526 2557390.96,
+	 * 						5562523.22 2557404.03,5562518.2 2557422.31,
+	 * 						5562512 2557437.16,5562508.37 2557441.79,
+	 * 						5562507.49 2557454.31,5562505.1 2557464.27,
+	 * 						5562503.97 2557473.24,5562502.97 2557491.67,
+	 * 						5562502.12 2557505.65,5562502.43 2557513.78,
+	 * 						5562501.12 2557520.89,5562498.79 2557528.5,
+	 * 						5562495.07 2557538.9,5562488.91 2557549.5,
+	 * 						5562483.83 2557558.55,5562476.61 2557569.07,
+	 * 						5562469.82 2557576.61,5562462.72 2557582.75,
+	 * 						5562457.92 2557588.57,5562452.56 2557590.38,
+	 * 						5562449.69 2557593.57,5562445.07 2557596.17,
+	 * 						5562441.31 2557601.71,5562433.93 2557612.97,
+	 * 						5562421.03 2557626,5562405.33 2557639.66,
+	 * 						5562389.75 2557653.69,5562371.12
+	 * 					</gml:coordinates>
+	 * 				</gml:LineString>
+	 * 			</ms:geometry>
+	 * 			<code>354</code>
+	 * 			<Verkehr>0</Verkehr>
+	 * 			<rlp>t</rlp>
+	 * 		</ms:ROUTE>
+	 * 	</gml:featureMember>
+	 * @return void
+	 * @param $domNode DOMNodeObject the feature tag of the GML
+	 * 								(<gml:featureMember> in the above example)
+	public function parse($domNode) {
+		$this->fid = $currentSibling->getAttribute("fid");
+		$currentSibling = $currentSibling->firstChild;
+			$name = $currentSibling->nodeName;
+			$value = $currentSibling->nodeValue;
+			$namespace = $this->sepNameSpace($name);
+			$ns = $namespace['ns'];
+			$columnName = $namespace['value'];
+			$isGeomColumn = ($this->geomFeaturetypeElement == null || $columnName == $this->geomFeaturetypeElement);
+			// check if this node is a geometry node.
+			// however, even if it is a property node,
+			// it has a child node, the text node!
+			// So we might need to do something more
+			// sophisticated here...
+			if ($currentSibling->hasChildNodes() && $isGeomColumn){
+				$geomNode = $currentSibling->firstChild;
+					$geomType = $geomNode->nodeName;
+							$this->geometry->parsePolygon($geomNode);
+							break;
+							$this->geometry->parseLine($geomNode);
+							break;
+							$this->geometry->parsePoint($geomNode);
+							break;
+							$this->geometry->parseMultiLine($geomNode);
+							break;
+							$this->geometry->parseMultiPolygon($geomNode);
+							break;
+							$this->geometry->parseEnvelope($geomNode);
+							break;
+						default:
+							$this->properties[$columnName] = $value;
+							break;
+			else {
+		$str = "";
+		$str .= "{\"type\":\"Feature\", \"id\":\"".$this->fid."\", \"geometry\": ";
+		if ($this->geometry) {
+			$str .= $this->geometry->toGeoJSON();
+		else {
+			$str .= "\"\"";
+		$prop = array();
+		$str .= ", \"properties\": ";
+		$cnt = 0;
+		foreach ($this->properties as $key => $value) {
+				$prop[$key] = $value;
+				$cnt ++;
+		$json = new Mapbender_JSON();
+		$str .= $json->encode($prop);
+		$str .= "}";
+		return $str;
+class GMLLine {
+	var $pointArray = array();
+			foreach(explode(' ',$currentSibling->nodeValue) as $cords){
+				list($x,$y,$z) = explode(',',$cords);
+				$this->addPoint($x, $y);
+	protected function addPoint ($x, $y) {
+		array_push($this->pointArray, array("x" => $x, "y" => $y));
+		$numberOfPoints = count($this->pointArray);
+		$str = "";
+		if ($numberOfPoints > 0) {
+			$str .= "{\"type\": \"LineString\", \"coordinates\":[";
+			for ($i=0; $i < $numberOfPoints; $i++) {
+				if ($i > 0) {
+					$str .= ",";
+				$str .= "[".$this->pointArray[$i]["x"].",".$this->pointArray[$i]["y"]."]";
+			$str .= "]}";
+		else {
+			$e = new mb_exception("GMLLine: toGeoJSON: this point is null.");
+		return $str;
+class GMLPoint {
+	var $point;
+	public function parsePoint ($domNode) {
+			list($x, $y, $z) = explode(",", $currentSibling->nodeValue);
+	protected function setPoint ($x, $y) {
+#		echo "x: " . $x . " y: " . $y . "\n";
+		$this->point = array("x" => $x, "y" => $y);
+		$str = "";
+		if ($this->point) {
+			$str .= "{\"type\": \"Point\", \"coordinates\":";
+			$str .= "[".$this->point["x"].",".$this->point["y"]."]";
+			$str .= "}";
+		else {
+			$e = new mb_exception("GMLPoint: toGeoJSON: this point is null.");
+		return $str;
+class GMLPolygon {
+	var $innerRingArray = array();
+		$simpleXMLNode = simplexml_import_dom($domNode);
+		$simpleXMLNode->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
+		$allCoords = $simpleXMLNode->xpath("gml:outerBoundaryIs/gml:LinearRing/gml:coordinates");
+		$cnt=0;
+		foreach ($allCoords as $Coords) {
+			$coordsDom = dom_import_simplexml($Coords);
+//			$name = $coordsDom->nodeName;
+//			$value = $coordsDom->nodeValue;
+//			echo "===> name: ".$name. ", Value: ".$value."<br>";
+			foreach(explode(' ',$coordsDom->nodeValue) as $pointCoords){
+				list($x,$y,$z) = explode(',',$pointCoords);
+			$cnt++;
+		$innerRingNodeArray = $simpleXMLNode->xpath("gml:innerBoundaryIs/gml:LinearRing");
+		if ($innerRingNodeArray) {
+			$ringCount = 0;
+			foreach ($innerRingNodeArray as $ringNode) {
+				$coordinates = $ringNode->xpath("gml:coordinates");
+				foreach ($coordinates as $coordinate) {
+					$coordsDom = dom_import_simplexml($coordinate);
+						$this->addPointToRing($ringCount, $x, $y);
+				$ringCount++;
+	protected function addPointToRing ($i, $x, $y) {
+		if (count($this->innerRingArray) <= $i) {
+			array_push($this->innerRingArray, array());
+		$index = count($this->innerRingArray);
+		$currentIndex = ($i < $index ? $i : $index);
+		array_push($this->innerRingArray[$currentIndex], array("x" => $x, "y" => $y));
+		$str = "";
+			$str .= "{\"type\": \"Polygon\", \"coordinates\":[[";
+				if ($i > 0) {
+					$str .= ",";
+			$str .= "]";
+			for ($i=0; $i < count($this->innerRingArray); $i++) {
+				$str .= ",[";
+				for ($j=0; $j < count($this->innerRingArray[$i]); $j++) {
+					if ($j > 0) {
+						$str .= ",";
+					$str .= "[".$this->innerRingArray[$i][$j]["x"].",".$this->innerRingArray[$i][$j]["y"]."]";
+				$str .= "]";
+			$str .= "]}";
+		else {
+			$e = new mb_exception("GMLPolygon: toGeoJSON: this point is null.");
+		return $str;
+class GMLEnvelope extends GMLPolygon{
+/*      <gml:Envelope>
+         <gml:lowerCorner>42.943 -71.032</gml:lowerCorner>
+         <gml:upperCorner>43.039 -69.856</gml:upperCorner>
+      </gml:Envelope>
+	public function parseEnvelope ($domNode) {
+		$corner1 = $domNode->firstChild;
+		$corner2 = $corner1->nextSibling;
+		list($y1,$x1) = explode(' ',$corner1->nodeValue);
+		list($y2,$x2) = explode(' ',$corner2->nodeValue);
+class GMLMultiLine {
+	var $lineArray = array();
+	public function parseMultiLine ($domNode) {
+		$allCoords = $simpleXMLNode->xpath("gml:lineStringMember/gml:LineString/gml:coordinates");
+		$cnt=0;
+			$this->lineArray[$cnt] = array();
+				$this->addPoint($x, $y, $cnt);
+			$cnt++;
+	protected function addPoint ($x, $y, $i) {
+		array_push($this->lineArray[$i], array("x" => $x, "y" => $y));
+		$numberlineArray = count($this->lineArray);
+		$str = "";
+		if ($numberlineArray > 0) {
+			$str .= "{\"type\": \"MultiLineString\", \"coordinates\":[";
+			for ($cnt =0; $cnt < $numberlineArray; $cnt++){
+				if ($cnt > 0) {
+						$str .= ",";
+					$str .="[";
+				for ($i=0; $i < count($this->lineArray[$cnt]); $i++) {
+					if ($i > 0) {
+						$str .= ",";
+					$str .= "[".$this->lineArray[$cnt][$i]["x"].",".$this->lineArray[$cnt][$i]["y"]."]";
+				$str .="]";
+			$str .= "]}";
+		else {
+			$e = new mb_exception("GMLMultiLine: toGeoJSON: this multiLine is null.");
+		return $str;
+class GMLMultiPolygon {
+	var $polygonArray = array();
+	protected function addPointToRing ($i, $j, $x, $y) {
+		if (count($this->innerRingArray[$i]) <= $j) {
+			array_push($this->innerRingArray[$i], array());
+		array_push($this->innerRingArray[$i][$j], array("x" => $x, "y" => $y));
+	public function parseMultiPolygon ($domNode) {
+//		echo $domNode->nodeName."<br>";
+		$allPolygons = $simpleXMLNode->xpath("gml:polygonMember/gml:Polygon");
+		$cnt=0;
+		foreach ($allPolygons as $polygon) {
+			$allCoords = $polygon->xpath("gml:outerBoundaryIs/gml:LinearRing/gml:coordinates");
+			$this->polygonArray[$cnt] = array();
+				foreach (explode(' ',$coordsDom->nodeValue) as $pointCoords) {
+			$this->innerRingArray[$cnt] = array();
+			$innerRingNodeArray = $polygon->xpath("gml:innerBoundaryIs");
+				$ringCount = 0;
+					$currentRingNode = $ringNode->xpath("gml:LinearRing");
+					foreach ($currentRingNode as $node) {
+						$coordinates = $node->xpath("gml:coordinates");
+								$this->addPointToRing($cnt, $ringCount, $x, $y);
+						$ringCount++;
+			$cnt++;
+			new mb_exception("create multipolygon " . serialize($this->innerRingArray));
+		array_push($this->polygonArray[$i], array("x" => $x, "y" => $y));
+		$numberPolygonArray = count($this->polygonArray);
+		$str = "";
+		if ($numberPolygonArray > 0) {
+			$str .= "{\"type\": \"MultiPolygon\", \"coordinates\":[";
+			for ($cnt =0; $cnt < $numberPolygonArray; $cnt++){
+				if ($cnt > 0) {
+					$str .= ",";
+				$str .= "[";
+				$str .= "[";
+				for ($i=0; $i < count($this->polygonArray[$cnt]); $i++) {
+					if ($i > 0) {
+						$str .= ",";
+					$str .= "[".$this->polygonArray[$cnt][$i]["x"].",".$this->polygonArray[$cnt][$i]["y"]."]";
+				$str .= "]";
+				for ($i=0; $i < count($this->innerRingArray[$cnt]); $i++) {
+					$str .= ",[";
+					for ($j=0; $j < count($this->innerRingArray[$cnt][$i]); $j++) {
+						if ($j > 0) {
+							$str .= ",";
+						$str .= "[".$this->innerRingArray[$cnt][$i][$j]["x"].",".$this->innerRingArray[$cnt][$i][$j]["y"]."]";
+					$str .= "]";
+				$str .= "]";
+			$str .= "]}";
+		else {
+			$e = new mb_exception("GMLMultiPolygon: toGeoJSON: this multiLine is null.");
+		return $str;
Added: branches/3_dev/core/lib/class_point.php
--- branches/3_dev/core/lib/class_point.php	                        (rev 0)
+++ branches/3_dev/core/lib/class_point.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,202 @@
+<?php
+# $Id: class_point.php 3402 2009-01-05 10:30:08Z christoph $
+ * A Mapbender_point is a 2- or 3-dimensional point with an EPSG.
+class Mapbender_point {
+	var $x;
+	var $y;
+	var $z;
+	var $epsg;
+	 * @constructor
+		if (func_num_args() == 4) {
+			$x = func_get_arg(0);
+			$y = func_get_arg(1);
+			$z = func_get_arg(2);
+			$epsg = func_get_arg(3);
+			$z = false;
+			$epsg = func_get_arg(2);
+		else {
+			return;
+		if (!isset($x) || !isset($y) || !isset($epsg)) {
+			$e = new mb_exception("Mapbender_point: constructor: some parameters are not set (set (x: ".$x.", y: ".$y.", z: ".$z.", epsg:".$epsg.")!");
+		$this->x = $x;
+		$this->y = $y;
+		$this->z = $z;
+	 * computes a new point with the minimal coordinates of this point and $point
+	static function min ($point1, $point2) {
+		if ($point1->epsg == $point2->epsg) {
+			if ($point1->isWestOf($point2)) {
+				$minx = $point1->x;
+			else {
+				$minx = $point2->x;
+			if ($point1->isSouthOf($point2)) {
+				$miny = $point1->y;
+			else {
+				$miny = $point2->y;
+			return new Mapbender_point($minx, $miny, $point1->epsg);
+		else {
+			$e = new mb_exception("Mapbender_point: cannot process min with different EPSG codes");
+	 * computes a new point with the maximal coordinates of this point and $point
+	static function max ($point1, $point2) {
+				$maxx = $point2->x;
+			else {
+				$maxx = $point1->x;
+				$maxy = $point2->y;
+			else {
+				$maxy = $point1->y;
+			return new Mapbender_point($maxx, $maxy, $point1->epsg);
+		else {
+	function isWestOf($point) {
+		if ($this->x < $point->x) {
+			return true;
+	function isSouthOf($point) {
+		if ($this->y < $point->y) {
+			return true;
+	 * Addition
+	 * @param anotherPoint another Mapbender_point
+	function plus ($anotherPoint) {
+		return new Mapbender_point($this->x + $anotherPoint->x, $this->y + $anotherPoint->y, $this->epsg);
+	 * Subtraction
+	function minus ($anotherPoint) {
+		return $this->plus($anotherPoint->times(-1));
+	 * Scalar multiplication
+	 * @param aFloat a floating point number
+	function times ($aFloat) {
+		return new Mapbender_point($this->x * $aFloat, $this->y * $aFloat, $this->epsg);
+	 * transforms this point to another EPSG
+	 * @param {Integer} toEpsg the coordinates are transformed to this EPSG code.
+			$currentEpsg = preg_replace("/EPSG:/", "", $this->epsg);
+			$targetEpsg = preg_replace("/EPSG:/", "", $toEpsg);
+			$sql = "SELECT X(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as x, ";
+			$sql .= "Y(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as y, ";
+			if (isset($this->z)) {
+				$sql .= "Z(transform(GeometryFromText('POINT(".$this->x." ".$this->y." ".$this->z.")',".$currentEpsg."),".$targetEpsg.")) as z";
+			$res = db_query($sql);
+				$point = new Mapbender_point(db_result($res,0,"x"), db_result($res,0,"y"), db_result($res,0,"z"), $toEpsg);
+			else {
+				$point = new Mapbender_point(db_result($res,0,"x"), db_result($res,0,"y"), $toEpsg);
+			$this->x = $point->x;
+			$this->y = $point->y;
+			$this->z = $point->z;
+			$this->epsg = $point->epsg;
+		else {
+			$e = new mb_exception("transformCoordinates needs PostgreSQL");
+		$str = "";
+		$xArray = explode(".", strval($this->x));
+		$str .= $xArray[0] . "°";
+		if ($xArray[1]) {
+			$str .= $xArray[1] . "'";
+		$str .= " O / ";
+		$yArray = explode(".", strval($this->y));
+		$str .= $yArray[0] . "°";
+		if ($yArray[1]) {
+			$str .= $yArray[1] . "'";
+		$str .= " N";
+		return $str;
+		return (string) "(" . $this->x . "," . $this->y . "," . $this->z . "," . $this->epsg . ")";
Added: branches/3_dev/core/lib/class_rss.php
--- branches/3_dev/core/lib/class_rss.php	                        (rev 0)
+++ branches/3_dev/core/lib/class_rss.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,181 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/class_Administration.php";
+require_once dirname(__FILE__) . "/class_rss_item.php";
+class Rss {
+    var $filename;
+	var $channel_url;
+    var $channel_title;
+    var $channel_description;
+    var $channel_lang;
+    var $channel_copyright;
+    var $channel_date;
+    var $channel_creator;
+    var $channel_subject;
+    var $image_url;
+    protected $items = array();
+    protected $nritems;
+	const MAX_ENTRIES = 10;
+		return new RssItem();
+	public function append () {
+		if (func_num_args() === 0) {
+			$item = $this->createItem();
+		else {
+			$item = func_get_arg(0);
+		$this->items[]= $item;
+		$this->nritems++;
+		return $item;
+	public function saveAsFile() {
+		if (func_num_args() === 1) {
+			$pathAndFilename = func_get_arg(0);
+		else {
+			if ($this->filename) {
+				$pathAndFilename = $this->filename;
+			else {
+					": saveAsFile(): must specify a filename!");
+				return false;
+		return administration::saveFile($pathAndFilename, $this->__toString());
+        $this->nritems=0;
+        $this->channel_url=LOGIN;
+        $this->channel_title="Mapbender GeoRSS";
+        $this->channel_description="New and updated WMS";
+        $this->channel_lang='';
+        $this->channel_copyright='';
+        $this->channel_date='';
+        $this->channel_creator='';
+        $this->channel_subject='';
+        $this->image_url='';
+	public function setTitle ($title) {
+        $this->channel_title=$title;
+	public function setDescription ($description) {
+        $this->channel_description=$description;
+	public function setUrl ($url) {
+        $this->channel_url=$url;
+    public function setChannel($url, $title, $description, $lang, $copyright, $creator, $subject) {
+        $this->channel_lang=$lang;
+        $this->channel_copyright=$copyright;
+        $this->channel_date=date("Y-m-d").'T'.date("H:i:s").'+01:00';
+        $this->channel_creator=$creator;
+        $this->channel_subject=$subject;
+    public function setImage($url) {
+        $this->image_url=$url;
+    public function setItem($rssItem) {
+    	if (is_a($rssItem, "RssItem")) {
+    		$this->items[]= $rssItem;
+	        $this->nritems++;
+			return true;
+			": setItem(): parameter is not an RSS item!");
+	public function getItem ($index) {
+		if (!is_numeric($index)) {
+			return null;
+		$i = intval($index);
+		if ($i >= 0 && $i < count($this->items)) {
+			return $this->items[$i];
+		return null;
+        $output =  '<?xml version="1.0" encoding="' . CHARSET . '"?>'."\n";
+        $output .= '<rss ' . $this->getNamespaceString() . ' version="2.0">'."\n";
+//        $output .= '<rdf:RDF ' . $this->getNamespaceString() . '>'."\n";
+//        $output .= '<channel rdf:about="'.htmlentities($this->channel_url, ENT_QUOTES, CHARSET)	.'">'."\n";
+        $output .= '<channel>'."\n";
+        $output .= '<title>'.$this->channel_title.'</title>'."\n";
+        $output .= '<link>'.htmlentities(
+				$this->channel_url,
+				ENT_QUOTES,
+				CHARSET
+			).'</link>'."\n";
+        $output .= '<description>'.$this->channel_description.'</description>'."\n";
+#        $output .= '<dc:language>'.$this->channel_lang.'</dc:language>'."\n";
+#        $output .= '<dc:rights>'.$this->channel_copyright.'</dc:rights>'."\n";
+#        $output .= '<dc:date>'.$this->channel_date.'</dc:date>'."\n";
+#        $output .= '<dc:creator>'.$this->channel_creator.'</dc:creator>'."\n";
+#        $output .= '<dc:subject>'.$this->channel_subject.'</dc:subject>'."\n";
+#        $output .= '<items>'."\n";
+#        $output .= '<rdf:Seq>';
+#        for($k=0; $k<$this->nritems; $k++) {
+#            $output .= '<rdf:li rdf:resource="'.
+#				htmlentities(
+#					$this->items[$k]->getUrl(),
+#					ENT_QUOTES,
+#					CHARSET
+#				.'"/>'."\n";
+#        $output .= '</rdf:Seq>'."\n";
+#        $output .= '</items>'."\n";
+#        $output .= '<image rdf:resource="'.$this->image_url.'"/>'."\n";
+        for($k=0; $k<$this->nritems; $k++) {
+            $output .= $this->items[$k];
+        $output .= '</channel>'."\n";
+//        $output .= '</rdf:RDF>'."\n";
+        $output .= '</rss>'."\n";
+        return $output;
+		return "";
+#		return 'xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#" ' .
+#			'xmlns="http://purl.org/rss/1.0/" ' .
+#			'xmlns:slash="http://purl.org/rss/1.0/modules/slash/" ' .
+#			'xmlns:taxo="http://purl.org/rss/1.0/modules/taxonomy/" ' .
+#			'xmlns:dc="http://purl.org/dc/elements/1.1/" ' .
+#			'xmlns:syn="http://purl.org/rss/1.0/modules/syndication/" ' .
+#			'xmlns:admin="http://webns.net/mvcb/" ' .
+#			'xmlns:feedburner="http://rssnamespace.org/feedburner/ext/1.0"';
Added: branches/3_dev/core/lib/class_rss_factory.php
--- branches/3_dev/core/lib/class_rss_factory.php	                        (rev 0)
+++ branches/3_dev/core/lib/class_rss_factory.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,131 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/class_rss.php";
+class RssFactory {
+		$rss = new Rss();
+		return $rss;
+		$rssItem = new RssItem();
+		return $rssItem;
+	public function loadOrCreate ($pathAndFilename) {
+		$rss = $this->createFromUrl($pathAndFilename);
+		if (is_null($rss)) {
+			$rss = $this->createAt($pathAndFilename);
+				return null;
+		return $rss;
+	public function createAt ($pathAndFilename) {
+		$rss = $this->createRss();
+		if ($rss->saveAsFile($pathAndFilename)) {
+			$rss->filename = $pathAndFilename;
+			return $rss;
+		return null;
+	public function createFromUrl ($url) {
+		$rss = $this->parseDocument($url, $this->createRss());
+			return null;
+		$rss->filename = $url;
+		return $this->parseItems($url, $rss);
+	protected function parseDocument ($url, $rss) {
+		$domxpath = $this->createDomXpathFromUrl($url, $rss);
+		if (is_null($domxpath)) {
+			return null;
+		$nodeList = $domxpath->query("/rss/channel/title");
+		if ($nodeList->length === 1) {
+			$rss->channel_title = trim($nodeList->item(0)->nodeValue);
+		else {
+			new mb_warning(__FILE__ . ": load(): Could not find title in RSS feed.");
+		$nodeList = $domxpath->query("/rss/channel/description");
+			$rss->channel_description = trim($nodeList->item(0)->nodeValue);
+		else {
+			new mb_warning(__FILE__ . ": load(): Could not find description in RSS feed.");
+		$nodeList = $domxpath->query("/rss/channel/link");
+			$rss->channel_url = trim($nodeList->item(0)->nodeValue);
+		else {
+			new mb_warning(__FILE__ . ": load(): Could not find url in RSS feed.");
+		return $rss;
+	protected function createDomXpathFromUrl ($url) {
+		$dom = new DOMDocument();
+		$dom->preserveWhitespace = false;
+		$success = $dom->load($url);
+		if (!$success) {
+			new mb_exception(__FILE__ . ": load(): Could not load " . $url);
+			return null;
+		return new DOMXPath($dom);
+	protected function parseItems ($url, $rss) {
+			return null;
+		$nodeList = $domxpath->query("/rss/channel/item");
+		foreach ($nodeList as $node) {
+			$item = $this->createRssItem();
+			$item = $this->parseItem($node, $item);
+			$rss->append($item);
+		return $rss;
+				case "title":
+					$item->setTitle(trim($childNode->nodeValue));
+					break;
+				case "description":
+					$item->setDescription(trim($childNode->nodeValue));
+					break;
+				case "link":
+					$item->setUrl(trim($childNode->nodeValue));
+					break;
+		return $item;
Added: branches/3_dev/core/lib/class_rss_item.php
--- branches/3_dev/core/lib/class_rss_item.php	                        (rev 0)
+++ branches/3_dev/core/lib/class_rss_item.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,50 @@
+<?php
+# License:
+class RssItem {
+	protected $title;
+	protected $description;
+	protected $url;
+	public function __construct () {
+        $this->url = $url;
+	public function getUrl () {
+        return $this->url;
+        $this->title = $title;
+        $this->description = $description;
+        return '<item>'."\n" .
+        	$this->getItemString() . '</item>'."\n";
+#        return '<item rdf:about="' . $this->url . '">'."\n" .
+#        	$this->getItemString() . '</item>'."\n";
+        return '<title>' . $this->title . '</title>' . "\n" .
+			'<link>' . htmlentities($this->url, ENT_QUOTES, CHARSET) . '</link>' . "\n" .
+			'<description>' . $this->description . '</description>' . "\n";
+//			'<feedburner:origLink>' . $this->url . '</feedburner:origLink>' .
+//			"\n";
Added: branches/3_dev/core/lib/initWms.php
--- branches/3_dev/core/lib/initWms.php	                        (rev 0)
+++ branches/3_dev/core/lib/initWms.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,18 @@
+<?php
+// Load WMS
+require_once(dirname(__FILE__)."/../validateSession.php");
+require_once(dirname(__FILE__)."/class_Wms.php");
+require_once(dirname(__FILE__)."/class_Administration.php");
+$wmsArray = wms::selectMyWmsByApplication($gui_id);
+for ($i = 0; $i < count($wmsArray); $i++) {
+	$currentWms = $wmsArray[$i];
+	$output = $currentWms->createJsObjFromWMS_();
+	echo administration::convertOutgoingString($output);
+	unset($output);
Added: branches/3_dev/core/lib/mod_map_messages.php
--- branches/3_dev/core/lib/mod_map_messages.php	                        (rev 0)
+++ branches/3_dev/core/lib/mod_map_messages.php	2010-05-09 16:02:50 UTC (rev 6120)
@@ -0,0 +1,37 @@
+<?php
+#$Id: mod_insertWmcIntoDb.php 507 2006-11-20 10:55:57Z christoph $
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+$e = new mb_notice("locale: " . Mapbender::session()->get("mb_locale") . "; lang: " . Mapbender::session()->get("mb_lang"));
+$e = new mb_notice(setlocale(LC_ALL, Mapbender::session()->get("mb_locale")));
+// Messages
+$msg_obj = array();
+$msg_obj["srsNotSupported"] = _mb("The following WMS do not support the current SRS");
+$json = new Mapbender_JSON();
+$output = $json->encode($msg_obj);
+header("Content-type:application/x-json; charset=utf-8");
+echo $output;
\ No newline at end of file
More information about the Mapbender_commits mailing list
