[Mapbender-commits] r6128 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Sun May 9 15:05:40 EDT 2010
Author: astrid_emde
Date: 2010-05-09 15:05:39 -0400 (Sun, 09 May 2010)
New Revision: 6128
trunk/mapbender/http/plugins/jq_ui_resizable.js
Documentation added
Modified: trunk/mapbender/http/plugins/jq_ui_resizable.js
--- trunk/mapbender/http/plugins/jq_ui_resizable.js 2010-05-09 17:02:48 UTC (rev 6127)
+++ trunk/mapbender/http/plugins/jq_ui_resizable.js 2010-05-09 19:05:39 UTC (rev 6128)
@@ -1,27 +1,28 @@
- * Package: <Application element name>
+ * Package: jq_ui_resizable
* Description:
- * <A description>
+ * resizable from the jQuery UI framework
* Files:
- * - <path and filename, like http/javascripts/mod_zoomIn1.php>
+ * - http/plugins/jq_ui_resizable.js
+ * - http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js
* SQL:
- * > <SQL for element>
- * > <SQL for element var>
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>',
+ * > 'jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','',
+ * > '','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_resizable.js',
+ * > '../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js','','jq_ui','http://docs.jquery.com/UI/Resizable');
* Help:
- * http://www.mapbender.org/<wiki site name>
+ * http://jqueryui.com/demos/resizable/
* Maintainer:
- * http://www.mapbender.org/User:<user>
+ * http://www.mapbender.org/User:Christoph_Baudson
- * Parameters:
- * <normal element var name> - <type and description>
- * <optional element var name> - *[optional]* <type and description>
- * <deprecated element var name> - *[deprecated]* <type and description>
* License:
* Copyright (c) 2009, Open Source Geospatial Foundation
@@ -63,4 +64,4 @@
\ No newline at end of file
More information about the Mapbender_commits
