[Mapbender-commits] r6143 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Mon May 10 07:52:42 EDT 2010
Author: christoph
Date: 2010-05-10 07:52:41 -0400 (Mon, 10 May 2010)
New Revision: 6143
trunk/mapbender/http/plugins/mb_metadata_edit.js
trunk/mapbender/http/plugins/mb_metadata_edit.php
trunk/mapbender/http/plugins/mb_metadata_layer.js
trunk/mapbender/http/plugins/mb_metadata_server.php
Modified: trunk/mapbender/http/plugins/mb_metadata_edit.js
--- trunk/mapbender/http/plugins/mb_metadata_edit.js 2010-05-10 10:32:04 UTC (rev 6142)
+++ trunk/mapbender/http/plugins/mb_metadata_edit.js 2010-05-10 11:52:41 UTC (rev 6143)
@@ -28,9 +28,18 @@
var wmsId;
this.events = {
- showOriginalMetadata : new Mapbender.Event()
+ showOriginalMetadata : new Mapbender.Event(),
+ submit: new Mapbender.Event()
+ this.serialize = function (callback) {
+ var data = $metadataForm.easyform("serialize");
+ if ($.isFunction(callback)) {
+ callback(data);
+ return data;
this.valid = function () {
if (validator && validator.numberOfInvalids() > 0) {
$metadataForm.valid();
Modified: trunk/mapbender/http/plugins/mb_metadata_edit.php
--- trunk/mapbender/http/plugins/mb_metadata_edit.php 2010-05-10 10:32:04 UTC (rev 6142)
+++ trunk/mapbender/http/plugins/mb_metadata_edit.php 2010-05-10 11:52:41 UTC (rev 6143)
@@ -20,8 +20,8 @@
<img class="metadata_img" src="../img/misc/inspire_eu_klein.png"></img>
</p>
<p>
- <label for="">WMS Keywords (OWS):</label>
- <input name=" "id=""/>
+ <label for="wms_keywords">WMS Keywords (OWS):</label>
+ <input name="wms_keywords" id="wms_keywords"/>
</p>
<p>
@@ -89,13 +89,13 @@
</p>
<p>
- <label for="">Date of first registration (Registry):</label>
- <input name="" id=""/>
+ <label for="wms_timestamp_create">Date of first registration (Registry):</label>
+ <input name="wms_timestamp_create" id="wms_timestamp_create"/>
</p>
<p>
- <label for="">Date of last revision (Registry):</label>
- <td><input name="" id=""/>
+ <label for="wms_timestamp">Date of last revision (Registry):</label>
+ <td><input name="wms_timestamp" id="wms_timestamp"/>
</p>
</fieldset>
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.js
--- trunk/mapbender/http/plugins/mb_metadata_layer.js 2010-05-10 10:32:04 UTC (rev 6142)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.js 2010-05-10 11:52:41 UTC (rev 6143)
@@ -32,8 +32,18 @@
+ callback(data);
+ return data;
this.events = {
- initialized: new Mapbender.Event()
+ initialized: new Mapbender.Event(),
var initialized = function (obj) {
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php 2010-05-10 10:32:04 UTC (rev 6142)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php 2010-05-10 11:52:41 UTC (rev 6143)
@@ -78,21 +78,43 @@
$sql = <<<SQL
-SELECT * FROM wms WHERE wms_id = $wmsId;
+SELECT wms_id, wms_abstract, wms_title, fees, accessconstraints,
+contactperson, contactposition, contactvoicetelephone,
+contactfacsimiletelephone, contactorganization, address, city,
+stateorprovince, postcode, country, contactelectronicmailaddress
+FROM wms WHERE wms_id = $wmsId;
SQL;
$res = db_query($sql);
$resultObj = array();
- while ($row = db_fetch_assoc($res)) {
- foreach ($row as $key => $value) {
-// $resultObj["wms:".$key] = $value;
- $resultObj[$key] = $value;
+ $row = db_fetch_assoc($res);
+ foreach ($row as $key => $value) {
+ $resultObj[$key] = $value;
+ $keywordSql = <<<SQL
+SELECT keyword FROM keyword, layer_keyword
+WHERE keyword_id = fkey_keyword_id AND fkey_layer_id IN (
+ SELECT layer_id from layer, wms
+ WHERE layer_pos = 0 AND fkey_wms_id = wms_id AND wms_id = $wmsId
+SQL;
+ $keywordRes = db_query($keywordSql);
+ $keywords = array();
+ while ($keywordRow = db_fetch_assoc($keywordRes)) {
+ $keywords[]= $keywordRow["keyword"];
+ $resultObj["wms_keywords"] = implode(", ", $keywords);
$ajaxResponse->setResult($resultObj);
$ajaxResponse->setSuccess(true);
break;
More information about the Mapbender_commits
