[Mapbender-commits] r6151 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Mon May 10 10:43:50 EDT 2010
Author: kmq
Date: 2010-05-10 10:43:49 -0400 (Mon, 10 May 2010)
New Revision: 6151
trunk/mapbender/http/plugins/mb_loadkmlgeorss.js
reorganized a little bit
Modified: trunk/mapbender/http/plugins/mb_loadkmlgeorss.js
--- trunk/mapbender/http/plugins/mb_loadkmlgeorss.js 2010-05-10 13:25:39 UTC (rev 6150)
+++ trunk/mapbender/http/plugins/mb_loadkmlgeorss.js 2010-05-10 14:43:49 UTC (rev 6151)
@@ -69,7 +69,8 @@
var $dialog = $(this);
$dialog.dialog("close");
- if($("input:checked",$dialog).val() == "GeoRSS"){
+ var format = $("input:checked",$dialog).val();
+ if( format == "GeoRSS"){
var endpointURL = "../php/geoRSSToGeoJSON.php";
}else{
var endpointURL = "../php/kmlToGeoJSON.php";
@@ -92,6 +93,9 @@
$("table", $dialog).remove();
var $table = $("<table><thead><tr><th>Name</th></tr></thead><tbody></tbody></table>");
if(data.features){
+ // we always transform _from_ 4326 geoRSS and KML use this as their default
+ var projSrc = new Proj4js.Proj('EPSG:4326');
+ var projDest = new Proj4js.Proj($map.epsg);
var markeroptions = {width: "19px", height: "34px"};
for(var i in data.features){
title = data.features[i].properties.title || data.features[i].properties.name || "untitled";
@@ -101,41 +105,55 @@
var x = data.features[i].geometry.coordinates[0];
var y = data.features[i].geometry.coordinates[1];
- $row.click((function(feature){
+ point = Proj4js.transform(projSrc, projDest,new Mapbender.Point(x,y));
+ marker = new Mapbender.Marker(point,$map, markeroptions);
+ markers.push(marker);
+ $row.click((function(feature, marker, markerIndex){
return function(){
var x = feature.geometry.coordinates[0];
var y = feature.geometry.coordinates[1];
- var buffer = new Mapbender.Point(options.buffer,options.buffer);
- var a = new Mapbender.Point(x,y);
+ var buffer = new Mapbender.Point(options.buffer,options.buffer);
+ var a = Proj4js.transform(projSrc,projDest,new Mapbender.Point(x,y));
a = a.minus(buffer);
- var b = new Mapbender.Point(x,y);
+ var b = Proj4js.transform(projSrc,projDest,new Mapbender.Point(x,y));
b = b.plus(buffer);
$map.calculateExtent( new Mapbender.Extent(a,b));
$map.setMapRequest();
var offset = $('#'+options.target).offset();
- var mapPoint = $map.convertRealToPixel(new Mapbender.Point(x,y));
- if(popup) {popup.hide();}
- if(mb_popup){
- popup = new mb_popup({left: mapPoint.x + offset.left,
- top: mapPoint.y + offset.top,
- balloon: true,
- html: feature.properties.description,
- title :feature.properties.title || feature.properties.name || "untitled"
+ var mapPoint = $map.convertRealToPixel(Proj4js.transform(projSrc,projDest, new Mapbender.Point(x,y)));
+ marker.remove();
+ point = Proj4js.transform(projSrc, projDest, new Mapbender.Point(x,y));
+ var markeroptions = {width: "19px", height: "34px", img:{url: "../img/marker/orange.png", offset: new Point(-10,-34)}};
+ var highlightmarker = new Mapbender.Marker(point,$map, markeroptions);
+ $('<div style="max-height:20em; max-width:20em">'+ feature.properties.description + "</div>").dialog({
+ title: feature.properties.title || feature.properties.name || "untitled",
+ position: [mapPoint.x+offset.left+20, mapPoint.y + offset.top+20 ],
+ autoOpen: true,
+ buttons : {"Close":function(){
+ $(this).dialog("close");
+ close: function(){
+ highlightmarker.remove();
+ var markeroptions = {width: "19px", height: "34px"};
+ if(feature.properties.iconurl){
+ markeroptions.img = {url: feature.properties.iconurl, offset: {x:0,y:0}} ;
- popup.show();
- })(data.features[i]));
+ })(data.features[i], marker));
$row.css("cursor","pointer");
$("tbody",$table).append($row);
- point = new Mapbender.Point(x,y);
- marker = new Mapbender.Marker(point,$map, markeroptions);
- markers.push(marker);
More information about the Mapbender_commits
