[Mapbender-commits] r6159 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 11 04:01:20 EDT 2010
Author: christoph
Date: 2010-05-11 04:01:19 -0400 (Tue, 11 May 2010)
New Revision: 6159
   trunk/mapbender/http/plugins/mb_metadata_layer.php
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.php
--- trunk/mapbender/http/plugins/mb_metadata_layer.php	2010-05-11 07:56:11 UTC (rev 6158)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.php	2010-05-11 08:01:19 UTC (rev 6159)
@@ -41,20 +41,20 @@
 		    <div id="buttons">
 				<label>Add Information about the underlying data:</label>
 				<p>
-					<input class="" type="submit" value="Add new Metadata Record"/>
+					<input disabled="disabled" class="" type="submit" value="Add new Metadata Record"/>
 				</p>
 				<p>
-					<input class="" type="submit" value="Edit Metadata Linkage"/>
+					<input disabled="disabled" class="" type="submit" value="Edit Metadata Linkage"/>
 				</p>
 				<p>
-					<input class="" type="submit" value="Delete Metadata Linkage"/>
+					<input disabled="disabled" class="" type="submit" value="Delete Metadata Linkage"/>
 				</p>
 			</div>
 			<div id="selectbox">
-				<select class="metadata_selectbox" size="2" multiple>
-					<option>test</option>
+				<select disabled="disabled" class="metadata_selectbox" size="2" multiple>
+					<option>not</option>
+					<option>yet</option>
+					<option>implemented</option>
 				</select>
 			</div>
 		</p>
More information about the Mapbender_commits mailing list
