[Mapbender-commits] r6165 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 11 06:19:37 EDT 2010
Author: verenadiewald
Date: 2010-05-11 06:19:29 -0400 (Tue, 11 May 2010)
New Revision: 6165
   trunk/mapbender/resources/db/metadataGui.sql
Modified: trunk/mapbender/resources/db/metadataGui.sql
--- trunk/mapbender/resources/db/metadataGui.sql	2010-05-11 10:13:31 UTC (rev 6164)
+++ trunk/mapbender/resources/db/metadataGui.sql	2010-05-11 10:19:29 UTC (rev 6165)
@@ -162,6 +162,16 @@
                 "attr": "callback"
+        "method": "fill",
+        "linkedTo": [
+                "id": "mb_md_showOriginal",
+                "event": "replaceMetadata",
+                "attr": "data"
 ] ', '', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer', 'inputs', '[
@@ -268,6 +278,9 @@
 ]', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin_wms_metadata', 'mb_md_showOriginal', 'differentFromOriginalCss', '.differentFromOriginal{
+background-color:#FFFACD;
+}', 'css for class differentFromOriginal' ,'text/css');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_pane', 'center', 'mb_tabs_horizontal', '', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_pane', 'south', 'mb_md_submit', '', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_tabs_horizontal', 'inputs', '[
More information about the Mapbender_commits mailing list
