[Mapbender-commits] r6168 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 11 06:31:14 EDT 2010
Author: verenadiewald
Date: 2010-05-11 06:31:14 -0400 (Tue, 11 May 2010)
New Revision: 6168
   trunk/mapbender/http/plugins/mb_metadata_showOriginal.js
don't check wms_id in mergeOriginalWithCurrentMetadata
Modified: trunk/mapbender/http/plugins/mb_metadata_showOriginal.js
--- trunk/mapbender/http/plugins/mb_metadata_showOriginal.js	2010-05-11 10:26:00 UTC (rev 6167)
+++ trunk/mapbender/http/plugins/mb_metadata_showOriginal.js	2010-05-11 10:31:14 UTC (rev 6168)
@@ -36,7 +36,11 @@
 		var differenceFound = false;
 		for(metadataAttr in currentObj) {
 			var origMetadataAttr = "original_" + metadataAttr;
-			if(metadataAttr != "wms_timestamp" && metadataAttr != "wms_timestamp_create" && metadataAttr != "wms_keywords") {
+			if(metadataAttr != "wms_id" &&
+				metadataAttr != "wms_timestamp" &&
+				metadataAttr != "wms_timestamp_create" &&
+				metadataAttr != "wms_keywords" &&
+				metadataAttr != "wms_termsofuse") {
 				//check if both fields are filled
 				if(currentObj[metadataAttr] != "" && originalObj[origMetadataAttr] != "") {
 					if(currentObj[metadataAttr] == originalObj[origMetadataAttr]) {
@@ -67,19 +71,19 @@
 			$originalMetadataPopup.dialog("close");
 			var noDifferenceMsg = "No difference found.";
 			$("<div>" + noDifferenceMsg + "</div>").dialog(
-						title : "Show original metadata",
-						bgiframe: true,
-						autoOpen: true,
-						modal: false,
-						position : [600, 75],
-						buttons: {
-							"ok": function(){
-								$(this).dialog('close').remove();
+					title : "Show original metadata",
+					bgiframe: true,
+					autoOpen: true,
+					modal: false,
+					position : [600, 75],
+					buttons: {
+						"ok": function(){
+							$(this).dialog('close').remove();
More information about the Mapbender_commits mailing list
