[Mapbender-commits] r6182 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Tue May 11 12:15:02 EDT 2010
Author: christoph
Date: 2010-05-11 12:15:00 -0400 (Tue, 11 May 2010)
New Revision: 6182
trunk/mapbender/http/classes/class_wms.php
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php 2010-05-11 16:00:58 UTC (rev 6181)
+++ trunk/mapbender/http/classes/class_wms.php 2010-05-11 16:15:00 UTC (rev 6182)
@@ -37,6 +37,7 @@
var $wms_getlegendurl;
var $wms_upload_url;
var $wms_srs = array();
+ var $wms_termsofuse;
var $fees;
var $accessconstraints;
@@ -1632,6 +1633,7 @@
$this->insertLayerStyle($i);
if($this->overwrite == true){
$this->insertLayerKeyword($i);
+ $this->insertLayerCategories($i);
@@ -1689,6 +1691,20 @@
+ function insertTermsOfUse ($myWMS) {
+ if (!is_numeric($this->wms_termsofuse)) {
+ return;
+ $sql ="INSERT INTO wms_termsofuse (fkey_wms_id, fkey_termsofuse_id) ";
+ $sql .= " VALUES($1,$2)";
+ $v = array($myWMS,$this->wms_termsofuse);
+ $t = array('i','i');
+ $res = db_prep_query($sql,$v,$t);
+ if(!$res){
+ db_rollback();
function insertFormat($myWMS){
for($i=0; $i<count($this->data_type);$i++){
$sql ="INSERT INTO wms_format (fkey_wms_id, data_type, data_format) ";
@@ -1739,6 +1755,34 @@
+ function insertLayerCategories($i){
+ global $con;
+ $types = array("md_topic", "inspire", "custom");
+ foreach ($types as $cat) {
+ $sql = "DELETE FROM layer_{$cat}_category WHERE fkey_layer_id = $1";
+ $v = array($this->objLayer[$i]->db_id);
+ $t = array('i');
+ $attr = "layer_{$cat}_category_id";
+ $k = $this->objLayer[$i]->$attr;
+ for ($j = 0; $j < count($k); $j++) {
+ $sql = "INSERT INTO layer_{$cat}_category (fkey_layer_id, fkey_{$cat}_category_id) VALUES ($1, $2)";
+ $v = array($this->objLayer[$i]->db_id, $k[$j]);
+ $t = array('i', 'i');
+ if(!$res){
+ db_rollback();
+ return;
function insertLayerKeyword($i){
global $con;
$sql = "DELETE FROM layer_keyword WHERE fkey_layer_id = $1";
@@ -1854,6 +1898,16 @@
+ # delete and refill wms_termsofuse
+ $sql = "DELETE FROM wms_termsofuse WHERE fkey_wms_id = $1 ";
+ $v = array($myWMS);
+ $t = array('i');
+ if(!$res){
+ db_rollback();
+ $this->insertTermsOfUse($myWMS);
# delete and refill srs and formats
$sql = "DELETE FROM wms_srs WHERE fkey_wms_id = $1 ";
$v = array($myWMS);
@@ -2638,6 +2692,9 @@
var $layer_keyword = array();
var $layer_epsg = array();
var $layer_style = array();
+ var $layer_md_topic_category_id = array();
+ var $layer_inspire_category_id = array();
+ var $layer_custom_category_id = array();
var $gui_layer_wms_id;
var $gui_layer_status = 1;
More information about the Mapbender_commits
