[Mapbender-commits] r6191 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Wed May 12 05:32:55 EDT 2010
Author: verenadiewald
Date: 2010-05-12 05:32:55 -0400 (Wed, 12 May 2010)
New Revision: 6191
trunk/mapbender/http/plugins/mb_metadata_showOriginal.js
originalLayer Metadata
Modified: trunk/mapbender/http/plugins/mb_metadata_showOriginal.js
--- trunk/mapbender/http/plugins/mb_metadata_showOriginal.js 2010-05-12 09:32:16 UTC (rev 6190)
+++ trunk/mapbender/http/plugins/mb_metadata_showOriginal.js 2010-05-12 09:32:55 UTC (rev 6191)
@@ -4,6 +4,7 @@
var ShowOriginalApi = function() {
var that = this;
+ var layerName;
this.events = {
replaceMetadata : new Mapbender.Event()
@@ -36,34 +37,34 @@
var differenceFound = false;
for(metadataAttr in currentObj) {
var origMetadataAttr = "original_" + metadataAttr;
+ //some attr are excluded from check
if(metadataAttr != "wms_id" &&
metadataAttr != "wms_timestamp" &&
metadataAttr != "wms_timestamp_create" &&
metadataAttr != "wms_keywords" &&
- metadataAttr != "wms_termsofuse") {
- //check if both fields are filled
- if(currentObj[metadataAttr] != "" && originalObj[origMetadataAttr] != "") {
- if(currentObj[metadataAttr] == originalObj[origMetadataAttr]) {
- $("#" + origMetadataAttr).parent().hide();
- else {
- //mark all attr in main form which are different
- $("#" + metadataAttr).addClass("differentFromOriginal");
- (function () {
- var clickedAttr = metadataAttr;
- var attrValue = $("#" + origMetadataAttr).val();
- $("#" + origMetadataAttr).parent().append("<input type='button' value='Replace' id='replaceRecord_"+origMetadataAttr+"' />");
- $("#replaceRecord_" +origMetadataAttr).addClass("ui-state-default ui-corner-all");
- $("#replaceRecord_" +origMetadataAttr).bind("click", function () {
- replaceMetadata(clickedAttr, attrValue);
- var differenceFound = true;
+ metadataAttr != "wms_termsofuse" &&
+ metadataAttr != "layer_name" &&
+ metadataAttr != "layer_id" &&
+ metadataAttr != "changeEPSG" &&
+ metadataAttr != "scaleSelect") {
+ if(currentObj[metadataAttr] == originalObj[origMetadataAttr]) {
+ $("#" + origMetadataAttr).parent().hide();
- //if both fields are empty, hide the html
else {
+ //mark all attr in main form which are different
+ $("#" + metadataAttr).addClass("differentFromOriginal");
+ (function () {
+ var clickedAttr = metadataAttr;
+ var attrValue = $("#" + origMetadataAttr).val();
+ $("#" + origMetadataAttr).parent().append("<input type='button' value='Replace' id='replaceRecord_"+origMetadataAttr+"' />");
+ $("#replaceRecord_" +origMetadataAttr).addClass("ui-state-default ui-corner-all");
+ $("#replaceRecord_" +origMetadataAttr).bind("click", function () {
+ replaceMetadata(clickedAttr, attrValue);
+ var differenceFound = true;
@@ -87,20 +88,24 @@
- var getOriginalMetadata = function (currentWmsId, currentWmsData) {
+ var getOriginalMetadata = function (isWmsOrLayer, currentId, currentData) {
+ if(isWmsOrLayer == "layer") {
+ layerName = currentData.layer_name;
// get original metadata from server
var req = new Mapbender.Ajax.Request({
url: "../plugins/mb_original_metadata_server.php",
method: "getOriginalMetadata",
parameters: {
- "id": currentWmsId
+ "id": currentId,
+ "layerName": layerName
callback: function (obj, result, message) {
if (!result) {
return;
fillForm(obj);
- mergeOriginalWithCurrentMetadata(obj,currentWmsData);
+ mergeOriginalWithCurrentMetadata(obj,currentData);
req.send();
@@ -137,9 +142,16 @@
this.init = function (obj) {
$originalMetadataPopup.dialog("close");
$originalMetadataForm.load("../plugins/mb_metadata_showOriginal.html", function () {
- getOriginalMetadata(obj.wmsId, obj.wmsData);
+ getOriginalMetadata("wms", obj.wmsId, obj.wmsData);
+ this.initLayer = function (obj) {
+ $originalMetadataPopup.dialog("close");
+ $originalMetadataForm.load("../plugins/mb_metadata_showOriginalLayer.html", function () {
+ getOriginalMetadata("layer",obj.wmsId, obj.layerData);
$showOriginalDiv.mapbender(new ShowOriginalApi());
\ No newline at end of file
More information about the Mapbender_commits
