[Mapbender-commits] r6194 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Wed May 12 06:03:57 EDT 2010
Author: christoph
Date: 2010-05-12 06:03:53 -0400 (Wed, 12 May 2010)
New Revision: 6194
trunk/mapbender/http/plugins/mb_metadata_edit.js
trunk/mapbender/http/plugins/mb_metadata_edit.php
trunk/mapbender/http/plugins/mb_metadata_layer.js
trunk/mapbender/http/plugins/mb_metadata_layer.php
trunk/mapbender/http/plugins/mb_metadata_layerPreview.js
trunk/mapbender/http/plugins/mb_metadata_server.php
Modified: trunk/mapbender/http/plugins/mb_metadata_edit.js
--- trunk/mapbender/http/plugins/mb_metadata_edit.js 2010-05-12 09:48:02 UTC (rev 6193)
+++ trunk/mapbender/http/plugins/mb_metadata_edit.js 2010-05-12 10:03:53 UTC (rev 6194)
@@ -96,10 +96,6 @@
- var validate = function () {
- return false;
this.init = function (obj) {
wmsId = obj;
@@ -112,7 +108,11 @@
$metadataForm.find(".original-metadata-wms").bind("click", function() {
showOriginalMetadata();
- validator = $metadataForm.validate();
+ validator = $metadataForm.validate({
+ submitHandler: function () {
+ return false;
if (formData !== undefined) {
fillForm(obj, formData);
@@ -126,8 +126,6 @@
fillForm(obj);
- $metadataForm.bind("submit", validate);
Mapbender.events.localize.register(function () {
that.valid();
var formData = $metadataForm.easyform("serialize");
Modified: trunk/mapbender/http/plugins/mb_metadata_edit.php
--- trunk/mapbender/http/plugins/mb_metadata_edit.php 2010-05-12 09:48:02 UTC (rev 6193)
+++ trunk/mapbender/http/plugins/mb_metadata_edit.php 2010-05-12 10:03:53 UTC (rev 6194)
@@ -72,7 +72,7 @@
<input name="contactvoicetelephone" id="contactvoicetelephone"/>
</p>
<p>
- <label for="contactfacsimiletelephone"><?php echo _mb("");?>Contact Phone Fax (OWS):</label>
+ <label for="contactfacsimiletelephone"><?php echo _mb("Contact Phone Fax (OWS)");?>:</label>
<input name="contactfacsimiletelephone" id="contactfacsimiletelephone"/>
</p>
<p>
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.js
--- trunk/mapbender/http/plugins/mb_metadata_layer.js 2010-05-12 09:48:02 UTC (rev 6193)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.js 2010-05-12 10:03:53 UTC (rev 6194)
@@ -28,10 +28,20 @@
var formReady = false;
var wmsId;
var layerId;
+ var disabledFields = [
+ "layer_custom_category_id",
+ "layer_inspire_category_id",
+ "layer_md_topic_category_id",
+ "layer_keyword",
+ "layer_abstract",
+ "layer_title"
this.events = {
initialized: new Mapbender.Event(),
- submit: new Mapbender.Event()
+ submit: new Mapbender.Event(),
+ showOriginalLayerMetadata : new Mapbender.Event()
this.valid = function () {
@@ -57,7 +67,13 @@
this.fillForm = function (obj) {
+ $(disabledFields).each(function () {
+ $("#" + this).removeAttr("disabled");
layerId = obj.layer_id;
+ $metadataForm.easyform("reset");
// get metadata from server
var req = new Mapbender.Ajax.Request({
@@ -70,7 +86,6 @@
if (!result) {
return;
- $metadataForm.easyform("reset");
$metadataForm.easyform("fill", obj);
that.valid();
@@ -78,11 +93,22 @@
req.send();
- return false;
+ this.fill = function (obj) {
+ $metadataForm.easyform("fill", obj);
+ var showOriginalLayerMetadata = function () {
+ that.events.showOriginalLayerMetadata.trigger({
+ data : {
+ wmsId : wmsId,
+ layerData : $metadataForm.easyform("serialize")
+ delete layerId;
wmsId = obj;
@@ -91,8 +117,18 @@
if (!formReady) {
$metadataForm.load("../plugins/mb_metadata_layer.php", function () {
+ $metadataForm.find(".help-dialog").helpDialog();
+ $metadataForm.find(".original-metadata-layer").bind("click", function() {
+ showOriginalLayerMetadata();
+ return false;
that.events.initialized.trigger({
wmsId: wmsId
@@ -104,13 +140,14 @@
return;
+ $("#" + this).attr("disabled", "disabled");
wmsId: wmsId
that.valid();
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.php
--- trunk/mapbender/http/plugins/mb_metadata_layer.php 2010-05-12 09:48:02 UTC (rev 6193)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.php 2010-05-12 10:03:53 UTC (rev 6194)
@@ -43,17 +43,17 @@
<p>
<label for="layer_title"><?php echo _mb("Layer Title (WMS)");?>:</label>
<img class="metadata_img" title="<?php echo _mb("Inspire");?>" src="../img/misc/inspire_eu_klein.png"></img>
- <input name="layer_title" id="layer_title" class="required" />
+ <input disabled="disabled" name="layer_title" id="layer_title" class="required" />
</p>
<p>
<label for="layer_abstract"><?php echo _mb("Layer Abstract (WMS)");?>:</label>
- <input name="layer_abstract" id="layer_abstract"/>
+ <input disabled="disabled" name="layer_abstract" id="layer_abstract"/>
</p>
<p>
<label for="layer_keyword"><?php echo _mb("Layer Keywords (WMS)");?>:</label>
<span class="metadata_span"></span>
- <input name="layer_keyword" id="layer_keyword"/>
+ <input disabled="disabled" name="layer_keyword" id="layer_keyword"/>
</p>
<p>
<div id="buttons">
@@ -95,7 +95,7 @@
<p>
<label for="layer_md_topic_category_id" class="label_classification"><?php echo _mb("ISO Topic Category");?>:</label>
- <select class="metadata_selectbox" id="layer_md_topic_category_id" name="layer_md_topic_category_id" size="2" multiple="multiple">
+ <select disabled="disabled" class="metadata_selectbox" id="layer_md_topic_category_id" name="layer_md_topic_category_id" size="2" multiple="multiple">
<?php
$sql = "SELECT md_topic_category_id AS id, md_topic_category_code_en AS name FROM md_topic_category";
echo displayCategories($sql);
@@ -105,7 +105,7 @@
<p>
<label for="layer_inspire_category_id" class="label_classification"><?php echo _mb("INSPIRE Category");?>:</label>
- <select class="metadata_selectbox" id="layer_inspire_category_id" name="layer_inspire_category_id" size="2" multiple="multiple">
+ <select disabled="disabled" class="metadata_selectbox" id="layer_inspire_category_id" name="layer_inspire_category_id" size="2" multiple="multiple">
<?php
$sql = "SELECT inspire_category_id AS id, inspire_category_code_en AS name FROM inspire_category";
@@ -115,7 +115,7 @@
<p>
<label for="layer_custom_category_id" class="label_classification"><?php echo _mb("Custom Category");?>:</label>
- <select class="metadata_selectbox" id="layer_custom_category_id" name="layer_custom_category_id" size="2" multiple="multiple">
+ <select disabled="disabled" class="metadata_selectbox" id="layer_custom_category_id" name="layer_custom_category_id" size="2" multiple="multiple">
<?php
$sql = "SELECT custom_category_id AS id, custom_category_code_en AS name FROM custom_category";
Modified: trunk/mapbender/http/plugins/mb_metadata_layerPreview.js
--- trunk/mapbender/http/plugins/mb_metadata_layerPreview.js 2010-05-12 09:48:02 UTC (rev 6193)
+++ trunk/mapbender/http/plugins/mb_metadata_layerPreview.js 2010-05-12 10:03:53 UTC (rev 6194)
@@ -16,7 +16,6 @@
var len = layer.layer_epsg.length;
if (len === 0) {
// could not zoom to extent
-// console.log("Could not zoom to extent");
return;
for (var j = 0; j < len; j++) {
@@ -29,7 +28,6 @@
currentEpsg.maxy
map.calculateExtent(newExtent);
-// console.log("Zooming to " + newExtent.toString());
return;
@@ -45,7 +43,6 @@
srs: newEpsg.epsg,
extent: newExtent
-// console.log("Changing SRS to " + newEpsg.epsg + " and zooming to " + newExtent.toString());
// enable layer,. disabling all others
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php 2010-05-12 09:48:02 UTC (rev 6193)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php 2010-05-12 10:03:53 UTC (rev 6194)
@@ -362,7 +362,6 @@
if (!is_array($value)) {
$layer->$c = array($value);
- $firephp->log($layer->$c);
else {
$layer->$c = $value;
@@ -374,7 +373,6 @@
- $firephp->log($layer);
More information about the Mapbender_commits
