[Mapbender-commits] r6201 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Wed May 12 06:36:34 EDT 2010
Author: christoph
Date: 2010-05-12 06:36:32 -0400 (Wed, 12 May 2010)
New Revision: 6201
trunk/mapbender/resources/db/metadataGui.sql
Modified: trunk/mapbender/resources/db/metadataGui.sql
--- trunk/mapbender/resources/db/metadataGui.sql 2010-05-12 10:33:05 UTC (rev 6200)
+++ trunk/mapbender/resources/db/metadataGui.sql 2010-05-12 10:36:32 UTC (rev 6201)
@@ -27,7 +27,7 @@
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_edit',2,1,'Edit WMS metadata','Edit WMS metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'overflow:auto','','div','../plugins/mb_metadata_edit.js','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer',3,1,'Edit layer metadata','Edit layer metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_layer.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview',2,1,'Allows selection of a preview image of a Map','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_layerPreview.js','mod_addWMSgeneralFunctions.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview',4,1,'Allows selection of a preview image of a Map','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_layerPreview.js','mod_addWMSgeneralFunctions.js','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview_save',2,1,'','','img','../img/button_gray/wmc_save_off.png','',NULL ,NULL ,NULL ,NULL ,NULL ,'display: none;','','','../plugins/mb_metadata_saveLayerPreview.js','','mapframe1','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_tree',2,1,'Select a layer from a layer tree','Select a layer from a layer tree','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_layerTree.js','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_select',2,1,'Select a WMS','Select WMS','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<table class=''display''></table>','div','../plugins/mb_metadata_select.js','','','jq_datatables','');
@@ -75,6 +75,10 @@
vertical-align: top;
+.help-dialog {
+ cursor: pointer;
.metadata_img, .help-dialog, .original-metadata-wms {
width: 25px;
height: 25px;
@@ -105,8 +109,8 @@
div#preview {
+ padding-top: 5px;
width: 25%;
- padding-top: 5px;
float: left;
@@ -116,17 +120,13 @@
width: 40%;
-div#save {
- margin-left: 45em;
div#buttons {
float: left;
div#selectbox {
- margin-left: 312px;
- padding-top: 20px;
+ margin-left: 280px;
+ padding-top: 60px;
}', 'to define the color of the body', 'text/css');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'favicon', '../img/favicon.png', 'favicon', 'php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'includeWhileLoading', '', 'show splash screen while the application is loading', 'php_var');
@@ -284,7 +284,7 @@
-]', '', 'var');
+] ', '', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_showOriginal', 'differentFromOriginalCss', '.differentFromOriginal{
background-color:#FFFACD;
}', 'css for class differentFromOriginal', 'text/css');
@@ -297,7 +297,7 @@
"id": "mb_md_edit",
"event": "showOriginalMetadata",
"attr": "data"
More information about the Mapbender_commits
