[Mapbender-commits] r6204 -
trunk/mapbender/http/extensions/dataTables-1.5/lang
svn_mapbender at osgeo.org
Mon May 17 06:25:40 EDT 2010
Author: verenadiewald
Date: 2010-05-17 06:25:35 -0400 (Mon, 17 May 2010)
New Revision: 6204
Added:
trunk/mapbender/http/extensions/dataTables-1.5/lang/bg.txt
trunk/mapbender/http/extensions/dataTables-1.5/lang/es.txt
trunk/mapbender/http/extensions/dataTables-1.5/lang/gr.txt
trunk/mapbender/http/extensions/dataTables-1.5/lang/hu.txt
trunk/mapbender/http/extensions/dataTables-1.5/lang/it.txt
trunk/mapbender/http/extensions/dataTables-1.5/lang/pt.txt
new translations for dataTables
Added: trunk/mapbender/http/extensions/dataTables-1.5/lang/bg.txt
--- trunk/mapbender/http/extensions/dataTables-1.5/lang/bg.txt (rev 0)
+++ trunk/mapbender/http/extensions/dataTables-1.5/lang/bg.txt 2010-05-17 10:25:35 UTC (rev 6204)
@@ -0,0 +1,17 @@
+ "sProcessing": "Обработка на резултатите...",
+ "sLengthMenu": "Показване на _MENU_ резултата",
+ "sZeroRecords": "Няма намерени резултати",
+ "sInfo": "Показване на резултати от _START_ до _END_ от общо _TOTAL_",
+ "sInfoEmpty": "Показване на резултати от 0 до 0 от общо 0",
+ "sInfoFiltered": "(филтрирани от общо _MAX_ резултата)",
+ "sInfoPostFix": "",
+ "sSearch": "Търсене във всички колони:",
+ "sUrl": "",
+ "oPaginate": {
+ "sFirst": "Първа",
+ "sPrevious": "Предишна",
+ "sNext": "Следваща",
+ "sLast": "Последна"
\ No newline at end of file
Added: trunk/mapbender/http/extensions/dataTables-1.5/lang/es.txt
--- trunk/mapbender/http/extensions/dataTables-1.5/lang/es.txt (rev 0)
+++ trunk/mapbender/http/extensions/dataTables-1.5/lang/es.txt 2010-05-17 10:25:35 UTC (rev 6204)
@@ -0,0 +1,17 @@
+ "sProcessing": "Procesando...",
+ "sLengthMenu": "Mostrar _MENU_ registros",
+ "sZeroRecords": "No se encontraron resultados",
+ "sInfo": "Mostrando desde _START_ hasta _END_ de _TOTAL_ registros",
+ "sInfoEmpty": "Mostrando desde 0 hasta 0 de 0 registros",
+ "sInfoFiltered": "(filtrado de _MAX_ registros en total)",
+ "sSearch": "Buscar:",
+ "sUrl": "",
+ "oPaginate": {
+ "sFirst": "Primero",
+ "sPrevious": "Anterior",
+ "sNext": "Siguiente",
+ "sLast": "Último"
Added: trunk/mapbender/http/extensions/dataTables-1.5/lang/gr.txt
--- trunk/mapbender/http/extensions/dataTables-1.5/lang/gr.txt (rev 0)
+++ trunk/mapbender/http/extensions/dataTables-1.5/lang/gr.txt 2010-05-17 10:25:35 UTC (rev 6204)
@@ -0,0 +1,17 @@
+ "sProcessing": "Επεξεργασία...",
+ "sLengthMenu": "Δείξε _MENU_ εγγραφές",
+ "sZeroRecords": "Δεν βρέθηκαν εγγραφές που να ταιριάζουν",
+ "sInfo": "Δείχνοντας _START_ εως _END_ από _TOTAL_ εγγραφές",
+ "sInfoEmpty": "Δείχνοντας 0 εως 0 από 0 εγγραφές",
+ "sInfoFiltered": "(φιλτραρισμένες από _MAX_ συνολικά εγγραφές)",
+ "sSearch": "Αναζήτηση:",
+ "sUrl": "",
+ "oPaginate": {
+ "sFirst": "Πρώτη",
+ "sPrevious": "Προηγούμενη",
+ "sNext": "Επόμενη",
+ "sLast": "Τελευταία"
Added: trunk/mapbender/http/extensions/dataTables-1.5/lang/hu.txt
--- trunk/mapbender/http/extensions/dataTables-1.5/lang/hu.txt (rev 0)
+++ trunk/mapbender/http/extensions/dataTables-1.5/lang/hu.txt 2010-05-17 10:25:35 UTC (rev 6204)
@@ -0,0 +1,17 @@
+ "sProcessing": "Feldolgozás...",
+ "sLengthMenu": "_MENU_ találat oldalanként",
+ "sZeroRecords": "Nincs a keresésnek megfelelő találat",
+ "sInfo": "Találatok: _START_ - _END_ Összesen: _TOTAL_",
+ "sInfoEmpty": "Nulla találat",
+ "sInfoFiltered": "(_MAX_ összes rekord közül szűrve)",
+ "sSearch": "Keresés:",
+ "sUrl": "",
+ "oPaginate": {
+ "sFirst": "Első",
+ "sPrevious": "Előző",
+ "sNext": "Következő",
+ "sLast": "Utolsó"
Added: trunk/mapbender/http/extensions/dataTables-1.5/lang/it.txt
--- trunk/mapbender/http/extensions/dataTables-1.5/lang/it.txt (rev 0)
+++ trunk/mapbender/http/extensions/dataTables-1.5/lang/it.txt 2010-05-17 10:25:35 UTC (rev 6204)
@@ -0,0 +1,17 @@
+ "sProcessing": "Caricamento...",
+ "sLengthMenu": "Visualizza _MENU_ elementi",
+ "sZeroRecords": "La ricerca non ha portato alcun risultato.",
+ "sInfo": "Vista da _START_ a _END_ di _TOTAL_ elementi",
+ "sInfoEmpty": "Vista da 0 a 0 di 0 elementi",
+ "sInfoFiltered": "(filtrati da _MAX_ elementi totali)",
+ "sSearch": "Cerca:",
+ "sUrl": "",
+ "oPaginate": {
+ "sFirst": "Inizio",
+ "sPrevious": "Precedente",
+ "sNext": "Successivo",
+ "sLast": "Fine"
Added: trunk/mapbender/http/extensions/dataTables-1.5/lang/pt.txt
--- trunk/mapbender/http/extensions/dataTables-1.5/lang/pt.txt (rev 0)
+++ trunk/mapbender/http/extensions/dataTables-1.5/lang/pt.txt 2010-05-17 10:25:35 UTC (rev 6204)
@@ -0,0 +1,17 @@
+ "sProcessing": "A processar...",
+ "sLengthMenu": "Mostrar _MENU_ registos",
+ "sZeroRecords": "Não foram encontrados resultados",
+ "sInfo": "Mostrando de _START_ até _END_ de _TOTAL_ registos",
+ "sInfoEmpty": "Mostrando de 0 até 0 de 0 registros",
+ "sInfoFiltered": "(filtrado de _MAX_ registos no total)",
+ "sSearch": "Procurar:",
+ "sUrl": "",
+ "oPaginate": {
+ "sFirst": "Primeiro",
+ "sNext": "Seguinte",
+ "sLast": "Último"
More information about the Mapbender_commits
