[Mapbender-commits] r7087 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Nov 3 11:30:26 EDT 2010
Author: apour
Date: 2010-11-03 08:30:26 -0700 (Wed, 03 Nov 2010)
New Revision: 7087
   trunk/mapbender/http/php/mod_saveWKT.php
Fixed possible SQL injection vulnerability
Modified: trunk/mapbender/http/php/mod_saveWKT.php
--- trunk/mapbender/http/php/mod_saveWKT.php	2010-11-03 14:20:26 UTC (rev 7086)
+++ trunk/mapbender/http/php/mod_saveWKT.php	2010-11-03 15:30:26 UTC (rev 7087)
@@ -96,10 +96,11 @@
 $con = pg_connect ($con_string) or die ("Error while connecting database DBname");
- * @security_patch sqli open
+ * @security_patch sqli done
 $sql = "SELECT f_table_name, f_geometry_column,type,srid FROM geometry_columns
-        where f_table_name like '$tblmb'"; //pick only certain tables (see above)
+        where f_table_name like '".addslashes($tblmb)."'"; //pick only certain tables (see above)
 //$sql = "SELECT f_table_name, f_geometry_column,type,srid FROM geometry_columns";
 $res = pg_query($con,$sql);
 $cnt = 0;
@@ -122,10 +123,10 @@
 echo "</select>";
 if(isset($tablenames)){
-   $sql = "SELECT * from ".$tablenames." limit 1";
+   $sql = "SELECT * from ".addslashes($tablenames)." limit 1";
    $num = pg_num_fields($res);
More information about the Mapbender_commits mailing list
