[Mapbender-commits] r7093 - in trunk/mapbender: conf log
resources/db
svn_mapbender at osgeo.org
Fri Nov 5 09:04:15 EDT 2010
Author: kmq
Date: 2010-11-05 06:04:15 -0700 (Fri, 05 Nov 2010)
New Revision: 7093
Removed:
trunk/mapbender/conf/mapbender.conf
trunk/mapbender/log/mb_error_2010_11_03.log
trunk/mapbender/log/security_patch.log
trunk/mapbender/resources/db/error.log
trunk/mapbender/resources/db/log_schema.txt
removing mistakenly commited files
Deleted: trunk/mapbender/conf/mapbender.conf
--- trunk/mapbender/conf/mapbender.conf 2010-11-04 19:06:12 UTC (rev 7092)
+++ trunk/mapbender/conf/mapbender.conf 2010-11-05 13:04:15 UTC (rev 7093)
@@ -1,182 +0,0 @@
-<?php
-# $Id: mapbender.conf-dist 7039 2010-10-12 07:20:11Z armin11 $
-# http://www.mapbender.org/index.php/Mapbender.conf
-# Copyright (C) 2002 CCGIS
-# type of mapbender database
-define("SYS_DBTYPE", "pgsql");
-# database information
-define("DBSERVER", "localhost"); //default "localhost"
-define("PORT", "5432"); //default "5432"
-define("DB", "mapbender_trunk");
-define("OWNER", "admin");
-define("PW", "test");
-# prepared statements (PHP > 5.1.x, PostgreSQL > 7.4)
-define("PREPAREDSTATEMENTS",true);
-# encoding - default characterset UTF-8
-define("CHARSET","UTF-8");
-# error_reporting
-//ini_set('error_reporting', 'E_ALL & ~ E_NOTICE');
-# directory for temporary files
-define("TMPDIR", "../tmp");
-# URL to login
-define("LOGIN", "http://localhost/mapbender/frames/login.php");
-define("MAXLOGIN", 3);
-$login = LOGIN;
-# URL to owsproxy
-# (no terminating slash)
-define("OWSPROXY", "http://<ip or name>/owsproxy");
-# Definitions for HTTP Authentication
-define('REALM', 'mapbender_registry');
-define('NONCEKEY', 'mapbender');
-$nonceLife = 300;
-define('HTTP_AUTH_PROXY',"https://".$_SERVER['HTTP_HOST']."/http_auth"); //Problem - behind a rewrite rule - define it hardcoded?
-# type of server-connection
-# curl, socket, http
-#define("CONNECTION", "curl");
-define("CONNECTION", "http");
-#define("CONNECTION", "socket");
-define("CONNECTION_PROXY", ""); // ip
-define("CONNECTION_PORT", ""); // port
-define("CONNECTION_USER", ""); // user
-define("CONNECTION_PASSWORD", ""); // password
-define("CONNECTION_USERAGENT", "Mapbender");
-# HOSTs not for Proxy (curl)
-define("NOT_PROXY_HOSTS", "<ip>,<ip>,<ip>");
-# security: path to modules
-define("CHECK", true);
-# enable/disable portal
-define("PORTAL", false);
-# mail settings for internal mapbender mails
-# smtp mailing
-# for further settings check 'class_administration.php'
-# please check phpmailer for more information
-define("USE_PHP_MAILING", "false");
-define("MAILHOST", "<host>");
-define("MAILUSERNAME", "<user>");
-define("MAILPASSWORD", "<password>");
-define("MAILADMIN", "<mailaddress of the mailadmin>");
-define("MAILADMINNAME", "<mailadminname>");
-$mailHost = MAILHOST;
-$mailUsername = MAILUSERNAME;
-$mailPassword = MAILPASSWORD;
-# wms monitoring
-define("AUTO_UPDATE", "0");
-define("TIME_LIMIT", "300");
-define("PHP_PATH", "/usr/local/bin/");
-# Mapbender error logging
-define("LOG_LEVEL", "error"); //"off","error","warning","notice" or "all"
-define("LOG_JS", "off"); // "on", "alert", "console" or "off"
-# Internationalization
-define("USE_I18N", false); // requires gettext for PHP.
- // If "false", LANGUAGE is set to english
-define("LANGUAGE", "en"); // only available if USE_I18N is "true".
- // "en", "de", "bg", "gr", "nl", "hu", "it", "es","fr","pt"
-# RSS
-define("GEO_RSS_FILE", "../tmp/georss.xml");
-# PREVIEW
-define("PREVIEW_DIR", "../geoportal/preview");
-# UPLOAD
-define("UPLOAD_DIR", "../tmp");
-define("UPLOAD_WHITELIST_FILE_TYPES", "");
-define("UPLOAD_BLACKLIST_FILE_TYPES", "");
-define("UPLOAD_MAX_SIZE_KB", 2048);
-# use jQuery from Google CDN
-define("LOAD_JQUERY_FROM_GOOGLE", false);
-# define a public user
-define("PUBLIC_USER", "");
-###HACK for GLOBALS
-$DBSERVER=DBSERVER;
- $DB=DB;
- $OWNER=OWNER;
- $PW=PW;
Deleted: trunk/mapbender/log/mb_error_2010_11_03.log
--- trunk/mapbender/log/mb_error_2010_11_03.log 2010-11-04 19:06:12 UTC (rev 7092)
+++ trunk/mapbender/log/mb_error_2010_11_03.log 2010-11-05 13:04:15 UTC (rev 7093)
@@ -1,8 +0,0 @@
-2010.11.03, 09:22:41,ERROR: exists(): The session variable: addwms_showWMS is not set!'
-2010.11.03, 09:22:41,ERROR: exists(): The session variable: addwms_zoomToExtent is not set!'
-2010.11.03, 09:22:41,ERROR: exists(): The session variable: WMC is not set!'
-2010.11.03, 09:22:41,ERROR: exists(): The session variable: WMS is not set!'
-2010.11.03, 09:22:41,ERROR: exists(): The session variable: LAYER is not set!'
-2010.11.03, 09:22:41,ERROR: exists(): The session variable: FEATURETYPE is not set!'
-2010.11.03, 09:22:41,ERROR: exists(): The session variable: GEORSS is not set!'
-2010.11.03, 09:23:05,ERROR: connector: unable to load: http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS=Topographie,Grenze,Bundeslaender,Staedte,Postleitzahlbereiche,Bahnlinien,Strassen,Staedtepunkte,Staedtenamen,Bundeslaendernamen&QUERY_LAYERS=Postleitzahlbereiche,Staedtepunkte&WIDTH=500&HEIGHT=450&SRS=EPSG:4326&BBOX=-106.8888888888889,-80,80.8888888888889,89&STYLES=default,default,default,default,default,default,default,default,default,default&FORMAT=image/png&INFO_FORMAT=text/html&EXCEPTIONS=application/vnd.ogc.se_xml&X=274&Y=123&FEATURE_COUNT=100&=
Deleted: trunk/mapbender/log/security_patch.log
Deleted: trunk/mapbender/resources/db/error.log
--- trunk/mapbender/resources/db/error.log 2010-11-04 19:06:12 UTC (rev 7092)
+++ trunk/mapbender/resources/db/error.log 2010-11-05 13:04:15 UTC (rev 7093)
@@ -1,102 +0,0 @@
-psql:_install.sql:120: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »gui_kml_kml_id_seq« für die »serial«-Spalte »gui_kml.kml_id«
-psql:_install.sql:187: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »gui_treegde_id_seq« für die »serial«-Spalte »gui_treegde.id«
-psql:_install.sql:243: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »keyword_keyword_id_seq« für die »serial«-Spalte »keyword.keyword_id«
-psql:_install.sql:265: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »layer_layer_id_seq« für die »serial«-Spalte »layer.layer_id«
-psql:_install.sql:334: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »mb_group_mb_group_id_seq« für die »serial«-Spalte »mb_group.mb_group_id«
-psql:_install.sql:355: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »mb_log_id_seq« für die »serial«-Spalte »mb_log.id«
-psql:_install.sql:404: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »mb_user_mb_user_id_seq« für die »serial«-Spalte »mb_user.mb_user_id«
-psql:_install.sql:444: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »md_topic_category_md_topic_category_id_seq« für die »serial«-Spalte »md_topic_category.md_topic_category_id«
-psql:_install.sql:460: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »sld_user_layer_sld_user_layer_id_seq« für die »serial«-Spalte »sld_user_layer.sld_user_layer_id«
-psql:_install.sql:474: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »translations_trs_id_seq« für die »serial«-Spalte »translations.trs_id«
-psql:_install.sql:512: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »wfs_wfs_id_seq« für die »serial«-Spalte »wfs.wfs_id«
-psql:_install.sql:535: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »wfs_conf_wfs_conf_id_seq« für die »serial«-Spalte »wfs_conf.wfs_conf_id«
-psql:_install.sql:564: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »wfs_conf_element_wfs_conf_element_id_seq« für die »serial«-Spalte »wfs_conf_element.wfs_conf_element_id«
-psql:_install.sql:578: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »wfs_element_element_id_seq« für die »serial«-Spalte »wfs_element.element_id«
-psql:_install.sql:595: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »wfs_featuretype_featuretype_id_seq« für die »serial«-Spalte »wfs_featuretype.featuretype_id«
-psql:_install.sql:663: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »wms_wms_id_seq« für die »serial«-Spalte »wms.wms_id«
-psql:_install.sql:710: HINWEIS: ALTER TABLE / ADD UNIQUE erstellt implizit einen Index »keyword_keyword_key« für Tabelle »keyword«
-psql:_install.sql:720: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »mb_gui_kml_pkey« für Tabelle »gui_kml«
-psql:_install.sql:730: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »md_topic_category_pkey« für Tabelle »md_topic_category«
-psql:_install.sql:740: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_featuretype_id« für Tabelle »wfs_featuretype«
-psql:_install.sql:750: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_featuretype_namespace« für Tabelle »wfs_featuretype_namespace«
-psql:_install.sql:760: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_fkey_gui_id« für Tabelle »gui_element«
-psql:_install.sql:770: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_fkey_gui_id_fkey_e_id_var_name« für Tabelle »gui_element_vars«
-psql:_install.sql:780: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_fkey_mb_group_id« für Tabelle »gui_mb_group«
-psql:_install.sql:790: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_fkey_mb_user_id« für Tabelle »gui_mb_user«
-psql:_install.sql:800: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_fkey_mb_user_mb_group_id« für Tabelle »mb_user_mb_group«
-psql:_install.sql:810: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_fkey_treegde_id« für Tabelle »gui_treegde«
-psql:_install.sql:820: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_fkey_wfs_conf_id« für Tabelle »gui_wfs_conf«
-psql:_install.sql:830: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_group_id« für Tabelle »mb_group«
-psql:_install.sql:840: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_gui_id« für Tabelle »gui«
-psql:_install.sql:850: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_gui_layer« für Tabelle »gui_layer«
-psql:_install.sql:860: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_gui_wms« für Tabelle »gui_wms«
-psql:_install.sql:870: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_keyword_id« für Tabelle »keyword«
-psql:_install.sql:880: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_layer_id« für Tabelle »layer«
-psql:_install.sql:890: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_layer_keyword« für Tabelle »layer_keyword«
-psql:_install.sql:900: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_mb_log« für Tabelle »mb_log«
-psql:_install.sql:910: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_mb_monitor« für Tabelle »mb_monitor«
-psql:_install.sql:920: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_mb_user_id« für Tabelle »mb_user«
-psql:_install.sql:930: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_md_topic_category« für Tabelle »wms_md_topic_category«
-psql:_install.sql:940: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_sld_user_layer« für Tabelle »sld_user_layer«
-psql:_install.sql:950: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_user_wmc« für Tabelle »mb_user_wmc«
-psql:_install.sql:960: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_wfs_conf_element_id« für Tabelle »wfs_conf_element«
-psql:_install.sql:970: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_wfs_conf_id« für Tabelle »wfs_conf«
-psql:_install.sql:980: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_wfs_element« für Tabelle »wfs_element«
-psql:_install.sql:990: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_wfs_id« für Tabelle »wfs«
-psql:_install.sql:1000: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_wms_format« für Tabelle »wms_format«
-psql:_install.sql:1010: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_wms_id« für Tabelle »wms«
-psql:_install.sql:1020: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_wms_srs« für Tabelle »wms_srs«
-psql:_install.sql:1030: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »translations_pkey« für Tabelle »translations«
-psql:_install.sql:24108: HINWEIS: ALTER TABLE / ADD UNIQUE erstellt implizit einen Index »wfs_element_element_id_key« für Tabelle »wfs_element«
-psql:_install.sql:24404: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »gui_category_category_id_seq« für die »serial«-Spalte »gui_category.category_id«
-psql:_install.sql:24404: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »pk_category_id« für Tabelle »gui_category«
-psql:_install.sql:25847: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »cat_cat_id_seq« für die »serial«-Spalte »cat.cat_id«
-psql:_install.sql:25851: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »cat_pkey« für Tabelle »cat«
-psql:_install.sql:25859: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_cat_keyword« für Tabelle »cat_keyword«
-psql:_install.sql:25890: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »pk_con_cat_op« für Tabelle »cat_op_conf«
-psql:_install.sql:25940: FEHLER: Tabelle »wmc_keyword« existiert nicht
-psql:_install.sql:25941: FEHLER: Tabelle »wmc_md_topic_category« existiert nicht
-psql:_install.sql:25946: FEHLER: Constraint »mb_user_wmc_pkey« von Relation »mb_user_wmc« existiert nicht
-psql:_install.sql:25959: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_user_wmc« für Tabelle »mb_user_wmc«
-psql:_install.sql:25967: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_wmc_keyword« für Tabelle »wmc_keyword«
-psql:_install.sql:26774: HINWEIS: ALTER TABLE / ADD PRIMARY KEY erstellt implizit einen Index »pk_gui_gui_category« für Tabelle »gui_gui_category«
-psql:_install.sql:26984: FEHLER: Spalte »featuretype_searchable« von Relation »wfs_featuretype« existiert bereits
-psql:_install.sql:27020: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »inspire_md_data_data_id_seq« für die »serial«-Spalte »inspire_md_data.data_id«
-psql:_install.sql:27020: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »data_id_pkey« für Tabelle »inspire_md_data«
-psql:_install.sql:27043: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »conformity_conformity_id_seq« für die »serial«-Spalte »conformity.conformity_id«
-psql:_install.sql:27043: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »conformity_pkey« für Tabelle »conformity«
-psql:_install.sql:27067: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »spec_classification_spec_class_id_seq« für die »serial«-Spalte »spec_classification.spec_class_id«
-psql:_install.sql:27067: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »spec_class_id_pkey« für Tabelle »spec_classification«
-psql:_install.sql:27067: HINWEIS: CREATE TABLE / UNIQUE erstellt implizit einen Index »spec_classification_spec_class_key_key« für Tabelle »spec_classification«
-psql:_install.sql:27094: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »spec_spec_id_seq« für die »serial«-Spalte »spec.spec_id«
-psql:_install.sql:27094: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »spec_id_pkey« für Tabelle »spec«
-psql:_install.sql:27126: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »conformity_relation_relation_id_seq« für die »serial«-Spalte »conformity_relation.relation_id«
-psql:_install.sql:27126: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »relation_id_pkey« für Tabelle »conformity_relation«
-psql:_install.sql:27141: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »custom_category_custom_category_id_seq« für die »serial«-Spalte »custom_category.custom_category_id«
-psql:_install.sql:27141: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »custom_category_pkey« für Tabelle »custom_category«
-psql:_install.sql:27232: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »inspire_category_inspire_category_id_seq« für die »serial«-Spalte »inspire_category.inspire_category_id«
-psql:_install.sql:27232: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »inspire_category_pkey« für Tabelle »inspire_category«
-psql:_install.sql:27552: FEHLER: Sicht »search_wms_view« existiert nicht
-psql:_install.sql:27565: FEHLER: Funktion geometryfromtext(text, integer) existiert nicht
-ZEILE 2: ...c_cat_layer(wms_unref.layer_id) AS md_topic_cats, geometryfr...
-TIP: Keine Funktion stimmt mit dem angegebenen Namen und den Argumenttypen überein. Sie müssen möglicherweise ausdrückliche Typumwandlungen hinzufügen.
-psql:_install.sql:27567: FEHLER: Sicht »search_wfs_view« existiert nicht
-psql:_install.sql:27610: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »content_metadata_metadata_id_seq« für die »serial«-Spalte »content_metadata.metadata_id«
-psql:_install.sql:27610: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »metadata_pkey« für Tabelle »content_metadata«
-psql:_install.sql:27610: HINWEIS: CREATE TABLE / UNIQUE erstellt implizit einen Index »metadata_uuid_key« für Tabelle »content_metadata«
-psql:_install.sql:27676: FEHLER: Funktion f_collect_searchtext_wmc(character varying) existiert nicht
-psql:_install.sql:27677: FEHLER: Funktion f_collect_topic_cat_wmc(character varying) existiert nicht
-psql:_install.sql:27759: FEHLER: Relation »wmc_custom_category« existiert bereits
-psql:_install.sql:27847: FEHLER: Sicht »search_wmc_view« existiert nicht
-psql:_install.sql:27863: FEHLER: Funktion geometryfromtext(text, integer) existiert nicht
-ZEILE 2: ...t_wmc(wmc_dep.wmc_id) AS md_topic_cats, transform(geometryfr...
-psql:_install.sql:27865: FEHLER: Relation »search_wmc_view« existiert nicht
-psql:_install.sql:27896: HINWEIS: CREATE TABLE / UNIQUE erstellt implizit einen Index »layer_preview_fkey_layer_id_key« für Tabelle »layer_preview«
-psql:_install.sql:27909: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »termsofuse_pkey« für Tabelle »termsofuse«
-psql:_install.sql:28107: HINWEIS: CREATE TABLE erstellt implizit eine Sequenz »datalink_datalink_id_seq« für die »serial«-Spalte »datalink.datalink_id«
-psql:_install.sql:28107: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »pk_datalink_id« für Tabelle »datalink«
-psql:_install.sql:28128: HINWEIS: CREATE TABLE / PRIMARY KEY erstellt implizit einen Index »pk_datalink_keyword« für Tabelle »datalink_keyword«
-psql:_install.sql:28305: HINWEIS: CREATE TABLE / UNIQUE erstellt implizit einen Index »wmc_fkey_layer_id_key« für Tabelle »wmc_preview«
Deleted: trunk/mapbender/resources/db/log_schema.txt
--- trunk/mapbender/resources/db/log_schema.txt 2010-11-04 19:06:12 UTC (rev 7092)
+++ trunk/mapbender/resources/db/log_schema.txt 2010-11-05 13:04:15 UTC (rev 7093)
@@ -1,10595 +0,0 @@
-CREATE FUNCTION
- case
- language plpgsql created
-(1 Zeile)
-DROP FUNCTION
-CREATE FUNCTION
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-CREATE INDEX
-CREATE INDEX
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
- setval
-(1 Zeile)
- setval
- 20125
-(1 Zeile)
- setval
- 20
-(1 Zeile)
- setval
-(1 Zeile)
- setval
- 1
-(1 Zeile)
- setval
- 2
-(1 Zeile)
- setval
- 4
-(1 Zeile)
- setval
- 29
-(1 Zeile)
- setval
- 175
-(1 Zeile)
- setval
- 23
-(1 Zeile)
- setval
- 910
-(1 Zeile)
- setval
- 231
-(1 Zeile)
- setval
- 19
-(1 Zeile)
- setval
- 287
-(1 Zeile)
- setval
-(1 Zeile)
- setval
-(1 Zeile)
-UPDATE 108
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-DELETE 0
-ALTER TABLE
-ALTER TABLE
-UPDATE 4
-ALTER TABLE
-ALTER TABLE
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-ALTER TABLE
-UPDATE 3
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 5
-ALTER TABLE
-ALTER TABLE
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 2
-UPDATE 4
-UPDATE 4
-UPDATE 4
-INSERT 0 4
-UPDATE 4
-INSERT 0 4
-UPDATE 1
-DELETE 2
-DELETE 2
-DELETE 2
-DELETE 1
-UPDATE 1
-INSERT 0 1
-INSERT 0 1
-UPDATE 1
-INSERT 0 1
-UPDATE 7
-UPDATE 6
-UPDATE 2
-DELETE 0
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-UPDATE 1
-UPDATE 0
-UPDATE 0
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-CREATE TABLE
-CREATE TABLE
-ALTER TABLE
-ALTER TABLE
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
- setval
- 3
-(1 Zeile)
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-UPDATE 3
-UPDATE 3
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 2
-UPDATE 3
-UPDATE 4
-UPDATE 3
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 3
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 1
-INSERT 0 1
-UPDATE 1
-DELETE 4
-UPDATE 1
-UPDATE 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-UPDATE 1
-DELETE 0
-DELETE 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-UPDATE 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-INSERT 0 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 4
-UPDATE 2
-UPDATE 2
-UPDATE 2
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 2
-DELETE 0
-DELETE 0
-DELETE 0
-DELETE 0
-INSERT 0 0
-INSERT 0 0
-UPDATE 3
-INSERT 0 0
-INSERT 0 1
-UPDATE 1
-INSERT 0 0
-UPDATE 4
-UPDATE 0
-UPDATE 4
-DELETE 0
-UPDATE 1
-UPDATE 1
-UPDATE 1
-INSERT 0 3
-INSERT 0 3
-UPDATE 6
-UPDATE 1
-INSERT 0 0
-INSERT 0 0
-INSERT 0 0
-INSERT 0 0
-INSERT 0 0
-DELETE 0
-INSERT 0 0
-INSERT 0 0
-INSERT 0 0
-INSERT 0 0
-INSERT 0 0
-INSERT 0 0
-INSERT 0 15
-INSERT 0 0
-UPDATE 3
-UPDATE 2
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-DELETE 2
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 0
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-DELETE 0
-DELETE 2
-INSERT 0 1
-INSERT 0 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-UPDATE 3
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-UPDATE 0
-UPDATE 16
-UPDATE 4
-UPDATE 0
-UPDATE 1
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 2
-UPDATE 1
-UPDATE 1
-INSERT 0 4
-INSERT 0 4
-CREATE INDEX
-CREATE INDEX
-CREATE TABLE
-CREATE FUNCTION
-CREATE TRIGGER
-CREATE TABLE
-CREATE INDEX
-INSERT 0 1
-INSERT 0 1
-CREATE TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 5
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-UPDATE 1
-CREATE TABLE
-ALTER TABLE
-CREATE TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-CREATE TABLE
-CREATE TABLE
-UPDATE 4
-UPDATE 4
-UPDATE 1
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 1
-UPDATE 1
-UPDATE 3
-INSERT 0 4
-INSERT 0 4
-ALTER TABLE
-CREATE SEQUENCE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-UPDATE 0
-ALTER TABLE
-CREATE TABLE
-ALTER TABLE
-INSERT 0 4
-INSERT 0 4
-INSERT 0 4
-INSERT 0 4
-INSERT 0 4
-INSERT 0 4
-INSERT 0 1
-INSERT 0 1
-ALTER TABLE
-UPDATE 0
-INSERT 0 3
-UPDATE 8
-ALTER TABLE
-INSERT 0 3
-INSERT 0 3
-INSERT 0 1
-UPDATE 3
-UPDATE 3
-INSERT 0 0
-INSERT 0 16
-ALTER TABLE
-INSERT 0 1
-INSERT 0 1
-INSERT 0 3
-INSERT 0 3
-UPDATE 0
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-UPDATE 4
-UPDATE 4
-UPDATE 4
-UPDATE 3
-DELETE 4
-DELETE 4
-UPDATE 3
-UPDATE 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 16
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 0
-INSERT 0 0
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-INSERT 0 3
-DELETE 3
-ALTER TABLE
-INSERT 0 1
-UPDATE 3
-INSERT 0 1
-UPDATE 4
-UPDATE 1
-INSERT 0 1
-INSERT 0 4
-INSERT 0 1
-INSERT 0 1
-UPDATE 3
-INSERT 0 1
-UPDATE 5
-INSERT 0 0
-INSERT 0 0
-INSERT 0 0
-INSERT 0 3
-INSERT 0 4
-INSERT 0 4
-INSERT 0 4
-INSERT 0 4
-INSERT 0 1
-UPDATE 0
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-CREATE TABLE
-CREATE TABLE
-INSERT 19527 1
-INSERT 19528 1
-INSERT 19529 1
-CREATE TABLE
-INSERT 19543 1
-CREATE TABLE
-INSERT 19560 1
-CREATE TABLE
-CREATE TABLE
-INSERT 19605 1
-DELETE 0
-CREATE TABLE
-CREATE TABLE
-CREATE FUNCTION
-CREATE FUNCTION
-CREATE TABLE
-INSERT 19645 1
-INSERT 19646 1
-INSERT 19647 1
-INSERT 19648 1
-INSERT 19649 1
-INSERT 19650 1
-INSERT 19651 1
-INSERT 19652 1
-INSERT 19653 1
-INSERT 19654 1
-INSERT 19655 1
-INSERT 19656 1
-INSERT 19657 1
-INSERT 19658 1
-INSERT 19659 1
-INSERT 19660 1
-INSERT 19661 1
-INSERT 19662 1
-INSERT 19663 1
-INSERT 19664 1
-INSERT 19665 1
-INSERT 19666 1
-INSERT 19667 1
-INSERT 19668 1
-INSERT 19669 1
-INSERT 19670 1
-INSERT 19671 1
-INSERT 19672 1
-INSERT 19673 1
-INSERT 19674 1
-INSERT 19675 1
-INSERT 19676 1
-INSERT 19677 1
-INSERT 19678 1
-DELETE 0
-CREATE TABLE
-CREATE TABLE
-CREATE FUNCTION
-CREATE FUNCTION
-CREATE TABLE
-CREATE FUNCTION
-CREATE FUNCTION
-CREATE VIEW
-CREATE FUNCTION
-CREATE FUNCTION
-CREATE FUNCTION
-CREATE FUNCTION
-CREATE FUNCTION
-CREATE FUNCTION
-CREATE FUNCTION
-CREATE VIEW
-CREATE TABLE
-CREATE TABLE
-INSERT 0 3
-INSERT 0 3
-ALTER TABLE
-CREATE FUNCTION
-ALTER FUNCTION
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE FUNCTION
-ALTER FUNCTION
-CREATE FUNCTION
-ALTER FUNCTION
-CREATE FUNCTION
-ALTER FUNCTION
-UPDATE 1
-INSERT 0 1
-INSERT 0 3
-UPDATE 0
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-INSERT 19877 1
-DELETE 0
-UPDATE 5
-INSERT 0 5
-INSERT 0 5
-INSERT 0 5
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 5
-INSERT 0 1
-UPDATE 1
-UPDATE 1
-UPDATE 5
-UPDATE 1
-UPDATE 1
-UPDATE 1
-UPDATE 5
-UPDATE 5
-UPDATE 5
-UPDATE 5
-UPDATE 1
-INSERT 0 3
-UPDATE 1
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-UPDATE 4
-UPDATE 4
-ALTER TABLE
-INSERT 0 1
-UPDATE 16
-INSERT 0 3
-INSERT 0 4
-INSERT 0 4
-ALTER TABLE
-UPDATE 1647
-CREATE TABLE
-CREATE TABLE
-CREATE TABLE
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 3
-UPDATE 3
-UPDATE 530
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-DELETE 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-DELETE 1
-DELETE 1
-DELETE 1
-DELETE 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-INSERT 0 1
-DELETE 4
-UPDATE 4
-INSERT 0 4
-DELETE 4
-INSERT 0 0
-DELETE 4
-DELETE 2
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-ALTER TABLE
-UPDATE 1
-CREATE TABLE
-ALTER TABLE
-CREATE TABLE
-ALTER TABLE
-CREATE INDEX
-ALTER TABLE
-ALTER TABLE
-INSERT 19983 1
- setval
-(1 Zeile)
- setval
- 20125
-(1 Zeile)
- setval
- 20
-(1 Zeile)
- setval
-(1 Zeile)
- setval
- 1
-(1 Zeile)
- setval
- 2
-(1 Zeile)
- setval
- 4
-(1 Zeile)
- setval
- 29
-(1 Zeile)
- setval
- 175
-(1 Zeile)
- setval
- 23
-(1 Zeile)
- setval
- 910
-(1 Zeile)
- setval
- 231
-(1 Zeile)
- setval
- 19
-(1 Zeile)
- setval
- 541
-(1 Zeile)
- setval
-(1 Zeile)
- setval
-(1 Zeile)
- setval
- 3
-(1 Zeile)
- setval
- 2
-(1 Zeile)
- setval
-(1 Zeile)
- setval
- 3
-(1 Zeile)
- setval
- 1
-(1 Zeile)
- setval
- 1
-(1 Zeile)
- setval
-(1 Zeile)
- setval
- 2
-(1 Zeile)
- setval
- 34
-(1 Zeile)
More information about the Mapbender_commits
