[Mapbender-commits] r7096 - in trunk: documents/community
mapbender/resources/db
svn_mapbender at osgeo.org
Sun Nov 7 09:18:58 EST 2010
Author: arnulf
Date: 2010-11-07 06:18:58 -0800 (Sun, 07 Nov 2010)
New Revision: 7096
trunk/documents/community/flyer_osgeo_mapbender_de_A4.odp
trunk/mapbender/resources/db/install.sh
added hints to install script, wording
Modified: trunk/documents/community/flyer_osgeo_mapbender_de_A4.odp
(Binary files differ)
Modified: trunk/mapbender/resources/db/install.sh
--- trunk/mapbender/resources/db/install.sh 2010-11-05 13:08:23 UTC (rev 7095)
+++ trunk/mapbender/resources/db/install.sh 2010-11-07 14:18:58 UTC (rev 7096)
@@ -6,22 +6,24 @@
function show_disclaimer() {
# Disclaimer
echo ""
- echo "The script will create a database for you and will import the Mapbender data to the new database"
- echo "It will also compile the Mapbender.mo files"
+ echo "The script will create the database needed for Mapbender and enter the initial data"
+ echo "The script will also compile the Mapbender.mo files needed for multi language support."
echo ""
- echo "To run this script you have to set the following options"
+ echo "Before running this script make sure that:"
# echo " * set the right to execute on this install script"
# echo " * set the right to execute on mapbender/tools/i18n_update_mo.sh"
# echo " * write access to mapbender/log"
# echo " * write access to mapbender/http/tmp"
# echo " * write access to mapbender/resources/locale/ and subdirectories"
- echo " * provide a database user that is a superuser"
+ echo " * you have credentials for a PostgreSQL user with superuser privileges"
+ echo " * you know under which account the web server is running (on Debian Linux typically www-data)"
+ echo " * you know which group the web server user belongs (on Debian Linux typically www-data)"
echo ""
echo ""
echo "If everything is prepared you can continue."
echo "-------"
echo ""
- echo "You can give nearly all arguments on commandline:"
+ echo "You can also give all arguments on commandline using:"
echo "$0 <HOST> <PORT> <DBNAME> <DBTEMPLATE> <DBUSER>"
echo ""
echo "e.g."
@@ -42,13 +44,13 @@
#ask for database host
echo ""
- echo "database host (e.g. localhost)?"
+ echo "database host (Default: localhost)?"
read DBHOST
: ${DBHOST:="localhost"}
#ask for database port
echo ""
- echo "database port (e.g. 5432 for postgres)?"
+ echo "database port (Default: 5432 for postgres)?"
read DBPORT
: ${DBPORT:="5432"}
@@ -62,7 +64,7 @@
#ask for database template
echo ""
- echo "database template to use (just hit return for default template0)?"
+ echo "database template to use (Default: template0)?"
read DBTEMPLATE
: ${DBTEMPLATE:="template0"}
@@ -70,7 +72,7 @@
echo "database user?"
read DBUSER
-#using a password via commandline oder as shell var could lead to security problems, so we don't do it
+#using a password via commandline or as a shell variable could lead to security problems, so we don't do it
#see http://www.postgresql.org/docs/current/static/libpq-pgpass.html for a convenient way
# echo ""
# echo "Password for $DBUSER (will not be shown)?"
@@ -124,7 +126,7 @@
exit 1;
fi
echo "Your password will be asked twice, this is normal (unless .pgpass is used)"
- echo "creating database"
+ echo "creating database (this might take a while)"
createdb -U $DBUSER -h $DBHOST -p $DBPORT -E $DBENCODING $DBNAME -T $DBTEMPLATE
cat pgsql/pgsql_schema_2.5.sql \
pgsql/$DBENCODING/pgsql_data_2.5.sql \
@@ -138,7 +140,7 @@
pgsql/$DBENCODING/update/update_2.6.2_to_2.7rc1_pgsql_$DBENCODING.sql \
pgsql/pgsql_serial_set_sequences_2.7.sql \
> _install.sql
- echo "inserting data (this might take a few minutes)"
+ echo "inserting data (this might take a while longer)"
psql -U $DBUSER -h $DBHOST -p $DBPORT -f _install.sql $DBNAME > log_schema.txt 2> error.log
rm _install.sql
echo ""
@@ -148,7 +150,7 @@
# creating mapbender.conf
if [ -f ../../conf/mapbender.conf ]
then
- echo "mapbender.conf already exists, not changed"
+ echo "mapbender.conf already exists, not changed. Please check manually whether it needs to be updated!"
else
echo "Creating mapbender.conf..."
@@ -170,12 +172,14 @@
function set_permissions(){
- echo "The installer can set the permissions to the files"
- echo "and directory for you. If you want the installer to"
- echo "do this please enter (y)es else (n)o"
- echo "Please note, to do this you have to be"
- echo "read write access to the Mapbender directory"
- echo "set permissions, (y)es or (n)?"
+ echo "This installer can set the permissions of the Mapbender files "
+ echo "and directories for you. If you want the installer to proceed "
+ echo "please enter (y)es, otherwise (n)o."
+ echo ""
+ echo "Notice that you need write permission for the Mapbender"
+ echo "directory to do this."
+ echo ""
+ echo "Set permissions, (y)es or (n)?"
read automatic
if test $automatic != "n"
@@ -184,9 +188,9 @@
read setowner
if test $setowner != "n"
then
- echo "Please specify the webserver user"
+ echo "Please specify the webserver user (on Debian Linux typically www-data)"
read webservuser
- echo "Please specify the webserver group"
+ echo "Please specify the webserver group (on Debian Linux typically www-data)"
read webservgroup
chown -R $webservuser:$webservgroup ../../
@@ -253,6 +257,6 @@
compile_po;
echo ""
-echo "Finished...check the log and error files to see if an error occured.";
+echo "Finished...check the log and error files (./mapbender/log/*) to see if an error occured.";
More information about the Mapbender_commits
