[Mapbender-commits] r7099 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Tue Nov 9 05:38:25 EST 2010
Author: kmq
Date: 2010-11-09 02:38:25 -0800 (Tue, 09 Nov 2010)
New Revision: 7099
trunk/mapbender/http/javascripts/geometry.js
added support to import WKT LINESTRINGS into a geometry array
Modified: trunk/mapbender/http/javascripts/geometry.js
--- trunk/mapbender/http/javascripts/geometry.js 2010-11-08 10:11:14 UTC (rev 7098)
+++ trunk/mapbender/http/javascripts/geometry.js 2010-11-09 10:38:25 UTC (rev 7099)
@@ -354,8 +354,14 @@
GeometryArray.prototype.importGeometryFromText = function (text, srs) {
var i, j, m, currentPoint;
+ // remove whitespace after commata
+ text = text.replace(/,\s*/, ',');
var tmpArray = text.split("(");
- var geometryType = tmpArray[0];
+ // trim whitespace
+ var geometryType = tmpArray[0].replace(/^\s\s*/, '').replace(/\s\s*$/, '');
switch (geometryType) {
case "MULTIPOLYGON":
@@ -409,6 +415,20 @@
this.close();
break;
+ case "LINESTRING":
+ // generalize the Linestring to a multilinestring, because that's how Mapbender handles this type of thing
+ // Not generalizing Points, because I am not testing it now and something would later break and I'd have to Rage again
+ // It's probably possible though, to do it by just copying this case and converting all "linestring" to "point"
+ var multilinestring = text.replace('(','((');
+ var multilinestring = multilinestring.replace(')','))');
+ var multilinestring = multilinestring.replace("LINESTRING","MULTILINESTRING");
+ this.importGeometryFromText(multilinestring,srs);
+ break;
+ break;
+ default:
+ throw "Can't Import geometries of Type '" + geometryType + "'";
More information about the Mapbender_commits
