[Mapbender-commits] r7119 - in trunk/mapbender/http: plugins widgets
svn_mapbender at osgeo.org
Fri Nov 12 05:34:31 EST 2010
Author: christoph
Date: 2010-11-12 02:34:31 -0800 (Fri, 12 Nov 2010)
New Revision: 7119
trunk/mapbender/http/plugins/mb_measure_widget.js
trunk/mapbender/http/widgets/w_measure.js
some minor changes in new measure
Modified: trunk/mapbender/http/plugins/mb_measure_widget.js
--- trunk/mapbender/http/plugins/mb_measure_widget.js 2010-11-11 16:04:25 UTC (rev 7118)
+++ trunk/mapbender/http/plugins/mb_measure_widget.js 2010-11-12 10:34:31 UTC (rev 7119)
@@ -109,7 +109,7 @@
var updateDistance = function (evt, dist) {
- if (!dist) {
+ if (typeof dist !== "number") {
return;
var lastDistanceUnit = "m";
Modified: trunk/mapbender/http/widgets/w_measure.js
--- trunk/mapbender/http/widgets/w_measure.js 2010-11-11 16:04:25 UTC (rev 7118)
+++ trunk/mapbender/http/widgets/w_measure.js 2010-11-12 10:34:31 UTC (rev 7119)
@@ -276,10 +276,9 @@
&& !this._polygonIsInvalid;
var lastPointSnapped = this._isLastPointSnapped(mousePos);
var pos = {
mousePos: mousePos,
- pos: this._firstPointSnapped ?
+ pos: firstPointSnapped ?
this._measurePoints[0].pos : lastPointSnapped ?
this._measurePoints[this._measurePoints.length - 1].pos :
this._map.convertPixelToReal(mousePos)
@@ -295,10 +294,11 @@
previousPoint,
pos.pos
- console.log(previousPoint);
- console.log(pos.pos);
- this._trigger("onmeasuredistance", null, this._currentDistance);
+ if (this._measurePoints.length > 0) {
+ this._trigger("onmeasuredistance", null, this._currentDistance);
if (this._isPolygon(this._measurePoints, pos) && !this._polygonIsInvalid) {
this._currentArea = this._calculateArea(pos);
this._trigger("onmeasurearea", null, this._currentArea);
More information about the Mapbender_commits
