[Mapbender-commits] r7124 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Mon Nov 15 06:02:46 EST 2010
Author: christoph
Date: 2010-11-15 03:02:46 -0800 (Mon, 15 Nov 2010)
New Revision: 7124
trunk/mapbender/http/plugins/mb_sessionWmc.js
check if any wms have to be confirmed (formerly, we checked if any html had been generated, but that's always the case)
Modified: trunk/mapbender/http/plugins/mb_sessionWmc.js
--- trunk/mapbender/http/plugins/mb_sessionWmc.js 2010-11-15 10:56:13 UTC (rev 7123)
+++ trunk/mapbender/http/plugins/mb_sessionWmc.js 2010-11-15 11:02:46 UTC (rev 7124)
@@ -85,6 +85,8 @@
var displayConstraints = function (obj) {
var html = "";
var constraintTypeArray = [];
+ var wmsCount = 0;
for (var constraintType in obj) {
var caseObj = obj[constraintType];
//check if terms of use has been set - then there are tou given in the message!
@@ -92,7 +94,7 @@
html += "<fieldset>"+caseObj.message+"</fieldset>";
continue;
- if (caseObj.wms.length === 0) {
+ if (caseObj.wms && caseObj.wms.length === 0) {
continue;
@@ -104,15 +106,14 @@
html += "<label for='" + constraintType + "_" + wms.index + "'>" +
(constraintType === "noPermission" ? "<li>" : "<input id='" + options.id + "_" + constraintType + "_" + wms.index + "' " + "type='checkbox' />") +
wms.title + "</label><br>";
+ wmsCount++;
html += (constraintType === "noPermission" ? "</ul>" : "");
html += "</fieldset><br>";
constraintTypeArray.push(constraintType);
- if (html === "") {
+ if (wmsCount === 0) {
return;
More information about the Mapbender_commits
