[Mapbender-commits] r7127 - in trunk/mapbender/http: classes
geoportal javascripts php
svn_mapbender at osgeo.org
Mon Nov 15 09:45:42 EST 2010
Author: armin11
Date: 2010-11-15 06:45:42 -0800 (Mon, 15 Nov 2010)
New Revision: 7127
trunk/mapbender/http/classes/class_wmc.php
trunk/mapbender/http/geoportal/mod_initialStartWmc.php
trunk/mapbender/http/javascripts/mod_addWMS.php
trunk/mapbender/http/php/mod_callMetadata.php
trunk/mapbender/http/php/mod_createJSObjFromXML.php
trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php
some bugfixing and enhancement
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2010-11-15 14:42:43 UTC (rev 7126)
+++ trunk/mapbender/http/classes/class_wmc.php 2010-11-15 14:45:42 UTC (rev 7127)
@@ -551,7 +551,7 @@
$user = new user($this->userId);
catch (Exception $E) {
- $errMsg = "Error while saving WMC document " . $this->wmc_title . "': Invalud UserId";
+ $errMsg = "Error while saving WMC document " . $this->wmc_title . "': Invalid UserId";
$result["success"] = false;
$result["message"] = $errMsg;
$e = new mb_exception("mod_insertWMCIntoDB: " . $errMsg);
Modified: trunk/mapbender/http/geoportal/mod_initialStartWmc.php
--- trunk/mapbender/http/geoportal/mod_initialStartWmc.php 2010-11-15 14:42:43 UTC (rev 7126)
+++ trunk/mapbender/http/geoportal/mod_initialStartWmc.php 2010-11-15 14:45:42 UTC (rev 7127)
@@ -46,7 +46,7 @@
if (isset($_REQUEST["hostName"]) & $_REQUEST["hostName"] != "") {
//validate to some hosts
$testMatch = $_REQUEST["hostName"];
- if (!($testMatch == 'www.geoportal.rlp' or $testMatch == 'www.geoportal.rlp.de' or $testMatch == 'www.gdi-rp-dienste3.rlp.de' or $testMatch == '10.7.101.151')){
+ if (!($testMatch == 'www.geoportal.rlp' or $testMatch == 'www.geoportal.rlp.de' or $testMatch == 'www.gdi-rp-dienste3.rlp.de' or $testMatch == '10.7.101.151' or $testMatch == '10.7.101.165')){
echo 'hostName: <b>'.$testMatch.'</b> is not a valid server of gdi-rp.<br/>';
die();
Modified: trunk/mapbender/http/javascripts/mod_addWMS.php
--- trunk/mapbender/http/javascripts/mod_addWMS.php 2010-11-15 14:42:43 UTC (rev 7126)
+++ trunk/mapbender/http/javascripts/mod_addWMS.php 2010-11-15 14:45:42 UTC (rev 7127)
@@ -36,6 +36,118 @@
function mod_addWMS(){
var load = prompt("Capabilities - URL:","");
if(load){
- mod_addWMS_load(load);
+ mod_addWMS_load(base64_encode(load));
+ //mod_addWMS_load(base64_encode('http://www.google.de'));
\ No newline at end of file
+function base64_encode(data) {
+ // Encodes string using MIME base64 algorithm
+ // version: 909.322
+ // discuss at: http://phpjs.org/functions/base64_encode
+ // + original by: Tyler Akins (http://rumkin.com)
+ // + improved by: Bayron Guevara
+ // + improved by: Thunder.m
+ // + improved by: Kevin van Zonneveld (http://kevin.vanzonneveld.net)
+ // + bugfixed by: Pellentesque Malesuada
+ // - depends on: utf8_encode
+ // * example 1: base64_encode('Kevin van Zonneveld');
+ // * returns 1: 'S2V2aW4gdmFuIFpvbm5ldmVsZA=='
+ // mozilla has this native
+ // - but breaks in 2.0.0.12!
+ //if (typeof this.window['atob'] == 'function') {
+ // return atob(data);
+ var b64 = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=";
+ var o1, o2, o3, h1, h2, h3, h4, bits, i = 0, ac = 0, enc="", tmp_arr = [];
+ if (!data) {
+ return data;
+ data = utf8_encode(data+'');
+ do { // pack three octets into four hexets
+ o1 = data.charCodeAt(i++);
+ o2 = data.charCodeAt(i++);
+ o3 = data.charCodeAt(i++);
+ bits = o1<<16 | o2<<8 | o3;
+ h1 = bits>>18 & 0x3f;
+ h2 = bits>>12 & 0x3f;
+ h3 = bits>>6 & 0x3f;
+ h4 = bits & 0x3f;
+ // use hexets to index into b64, and append result to encoded string
+ tmp_arr[ac++] = b64.charAt(h1) + b64.charAt(h2) + b64.charAt(h3) + b64.charAt(h4);
+ } while (i < data.length);
+ enc = tmp_arr.join('');
+ switch (data.length % 3) {
+ case 1:
+ enc = enc.slice(0, -2) + '==';
+ break;
+ case 2:
+ enc = enc.slice(0, -1) + '=';
+ break;
+ return enc;
+function utf8_encode ( argString ) {
+ // Encodes an ISO-8859-1 string to UTF-8
+ // discuss at: http://phpjs.org/functions/utf8_encode
+ // + original by: Webtoolkit.info (http://www.webtoolkit.info/)
+ // + improved by: sowberry
+ // + tweaked by: Jack
+ // + bugfixed by: Onno Marsman
+ // + improved by: Yves Sucaet
+ // + bugfixed by: Ulrich
+ // * example 1: utf8_encode('Kevin van Zonneveld');
+ // * returns 1: 'Kevin van Zonneveld'
+ var string = (argString+''); // .replace(/\r\n/g, "\n").replace(/\r/g, "\n");
+ var utftext = "";
+ var start, end;
+ var stringl = 0;
+ start = end = 0;
+ stringl = string.length;
+ for (var n = 0; n < stringl; n++) {
+ var c1 = string.charCodeAt(n);
+ var enc = null;
+ if (c1 < 128) {
+ end++;
+ } else if (c1 > 127 && c1 < 2048) {
+ enc = String.fromCharCode((c1 >> 6) | 192) + String.fromCharCode((c1 & 63) | 128);
+ } else {
+ enc = String.fromCharCode((c1 >> 12) | 224) + String.fromCharCode(((c1 >> 6) & 63) | 128) + String.fromCharCode((c1 & 63) | 128);
+ if (enc !== null) {
+ if (end > start) {
+ utftext += string.substring(start, end);
+ utftext += enc;
+ start = end = n+1;
+ utftext += string.substring(start, string.length);
+ return utftext;
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php 2010-11-15 14:42:43 UTC (rev 7126)
+++ trunk/mapbender/http/php/mod_callMetadata.php 2010-11-15 14:45:42 UTC (rev 7127)
@@ -236,7 +236,7 @@
- if (!($testMatch == 'www.geoportal.rlp' or $testMatch == 'www.geoportal.rlp.de' or $testMatch == 'geoportal.rlp' or $testMatch == '10.7.101.165' or $testMatch == 'localhost:16580' or $testMatch == 'localhost' or $testMatch == 'www.gdi-rp-dienste3.rlp.de' )){
+ if (!($testMatch == 'www.geoportal.rlp' or $testMatch == 'www.geoportal.rlp.de' or $testMatch == 'geoportal.rlp' or $testMatch == '10.7.101.151' or $testMatch == 'localhost:16580' or $testMatch == 'localhost' or $testMatch == 'www.gdi-rp-dienste3.rlp.de' )){
echo 'hostName: <b>'.$testMatch.'</b> is not valid.<br/>';
die();
@@ -884,12 +884,7 @@
$str .= "'".$orderBy."' ";
$str .= " & ";
$e = new mb_exception($str);
- * @security_patch exec done
- * Added escapeshellcmd()
- exec(escapeshellcmd($str));
+ exec($str);
if ($resultTarget == 'web' or $resultTarget == 'debug') {
Modified: trunk/mapbender/http/php/mod_createJSObjFromXML.php
--- trunk/mapbender/http/php/mod_createJSObjFromXML.php 2010-11-15 14:42:43 UTC (rev 7126)
+++ trunk/mapbender/http/php/mod_createJSObjFromXML.php 2010-11-15 14:45:42 UTC (rev 7127)
@@ -20,6 +20,7 @@
require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
require_once(dirname(__FILE__)."/../classes/class_wms.php");
require_once(dirname(__FILE__)."/../classes/class_administration.php");
+#require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
$capabilitiesURL = $_REQUEST['caps'];
$noHtml = intval($_GET["noHtml"]);
@@ -28,8 +29,13 @@
$charset = CHARSET;
$mywms = new wms();
-$mywms->createObjFromXML($capabilitiesURL);
+#$e = new mb_exception("mod_createJSObjFromXML: CapUrl encoded to load: ".$capabilitiesURL);
+$caps = $capabilitiesURL;
+#$e = new mb_exception("mod_createJSObjFromXML: CapUrl decodes to load: ".$caps);
+$caps = html_entity_decode(base64_decode($_REQUEST['caps']));
+$mywms->createObjFromXML($caps);
$errorMessage = _mb("Error: The Capabilities Document could not be accessed. " .
"Please check whether the server is responding and accessible to " .
"Mapbender.");
Modified: trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php
--- trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php 2010-11-15 14:42:43 UTC (rev 7126)
+++ trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php 2010-11-15 14:45:42 UTC (rev 7127)
@@ -1,5 +1,5 @@
<?php
-#http://www.geoportal.rlp.de/mapbender/php/mod_layerISOMetadata.php?SERVICE=WMS&outputFormat=iso19139&Id=24356
+#http://www.geoportal.rlp.de/mapbender/php/mod_layerISOMetadataWriteToFolder.php?SERVICE=WMS&outputFormat=iso19139&Id=24356
# $Id: mod_layerISOMetadata.php 235
# http://www.mapbender.org/index.php/Inspire_Metadata_Editor
# Copyright (C) 2002 CCGIS
@@ -26,7 +26,7 @@
db_select_db(DB,$con);
//define the view or table where to read out the layer ids for which metadatafiles should be generated
-$wmsView = "wms_search_table_test";
+$wmsView = "wms_search_table";
//$wmsView = '';
//parse request parameter
//make all parameters available as upper case
More information about the Mapbender_commits
