[Mapbender-commits] r7130 - trunk/mapbender/http/frames
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Nov 16 03:40:20 EST 2010
Author: christoph
Date: 2010-11-16 00:40:20 -0800 (Tue, 16 Nov 2010)
New Revision: 7130
   trunk/mapbender/http/frames/login.php
removed obsolete code - no more mysql
Modified: trunk/mapbender/http/frames/login.php
--- trunk/mapbender/http/frames/login.php	2010-11-15 18:33:00 UTC (rev 7129)
+++ trunk/mapbender/http/frames/login.php	2010-11-16 08:40:20 UTC (rev 7130)
@@ -42,18 +42,6 @@
 			return $rown;
-	else if(SYS_DBTYPE == 'mysql' && $setEncPw == true){
-		$sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_password = password($2)";
-		$v = array($name,$pw);
-		$resn = db_prep_query($sql,$v,$t);
-		if($rown = db_fetch_array($resn)){
-			$sqlu = "UPDATE mb_user SET mb_user_password = $1 WHERE mb_user_id = $2";
-			$vu = array(md5($pw),$rown["mb_user_id"]);
-			$tu = array('s','i');
-			$rowu = db_prep_query($sqlu,$vu,$tu);
-			return $rown;
 function setSession(){
 	session_start();
More information about the Mapbender_commits mailing list
