[Mapbender-commits] r7132 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Tue Nov 16 05:04:01 EST 2010
Author: christoph
Date: 2010-11-16 02:04:01 -0800 (Tue, 16 Nov 2010)
New Revision: 7132
Removed:
trunk/mapbender/http/plugins/mb_measure.js
replaced by mb_measure_widget
Deleted: trunk/mapbender/http/plugins/mb_measure.js
--- trunk/mapbender/http/plugins/mb_measure.js 2010-11-16 08:54:58 UTC (rev 7131)
+++ trunk/mapbender/http/plugins/mb_measure.js 2010-11-16 10:04:01 UTC (rev 7132)
@@ -1,330 +0,0 @@
-var $measure = $(this);
-var MeasureApi = function (o) {
- var measureDialog,
- measurePoints = [],
- button,
- canvases = {},
- that = this,
- opacity = 0.4,
- srs;
- var hideMeasureData = function () {
- measureDialog.find(".mb-measure-clicked-point").parent().hide();
- measureDialog.find(".mb-measure-current-point").parent().hide();
- measureDialog.find(".mb-measure-distance").parent().hide();
- measureDialog.find(".mb-measure-area").parent().hide();
- var create = function () {
- // Initialise measure dialog
- var html = "<div>" +
- "<p class='mb-measure-text'>Fahren Sie mit der Maus über die Karte, um die Koordinaten anzuzeigen.<br> Klicken Sie, um eine Messung zu starten</p>" +
- "<p>Letzter Punkt: <span class='mb-measure-clicked-point' /></p>" +
- "<p>Aktuelle Koordinaten: <span class='mb-measure-current-point' /></p>" +
- "<p>Distanz: <span class='mb-measure-distance' /> m</p>" +
- "<p>Fläche: <span class='mb-measure-area' /> <span class='mb-measure-area-unit' /></p>" +
- "</div>";
- measureDialog = $(html).appendTo(o.$target);
- measureDialog.dialog({
- autoOpen: false
- }).bind("dialogclose", function () {
- button.stop();
- // Initialise Raphael canvas
- Mapbender.events.init.register(function () {
- o.$target.each(function () {
- var map = $(this).mapbender();
- var $canvas = $("<div />").css({
- "z-index": 100,
- "position": "relative"
- }).appendTo(this);
- canvases[map.elementName] =
- Raphael($canvas.get(0), map.getWidth(), map.getHeight());
- // Initialise button
- button = new Mapbender.Button({
- domElement: $measure.get(0),
- over: o.src.replace(/_off/, "_over"),
- on: o.src.replace(/_off/, "_on"),
- off: o.src,
- name: o.id,
- go: that.activate,
- stop: that.deactivate
- var draw = function (map, pos) {
- var canvas = canvases[map.elementName];
- canvas.clear();
- var str_path = "";
- measurePoints.push(pos);
- var len = measurePoints.length;
- if (len > 0){
- for (var k=0; k < len; k++) {
- var pk = measurePoints[k];
- var q = map.convertRealToPixel(pk);
- if (k === 0) {
- str_path += 'M';
- else {
- str_path += 'L';
- str_path += q.x + ' ' + q.y;
- var circle = canvas.circle(q.x, q.y, 3);
- if (k === 0) {
- circle.attr({
- fill: "#f00",
- stroke: "none",
- opacity: opacity
- else {
- circle.attr({
- fill: "#f00",
- stroke: "none",
- opacity: opacity
- measurePoints.pop();
- if (isPolygon(measurePoints, pos)) {
- var poly = canvas.path(str_path + 'Z');
- poly.attr({
- fill: "#0f0",
- opacity: opacity
- var line = canvas.path(str_path);
- line.attr({
- stroke: "#00f",
- "stroke-width": 2,
- opacity: opacity
- line.toFront();
- var updateCurrentPoint = function (p) {
- measureDialog.find(".mb-measure-current-point").text(
- p.x + " " + p.y
- ).parent().show();
- var updateClickedPoint = function (p) {
- measureDialog.find(".mb-measure-clicked-point").text(
- p.x + " " + p.y
- var updateDistance = function (dist) {
- if (!dist) {
- return;
- measureDialog.find(".mb-measure-distance").text(Math.abs(dist)).parent().show();
- var updateArea = function (area) {
- if (area === null) {
- return;
- var areaUnit = "m²";
- if (area > 10000000){
- area /= 1000000;
- areaUnit = "km²";
- else if (area > 100000){
- area /= 10000;
- areaUnit = "ha";
- area = Math.round(area*10)/10;
- measureDialog.find(".mb-measure-area-unit").html(areaUnit);
- measureDialog.find(".mb-measure-area").text(area).parent().show();
- var calculateDistanceGeographic = function (a, b) {
- var lon_from = (a.x * Math.PI) / 180;
- var lat_from = (a.y * Math.PI) / 180;
- var lon_to = (b.x * Math.PI) / 180;
- var lat_to = (b.y * Math.PI) / 180;
- return Math.abs(6371229 * Math.acos(
- Math.sin(lat_from) * Math.sin(lat_to) +
- Math.cos(lat_from) * Math.cos(lat_to) *
- Math.cos(lon_from - lon_to)
- var calculateDistanceMetric = function (a, b) {
- return Math.abs(Math.sqrt(
- Math.pow(Math.abs(b.x - a.x), 2) +
- Math.pow(Math.abs(b.y - a.y), 2)
- var calculateDistance = function (map, a, b) {
- if (a !== null && b !== null) {
- switch (map.getSrs()) {
- case "EPSG:4326":
- return calculateDistanceGeographic(a, b);
- default:
- return calculateDistanceMetric(a, b);
- return null;
- var calculateArea = function (pos) {
- if (measurePoints.length < 2) {
- return null;
- var area = 0;
- var p0 = measurePoints[0], pi, pj;
- for (var i = 0; i < measurePoints.length - 1; i++) {
- pi = measurePoints[i];
- pj = measurePoints[i + 1];
- area += (pi.y + pj.y) * (pi.x - pj.x) / 2;
- area += (p0.y + pj.y) * (p0.x - pj.x) / 2;
- return Math.abs(area);
- var isPolygon = function (measurePoints, pos) {
- if (len < 2) {
- return false;
- var pn = measurePoints[len - 1];
- for (var i = 0; i < measurePoints.length - 2; i++) {
- var p1 = measurePoints[i];
- var p2 = measurePoints[i + 1];
- if (lineIntersect(p1.x, p1.y, p2.x, p2.y, pn.x, pn.y, pos.x, pos.y)) {
- return false;
- return true;
- var lineIntersect = function ( a1, a2, b1, b2, c1, c2, d1, d2 ) {
- var s, t, N = (b1-a1)*(d2-c2)-(b2-a2)*(d1-c1);
- if (N === 0) {
- // parallel
- return false;
- s = ((c1-a1)*(d2-c2)-(c2-a2)*(d1-c1)) / N;
- t = (a1-c1 + s*(b1-a1)) / (d1-c1);
- if (s <= 1 && s>=0 && t <= 1 && t>=0) {
- return true;
- return false;
- var measure = function (e) {
- var map = $(e.currentTarget).mapbender();
- if (srs !== map.getSrs()){
- button.stop();
- return;
- var pos = map.convertPixelToReal(map.getMousePosition(e));
- updateCurrentPoint(pos);
- var previousPoint = measurePoints.length > 0 ?
- measurePoints[measurePoints.length - 1] : null;
- var distance = calculateDistance(map, previousPoint, pos);
- updateDistance(distance);
- updateArea(calculateArea(pos));
- draw(map, pos);
- var addPoint = function (e) {
- updateClickedPoint(pos);
- draw(map, pos);
- var addLastPoint = function (e) {
- if ($(e.currentTarget).size() > 0) {
- $(e.currentTarget).unbind("mousedown", addPoint)
- .unbind("dblclick", addLastPoint)
- .unbind("mousemove", measure);
- $(e.currentTarget).css("cursor", "auto");
- addPoint(e);
- this.activate = function () {
- if (o.$target.size() > 0) {
- o.$target.bind("mousedown", addPoint)
- .bind("dblclick", addLastPoint)
- .bind("mousemove", measure);
- o.$target.css("cursor", "crosshair");
- srs = o.$target.mapbender().getSrs();
- measureDialog.dialog("open");
- this.deactivate = function () {
- o.$target.unbind("mousedown", addPoint)
- o.$target.css("cursor", "auto");
- srs = undefined;
- for (var i in canvases) {
- canvases[i].clear();
- measurePoints = [];
- hideMeasureData();
- measureDialog.dialog("close");
- button.stop();
- create();
-$measure.mapbender(new MeasureApi(options));
More information about the Mapbender_commits
