[Mapbender-commits] r7135 - in trunk/mapbender/http: geoportal php
svn_mapbender at osgeo.org
Tue Nov 16 05:50:55 EST 2010
Author: armin11
Date: 2010-11-16 02:50:55 -0800 (Tue, 16 Nov 2010)
New Revision: 7135
Added:
trunk/mapbender/http/geoportal/authentication.php
trunk/mapbender/http/geoportal/forgotten_password.php
trunk/mapbender/http/geoportal/insertUserDataIntoDb.php
trunk/mapbender/http/geoportal/mod_logout.php
trunk/mapbender/http/geoportal/updateUserDataIntoDb.php
trunk/mapbender/http/php/tagCloud.php
some bugfixing and modules from geoportal.rlp project
Added: trunk/mapbender/http/geoportal/authentication.php
--- trunk/mapbender/http/geoportal/authentication.php (rev 0)
+++ trunk/mapbender/http/geoportal/authentication.php 2010-11-16 10:50:55 UTC (rev 7135)
@@ -0,0 +1,93 @@
+<?php
+include_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../../lib/class_Mapbender_session.php");
+#$_SESSION["mb_wmc"] = "";
+$pw = $_REQUEST['password'];
+$name = $_REQUEST['name'];
+$e = new mb_exception('SESSION[mb_user_name]: '.$_SESSION['mb_user_name']);
+# Q4U - Michael Spitz - 16.08.2006 - Falls Cookies deaktiviert sind, muss die Session-ID an die Folgeseiten weitergereicht werden
+$URLAdd="";
+if($_COOKIE[session_name()]=="") {
+ $URLAdd="?".session_name()."=".$_REQUEST[session_name()];
+$isAuthenticated = authenticate ($name,$pw);
+if($isAuthenticated != false) {
+ setSession();
+ #$_SESSION = array();
+ Mapbender::session()->set("mb_user_password",$pw);
+ Mapbender::session()->set("mb_user_id",$isAuthenticated["mb_user_id"]);
+ Mapbender::session()->set("mb_user_name",$isAuthenticated["mb_user_name"]);
+ Mapbender::session()->set("mb_user_ip",$_SERVER['REMOTE_ADDR']);
+ Mapbender::session()->set("mb_user_email",$isAuthenticated["mb_user_email"]);
+ Mapbender::session()->set("mb_user_department",$isAuthenticated["mb_user_department"]);
+ Mapbender::session()->set("mb_user_organisation_name",$isAuthenticated["mb_user_organisation_name"]);
+ Mapbender::session()->set("mb_user_position_name",$isAuthenticated["mb_user_position_name"]);
+ Mapbender::session()->set("mb_user_phone",$isAuthenticated["mb_user_phone"]);
+ Mapbender::session()->set("Textsize",$isAuthenticated["mb_user_textsize"]);
+ Mapbender::session()->set("Glossar",$isAuthenticated["mb_user_glossar"]);
+ Mapbender::session()->set("mb_user_description",$isAuthenticated["mb_user_description"]);
+ Mapbender::session()->set("mb_user_city",$isAuthenticated["mb_user_city"]);
+ Mapbender::session()->set("mb_user_postal_code",$isAuthenticated["mb_user_postal_code"]);
+#if(!isset($_SESSION["mb_wmc"]))
+#$_SESSION["mb_wmc"] = NULL;
+ Mapbender::session()->set("epsg","EPSG:31466");
+ Mapbender::session()->set("HTTP_HOST",$_SERVER["HTTP_HOST"]);
+ #Mapbender::session()->set("layer_preview",0);
+#$_SESSION["mb_myBBOX"] = "";
+//INSERT LAST LOGIN DATE AND TIME
+//NEW Filed required "ALTER TABLE mapbender.mb_user ADD COLUMN mb_user_last_login_date date;"
+ $sql = "UPDATE mb_user SET";
+ $sql .= " mb_user_last_login_date = now()";
+ $V[0] = Mapbender::session()->get('mb_user_id');
+ $T[0] = 'i';
+ $sql .= 'WHERE mb_user_id = $1';
+ $res = db_prep_query($sql, $V, $T);
+ //UPDATE USER LOGIN DATE and TIME
+ require_once(dirname(__FILE__)."/../php/mb_getGUIs.php");
+ $arrayGUIs = mb_getGUIs($isAuthenticated["mb_user_id"]);
+ Mapbender::session()->set("mb_user_guis",$arrayGUIs);
+ header ("Location: http://".$_SERVER['HTTP_HOST']."/portal/success.html".$URLAdd);
+ session_write_close();
+} else {
+ header ("Location: http://".$_SERVER['HTTP_HOST']."/portal/failed.html".$URLAdd);
+function authenticate ($name,$pw){
+ $con = db_connect(DBSERVER,OWNER,PW);
+ db_select_db(DB,$con);
+ $sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_password = $2";
+ $v = array($name,md5($pw)); // wird in unserer Lösung immer md5 genutzt?
+ $t = array('s','s');
+ $res = db_prep_query($sql,$v,$t);
+ if($row = db_fetch_array($res)){
+ $e = new mb_exception('row mb_user_name: '.$row['mb_user_name']);
+ return $row;
+ else
+ return false;
+function setSession(){
+ session_start();
+function killSession(){
+ Mapbender::session()->kill();
Added: trunk/mapbender/http/geoportal/forgotten_password.php
--- trunk/mapbender/http/geoportal/forgotten_password.php (rev 0)
+++ trunk/mapbender/http/geoportal/forgotten_password.php 2010-11-16 10:50:55 UTC (rev 7135)
@@ -0,0 +1,53 @@
+<?php
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+import_request_variables("PG");
+function forgotten_password() {
+ if(
+ !isset($_REQUEST["Benutzername"]) || !isset($_REQUEST["EMail"]) || ($_REQUEST["Benutzername"] == 'guest') ||
+ empty($_REQUEST["Benutzername"]) || empty($_REQUEST["EMail"]) ||
+ !(bool)trim($_REQUEST["Benutzername"]) || !(bool)trim($_REQUEST["EMail"])
+ return -1;
+ if(!USE_PHP_MAILING) {
+ return -4;
+ $administration = new administration();
+ define("USER_NAME", trim($_REQUEST["Benutzername"]));
+ define("USER_EMAIL",trim($_REQUEST["EMail"]));
+ if(
+ !$administration->getUserIdByUserName(USER_NAME) ||
+ USER_EMAIL != $administration->getEmailByUserId($administration->getUserIdByUserName(USER_NAME))
+ return -2;
+ $new_password = $administration->getRandomPassword();
+ $sql_update = "UPDATE mb_user SET mb_user_password = $1, mb_user_digest = $3 WHERE mb_user_id = $2";
+ $v = array(md5($new_password),$administration->getUserIdByUserName(USER_NAME),md5(USER_NAME.";".USER_EMAIL.":".REALM.":".$new_password));
+ $t = array("s","i");
+ if(!db_prep_query($sql_update,$v,$t)) {
+ return -3;
+ $email_subject = "New GeoPortal.rlp Password";
+ $email_body = sprintf("Your new GeoPortal.rlp password is: %s",$new_password);
+ if(!$administration->sendEmail(NULL,NULL,USER_EMAIL,USER_NAME,$email_subject,$email_body,$error_msg)) {
+ return -4;
+ return 1;
+$success = forgotten_password();
Added: trunk/mapbender/http/geoportal/insertUserDataIntoDb.php
--- trunk/mapbender/http/geoportal/insertUserDataIntoDb.php (rev 0)
+++ trunk/mapbender/http/geoportal/insertUserDataIntoDb.php 2010-11-16 10:50:55 UTC (rev 7135)
@@ -0,0 +1,86 @@
+<?php
+# $Id:
+# http://www.mapbender.org/index.php/Monitor_Capabilities
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+# require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+ require_once(dirname(__FILE__)."/../classes/class_administration.php");
+ require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+ $mb_user_password = '';
+ $adm = new administration();
+ ///Passort generieren
+ $pool = "qwertzupasdfghkyxcvbnm";
+ $pool .= "23456789";
+ $pool .= "WERTZUPLKJHGFDSAYXCVBNM";
+ srand ((double)microtime()*1000000);
+ for($index = 0; $index < 7; $index++)
+ $mb_user_password .= substr($pool,(rand()%(strlen ($pool))), 1);
+ //Check if user will register as 'guest'
+ $registerAsGuest = false;
+ if ($mb_user_name == 'guest') {
+ $registerAsGuest = true;
+ //// �berpr�fen ob User und oder Mail bereits existieren
+ $sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_email = $2";
+ $v = array($mb_user_name,$mb_user_email); // wird in unserer L�sung immer md5 genutzt?
+ //$row = db_fetch_array($res);
+ $emailValid = 1;
+ if(db_numrows($res) == 0 and !($registerAsGuest)){
+ $userAlreadyExists = 0;
+ /// pr�fen auf email und richtigkeit
+ if($adm->isValidEmail($mb_user_email))
+ $emailValid = 1;
+ /////INSERT
+ if(!isset($mb_user_postal_code) || $mb_user_postal_code == ''){ $mb_user_postal_code = 0;}
+ $sql = "INSERT INTO mb_user (mb_user_name,mb_user_password,mb_user_digest,mb_user_owner,mb_user_description,mb_user_email,mb_user_phone,mb_user_department,mb_user_organisation_name,mb_user_position_name,mb_user_city,mb_user_postal_code, mb_user_textsize, mb_user_glossar) VALUES ($1, $2,$13, '1', $3, $4, $5, $6, $7, $8, $9, $10,$11,$12)";
+ $v = array($mb_user_name, md5($mb_user_password), $mb_user_description, $mb_user_email, $mb_user_phone, $mb_user_department, $mb_user_organisation_name, $mb_user_position_name, $mb_user_city, $mb_user_postal_code, 'textsize1' ,'ja',md5($mb_user_name.";".$mb_user_email.":".REALM.":".$mb_user_password));
+ $t = array('s', 's', 's', 's', 's', 's', 's', 's', 's', 'i', 's', 's');
+ $res = db_prep_query($sql, $v, $t);
+ $sql = "SELECT mb_group_id FROM mb_group WHERE mb_group_name = 'guest' LIMIT 1";
+ $res = db_prep_query($sql, array(), array());
+ $row = db_fetch_array($res);
+ $group_id = $row['mb_group_id'];
+ $sql = "INSERT INTO mb_user_mb_group (fkey_mb_user_id, fkey_mb_group_id) VALUES ($1, $2)";
+ $v = array($adm->getUserIdByUserName($mb_user_name), $group_id);
+ $t = array('i', 'i');
+ //Mailversand
+ $mailBody=$mailBody1." ".$mb_user_password." ".$mailBody2;
+ $success = $adm->sendEmail(MAILADMIN, MAILADMINNAME, $mb_user_email, $mb_user_name, 'Ihre Registrierung', $mailBody, $error_msg );
+ else
+ $emailValid = 0;
+ else
+ $userAlreadyExists = 1;
Added: trunk/mapbender/http/geoportal/mod_logout.php
--- trunk/mapbender/http/geoportal/mod_logout.php (rev 0)
+++ trunk/mapbender/http/geoportal/mod_logout.php 2010-11-16 10:50:55 UTC (rev 7135)
@@ -0,0 +1,64 @@
+<?php
+# $Id: mod_logout.php 6728 2010-08-10 08:31:29Z christoph $
+# http://www.mapbender.org/index.php/Administration
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+ob_start();
+require_once(dirname(__FILE__)."/../include/dyn_php.php");
+ignore_user_abort();
+if (isset($_COOKIE[session_name()])) {
+ setcookie(session_name(), '', time()-42000, '/');
+session_destroy();
+$dir = preg_replace("/\\\/","/", dirname($_SERVER['SCRIPT_NAME']));
+if ($_GET['L'] == "en") {
+ $logout_location = "/portal/en/logout.html";
+else {
+ $logout_location = "/portal/logout.html";
+if (isset($logout_location) && $logout_location != ''){
+ header("Location: ".$logout_location);
+else {
+ if (is_file(dirname($_SERVER['SCRIPT_NAME'])."/login.php")) {
+ if (isset($_SERVER["HTTPS"]) && $_SERVER["HTTPS"] == "on") {
+ header("Location: https://".$_SERVER['HTTP_HOST'].$dir."/login.php");
+ else {
+ header("Location: http://".$_SERVER['HTTP_HOST'].$dir."/login.php");
+ else {
+ header("Location: https://".$_SERVER['HTTP_HOST'].preg_replace("/\/php/","/frames",$dir)."/login.php");
+ else {
+ header("Location: http://".$_SERVER['HTTP_HOST'].preg_replace("/\/php/","/frames",$dir)."/login.php");
Added: trunk/mapbender/http/geoportal/updateUserDataIntoDb.php
--- trunk/mapbender/http/geoportal/updateUserDataIntoDb.php (rev 0)
+++ trunk/mapbender/http/geoportal/updateUserDataIntoDb.php 2010-11-16 10:50:55 UTC (rev 7135)
@@ -0,0 +1,112 @@
+<?php
+#Script which is included by a typo3 script to register the users
+ // fields which should be updated
+ $fields = array();
+ // entries
+ $v = array();
+ // types
+ $t = array();
+ // start sql statement
+ $sql .= " mb_user_owner = 1"; #all users belong to the central administrator
+ //change username if field is not empty - the variables are from the calling script
+ if ($mb_user_name != '') {
+ $fields[] = array('mb_user_name', $mb_user_name, 's');
+ else
+ $mb_user_name = $_SESSION['mb_user_name'];
+ // change password if it was set
+ if ($mb_user_password != '') {
+ $fields[] = array('mb_user_password', md5($mb_user_password), 's');
+ #$fields[] = array('mb_user_digest', md5($mb_user_name.";".$mb_user_email.":".REALM.":".$mb_user_password), 's');
+ #else
+ # $mb_user_password = $_SESSION['mb_user_password']; # Don't update the password for a guest user - cause no one can get a anonymous user any more - this is done with password guest!
+ //update other fields
+ $fields[] = array('mb_user_description', $mb_user_description, 's');
+ $fields[] = array('mb_user_email', $mb_user_email, 's');
+ $fields[] = array('mb_user_phone', $mb_user_phone, 's');
+ #$fields[] = array('mb_user_department', $mb_user_department, 's'); # don't update department cause it is used for some relation - TODO uncomment it when relation is obsolet
+ $fields[] = array('mb_user_organisation_name', $mb_user_organisation_name, 's');
+ $fields[] = array('mb_user_position_name', $mb_user_position_name, 's');
+ $fields[] = array('mb_user_city', $mb_user_city, 's');
+ #$e = new mb_exception("x_geoportal/updateUserIntoDb.php: digest new: ".md5($mb_user_name.";".$mb_user_email.":".REALM.":".$mb_user_password));
+ $fields[] = array('mb_user_digest', md5($mb_user_name.";".$mb_user_email.":".REALM.":".$mb_user_password), 's');
+ if(is_int($mb_user_postal_code) && $mb_user_postal_code >= 0){
+ $fields[] = array('mb_user_postal_code', $mb_user_postal_code, 'i'); //postal_code als integer?
+ $fields[] = array('mb_user_textsize', $Textsize, 's');
+ $fields[] = array('mb_user_glossar', $Glossar, 's');
+ // build sql statement
+ foreach ($fields as $idx => $field) {
+ $sql .= ', '.$field[0].' = $'.($idx + 1);
+ $v[] = $field[1];
+ $t[] = $field[2];
+ // + where condition
+ $v[] = $_SESSION["mb_user_id"];
+ $t[] = 'i';
+ $sql .= 'WHERE mb_user_id = $'.count($v);//.' AND mb_user_name != \'guest\'';
+ if ($_SESSION["mb_user_id"] != ANONYMOUS_USER) {
+ if(!$res)
+ $e = new mb_exception("db_query($qstring)=$ret db_error=".db_error());
+ //UPDATE of the SESSION VARS
+ $_SESSION["mb_user_email"] = $mb_user_email;
+ $_SESSION["mb_user_department"] = $mb_user_department;
+ $_SESSION["mb_user_organisation_name"] = $mb_user_organisation_name;
+ $_SESSION["mb_user_position_name"] = $mb_user_position_name;
+ $_SESSION["mb_user_phone"] = $mb_user_phone;
+ $_SESSION["Textsize"] = $Textsize;
+ $_SESSION["Glossar"] = $Glossar;
+ $_SESSION["mb_user_description"]= $mb_user_description;
+ $_SESSION["mb_user_city"]= $mb_user_city;
+ $_SESSION["mb_user_postal_code"]= $mb_user_postal_code;
+/* //Push registrated user into ANONYMOUS_GROUP guest????
Modified: trunk/mapbender/http/php/tagCloud.php
--- trunk/mapbender/http/php/tagCloud.php 2010-11-16 10:06:01 UTC (rev 7134)
+++ trunk/mapbender/http/php/tagCloud.php 2010-11-16 10:50:55 UTC (rev 7135)
@@ -8,6 +8,7 @@
$pathToSearchScript = '/portal/servicebereich/suche.html?cat=dienste&searchfilter=';
$languageCode = 'de';
$maxFontSize = 40;
+$minFontSize = 10;
$maxObjects = 10;
$outputFormat = 'html';
$hostName = $_SERVER['HTTP_HOST'];
@@ -123,7 +124,7 @@
$i = 0;
//max pixelsize
-$inc = $maxFontSize/$maxObjects;//maybe 10 or 5 or ...
+$inc = ($maxFontSize-$minFontSize)/$maxObjects;//maybe 10 or 5 or ...
$maxWeight = 0;
while($row = db_fetch_array($res)){
@@ -143,7 +144,7 @@
for($i=0; $i<count($tags); $i++){
if ($scale == 'linear'){
- $tags[$i]['weight'] = $maxFontSize-($i*$inc);
+ $tags[$i]['weight'] = $minFontSize+($i*$inc);
} else {
$tags[$i]['weight'] = $tags[$i]['weight']*$maxFontSize/$maxWeight;
More information about the Mapbender_commits
