[Mapbender-commits] r7143 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Nov 19 09:49:32 EST 2010
Author: christoph
Date: 2010-11-19 06:49:32 -0800 (Fri, 19 Nov 2010)
New Revision: 7143
trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
do not display geometry symbol if not explicitly point, line, or polygon
Modified: trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
--- trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php 2010-11-19 13:25:43 UTC (rev 7142)
+++ trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php 2010-11-19 14:49:32 UTC (rev 7143)
@@ -1,8 +1,8 @@
-<?php
+<?php
# $Id$
# maintained by http://www.mapbender.org/index.php/User:Verena Diewald
# http://www.mapbender.org/index.php/WFS_gazetteer
-# Copyright (C) 2002 CCGIS
+# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
@@ -27,7 +27,7 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
-<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>">
+<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>">
<title>mod_wfs_gazetteer</title>
<?php
@@ -39,15 +39,15 @@
* Description:
* A WFS gazetteer for pre configured WFS configurations.
* Files:
* - http/javascripts/mod_wfs_gazetteer_client.php
* - http/php/mod_wfs_gazetteer_server.php
* SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
- * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
- * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
* > e_mb_mod, e_target, e_requires, e_url) VALUES ('<appId>','gazetteerWFS',
* > 2,1,'a gazetteer for user in the mapbender user map','Search','iframe',
* > '../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview',
@@ -57,29 +57,29 @@
* > 'mapframe1,overview','','http://www.mapbender.org/GazetteerWFS');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
- * > var_value, context, var_type) VALUES ('<appId>', 'gazetteerWFS',
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES ('<appId>', 'gazetteerWFS',
* > 'wfsConfIdString', '<value>', 'comma seperated list of WFS conf ids' ,
* > 'php_var');
- * > var_value, context, var_type) VALUES('<appId>', 'gazetteerWFS',
- * > 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf',
+ * > var_value, context, var_type) VALUES('<appId>', 'gazetteerWFS',
+ * > 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf',
* > 'location and name of the WFS configuration file for spatialRequest' ,
* > 'php_var');
- * > INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+ * > INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
* > 'initializeOnLoad', '0', 'start gazetteer onload' ,'var');
- * > 'enableSearchWithoutParams', '0',
+ * > 'enableSearchWithoutParams', '0',
* > 'define that search can be started without any search params' ,
* > 'var');
* > 'removeSpatialRequestHighlight', '0', 'remove spatialrequest highlighting when firing search' ,'var');
* Help:
@@ -87,23 +87,23 @@
* Maintainer:
* http://www.mapbender.org/User:Verena_Diewald
* Parameters:
* wfsConfIdString - comma seperated list of WFS conf ids
- * wfs_spatial_request_conf_filename - location and name of the WFS
+ * wfs_spatial_request_conf_filename - location and name of the WFS
* configuration file for spatialRequest
* initializeOnLoad - start gazetteer onload
- * enableSearchWithoutParams - define that search can be started without any
+ * enableSearchWithoutParams - define that search can be started without any
* search params
* removeSpatialRequestHighlight - remove spatialrequest highlighting when firing search
* License:
* Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
* http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-<?php
+<?php
include '../include/dyn_js.php';
include '../extensions/jquery-ui-1.7.2.custom/js/jquery-1.3.2.min.js';
include '../include/dyn_php.php';
@@ -191,12 +191,12 @@
function filteredCopy(obj,filter){
filter = filter || /.*/;
obj = obj || {};
- var deleteStack = [];
+ var deleteStack = [];
var subtree = null;
var entry = null;
- // visit each node, and check it's subtree for
+ // visit each node, and check it's subtree for
// nodes containing "filter"
// if it doesn contain any of those, put the subtree index
// on a list
@@ -226,7 +226,7 @@
for( entry in deleteStack)
if(deleteStack.hasOwnProperty(entry)) {
@@ -237,11 +237,11 @@
function localizeGazetteer(){
// make overlaytree containing only entries to be translated
var inObj = $.extend(true,{},global_wfsConfObj);
var labels = filteredCopy(inObj,/button_id$|label$/);
var req = new parent.Mapbender.Ajax.Request({
url: "../php/mod_wfs_gazetteer_l10n.php",
method: "translateServiceData" ,
@@ -271,10 +271,10 @@
parent.Mapbender.modules.gazetteerWFS.events = {};
var ev = parent.Mapbender.modules.gazetteerWFS.events;
ev.receiveFeatureCollection = parent.Mapbender.modules.gazetteerWFS.receiveFeatureCollection;
* Property: events.onWfsConfSelect
* Description:
* event is fired whenever a new WFS is selected
@@ -282,7 +282,7 @@
* Property: events.onFormReset
* Description:
* event is fired whenever the form is resetted
@@ -293,10 +293,10 @@
var styleProperties = {"position":"absolute", "top":"0px", "left":"0px", "z-index":80};
requestGeometryHighlight = new parent.Highlight(targetArray, "requestGeometryHighlight", styleProperties, 2);
parent.mb_registerSubFunctions("window.frames['" + frameName +"'].requestGeometryHighlight.paint()");
- initModWfsGazetteer();
- init_wfsSpatialRequest();
+ initModWfsGazetteer();
+ init_wfsSpatialRequest();
catch (exc) {
alert(exc);
@@ -308,7 +308,7 @@
catch (exc) {
try {
@@ -370,9 +370,9 @@
function wfsInitFunction (j) {
var functionCall = "parent.mb_regButton_frame('initWfsButton', '"+frameName+"', "+j+")";
- var x = new Function ("", functionCall);
+ var x = new Function ("", functionCall);
x();
function initWfsButton(ind, pos) {
parent.mb_button[ind] = document.getElementById(buttonWfs_id[pos]);
@@ -390,7 +390,7 @@
mod_wfs_spatialRequest_height = parent.mb_mapObj[ind].height;
mod_wfs_spatialRequest_epsg = parent.mb_mapObj[ind].epsg;
parent.mb_registerPanSubElement("measuring");
function displayButtons() {
for (var i = 0 ; i < buttonWfs_id.length ; i ++) {
@@ -404,7 +404,7 @@
currentImg.onmouseover = new Function("wfsInitFunction("+i+")");
var b = document.getElementById("displaySpatialButtons");
if (b !== null) {
- b.appendChild(currentImg);
+ b.appendChild(currentImg);
@@ -424,7 +424,7 @@
el.onmousedown = null;
el.onmouseup = null;
el.onmousemove = null;
if (obj.id == button_point) {
if (activeButton == null) {
activeButton = obj;
@@ -466,13 +466,13 @@
spatialRes.className = "spatialResHint";
if (b !== null) {
- b.appendChild(spatialRes);
+ b.appendChild(spatialRes);
document.getElementById("spatialResHint").innerHTML = "<br><img src='"+spatialRequestIsSetImg+"'></img>"+spatialRequestIsSetMessage;
spatialRequestGeom = queryGeom;
parent.mb_disableThisButton(selectedType);
// spatialRequestGeom is a Geometry, but for the highlight
// a MultiGeometry is needed.
var multiGeom;
@@ -496,11 +496,11 @@
multiGeom = new parent.MultiGeometry(spatialRequestGeom.geomType);
multiGeom.add(spatialRequestGeom);
// add highlight of geometry
requestGeometryHighlight.add(multiGeom);
requestGeometryHighlight.paint();
@@ -537,7 +537,7 @@
// rebuild form
function removeChildNodes(node) {
@@ -551,24 +551,24 @@
catch (exc) {
* removes whitespaces and endlines before and after a string
function trimString (str) {
return str.replace(/^\s+|\s+|\n+$/g, '');
function appendStyles() {
- //first of all remove all style tags from former wfs confs
+ //first of all remove all style tags from former wfs confs
var styleNodes = document.getElementsByTagName("style");
for (var i=0; i < styleNodes.length; i++) {
var parentNodeOfStyle = styleNodes[i].parentNode;
- parentNodeOfStyle.removeChild(styleNodes[i]);
+ parentNodeOfStyle.removeChild(styleNodes[i]);
var styleObj;
var rule = global_wfsConfObj[global_selectedWfsConfId].g_style + global_wfsConfObj[global_selectedWfsConfId].g_res_style;
@@ -589,7 +589,7 @@
styleObj=document.createElement("style");
styleObj.setAttribute("type","text/css");
document.getElementsByTagName("head")[0].appendChild(styleObj);
- styleObj.appendChild(document.createTextNode(rule+"\n"));
+ styleObj.appendChild(document.createTextNode(rule+"\n"));
@@ -603,11 +603,11 @@
var currentNode = document.getElementById(currentId);
removeChildNodes(currentNode);
geomArray = new parent.GeometryArray();
// Would be much nicer to have
- // initWFSConf() and reloadWFSConf
+ // initWFSConf() and reloadWFSConf
parent.mb_ajax_json("../php/mod_wfs_gazetteer_server.php", {command:"getWfsConf",wfsConfIdString:wfsConfIdString}, function(json,status) {
reapplyWFSConfObject(json, status);
localizeGazetteer();
@@ -630,7 +630,7 @@
global_wfsConfObj = json;
var wfsCount = 0;
for (var wfsConfId in global_wfsConfObj) {
- global_selectedWfsConfId = wfsConfId;
+ global_selectedWfsConfId = wfsConfId;
if (typeof(global_wfsConfObj[wfsConfId] != 'function')) {
wfsCount++;
@@ -644,15 +644,15 @@
else {
appendWfsConfSelectBox();
function setWfsInfo() {
var bodyNode = document.getElementById("wfsIcons");
removeChildNodes(bodyNode);
- var bulbNode = document.createElement("a");
+ var bulbNode = document.createElement("a");
bulbNode.name = "wfsInfo";
bulbNode.id = "wfsInfo";
bodyNode.appendChild(bulbNode);
@@ -668,7 +668,7 @@
bulbNode.appendChild(imgNode);
bulbNode.href = "javascript:openwindow('../php/mod_featuretypeMetadata.php?wfs_conf_id=" + global_selectedWfsConfId.toString() + "');";
bulbNode.style.visibility = "visible";
// set image: remove this WFS
var wfsRemoveNode = document.createElement("img");
wfsRemoveNode.name = "wfsRemove";
@@ -681,8 +681,8 @@
// Internet explorer
if (parent.ie) {
wfsRemoveNode.onclick = function() {
- var x = new Function ("", "delete global_wfsConfObj[global_selectedWfsConfId];setWfsConfIdString();initModWfsGazetteer();parent.mb_setWmcExtensionData({'WFSCONFIDSTRING':wfsConfIdString});");
- x();
+ var x = new Function ("", "delete global_wfsConfObj[global_selectedWfsConfId];setWfsConfIdString();initModWfsGazetteer();parent.mb_setWmcExtensionData({'WFSCONFIDSTRING':wfsConfIdString});");
+ x();
// Firefox
@@ -690,10 +690,10 @@
wfsRemoveNode.onclick = function () {
parent.mb_setWmcExtensionData({"WFSCONFIDSTRING":wfsConfIdString});
// set wfsGeomType image
var wfsGeomTypeNode = document.createElement("img");
wfsGeomTypeNode.name = "wfsGeomType";
@@ -719,6 +719,7 @@
wfsGeomTypeNode.title = '<?php echo _mb("Polygon");?>';
else {
+ wfsGeomTypeNode.style.display = "none";
var e = new parent.Mb_exception("WFS gazetteer: geometry type unknown.");
@@ -726,7 +727,7 @@
function setWfsConfIdString() {
var str = [];
str.push(wfsConfId);
@@ -743,7 +744,7 @@
global_selectedWfsConfId = this.value;
initializeOnLoad = 0;
- //close old dialogs
+ //close old dialogs
parent.$('.resultList').dialog('close');
parent.$('.infoPopup').dialog('close');
@@ -760,7 +761,7 @@
var isSelected = false;
var optionNode = document.createElement("option");
optionNode.value = wfsConfId;
optionNode.innerHTML = global_wfsConfObj[wfsConfId].wfs_conf_abstract;
@@ -774,7 +775,7 @@
var form = document.getElementById('selectWfsConfForm');
form.appendChild(selectNode);
appendStyles();
appendWfsForm();
@@ -787,12 +788,12 @@
removeChildNodes(form);
var resultDiv = document.getElementById("res");
removeChildNodes(resultDiv);
var divContainer = document.createElement("div");
divContainer.className = global_wfsConfObj[global_selectedWfsConfId].g_label_id;
divContainer.innerHTML = global_wfsConfObj[global_selectedWfsConfId].g_label;
form.appendChild(divContainer);
var wfsConfElementArray = global_wfsConfObj[global_selectedWfsConfId].element;
@@ -813,7 +814,7 @@
inputNode.id = wfsConfElementArray[i].element_name+"Checkbox";
inputNode.innerHTML = wfsConfElementArray[i].f_form_element_html;
- else{
+ else{
var inputNode = document.createElement("input");
inputNode.type = "text";
inputNode.className = wfsConfElementArray[i].f_style_id;
@@ -826,7 +827,7 @@
form.appendChild(spanNode);
form.appendChild(inputNode);
//build imgNode for datepicker image
if(wfsConfElementArray[i].f_form_element_html.match(/datepicker/)){
var imgNode = document.createElement("span");
@@ -843,9 +844,9 @@
submitButton.id = "submitButton";
submitButton.className = global_wfsConfObj[global_selectedWfsConfId].g_button_id;
submitButton.value = global_wfsConfObj[global_selectedWfsConfId].g_button;
form.appendChild(submitButton);
var delFilterButton = document.createElement("input");
delFilterButton.type = "button";
delFilterButton.style.marginLeft = "5px";
@@ -854,8 +855,8 @@
if (parent.ie) {
delFilterButton.onclick = function() {
- var x = new Function ("", "clearFilter();");
- x();
+ var x = new Function ("", "clearFilter();");
+ x();
// Firefox
@@ -863,11 +864,11 @@
delFilterButton.onclick = function () {
clearFilter();
form.appendChild(delFilterButton);
checkSrs();
if(initializeOnLoad == 1) {
return validate();
@@ -902,17 +903,17 @@
if (parseInt(wfsConfElementArray[i].f_search)) {
if(wfsConfElementArray[i].f_form_element_html.match(/checkbox/)){
var elementArray = document.getElementsByName(wfsConfElementArray[i].element_name);
- for (var j = 0; j < elementArray.length; j++){
+ for (var j = 0; j < elementArray.length; j++){
elementArray[j].checked = "";
document.getElementById('checkAll').checked = "";
else{
- document.getElementById(wfsConfElementArray[i].element_name).value = "";
+ document.getElementById(wfsConfElementArray[i].element_name).value = "";
//remove geometry from spatialrequest, remove drawn rectangle or polygon and hint
spatialRequestGeom = null;
requestGeometryHighlight.clean();
@@ -920,11 +921,11 @@
if(document.getElementById('spatialResHint')){
document.getElementById("spatialResHint").innerHTML = "";
@@ -936,7 +937,7 @@
var el = global_wfsConfObj[global_selectedWfsConfId].element;
inputNotEnough = [];
for (var i = 0; i < el.length; i++){
if( el[i]['f_search'] == 1){
if(el[i]['f_form_element_html'].match(/\<select/)){
var elementValue = document.getElementById(el[i]['element_name']).options[document.getElementById(el[i]['element_name']).selectedIndex].value;
@@ -944,8 +945,8 @@
else if(el[i]['f_form_element_html'].match(/checkbox/)){
var elementArray = document.getElementsByName(el[i]['element_name']);
var selectedVal = [];
- if (elementArray[j].checked == true){
+ if (elementArray[j].checked == true){
selectedVal.push(elementArray[j].value);
@@ -954,7 +955,7 @@
else{
var elementValue = document.getElementById(el[i]['element_name']).value;
if (elementValue != '') {
cnt++;
@@ -963,21 +964,21 @@
if(inputNotEnough.length>0){
alert("Mandatory fields: "+inputNotEnough.join(', '));
return false;
if(enableSearchWithoutParams == 1) {
cnt = 2;
// if(spatialRequestGeom == null){
// alert("Bitte räumliche Eingrenzung vornehmen.");
// return false;
return cnt;
function validate(){
@@ -988,17 +989,17 @@
if(geomArray.count()>0){
geomArray.empty();
- if(removeSpatialRequestHighlight == 1) {
+ if(removeSpatialRequestHighlight == 1) {
var filterParameterCount = getNumberOfFilterParameters();
if(filterParameterCount == 0 && spatialRequestGeom == null && initializeOnLoad != 1){
//if(filterParameterCount == 0 && spatialRequestGeom == null){
//if(filterParameterCount == 0){
@@ -1008,7 +1009,7 @@
else{
if(inputNotEnough.length==0){
var andConditions = [];
//var srs = global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
var ind = parent.getMapObjIndexByName("mapframe1");
@@ -1031,8 +1032,8 @@
@@ -1044,7 +1045,7 @@
a = elementValue.split(",");
if (el[i]['f_search'] == 1 && elementValue != '') {
var orConditions = "";
for (var j=0; j < a.length; j++) {
@@ -1161,11 +1162,11 @@
if(spatialRequestGeom!=null){
var currentAndCondition = "";
if(spatialRequestGeom.geomType == "polygon"){
- if(buttonPolygon.filteroption=='within'){
+ if(buttonPolygon.filteroption=='within'){
currentAndCondition = "<Within><ogc:PropertyName>";
for (var j=0; j < el.length; j++) {
if(el[j]['f_geom']==1){
@@ -1189,7 +1190,7 @@
currentAndCondition += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\">";
- currentAndCondition += "<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+ currentAndCondition += "<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
for(var k=0; k<spatialRequestGeom.count(); k++){
if(k>0) currentAndCondition += " ";
currentAndCondition += spatialRequestGeom.get(k).x+","+spatialRequestGeom.get(k).y;
@@ -1197,12 +1198,12 @@
currentAndCondition += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>";
currentAndCondition += "</gml:Polygon></Intersects>";
else if(spatialRequestGeom.geomType == "line"){
var rectangle = [];
rectangle = spatialRequestGeom.getBBox();
- if(buttonRectangle.filteroption=='within'){
+ if(buttonRectangle.filteroption=='within'){
@@ -1231,7 +1232,7 @@
currentAndCondition += rectangle[0].x+","+rectangle[0].y;
currentAndCondition += rectangle[0].x+","+rectangle[1].y;
@@ -1243,13 +1244,13 @@
else if(spatialRequestGeom.geomType == "point"){
var tmp = spatialRequestGeom.get(0);
var mapPos = parent.makeRealWorld2mapPos("mapframe1",tmp.x, tmp.y);
var buffer = mb_wfs_tolerance/2;
- var mapPosXAddPix = mapPos[0] + buffer;
+ var mapPosXAddPix = mapPos[0] + buffer;
var mapPosYAddPix = mapPos[1] +buffer;
var mapPosXRemovePix = mapPos[0] - buffer;
var mapPosYRemovePix = mapPos[1] - buffer;
@@ -1263,9 +1264,9 @@
currentAndCondition += ftns + el[j]['element_name'];
- currentAndCondition += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+ currentAndCondition += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
currentAndCondition += realWorld1[0] + "," + realWorld1[1] + " " + realWorld2[0] + "," + realWorld2[1] + " ";
- currentAndCondition += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
+ currentAndCondition += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
currentAndCondition += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects>";
if (currentAndCondition !== "") {
@@ -1273,21 +1274,21 @@
var andConditionString = andConditions.join("");
if (andConditions.length > 1) {
andConditionString = "<And>" + andConditionString + "</And>";
var filter = "<ogc:Filter>"+andConditionString+"</ogc:Filter>";
document.getElementById("res").innerHTML = "<table><tr><td><img src='"+progressIndicatorImg+"'></td><td>"+progressIndicatorText+"</td></tr></table>";
var parameters = {
- "command" : "getSearchResults",
- "wfs_conf_id" : global_selectedWfsConfId,
+ "command" : "getSearchResults",
+ "wfs_conf_id" : global_selectedWfsConfId,
"typename" : global_wfsConfObj[global_selectedWfsConfId].featuretype_name,
- "frame" : this.name,
- "filter" : filter,
+ "frame" : this.name,
+ "filter" : filter,
"backlink" : "",
"destSrs" : srs
@@ -1298,11 +1299,11 @@
for (var i=0; i < parent.wms.length; i++) {
for (var j=0; j < parent.wms[i].objLayer.length; j++) {
var currentLayer = parent.wms[i].objLayer[j];
- var wms_id = parent.wms[i].wms_id;
+ var wms_id = parent.wms[i].wms_id;
if (currentLayer.gui_layer_wfs_featuretype == global_selectedWfsConfId) {
- var layer_name = currentLayer.layer_name;
- parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'querylayer',1);
- parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'visible',1);
+ var layer_name = currentLayer.layer_name;
+ parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'querylayer',1);
+ parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'visible',1);
@@ -1326,15 +1327,15 @@
if (typeof(geoObj) == 'object') {
geomArray.importGeoJSON(geoObj);
document.getElementById("res").innerHTML = '';
parent.Mapbender.modules.gazetteerWFS.receiveFeatureCollection.trigger(geoObj);
var resultList = parent.Mapbender.modules.resultList;
resultList.clear();
resultList.setTitle(global_wfsConfObj[global_selectedWfsConfId].wfs_conf_abstract);
resultList.setWFSconf(global_wfsConfObj[global_selectedWfsConfId]);
resultList.addFeatureCollection(geoObj);
- resultList.show();
+ resultList.show();
else {
@@ -1352,7 +1353,7 @@
else{
return false;
//spatialRequestGeom = null;
return false;
@@ -1375,4 +1376,4 @@
<div id="uploader"></div>
<div class='resultDiv' name='res' id='res'></div>
</body>
-</html>
+</html>
\ No newline at end of file
More information about the Mapbender_commits
