[Mapbender-commits] r7170 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Tue Nov 30 11:28:58 EST 2010
Author: armin11
Date: 2010-11-30 08:28:58 -0800 (Tue, 30 Nov 2010)
New Revision: 7170
trunk/mapbender/http/php/mod_interfaceWms4Kml.php
trunk/mapbender/http/php/mod_layerISOMetadata.php
trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php
trunk/mapbender/http/php/tagCloud.php
some bugfixing and modules from geoportal.rlp project
Modified: trunk/mapbender/http/php/mod_interfaceWms4Kml.php
--- trunk/mapbender/http/php/mod_interfaceWms4Kml.php 2010-11-30 15:44:48 UTC (rev 7169)
+++ trunk/mapbender/http/php/mod_interfaceWms4Kml.php 2010-11-30 16:28:58 UTC (rev 7170)
@@ -59,6 +59,6 @@
$kml.="</GroundOverlay>".chr(13).chr(10);
$kml.="</kml>".chr(13).chr(10);
header("Content-Type: application/vnd.google-earth.kml+xml");
-header("Content-Disposition: attachment; filename=\"KML WMS Layer\"");
+header("Content-Disposition: attachment; filename=\"Geoportal.rlp_layer_".$layerId.".kml\"");
echo $kml;
Modified: trunk/mapbender/http/php/mod_layerISOMetadata.php
--- trunk/mapbender/http/php/mod_layerISOMetadata.php 2010-11-30 15:44:48 UTC (rev 7169)
+++ trunk/mapbender/http/php/mod_layerISOMetadata.php 2010-11-30 16:28:58 UTC (rev 7170)
@@ -26,7 +26,7 @@
db_select_db(DB,$con);
//define the view or table to use as input for metadata generation
-$wmsView = "wms_search_table_test";
+$wmsView = "wms_search_table";
$wmsView = '';
//parse request parameter
//make all parameters available as upper case
@@ -427,7 +427,7 @@
$MD_BrowseGraphic=$iso19139->createElement("gmd:MD_BrowseGraphic");
$fileName=$iso19139->createElement("gmd:fileName");
$fileName_cs=$iso19139->createElement("gco:CharacterString");
- $previewFilenameText = $iso19139->createTextNode("http://www.gdi-rp-dienste3.rlp.de/mapbender/x_geoportal/layer_preview/".$row['layer_map_preview_filename']);
+ $previewFilenameText = $iso19139->createTextNode("http://www.gdi-rp-dienste3.rlp.de/mapbender/geoportal/preview/".$row['layer_map_preview_filename']);
$fileName_cs->appendChild($previewFilenameText);
$fileName->appendChild($fileName_cs);
@@ -561,6 +561,18 @@
$localName->appendChild($serviceTypeText);
$serviceType->appendChild($localName);
$SV_ServiceIdentification->appendChild($serviceType);
+ $serviceTypeVersion=$iso19139->createElement("srv:serviceTypeVersion");
+ $serviceTypeVersion_cs=$iso19139->createElement("gco:CharacterString");
+ $serviceTypeVersionText=$iso19139->createTextNode("1.1.1");
+ $serviceTypeVersion_cs->appendChild($serviceTypeVersionText);
+ $serviceTypeVersion->appendChild($serviceTypeVersion_cs);
+ $SV_ServiceIdentification->appendChild($serviceTypeVersion);
# Part B 1.7 Dataset Language
#if(isset($detail_array['t01_object.data_language'])){
#$language=$iso19139->createElement("gmd:language");
@@ -631,7 +643,69 @@
$extent->appendChild($EX_Extent);
$SV_ServiceIdentification->appendChild($extent);
+#to the things which have to be done for integrating the service into a client like portalu ... they have defined another location to put the GetCap URL than INSPIRE does it
+ $containsOperation=$iso19139->createElement("srv:containsOperation");
+ $SV_OperationMetadata=$iso19139->createElement("srv:SV_OperationMetadata");
+ $operationName=$iso19139->createElement("srv:operationName");
+ $operationName_cs=$iso19139->createElement("gco:CharacterString");
+ $operationNameText=$iso19139->createTextNode("GetCapabilities");
+ $operationName_cs->appendChild($operationNameText);
+ $operationName->appendChild($operationName_cs);
+//srv DCP **************************************
+ $DCP=$iso19139->createElement("srv:DCP");
+ $DCPList=$iso19139->createElement("srv:DCPList");
+ $DCPList->setAttribute("codeList", "DCPList");
+ $DCPList->setAttribute("codeListValue", "WebService");
+ $DCP->appendChild($DCPList);
+//connectPoint **********************************
+ $connectPoint=$iso19139->createElement("srv:connectPoint");
+ $CI_OnlineResource=$iso19139->createElement("gmd:CI_OnlineResource");
+ $gmd_linkage=$iso19139->createElement("gmd:linkage");
+ $gmd_URL=$iso19139->createElement("gmd:URL");
+ //Check if anonymous user has rights to access this layer - if not ? which resource should be advertised? TODO
+ if ($hasPermission) {
+ $gmd_URLText=$iso19139->createTextNode("http://".$_SERVER['HTTP_HOST']."/mapbender/php/wms.php?layer_id=".$mapbenderMetadata['layer_id']."");
+ else {
+ $gmd_URLText=$iso19139->createTextNode("https://".$_SERVER['HTTP_HOST']."/http_auth/".$mapbenderMetadata['layer_id']."?");
+ $gmd_URL->appendChild($gmd_URLText);
+ $gmd_linkage->appendChild($gmd_URL);
+ $CI_OnlineResource->appendChild($gmd_linkage);
+ $connectPoint->appendChild($CI_OnlineResource);
+//connectPoint END *****************************
+$SV_OperationMetadata->appendChild($operationName);
+$SV_OperationMetadata->appendChild($DCP);
+$SV_OperationMetadata->appendChild($connectPoint);
+$SV_ServiceIdentification->appendChild($SV_OperationMetadata);
$identificationInfo->appendChild($SV_ServiceIdentification);
//distributionInfo
@@ -653,7 +727,7 @@
- $gmd_URLText=$iso19139->createTextNode("http://www.geoportal.rlp.de/mapbender/x_geoportal/wms.php?layer_id=".$mapbenderMetadata['layer_id']."");
+ $gmd_URLText=$iso19139->createTextNode("http://www.geoportal.rlp.de/mapbender/php/wms.php?layer_id=".$mapbenderMetadata['layer_id']."");
else {
$gmd_URLText=$iso19139->createTextNode("https://www.geoportal.rlp.de/http_auth/".$mapbenderMetadata['layer_id']."?");
Modified: trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php
--- trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php 2010-11-30 15:44:48 UTC (rev 7169)
+++ trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php 2010-11-30 16:28:58 UTC (rev 7170)
@@ -55,7 +55,7 @@
$res = db_prep_query($sql,$v,$t);
$generatorScript = '/mapbender/php/mod_layerISOMetadata.php?';
-$generatorBaseUrl = 'http://localhost'.$generatorScript;
+$generatorBaseUrl = 'http://'.$_SERVER['HTTP_HOST'].$generatorScript;
echo $generatorBaseUrl."<br>";
Modified: trunk/mapbender/http/php/tagCloud.php
--- trunk/mapbender/http/php/tagCloud.php 2010-11-30 15:44:48 UTC (rev 7169)
+++ trunk/mapbender/http/php/tagCloud.php 2010-11-30 16:28:58 UTC (rev 7170)
@@ -144,7 +144,7 @@
for($i=0; $i<count($tags); $i++){
if ($scale == 'linear'){
- $tags[$i]['weight'] = $minFontSize+($i*$inc);
+ $tags[$i]['weight'] = $maxFontSize-($i*$inc);
} else {
$tags[$i]['weight'] = $tags[$i]['weight']*$maxFontSize/$maxWeight;
More information about the Mapbender_commits
