[Mapbender-commits] r6878 - trunk/mapbender/resources/db/pgsql/UTF-8
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Sep 2 11:48:23 EDT 2010
Author: christoph
Date: 2010-09-02 15:48:23 +0000 (Thu, 02 Sep 2010)
New Revision: 6878
Added:
   trunk/mapbender/resources/db/pgsql/UTF-8/layout.sql
   trunk/mapbender/resources/db/pgsql/UTF-8/layout_with_germany_map.sql
new apps
Added: trunk/mapbender/resources/db/pgsql/UTF-8/layout.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/layout.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/layout.sql	2010-09-02 15:48:23 UTC (rev 6878)
@@ -0,0 +1,28 @@
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('layout','layout','This application uses the jQuery UI Layout plugin to create a layout with columns and rows',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','jq_ui_position',1,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','outer_west',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','This is the west pane','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','outer_north',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','This is the north pane','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','outer_south',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','This is the south pane','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','outer_east',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','This is the east pane','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','jq_layout',1,1,'This jQuery plugin can create a sophisticated pane layout ','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','pane',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout','pane','center','sql','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout','pane','east','outer_east','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout','pane','layoutOptions','{
+	applyDefaultStyles: true
+}','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout','pane','north','outer_north','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout','pane','south','outer_south','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout','pane','west','outer_west','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','sql',1,1,'','Export to SQL','a','','href=''#''',NULL ,NULL,NULL ,NULL,NULL ,'','Export to SQL','a','../plugins/mb_sql.js','','','jq_ui_dialog','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','jq_ui',1,1,'jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout','body','favicon','../img/favicon.png','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout','body','jq_ui_theme','../extensions/jquery-ui-1.8.1.custom/css/ui-lightness/jquery-ui-1.8.1.custom.css','UI Theme from Themeroller','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.resizable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
Added: trunk/mapbender/resources/db/pgsql/UTF-8/layout_with_germany_map.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/layout_with_germany_map.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/layout_with_germany_map.sql	2010-09-02 15:48:23 UTC (rev 6878)
@@ -0,0 +1,56 @@
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('layout_with_map','layout_with_map','This application uses the jQuery UI Layout plugin to create a layout with columns and rows',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','body','favicon','../img/favicon.png','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','body','jq_ui_theme','../extensions/jquery-ui-1.8.1.custom/css/ui-lightness/jquery-ui-1.8.1.custom.css','UI Theme from Themeroller','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','body','treeGDE_css','../css/treeGDE2.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','body','pane_css','../extensions/jquery.layout.all-1.2.0/jquery.layout.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','pane',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','pane','center','mapframe1','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','pane','east','legend','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','pane','layoutOptions','{
+}','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','pane','north','logo','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','pane','south','sql','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','pane','west','treeGDE','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','jq_ui',1,1,'jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','jq_ui_position',1,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','jq_layout',1,1,'This jQuery plugin can create a sophisticated pane layout ','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','mapframe1_zoomBar',1,1,'Finally, a zoom bar','Zoom to scale','div','','',30,100,NULL ,200,100,'','','div','../plugins/mb_zoomBar.js','','mapframe1','mapframe1, jq_ui_slider','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','mapframe1_zoomBar','defaultLevel','1','define the default level for application start','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','mapframe1_zoomBar','level','[2500,5000,10000,50000,100000,500000,1000000,5000000,10000000,50000000]','define an array of levels for the slider (element_var has to be defined)','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','sql',1,1,'','Export to SQL','a','','href=''#''',NULL ,NULL,NULL ,NULL,NULL ,'','Export to SQL','a','../plugins/mb_sql.js','','','jq_ui_dialog','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','logo',1,1,'','','img','../img/Mapbender_logo_and_text_200x50.png','',NULL ,NULL,NULL ,NULL,NULL ,'','','img','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','mapframe1_pan',2,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_pan.js','../widgets/w_pan.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','mousewheelZoom',2,1,'adds mousewheel zoom to map module (target)','Mousewheel zoom','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','mod_mousewheelZoom.js','../extensions/jquery.mousewheel.min.js','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','mousewheelZoom','factor','2','The factor by which the map is zoomed on each mousewheel unit','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Karten','div','','class="ui-widget ui-widget-content"',NULL ,NULL,NULL ,NULL,NULL ,'overflow:auto','','div','../html/mod_treefolderPlain.php','jsTree.js','mapframe1','mapframe1','http://www.mapbender.org/index.php/TreeGde');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','treeGDE','alerterror','true','alertbox for wms loading error','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','treeGDE','ficheckbox','true','checkbox for featureInfo requests','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','treeGDE','imagedir','../img/tree_new','image directory','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','treeGDE','menu','opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove','context menu elements','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','treeGDE','showstatus','true','show status in folderimages','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','treeGDE','switchwms','true','enables/disables all layer of a wms','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','treeGDE','openfolder','false','initial open folder','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','treeGDE','metadatalink','false','link for layer-metadata','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','treeGDE','wmsbuttons','false','wms management buttons','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','legend',2,1,'legend','Legende','iframe','../javascripts/mod_legend.php?sessionID&wms_legend = yes','frameborder=''0''',1,1,NULL ,NULL,NULL ,'','','iframe','','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','legend','checkbox_on_off','false','display or hide the checkbox to set the legend on/off','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','legend','css_file_legend','../css/legend.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','legend','legendlink','false','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','legend','showgroupedlayertitle','true','show the title of the grouped layers in the legend','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','legend','showlayertitle','true','show the layer title in the legend','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','legend','showwmstitle','true','show the wms title in the legend','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','legend','stickylegend','false','parameter to decide wether the legend should stick on the mapframe1','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','mb_navigation',2,1,'Adds navigation arrows on top of the map','Navigation','div','','',20,30,NULL ,NULL,100,'','','div','../plugins/mb_navigation.js','','mapframe1','mapframe1','http://www.mapbender.org/Navigation');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','jq_ui_slider',5,1,'slider from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.slider.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.resizable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('layout_with_map','mapframe1',6,1,'frame for a map','','div','','',NULL ,NULL,NULL ,NULL,2,'overflow:hidden;background-color:#ffffff','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWmcObj.php','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','mapframe1','skipWmsIfSrsNotSupported','0','if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('layout_with_map','mapframe1','slippy','1','1 = Activates an animated, pseudo slippy map','var');
More information about the Mapbender_commits mailing list
