[Mapbender-commits] r6883 -
	trunk/mapbender/resources/db/pgsql/UTF-8/update
    svn_mapbender at osgeo.org
    Fri Sep  3 10:50:07 EDT 2010
Author: christoph
Date: 2010-09-03 14:50:07 +0000 (Fri, 03 Sep 2010)
New Revision: 6883
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
latest css
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql	2010-09-03 14:49:50 UTC (rev 6882)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql	2010-09-03 14:50:07 UTC (rev 6883)
@@ -2743,3 +2743,25 @@
 -- Add layout to toolbox jquery
 INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('toolbox_jquery','jq_layout',1,1,'This jQuery plugin can create a sophisticated pane layout ','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
+-- Now index.php loads all CSS not in iframes, they do no longer have to be bound to body
+DELETE FROM gui_element_vars WHERE var_name = 'cssfileAddWMS' AND fkey_e_id = 'addWMSfromfilteredList_ajax';
+-- Remove class ui-widget-content from treeGDE
+UPDATE gui_element SET e_attributes = 'class="ui-widget"' WHERE e_id = 'treeGDE';
+-- Move treeGDE CSS to treeGDE
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'treeGDE', 'css', '../css/treeGDE2.css', '' ,'file/css' FROM gui_element WHERE gui_element.e_id = 'treeGDE';
+DELETE FROM gui_element_vars WHERE fkey_e_id = 'body' AND var_name = 'treeGDE_css';
+-- Add pane CSS
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT DISTINCT gui_element.fkey_gui_id, gui_element.e_id, 'css' AS var_name, '../extensions/jquery.layout.all-1.2.0/jquery.layout.css' AS var_value, '' AS context, 'file/css' AS var_type FROM gui_element, gui_element_vars WHERE fkey_e_id = e_id AND gui_element.e_js_file = '../plugins/mb_pane.js';
More information about the Mapbender_commits
