[Mapbender-commits] r7744 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Tue Apr 5 04:03:56 EDT 2011
Author: kmq
Date: 2011-04-05 01:03:56 -0700 (Tue, 05 Apr 2011)
New Revision: 7744
trunk/mapbender/http/classes/class_wfs_1_0_factory.php
trunk/mapbender/http/classes/class_wfs_1_1_factory.php
support for anonymous types in when parsing featuretype xsd
Modified: trunk/mapbender/http/classes/class_wfs_1_0_factory.php
--- trunk/mapbender/http/classes/class_wfs_1_0_factory.php 2011-04-05 07:45:22 UTC (rev 7743)
+++ trunk/mapbender/http/classes/class_wfs_1_0_factory.php 2011-04-05 08:03:56 UTC (rev 7744)
@@ -74,20 +74,30 @@
$elementName = $elementNode->getAttribute("name");
$elementType = $elementNode->getAttribute("type");
- // The elementType is now bound to a prefix e.g. topp:housType
- // if the prefix is in the targetNamespace, changces are good it's defined in this very document
- // if the prefiox is not in the targetNamespace, it's likely not defined here, and we bail
+ // if Type is empty, we assume an anonymousType, else we go looking for the anmed Type
+ if($elementType == ""){
+ // Just querying for complexTypes containing a Sequence - good enough for Simple Features
+ $query = "xs:complexType//xs:element";
+ $subElementList = $xpath->query($query,$elementNode);
- list($elementTypeLocalname,$elementTypePrefix) = array_reverse(explode(":",$elementType));
- $elementTypeNamespace = $doc->lookupNamespaceURI($elementTypePrefix);
- if($elementTypeNamespace !== $targetNamespaceNode->nodeValue){
- $e = new mb_warning("Tried to parse FeatureTypeName $featureTypeName : $elementType is not in the targetNamespace");
- break;
+ }else{
- // Just querying for complexTypes containing a Sequence - good enough for Simple Features
- $query = sprintf("//xs:complexType[@name='%s']//xs:element",$elementTypeLocalname);
- $subElementList = $xpath->query($query);
+ // The elementType is now bound to a prefix e.g. topp:housType
+ // if the prefix is in the targetNamespace, changces are good it's defined in this very document
+ // if the prefiox is not in the targetNamespace, it's likely not defined here, and we bail
+ list($elementTypeLocalname,$elementTypePrefix) = array_reverse(explode(":",$elementType));
+ $elementTypeNamespace = $doc->lookupNamespaceURI($elementTypePrefix);
+ if($elementTypeNamespace !== $targetNamespaceNode->nodeValue){
+ $e = new mb_warning("Tried to parse FeatureTypeName $featureTypeName : $elementType is not in the targetNamespace");
+ break;
+ $query = sprintf("//xs:complexType[@name='%s']//xs:element",$elementTypeLocalname);
+ $subElementList = $xpath->query($query);
foreach($subElementList as $subElement){
// Since this is a rewrite of the old way, it reproduces it quirks
// in this case the namespace of the type was cut off for some reason
Modified: trunk/mapbender/http/classes/class_wfs_1_1_factory.php
--- trunk/mapbender/http/classes/class_wfs_1_1_factory.php 2011-04-05 07:45:22 UTC (rev 7743)
+++ trunk/mapbender/http/classes/class_wfs_1_1_factory.php 2011-04-05 08:03:56 UTC (rev 7744)
@@ -105,7 +105,6 @@
$newFeatureType->addNamespace($namespaceNode->localName, $namespaceNode->nodeValue);
list($ftLocalname,$ftTypePrefix) = array_reverse(explode(":",$featureTypeName));
// for the sake of simplicity we only care about top level elements. Seems to have worked so far
$query = sprintf("/xs:schema/xs:element[@name='%s']",$ftLocalname);
@@ -115,21 +114,30 @@
- break;
+ }else{
- $e = new mb_exception("NNN sub $query $subElementList->length");
+ break;
@@ -144,6 +152,7 @@
+ echo "<br /><br /> ";
return $newFeatureType;
More information about the Mapbender_commits
