[Mapbender-commits] r8039 - branches/mobile/http/javascripts
svn_mapbender at osgeo.org
Tue Aug 2 05:02:29 EDT 2011
Author: pschmidt
Date: 2011-08-02 02:02:29 -0700 (Tue, 02 Aug 2011)
New Revision: 8039
branches/mobile/http/javascripts/mod_wfs_SpatialRequest.php
Fehlerbeseitigung: Abfrage, ob requestGeo!=null
Modified: branches/mobile/http/javascripts/mod_wfs_SpatialRequest.php
--- branches/mobile/http/javascripts/mod_wfs_SpatialRequest.php 2011-07-29 14:08:33 UTC (rev 8038)
+++ branches/mobile/http/javascripts/mod_wfs_SpatialRequest.php 2011-08-02 09:02:29 UTC (rev 8039)
@@ -253,25 +253,26 @@
var multiGeom;
// a line represents a bbox...but highlight must be a polyon
// (extent or box selection)
- if (requestGeom.geomType == geomType.line) {
- multiGeom = new MultiGeometry(geomType.polygon);
- newGeom = new Geometry(geomType.polygon);
- var p1 = requestGeom.get(0);
- var p2 = requestGeom.get(1);
- newGeom.addPoint(p1);
- newGeom.addPointByCoordinates(p1.x, p2.y);
- newGeom.addPoint(p2);
- newGeom.addPointByCoordinates(p2.x, p1.y);
- newGeom.close();
- multiGeom.add(newGeom);
+ if (requestGeom != null){
+ if (requestGeom.geomType == geomType.line) {
+ multiGeom = new MultiGeometry(geomType.polygon);
+ newGeom = new Geometry(geomType.polygon);
+ var p1 = requestGeom.get(0);
+ var p2 = requestGeom.get(1);
+ newGeom.addPoint(p1);
+ newGeom.addPointByCoordinates(p1.x, p2.y);
+ newGeom.addPoint(p2);
+ newGeom.addPointByCoordinates(p2.x, p1.y);
+ newGeom.close();
+ multiGeom.add(newGeom);
+ // standard case
+ // (polygon and point selection)
+ else {
+ multiGeom = new MultiGeometry(requestGeom.geomType);
+ multiGeom.add(requestGeom);
- // standard case
- // (polygon and point selection)
- else {
- multiGeom = new MultiGeometry(requestGeom.geomType);
- multiGeom.add(requestGeom);
// add highlight of geometry
//requestGeometryHighlight.add(multiGeom);
//requestGeometryHighlight.paint();
@@ -393,7 +394,7 @@
numberOfAjaxCalls = js_wfs_conf_id.length;
- if(requestGeom.geomType==geomType.polygon){
+ if(requestGeom != null && requestGeom.geomType==geomType.polygon){
for(var i=0; i<js_wfs_conf_id.length; i++){
// I guess we should use the SRS of the map client, not the WFS?
// The coordinates come from the current client (?)
@@ -444,7 +445,7 @@
mb_get_geom(filter, i, wfs_config[js_wfs_conf_id[i]]['featuretype_name'], js_wfs_conf_id[i], db_wfs_conf_id[i]);
- else if(requestGeom.geomType==geomType.line){
+ else if(requestGeom != null && requestGeom.geomType==geomType.line){
var rectangle = requestGeom.getBBox();
@@ -507,7 +508,7 @@
- else if(requestGeom.geomType == geomType.point){
+ else if(requestGeom != null && requestGeom.geomType == geomType.point){
var tmp = requestGeom.get(0);
var mapPos = makeRealWorld2mapPos("mapframe1",tmp.x, tmp.y);
var buffer = mb_wfs_tolerance/2;
@@ -547,6 +548,7 @@
+ requestGeom = null;
// highlight = new Highlight(mb_wfs_targets, highlight_tag_id, {"position":"absolute", "top":"0px", "left":"0px", "z-index":generalHighlightZIndex}, generalHighlightLineWidth);
return true;
More information about the Mapbender_commits
