[Mapbender-commits] r8083 - branches/2.7/http/plugins
svn_mapbender at osgeo.org
Wed Aug 31 04:13:51 EDT 2011
Author: verenadiewald
Date: 2011-08-31 01:13:51 -0700 (Wed, 31 Aug 2011)
New Revision: 8083
branches/2.7/http/plugins/mb_print.php
show printbox when opening print dialog
Modified: branches/2.7/http/plugins/mb_print.php
--- branches/2.7/http/plugins/mb_print.php 2011-08-31 08:11:44 UTC (rev 8082)
+++ branches/2.7/http/plugins/mb_print.php 2011-08-31 08:13:51 UTC (rev 8083)
@@ -145,14 +145,13 @@
var $scaleInput = $("#scale");
if (printBox !== null) {
- printBox.destroy();
- printBox = null;
+ destroyPrintBox();
jqForm[0].scale.value = "";
jqForm[0].coordinates.value = "";
jqForm[0].angle.value = "";
else {
- printBox = new Mapbender.PrintBox({
+ printBox = new Mapbender.PrintBox({
target : myTarget,
printWidth : getPDFMapSize("width")/10,
printHeight : getPDFMapSize("height")/10,
@@ -212,6 +211,7 @@
var destroyPrintBox = function () {
if (printBox) {
printBox.destroy();
+ printBox = null;
@@ -228,6 +228,11 @@
/* than we need the translation of the print button */
$("#submit").val("<?php echo htmlentities(_mb("print"), ENT_QUOTES, "UTF-8");?>");
+ //show printBox for first entry in printTemplate selectbox
+ $("."+myId+"-dialog").bind("dialogopen", function () {
+ printObj.createPrintBox();
//destroy printBox if printDialog is closed
$("."+myId+"-dialog").bind("dialogclose", function () {
destroyPrintBox();
@@ -240,7 +245,7 @@
* GETs the config, build corresponding form, remove an existing printBox
this.loadConfig = function (configFilename, callback) {
- // the dataType to $.get is given explicitely, because there were instances of Mapbender that were returning
+ // the dataType to $.get is given explicitely, because there were instances of Mapbender that were returning
// either json or a string, which trips up $.parseJSON which was being used in the callback
$.get(mbPrintConfigPath + configFilename, function(json, status){
actualConfig = json;
@@ -248,10 +253,11 @@
hookForm();
if (typeof callback === "function") {
printBox = null;
- callback();
+ callback();
},"json");
destroyPrintBox();
@@ -604,9 +610,10 @@
if (str) {
$("#printPDF_selector").append(str).find("#printPDF_template").change(function () {
printObj.loadConfig(mbPrintConfigFilenames[this.selectedIndex], function () {
- printObj.createPrintBox()
$("#printPDF_handle").click(function () {
More information about the Mapbender_commits
