[Mapbender-commits] r8086 - in trunk/mapbender/http: javascripts php
svn_mapbender at osgeo.org
Wed Aug 31 04:48:20 EDT 2011
Author: verenadiewald
Date: 2011-08-31 01:48:20 -0700 (Wed, 31 Aug 2011)
New Revision: 8086
trunk/mapbender/http/javascripts/mod_measure.php
trunk/mapbender/http/php/mod_evalArea.php
http://trac.osgeo.org/mapbender/ticket/865
Modified: trunk/mapbender/http/javascripts/mod_measure.php
--- trunk/mapbender/http/javascripts/mod_measure.php 2011-08-31 08:45:24 UTC (rev 8085)
+++ trunk/mapbender/http/javascripts/mod_measure.php 2011-08-31 08:48:20 UTC (rev 8086)
@@ -1,7 +1,7 @@
<?php
# $Id$
# http://www.mapbender.org/index.php/mod_measure.php
-# Copyright (C) 2002 CCGIS
+# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
@@ -72,12 +72,12 @@
el1.id = mod_measure_target+"_measure_display";
el1.style.zIndex = "22";
el2.id = mod_measure_target+"_measuring";
map_el.appendChild(el);
map_el.appendChild(el1);
map_el.appendChild(el2);
mb_button[ind] = document.getElementById(mod_measure_elName);
mb_button[ind].img_over = mod_measure_img_over.src;
mb_button[ind].img_on = mod_measure_img_on.src;
@@ -129,7 +129,7 @@
function mod_measure_start(e){
var mousepos = mod_measure_mapObj.getMousePosition(e);
var realWorldPos = makeClickPos2RealWorldPos(mod_measure_target,mousepos.x,mousepos.y);
if(mod_measure_epsg=="EPSG:4326"){
mod_measure_RX[mod_measure_RX.length] = realWorldPos[0];
@@ -213,7 +213,7 @@
str_dashedLine += "<div style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color1+";";
if(mod_measure_bg != ""){
str_dashedLine += "background-color:"+mod_measure_bg+";";
str_dashedLine += "position:absolute;top:"+(Math.round(y1 + (y2-y1)/2 +3))+"px;left:"+(Math.round(x1 + (x2-x1)/2 +3))+"px'>"+mod_measure_Dist[count]+"</div>";
str_dashedLine += "<div style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color2+";position:absolute;top:"+(Math.round(y1 + (y2-y1)/2 + 4))+"px;left:"+(Math.round(x1 + (x2-x1)/2+4))+"px'>"+mod_measure_Dist[count]+"</div>";
return str_dashedLine;
@@ -344,6 +344,22 @@
url += "&srs="+ escape(srs[1]);
url += "&length=" + mod_measure_TotalDist[mod_measure_TotalDist.length-1];
url += "&distance=" + mod_measure_TotalDist[mod_measure_TotalDist.length-2];
+ $.get(url, function (json) {
+ var data = eval('(' + json + ')');
+ if (!measurePopupInstance) {
+ var measurePopupInstance = $("<div />").html("<h3>Fläche:</h3> " + data.area + " m²<br><br><h3>Umfang:</h3> " + data.perimeter + " m<br>").dialog({
+ title: "Messinformationen"});
+ else {
+ measurePopupInstance.html("<h3>Fläche:</h3>" + data.area + " m²<br><br><h3>Umfang:</h3> " + data.perimeter + " m<br>").dialog("open");
+ return;
+ return;
if(!mod_measure_win || mod_measure_win == null || mod_measure_win.closed == true){
mod_measure_win = window.open(url,"mod_measure_win","width=200,height=150,resizable=yes");
@@ -351,19 +367,32 @@
mod_measure_win.document.location.href = url;
mod_measure_win.focus();
else{
+ var measurePopupInstance = $("<div />").html("<h3>Strecke: </h3>" + mod_measure_TotalDist[mod_measure_TotalDist.length-1] + " m").dialog({
+ title: "Messinformation"
+ else {
+ measurePopupInstance.html("<h3>Strecke: </h3>" + mod_measure_TotalDist[mod_measure_TotalDist.length-1] + " m").dialog("open");
+ return;
mod_measure_win = window.open("","mod_measure_win","width=200,height=150,resizable=yes");
mod_measure_win.document.open("text/html");
mod_measure_win.document.write("<span style = 'font-family : Arial, Helvetica, sans-serif;font-size : 12px;font-weight : bold;';>Strecke: " +mod_measure_TotalDist[mod_measure_TotalDist.length-1]+" m</span>");
- mod_measure_win.document.close();
+ mod_measure_win.document.close();
else{
- mod_measure_win.focus();
+ mod_measure_win.focus();
Modified: trunk/mapbender/http/php/mod_evalArea.php
--- trunk/mapbender/http/php/mod_evalArea.php 2011-08-31 08:45:24 UTC (rev 8085)
+++ trunk/mapbender/http/php/mod_evalArea.php 2011-08-31 08:48:20 UTC (rev 8086)
@@ -1,7 +1,7 @@
<?php
# $Id$
# http://www.mapbender.org/index.php/mod_evalArea.php
@@ -17,37 +17,10 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+import_request_variables("PG");
require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
require_once(dirname(__FILE__)."/../classes/class_administration.php");
-include '../include/dyn_css.php';
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Resultset</title>
-<style type="text/css">
- body{
- font-family : Arial, Helvetica, sans-serif;
- font-size : 12px;
- font-weight : bold;
- .h{
- font-style : oblique;
-</style>
-</head>
-<body>
-<?php
$x = $_REQUEST["x"];
$y = $_REQUEST["y"];
$epsg = $_REQUEST["srs"];
@@ -55,94 +28,27 @@
$posX = explode (",", $x);
$posY = explode (",", $y);
-$numeric = is_numeric($epsg);
-foreach($posX as $x) $numeric = $numeric && is_numeric($x);
-foreach($posY as $y) $numeric = $numeric && is_numeric($y);
-if (!$numeric) // Security check
- die("Elements of x and y, as well as srs need to be numeric!");
-if(SYS_DBTYPE=='pgsql'){
- if(count($posX) > 3){
- $sql = "SELECT area2d(GeometryFromText('MULTIPOLYGON(((";
- for($i=0; $i<count($posX); $i++){
- if($i>0){$sql .= ",";}
- $sql .= $posX[$i] . " " . $posY[$i];
- $sql .= ")))',".rawurldecode($epsg).")) as myArea";
- $res = db_query($sql);
- if($row = db_fetch_array($res)){
- echo "Fläche: ".round($row[0]*100)/100 . " m<sup>2</sup>";
+echo "{";
+if(SYS_DBTYPE=='pgsql' && count($posX) > 3){
+ $sql = "SELECT area2d(GeometryFromText('MULTIPOLYGON(((";
+ for($i=0; $i<count($posX); $i++){
+ if($i>0){$sql .= ",";}
+ $sql .= $posX[$i] . " " . $posY[$i];
+ $sql .= ")))',".rawurldecode($epsg).")) as myArea";
+ $res = db_query($sql);
+ if($row = db_fetch_array($res)){
+ echo "'area': ".round($row[0]*100)/100 ;
else{
- echo "Fläche: 0 m<sup>2</sup>";
+ echo "'area': 0";
-}else{
- #echo "Fl�chenberechnung f�r MySQL liegt derzeit nicht vor<br></sup>";
- #$con = db_connect($GEOS_DBSERVER,$GEOS_PORT,$GEOS_OWNER,$GEOS_PW);
- #db_select_db($GEOS_DBSERVER,$con);
- $con_string = "host=$GEOS_DBSERVER port=$GEOS_PORT dbname=$GEOS_DB user=$GEOS_OWNER password=$GEOS_PW";
- $con = pg_connect($con_string) or die ("Error while connecting database");
- $i==0;
- $res = pg_query($con,$sql);
- $cnt = 0;
- while(pg_fetch_row($res)){
- $area = pg_fetch_result($res,$cnt,0);
- echo "Fläche: ".round($area*100)/100 . " m<sup>2</sup>";
- $cnt++;
- else{
-echo "<br>";
-echo "Umfang: ". htmlentities($length,ENT_QUOTES) . " m";
-echo "<br><br><input type='button' value='Schließen' onclick='window.close()'>";
-#Centroid(geometry)
-$sql = "SELECT Centroid(GeometryFromText('MULTIPOLYGON(((";
-for($i=0; $i<count($posX); $i++){
+else{
+ echo "'area': 0";
-$sql .= ")))',".rawurldecode($epsg).")) as myCentroid";
-$res = db_query($con,$sql);
-if(db_fetch_row($res)){
- echo "Zentrum: ".db_result($res,0,"myCentroid");
+if($length == "undefined") {
+ $length = "0";
-#box3d(geometry)
-$sql = "SELECT box3d(GeometryFromText('MULTIPOLYGON(((";
-$sql .= ")))',".rawurldecode($epsg).")) as myBox";
-$res = db_query($sql);
- echo "Aussen: ".db_result($res,0,"myBox");
-</body>
-</html>
+echo ",'perimeter': ". $length . "}";
\ No newline at end of file
More information about the Mapbender_commits
