[Mapbender-commits] r8224 -
	trunk/mapbender/resources/db/pgsql/UTF-8/update
    svn_mapbender at osgeo.org
    Fri Dec  2 06:30:49 EST 2011
Author: armin11
Date: 2011-12-02 03:30:49 -0800 (Fri, 02 Dec 2011)
New Revision: 8224
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
Bugfix, missing wmc_serial_id filter for generating wmc search results.
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql	2011-11-30 15:52:31 UTC (rev 8223)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql	2011-12-02 11:30:49 UTC (rev 8224)
@@ -150,6 +150,36 @@
   LANGUAGE plpgsql VOLATILE STRICT
   COST 100;
+-- Fix error of missing wmc_serial_id
+-- Function: f_collect_searchtext_wmc(integer)
+-- DROP FUNCTION f_collect_searchtext_wmc(integer);
+CREATE OR REPLACE FUNCTION f_collect_searchtext_wmc(integer)
+  RETURNS text AS
+$BODY$
+DECLARE
+    p_wmc_id ALIAS FOR $1;
+    r_keywords RECORD;
+    l_result TEXT;
+BEGIN
+    l_result := '';
+    l_result := l_result || (SELECT COALESCE(wmc_title, '') || ' ' || COALESCE(abstract, '') FROM mb_user_wmc WHERE wmc_serial_id = p_wmc_id);
+    FOR r_keywords IN SELECT DISTINCT keyword FROM
+        (SELECT keyword FROM wmc_keyword L JOIN keyword K ON (K.keyword_id = L.fkey_keyword_id AND L.fkey_wmc_serial_id = p_wmc_id)
+        ) AS __keywords__ LOOP
+        l_result := l_result || ' ' || COALESCE(r_keywords.keyword, '');
+    END LOOP;
+   l_result := UPPER(l_result);
+   l_result := replace(replace(replace(replace(replace(replace(replace(l_result,'Ä','AE'),'ß','SS'),'Ö','OE'),'Ü','UE'),'ä','AE'),'ü','UE'),'ö','OE');
+    RETURN l_result;
+END;
+$BODY$
+  LANGUAGE plpgsql VOLATILE
+  COST 100;
More information about the Mapbender_commits
