[Mapbender-commits] r8226 - in trunk/mapbender: http/classes
	http/css http/plugins lib
    svn_mapbender at osgeo.org
    Tue Dec  6 09:57:06 EST 2011
Author: armin11
Date: 2011-12-06 06:57:06 -0800 (Tue, 06 Dec 2011)
New Revision: 8226
Added:
   trunk/mapbender/http/css/kmltree.css
   trunk/mapbender/http/plugins/kmlTree.js
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
   trunk/mapbender/http/classes/class_weldMaps2PNG_rotate.php
Draft for integrating kmls into mapbender and little bugfix.
Modified: trunk/mapbender/http/classes/class_weldMaps2PNG_rotate.php
--- trunk/mapbender/http/classes/class_weldMaps2PNG_rotate.php	2011-12-05 10:52:58 UTC (rev 8225)
+++ trunk/mapbender/http/classes/class_weldMaps2PNG_rotate.php	2011-12-06 14:57:06 UTC (rev 8226)
@@ -75,7 +75,7 @@
         $imagick->cropImage($width, $height, ($imgWidth-$width)/2, ($imgHeight-$height)/2);
         //write modified image
-        $imagick->writeImage();
+        $imagick->writeImage($filename);
         $image = imagecreatefrompng($filename);
         imagepng($image,$filename);
Added: trunk/mapbender/http/css/kmltree.css
--- trunk/mapbender/http/css/kmltree.css	                        (rev 0)
+++ trunk/mapbender/http/css/kmltree.css	2011-12-06 14:57:06 UTC (rev 8226)
@@ -0,0 +1,134 @@
+li{ border: 1px solid black; }
+ul{ border: 1px dotted blue; }
+a{ border: 1px dotted red; }
+/* The Whole kml Tree */
+ul.kmlTree {
+	overflow: auto;
+	width: 10em;
+/*	background-image: url("http://localhost:8888/vertical_dots.png");*/
+	background-repeat: repeat-y	;
+	background-position: 20px;
+ul.kmlTree, ul.kmlTree ul {
+	list-style-type: none;
+	margin-left: 0;
+	padding-left: 0;
+ul.kmlTree a{
+	font-size: x-small;
+ul.kmlTree  li{
+	padding-left: 2px;
+/*	margin-left: 1em;*/
+ul.kmlTree button {
+	padding: 0;
+	margin-left: 0;
+	background-color: transparent;
+	width: 20px;
+	height: 20px;
+	vertical-align: middle;
+	border: none;
+ul.kmlTree a:link, ul.kmlTree a:visited, ul.kmlTree a:hover, ul.kmlTree a:active {
+	text-decoration: none;
+	color: black;
+/* a Root Node  */
+ul.kmlTree  li.kml.open{
+	padding-left: 0;
+ul.kmlTree li.kml ul li{
+	margin-left:  0.2em;
+ul.kmlTree li.kml > button.add{
+	background-image:  url("../img/add.png");
+	background-repeat: no-repeat;
+	background-position: 50% 50%;
+ul.kmlTree li.open.kml > button.toggle{
+	background-image: url("../img/geokml_logo_folder.png");
+ul.kmlTree li.closed.kml > button.toggle{
+ul.kmlTree li.kml.open, ul.kmlTree li.kml.closed {
+	background-image: none;
+/*  a kml Node */
+ul.kmlTree li.open > button.toggle{
+	background-image: url("../img/tree_new/expanded_folder.png");
+	background-position: 0 0;
+ul.kmlTree li.closed >  button.toggle{
+	background-image: url("../img/tree_new/closed_folder.png");
+ul.kmlTree li button.remove{
+	background-image: url("../img/button_digitize/geomRemove.png");
+ul.kmlTree li.open, ul.kmlTree li.closed {
+	background-repeat: repeat-x	;
+	background-position: 10px 10px;
+	padding-bottom: 0.5em;
+ul.kmlTree li.closed >ul{
+	display: none;
+ul.kmlTree li.kml  li input{
+	margin: 0;
+/* a kmlItem Node */
+ul.kmlTree  ul ul {
+	padding: 0;
+ul.kmlTree  ul ul li {
+	padding: 0;
+	border: 1px solid transparent;
+ul.kmlTree  ul ul li:hover {
+	border: 1px dotted gray;
Added: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/kmlTree.js	2011-12-06 14:57:06 UTC (rev 8226)
@@ -0,0 +1,185 @@
+  * Package: kmlTree
+  * Description:
+  * Module to load KML temporary in a tree
+  * Files:
+  *  - mapbender/http/plugins/kmlTree.js
+  *  - mapebnder/lib/mb.ui.displayKmlFeatures.js
+  *  - mapbender/http/css/kmltree.css
+  * SQL:
+  * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,
+  * > e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+  * > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>',
+  * > 'kmlTree',2,1,'Displays KML on the map','KML','ul','','',1,1,200,200,NULL ,
+  * > 'visibility:visible','','ul','../plugins/kmlTree.js','../../lib/mb.ui.displayKmlFeatures.js',
+  * > 'mapframe1','jq_ui_widget','http://www.mapbender.org/Loadkml');
+  * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+  * > VALUES('gui', 'kmlTree', 'styles', '../css/kmltree.css', '' ,'file/css');
+  * Help:
+  * http://www.mapbender.org/Loadkml
+  * Maintainer:
+  * http://www.mapbender.org/User:Armin_Retterath
+  * License:
+  * Copyright (c) 2009, Open Source Geospatial Foundation
+  * This program is dual licensed under the GNU General Public License
+  * and Simplified BSD license.
+  * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var $kmlTree = $(this);
+var KmlTree = function(o){
+	$kmlTree.children().remove();
+	$kmlTree.addClass('kmlTree');
+	var $KMLfolder = $('<li class="open kml"><img src="../img/kml_logo.png" /><a href="#">KML</a><ul></ul></li>');
+	$kmlTree.append($KMLfolder);
+	$addButton = $('<button class="add" name="addkml" value="addkml"></button>');
+	$addButton.click(function(){
+		$('<div ><input class="kmlurl" /></div>').dialog({
+			"title": "KML hinzufügen",
+			"buttons":{
+				"OK": function(){
+					$('#mapframe1').kml({ url: $(this).find('.kmlurl').val()});
+					$(this).dialog('destroy');
+	$KMLfolder.find("a").after($addButton);
+	o.$target.bind('kml:loaded',function(e,obj){
+		//console.log(obj);
+		var checked = obj.display ? 'checked="checked"':'';
+		title = obj.url;
+		abbrevTitle = title.length < 20 ?  title : title.substr(0,17) + "...";
+		$kmlEntry = $('<li title="'+ title +'" class="open"><button class="toggle" name="toggle" value="toggle" ></button> <input type="checkbox"'+checked  +'/><button class="remove" name="remove" value="remove" ></button><a href="#">'+abbrevTitle+'</a></li>');
+		$KMLfolder.children("ul").append($kmlEntry);
+		$kmlEntry.find("a").bind("click",(function(jsonFeatureCollection){return function(){
+				var map = o.$target.mapbender();
+				var g = new GeometryArray();
+				g.importGeoJSON(jsonFeatureCollection,false);
+				var bbox = g.getBBox();
+				var bufferFloat = parseFloat(0.1);
+				var buffer = new Point(bufferFloat,bufferFloat);
+				bbox[0] = bbox[0].minus(buffer);
+				bbox[1] = bbox[1].plus(buffer);
+				map.calculateExtent(
+				  new Mapbender.Extent(bbox[0], bbox[1])
+				map.setMapRequest();
+		})(obj.data));
+		$featureList = $("<ul />");
+		$kmlEntry.append($featureList);
+		for(var i = 0;i < obj.data.features.length;i++){
+			title = obj.data.features[i].properties.name;
+			$feature = $('<li title="'+ title +'"><a href="#" >'+ abbrevTitle + '</a></li>');
+			$featureList.append($feature);
+			$feature.bind('click',(function(jsonFeature){return function(){
+				g.importGeoJSON(jsonFeature,false);
+				var feature = g.get(0);
+				var bbox = feature.getBBox();
+			})(obj.data.features[i]));
+			$feature.bind('mouseout',(function(jsonFeature){return function(){
+				var me = $kmlTree.mapbender();
+				me.resultHighlight.clean();
+				me.resultHighlight.paint();
+			$feature.bind('mouseover',(function(jsonFeature){return function(){
+				if(feature.geomType != "point"){
+					feature = feature.getBBox4();
+					me.resultHighlight = new Highlight(
+							[o.target],
+							"KmlTreeHighlight",
+							{"position":"absolute", "top":"0px", "left":"0px", "z-index":100},
+							2);
+					me.resultHighlight.add(feature, "#00ff00");
+				else if(feature.geomType == "point"){
+		$("*:checkbox",$kmlEntry).bind('click', function(){
+			if($(this).attr('checked')){
+				o.$target.kml('show',obj.url);
+			}else{
+				o.$target.kml('hide',obj.url);
+		$("button.toggle",$kmlEntry).bind('click', function(){
+			if($(this).parent().hasClass("open")){
+				$(this).parent().removeClass("open");
+				$(this).parent().addClass("closed");
+			}else{
+				$(this).parent().removeClass("closed");
+				$(this).parent().addClass("open");
+		$("button.remove",$kmlEntry).bind('click', function(){
+			o.$target.kml('remove',obj.url);
+			$(this).parent().remove();
+Mapbender.events.init.register(function(){
+	$kmlTree.mapbender(new KmlTree(options));
Added: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	                        (rev 0)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2011-12-06 14:57:06 UTC (rev 8226)
@@ -0,0 +1,352 @@
+// events
+// 	geojson:loaded  	- a georssfeed was loaded from a server and is now available: function(url,geojson)
+// 	georss:error	- a georssfeed failed to load: function(url,error);
+var originalI18nObject = {
+	"labelLoadError" : "Could not load Document",
+	"labelName":"Name",
+	"labelUntitled":"Untitled",
+	"labelUrlBox": "Paste URL here",
+	"sProcessing":   "Processing...",
+	"sLengthMenu":   "Show _MENU_ entries",
+	"sZeroRecords":  "No matching records found",
+	"sInfo":         "SLowing _START_ to _END_ of _TOTAL_ entries",
+	"sInfoEmpty":    "Showing 0 to 0 of 0 entries",
+	"sInfoFiltered": "(filtered from _MAX_ total entries)",
+	"sInfoPostFix":  "",
+	"sSearch":       "Search:",
+	"sUrl":          "",
+	"oPaginate": {
+		"sFirst":    "First",
+		"sPrevious": "Previous",
+		"sNext":     "Next",
+		"sLast":     "Last"
+//var translatedI18nObject = Mapbender.cloneObject(originalI18nObject);
+var translatedI18nObject = originalI18nObject;
+var displayFeatures = {
+	options: {
+		url: "",
+		position: 'right',
+		autoOpen: true,
+		autoDisplay: true
+	_kmls: {},
+	_popup : null,
+	_create: function(){
+		var self = this, o = this.options;
+		this.element.bind('click', function(e){
+			var map = self.element.mapbender();
+			var pos = map.getMousePosition(e);
+			var clickPoint =  map.convertPixelToReal(new Point(pos.x,pos.y));
+			var feed = null;
+			var requestGeometries = [];
+			// This uses two methods to determine wether a clickposition is on a geometry
+			// - Points are represented as icons, so we check if the click is on an icon
+			// - Polygons don't have a dom Element when not using Rapheljs, so we go ask postgis
+			// after that's finished the results are merged and displayed in a box
+			var pointGeometries = {};
+			var g,h,nodes = null;
+			$("*",self._popup).remove();
+			var $tabs = $("<ul></ul>");
+			for (var i in self._kmls){
+				feed = self._kmls[i] ;
+				if(!feed.display){ continue; }
+				requestGeometries = [];
+				for(var j = 0; j < feed.geomArray.count(); j++){
+					g = feed.geomArray.get(j);
+					h = feed.highlightArray[j];
+					nodes = h.getNodes();
+					if(g.geomType == geomType.point){
+						// we only add one point per highlight so we can assume there's only one node
+						if(!nodes[0]){ continue;}
+						var rect = nodes[0].getBoundingClientRect();
+						if(e.clientX >= rect.left && e.clientX <= rect.right &&
+						   e.clientY >= rect.top  && e.clientY <= rect.bottom){
+							// we just need the keys to exist
+							// theywill be merged with the ones coming from the
+							// server
+							pointGeometries[j] = true;
+					}else{
+						requestGeometries.push(g.toText());
+				var req = new Mapbender.Ajax.Request({
+				url: "../php/intersection.php",
+				method: "intersect",
+				parameters: {
+					clickPoint:	clickPoint.toText(),
+					geometries: requestGeometries
+				callback: (function(geomArray,pointGeometries){ return function(result, success, message){
+					if(!success){
+						return;
+					// this is basically an onclick handler, !intersects means
+					// the click didn't happen on the polygon
+					$.extend(result.geometries,pointGeometries);
+					if(!result.geometries || result.geometries.length <1){
+						return;
+					// this iterates over an object where the keys are _not_ the incremential
+					// basically a sparse array. therefore It cannot be used to count the entries in the object
+					// this is why j is used
+					for(i in result.geometries){
+						var g = geomArray.get(i);
+						title = g.e.getElementValueByName("title");
+						name  = g.e.getElementValueByName("name");
+						if(typeof(name) == "string"){
+							title = name != "false" ? name : title;
+							if (icon == "false"){
+								g.e.setElement("Mapbender:icon","../img/marker/red.png");
+						}else{
+							//sane browsers go here
+							title = name != false ? name : title;
+							if (icon === false){
+						description = g.e.getElementValueByName("description");
+						$tabs.append('<li><a href="#rsspopup_'+ i +'">'+ title + '</a></li>');
+						self._popup.append('<div id="rsspopup_'+ i +'"><h1>'+ title +'</h1><p>'+ description +'</p></h1>');
+						if($tabs.children().size() > 1){
+						self._popup.dialog('open');
+						var $tabcontainer = $("<div><div>");
+						$tabcontainer.append($tabs);
+						$tabcontainer.append($('div',self._popup));
+						$tabs.css("display","none");
+						self._popup.append($tabcontainer);
+						$tabcontainer.tabs();
+						// -1 because we need it zero based later
+						var tabcount = $tabcontainer.find(".ui-tabs-panel").size() -1;
+						$tabcontainer.find(".ui-tabs-panel").each(function(i){
+							var  $navbar = $("<div></div>");
+							$(this).append($navbar);
+							// add to first panel
+							if(i == 0 ){
+								var next = i+1;
+								$navbar.append('<a style="float:right;" href="#" class="next-tab" rel="'+next+'">mehr</a>');
+							// add to all except the first panel
+							if(i > 0 ){
+								var prev = i-1;
+								$navbar.append('<a href="#" class="prev-tab" rel="'+prev+'">zurück</a>');
+							// add to all except first and last panel
+							if( tabcount  > i && i > 0  ){
+								var next = i+1;
+								$navbar.append('<a style="float:right;" href="#" class="next-tab" rel="'+next+'">vor</a>');
+						$tabcontainer.find(".next-tab, .prev-tab").click(function(){
+							$tabcontainer.tabs("select",$(this).attr("rel"));
+							return false;
+				};})(feed.geomArray, pointGeometries)
+				req.send();
+				pointGeometries = {};
+		self.element.bind('kml:loaded',function(event,obj){
+			if(o.autoOpen){
+				self._display(obj);
+		self.element.bind('kml:error',function(event,message){
+			alert(message);
+	_init: function(){
+		this._popup = $('<div></div>').dialog({autoOpen : false, height: 500, width: 500});
+		if(o.url){
+			self._load(o.url);
+	_load : function(url){
+		var epsg = $(self.element).mapbender().epsg;
+		epsg = epsg.split(":")[1];
+		if(self._kmls[o.url]){
+			//not adding feed twice
+			return;
+		$.ajax({ url: self._endpointURL,
+			data: {url: o.url, targetEPSG: epsg},
+			type: 'POST',
+			dataType: "json",
+			success : function(data,textStatus,xhr){
+				if(!data){
+					self.element.trigger('kml:error',"request returned no data");
+				else if(data.errorMessage){
+					self.element.trigger('kml:error',data.errorMessage);
+				}else{
+					self._kmls[o.url] = {type:"geojson",data:data,url:o.url,display: o.autoDisplay};
+					self.element.trigger('kml:loaded',{type:"geojson",data:data,url:o.url,display: o.autoDisplay});
+			error: function(XMLHttpRequest, textStatus, errorThrown){
+				self.element.trigger('kml:error',"Problem talking to server: " + errorThrown);
+	show : function(url){
+		this._kmls[url].display = true;
+		var $map = $(this.element).mapbender();
+		var extent = $map.getExtentInfos();
+		$map.calculateExtent(extent);
+		$map.setMapRequest();
+		$(this.element).mapbender().setMapRequest();
+	hide : function(url){
+		this._kmls[url].display = false;
+	remove: function(url){
+		// nrgh there are still references to the highlightobjects somewhere!
+		for(var i in this._kmls[url].highlightArray){
+			this._kmls[url].highlightArray[i].clean();
+		delete(this._kmls[url]);
+	_display : function(mapitem){
+		// getting the mapitem from the events bre
+		var mapitem = self._kmls[mapitem.url];
+		var geojson = mapitem.data;
+		if(typeof(Mapbender) != "undefined"){
+			var $map = $(self.element).mapbender();
+			var markers = [];
+			var title = "";
+			if(geojson.features){
+				// we always transform _from_ 4326 KML use this as their default
+				//var projSrc = new Proj4js.Proj('EPSG:4326');
+				//var projDest = new Proj4js.Proj($map.epsg);
+				var markeroptions = {width: "19px", height: "34px"};
+				var g = null;
+				mapitem.geomArray = new GeometryArray();
+				mapitem.highlightArray = [];
+				mapitem.geomArray.importGeoJSON(geojson);
+				for(var i =0; i < mapitem.geomArray.count(); i++){
+					var h = new Highlight([self.element.attr('id')], "mapframe1_" + parseInt(Math.random()*100000,10),{
+						"position":"absolute",
+						"top": "0px",
+						"left": "0px",
+						"z-index": "80" },1);
+					g = mapitem.geomArray.get(i);
+					icon = g.e.getElementValueByName("Mapbender:icon");
+					//title = g.e.getElementValueByName("title");
+					if(name != "false" && name !== false){
+						title = name; // use for tooltip
+					if(icon == "false" || icon === false){
+						g.e.setElement("Mapbender:iconOffsetX", -10);
+						g.e.setElement("Mapbender:iconOffsetY", -34);
+					h.add(g);
+					mapitem.highlightArray.push(h);
+					title = "";
+					name = "";
+				if(mapitem.display){
+					for(var j in mapitem.highlightArray){
+						mapitem.highlightArray[j].paint();
+				}else{
+						mapitem.highlightArray[j].hide();
+				self.element.mapbender().events.afterMapRequest.register(function () {
+						for(var i in mapitem.highlightArray){
+							mapitem.highlightArray[i].paint();
+					}else{
+							mapitem.highlightArray[i].hide();
+var displayKML = $.extend({},displayFeatures, {
+	_endpointURL: "../php/kmlToGeoJSON.php",
+	_eventNamespace : "kml"
+$.widget('ui.kml',displayKML);
+var displayGeoJSON = $.extend({},displayFeatures,{
+	_endpointURL: "",
+	_load: function(){
+		$.ajax({ url: o.url,
+			type: "GET",
+			dataType: "json",
+				self._display(data);
+$.widget('ui.geojson',displayKML);
More information about the Mapbender_commits
