[Mapbender-commits] r8229 - in trunk/mapbender: http/javascripts
resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Mon Dec 12 10:15:23 EST 2011
Author: verenadiewald
Date: 2011-12-12 07:15:23 -0800 (Mon, 12 Dec 2011)
New Revision: 8229
trunk/mapbender/http/javascripts/mod_legend.php
trunk/mapbender/http/javascripts/mod_legendDiv.php
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
added opportunity to show legend in reverse direction as element var
Modified: trunk/mapbender/http/javascripts/mod_legend.php
--- trunk/mapbender/http/javascripts/mod_legend.php 2011-12-12 15:10:29 UTC (rev 8228)
+++ trunk/mapbender/http/javascripts/mod_legend.php 2011-12-12 15:15:23 UTC (rev 8229)
@@ -68,6 +68,7 @@
var checkbox_on_off = typeof checkbox_on_off === "undefined" ? 'false' : checkbox_on_off;
var stickylegend = typeof stickylegend === "undefined" ? "false" : stickylegend;
+var reverse = typeof reverse === "undefined" ? "false" : reverse;
function mod_legend_pos(frameName){
if(frameName == mod_legend_target){
@@ -85,9 +86,9 @@
var str = "";
var str_tmp = "";
- for(var i=0; i<parent.mb_mapObj[ind].wms.length; i++){
+ if(reverse == 'true') {
+ for(var i=parent.mb_mapObj[ind].wms.length-1; i>=0; i--){
var layerNames = parent.mb_mapObj[ind].wms[i].getLayers(parent.mb_mapObj[ind]);
for(var j=0; j<layerNames.length; j++){
var layerParent = parent.mb_mapObj[ind].wms[i].checkLayerParentByLayerName(layerNames[j]);
@@ -124,14 +125,63 @@
- if(str_tmp !=''){
- if (showwmstitle == 'true'){
- str += "<div><span class='header'>" +parent.mb_mapObj[ind].wms[i].wms_title+ "</span></div>";
+ if(str_tmp !=''){
+ if (showwmstitle == 'true'){
+ str += "<div><span class='header'>" +parent.mb_mapObj[ind].wms[i].wms_title+ "</span></div>";
+ str += str_tmp;
+ str_tmp ='';
- str += str_tmp;
- str_tmp ='';
+ else {
+ for(var i=0; i<parent.mb_mapObj[ind].wms.length; i++){
+ var layerNames = parent.mb_mapObj[ind].wms[i].getLayers(parent.mb_mapObj[ind]);
+ for(var j=0; j<layerNames.length; j++){
+ var layerParent = parent.mb_mapObj[ind].wms[i].checkLayerParentByLayerName(layerNames[j]);
+ var layerTitle = parent.mb_mapObj[ind].wms[i].getTitleByLayerName(layerNames[j]);
+ var layerStyle = parent.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layerNames[j]);
+ var legendUrl = false;
+ if(layerStyle == false){
+ legendUrl = parent.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],"");
+ //alert("mapObj ind: "+ind+" wms index: "+i+"layer name: "+layerNames[j]+" : LegendUrl (style false): "+legendUrl);
+ else{
+ legendUrl = parent.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],layerStyle);
+ if (legendUrl !== false){
+ // if(layerParent == 0){
+ if(showlayertitle == 'true'){
+ str_tmp += "<div><span class='titles'>" + layerTitle+ "</span></div>";
+ str_tmp += "<div>";
+ if(legendlink == 'true'){
+ str_tmp += "<a href='../php/result.php?lingo=deutsch&layer="+layerNames[j]+"' class='link_metadata' title='Zeigt Liste zum Thema: "+layerTitle+"' target='result'>";
+ str_tmp += "<img border=0 src = '";
+ str_tmp += legendUrl;
+ str_tmp += "'></img>";
+ if (legendlink == 'true'){
+ str_tmp += "</a>";
+ str_tmp += "</div>";
+ if(str_tmp !=''){
+ str += str_tmp;
+ str_tmp ='';
if(str != ""){
parent.writeTag("legend", "leg", str);
Modified: trunk/mapbender/http/javascripts/mod_legendDiv.php
--- trunk/mapbender/http/javascripts/mod_legendDiv.php 2011-12-12 15:10:29 UTC (rev 8228)
+++ trunk/mapbender/http/javascripts/mod_legendDiv.php 2011-12-12 15:15:23 UTC (rev 8229)
@@ -43,6 +43,7 @@
var showwmstitle = typeof showwmstitle === "undefined" ? "false" : showwmstitle;
var showlayertitle = typeof showlayertitle === "undefined" ? "false" : showlayertitle;
var showgroupedlayertitle = typeof showgroupedlayertitle === "undefined" ? "false" : showgroupedlayertitle;
@@ -52,49 +53,97 @@
var str = "";
var str_tmp = "";
- for(var i=0; i<mb_mapObj[ind].wms.length; i++){
- var layerNames = mb_mapObj[ind].wms[i].getLayers(mb_mapObj[ind]);
- for(var j=0; j<layerNames.length; j++){
- var layerParent = mb_mapObj[ind].wms[i].checkLayerParentByLayerName(layerNames[j]);
- var layerTitle = mb_mapObj[ind].wms[i].getTitleByLayerName(layerNames[j]);
- var layerStyle = mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layerNames[j]);
- var legendUrl = false;
- if(layerStyle == false){
- legendUrl = mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],"");
+ var layerNames = mb_mapObj[ind].wms[i].getLayers(mb_mapObj[ind]);
+ var layerParent = mb_mapObj[ind].wms[i].checkLayerParentByLayerName(layerNames[j]);
+ var layerTitle = mb_mapObj[ind].wms[i].getTitleByLayerName(layerNames[j]);
+ var layerStyle = mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layerNames[j]);
+ legendUrl = mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],"");
+ else{
+ legendUrl = mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],layerStyle);
- else{
- legendUrl = mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],layerStyle);
+ if(str_tmp !=''){
+ str += "<div><span class='header'>" +mb_mapObj[ind].wms[i].wms_title+ "</span></div>";
- if (legendUrl !== false){
-// if(layerParent == 0){
- if(showlayertitle == 'true'){
- str_tmp += "<div><span class='titles'>" + layerTitle+ "</span></div>";
- str_tmp += "<div>";
- if(legendlink == 'true'){
- str_tmp += "<a href='../php/result.php?lingo=deutsch&layer="+layerNames[j]+"' class='link_metadata' title='Zeigt Liste zum Thema: "+layerTitle+"' target='result'>";
- str_tmp += "<img border=0 src = '";
- str_tmp += legendUrl;
- str_tmp += "'></img>";
- if (legendlink == 'true'){
- str_tmp += "</a>";
- str_tmp += "</div>";
+ str += str_tmp;
+ str_tmp ='';
+ else {
+ for(var i=0; i<mb_mapObj[ind].wms.length; i++){
+ else{
+ if(str_tmp !=''){
+ str += str_tmp;
+ str_tmp ='';
- if(str_tmp !=''){
- str += "<div><span class='header'>" +mb_mapObj[ind].wms[i].wms_title+ "</span></div>";
- str += str_tmp;
- str_tmp ='';
if(str != ""){
writeTag("", "legend", str);
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2011-12-12 15:10:29 UTC (rev 8228)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2011-12-12 15:15:23 UTC (rev 8229)
@@ -181,5 +181,13 @@
LANGUAGE plpgsql VOLATILE
COST 100;
+-- new element_var reverse for element legend
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+SELECT gui_element.fkey_gui_id,
+'legend', 'reverse', 'false', 'parameter to decide wether the legend should be in the reverse direction' ,'var'
+from gui_element
+WHERE
+gui_element.e_id = 'legend' AND
+gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'legend' AND var_name = 'reverse');
More information about the Mapbender_commits
