[Mapbender-commits] r7517 - in trunk/mapbender/http: classes
javascripts php plugins
svn_mapbender at osgeo.org
Wed Feb 2 13:28:18 EST 2011
Author: kmq
Date: 2011-02-02 10:28:18 -0800 (Wed, 02 Feb 2011)
New Revision: 7517
trunk/mapbender/http/classes/class_elementVar.php
trunk/mapbender/http/classes/class_wfs_conf.php
trunk/mapbender/http/classes/class_wmc.php
trunk/mapbender/http/javascripts/initWmcObj.php
trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php
trunk/mapbender/http/php/mod_wfs_conf_server.php
trunk/mapbender/http/plugins/wfsConfTree.js
wfsconftree now persists in the sessionwmc
Modified: trunk/mapbender/http/classes/class_elementVar.php
--- trunk/mapbender/http/classes/class_elementVar.php 2011-02-02 16:52:38 UTC (rev 7516)
+++ trunk/mapbender/http/classes/class_elementVar.php 2011-02-02 18:28:18 UTC (rev 7517)
@@ -37,7 +37,7 @@
$this->load();
catch (Exception $e) {
- throw new Exception ("Could not initialize element var.");
+ throw new Exception ("Could not initialize element var, because: " . $e);
Modified: trunk/mapbender/http/classes/class_wfs_conf.php
--- trunk/mapbender/http/classes/class_wfs_conf.php 2011-02-02 16:52:38 UTC (rev 7516)
+++ trunk/mapbender/http/classes/class_wfs_conf.php 2011-02-02 18:28:18 UTC (rev 7517)
@@ -153,7 +153,8 @@
"f_auth_varname" => $row["f_auth_varname"],
"f_detailpos" => $row["f_detailpos"],
"f_operator" => $row["f_operator"],
- "f_show_detail" => $row["f_show_detail"]
+ "f_show_detail" => $row["f_show_detail"],
+ "f_helptext" => $row["f_helptext"] == null? "":$row["f_helptext"]
array_push($elementArray, $currentElement);
@@ -187,7 +188,7 @@
* get WFS conf data from database
- private function getWfsConfFromDB ($idArray) {
+ public function getWfsConfFromDB ($idArray) {
// if a user has access to some WFS confs...
if (count($idArray) > 0) {
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2011-02-02 16:52:38 UTC (rev 7516)
+++ trunk/mapbender/http/classes/class_wmc.php 2011-02-02 18:28:18 UTC (rev 7517)
@@ -18,7 +18,7 @@
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require_once(dirname(__FILE__) . "/../classes/class_wms.php");
-require_once(dirname(__FILE__) . "/../classes/class_wfs_configuration.php");
+require_once(dirname(__FILE__) . "/../classes/class_wfs_conf.php");
require_once(dirname(__FILE__) . "/../classes/class_layer_monitor.php");
require_once(dirname(__FILE__) . "/../classes/class_point.php");
require_once(dirname(__FILE__) . "/../classes/class_bbox.php");
@@ -183,6 +183,18 @@
// get the map objects "overview" and "mapframe1"
$this->mainMap = map::selectMainMapByApplication($appId);
$this->overviewMap = map::selectOverviewMapByApplication($appId);
+ // a wWFS is basically just a vectorlayer, and a WFSconf is just a configured WFS,
+ // so it makes sense to attach the WFSCONFIDstring to to the mapobject
+ // this clearly needs a better solution though...
+ try{
+ $ev = new ElementVar($appId,"mapframe1","wfsConfIdString");
+ $this->generalExtensionArray['WFSCONFIDSTRING'] = $ev->value;
+ }catch(Exception $E){
+ // ... exceprtions are a terribkle way to do this, but I am not going to rewrite the ElementVar class
+ $this->generalExtensionArray['WFSCONFIDSTRING'] = "";
$this->createXml();
$this->saveAsFile();
@@ -1021,11 +1033,12 @@
public function featuretypeConfToJavaScript() {
$wfsConfIds = $this->generalExtensionArray['WFSCONFIDSTRING'];
+ new mb_exception("app AAAA idstr $wfsConfIds");
$featuretypeConfs = array();
$featuretypeConfArray = is_string($wfsConfIds) ?
explode(",", $wfsConfIds) : array();
for ($i = 0; $i < count($featuretypeConfArray); $i++) {
- $featuretypeConf = WfsConfiguration::createFromDb($featuretypeConfArray[$i]);
+ $featuretypeConf = WfsConf::getWfsConfFromDb($featuretypeConfArray[$i]);
array_push($featuretypeConfs,$featuretypeConf);
$featuretypeConfObj = new Mapbender_JSON();
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php 2011-02-02 16:52:38 UTC (rev 7516)
+++ trunk/mapbender/http/javascripts/initWmcObj.php 2011-02-02 18:28:18 UTC (rev 7517)
@@ -492,10 +492,13 @@
$wmcFeaturetypeJson = $wmc->featuretypeConfToJavaScript();
+$wfsConfIdString = $wmcGetApi->generalExtensionArray['WFSCONFIDSTRING'];
$wmcFeaturetypeStr = <<<JS
Mapbender.events.afterInit.register(function () {
+ console.log("triggering the thing");
$('#body').trigger('addFeaturetypeConfs', [
- {featuretypeConfObj : $wmcFeaturetypeJson}
+ { featuretypeConfObj : $wmcFeaturetypeJson,
+ wfsConfIdString: "$wfsConfIdString"}
JS;
Modified: trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php
--- trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php 2011-02-02 16:52:38 UTC (rev 7516)
+++ trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php 2011-02-02 18:28:18 UTC (rev 7517)
@@ -159,7 +159,36 @@
var geomArray = null;
var frameIsReady = function () {
+ var req = parent.Mapbender.Ajax.Request({
+ url: "../php/mod_wfs_conf_server.php",
+ method: "getWfsConfsFromId",
+ parameters: {
+ wfsConfIdString: global_selectedWfsConfId
+ callback: function(result,success,message){
+ console.debug("b");
+ console.debug(result);
+ // the rest of the script doesn't expect an array, but an object, so the result must be converted
+ global_wfsConfObj = {};
+ for(var i in result){
+ if(!result.hasOwnProperty(i)){ continue;}
+ global_wfsConfObj[result[i].id] = result[i];
+ init_wfsSpatialRequest();
+ appendWfsForm();
+ appendStyles();
+ setWfsInfo();
+ // creates a Highlight object for the request geometry
+ var styleProperties = {"position":"absolute", "top":"0px", "left":"0px", "z-index":100};
+ requestGeometryHighlight = new parent.Highlight(targetArray, "requestGeometryHighlight", styleProperties, 2);
+ parent.mb_registerSubFunctions("window.frames['" + frameName +"'].requestGeometryHighlight.paint()");
+// req.send();
parent.mb_ajax_json("../php/mod_wfs_gazetteer_server.php", {command:"getWfsConf",wfsConfIdString: global_selectedWfsConfId }, function(json,status){
global_wfsConfObj = json;
@@ -556,8 +585,8 @@
form.appendChild(spanNode);
form.appendChild(inputNode);
- //if(wfsConfElementArray[i].f_helptext.length > 0) { form.appendChild(helptextNode); }
- //if(wfsConfElementArray[i].f_helptext.length > 0) { form.appendChild(helptextDisplay); }
+ if(wfsConfElementArray[i].f_helptext.length > 0) { form.appendChild(helptextNode); }
+ if(wfsConfElementArray[i].f_helptext.length > 0) { form.appendChild(helptextDisplay); }
form.appendChild(document.createElement("br"));
@@ -1061,7 +1090,10 @@
title: searchPopupTitle,
width:searchPopupWidth,
height: searchPopupHeight,
- position: [ searchPopupX,searchPopupY]
+ position: [ searchPopupX,searchPopupY],
+ onclose: function(){
+ resultList.hide();
else {
Modified: trunk/mapbender/http/php/mod_wfs_conf_server.php
--- trunk/mapbender/http/php/mod_wfs_conf_server.php 2011-02-02 16:52:38 UTC (rev 7516)
+++ trunk/mapbender/http/php/mod_wfs_conf_server.php 2011-02-02 18:28:18 UTC (rev 7517)
@@ -27,6 +27,32 @@
$command = $ajaxResponse->getMethod();
switch ($command) {
+ case "getWfsConfsFromId":
+ $wfsConfIdString = $ajaxResponse->getParameter("wfsConfIdString");
+ if(!$wfsConfIdString){
+ $ajaxResponse->setSuccess($false);
+ $ajaxResponse->setMessage("missing wfsConfIdString");
+ $ajaxResponse->send();
+ break;
+ $wfsConfIdString = trim($wfsConfIdString,',');
+ $wfsConfIds = explode(',',$wfsConfIdString);
+ $result = array();
+ foreach($wfsConfIds as $wfsId){
+ new mb_exception("AAAAAAAAAA '$wfsId' of $wfsConfIdString ");
+ $currentWfsConf = WfsConfiguration::createFromDb($wfsId);
+ if ($currentWfsConf !== null) {
+ $result[]= $currentWfsConf;
+ }else{
+ $result[] = "OMG";
+ $ajaxResponse->setResult($result);
+ break;
case "getWfsConfs" :
$currentUser = new User(Mapbender::session()->get("mb_user_id"));
$wfsConfIds = $currentUser->getWfsConfByWfsOwner();
@@ -130,4 +156,4 @@
$ajaxResponse->setMessage("Invalid command.");
$ajaxResponse->setSuccess(false);
\ No newline at end of file
Modified: trunk/mapbender/http/plugins/wfsConfTree.js
--- trunk/mapbender/http/plugins/wfsConfTree.js 2011-02-02 16:52:38 UTC (rev 7516)
+++ trunk/mapbender/http/plugins/wfsConfTree.js 2011-02-02 18:28:18 UTC (rev 7517)
@@ -1,22 +1,40 @@
+ * default wfsConfIdString is taken from the elementVar "wfsConfIdString" to the mapframe1 element
var $confTree = $(this);
var ConfTree = function(o){
- wfsConfIdString = o.wfsConfIdString || "";
+ var that = this;
+ var wfsConfIdString = o.wfsConfIdString || "";
+ var wfsconfs = wfsConfIdString.split(',');
// getParams is a global variable that contains the Querystring as a json object
var getwfsConfIdString = getParams['FEATURETYPE'] || "";
+ if(getwfsConfIdString !== ""){
+ wfsconfs = wfsconfs.concat(getwfsConfIdString.split(','));
+ wfsConfIdString = wfsconfs.join(',');
+ var currentWFSConf = {};
- wfsConfIdString = wfsConfIdString + "," + getwfsConfIdString;
+ if(parent.Mapbender.modules.loadwmc){
+ parent.Mapbender.modules.loadwmc.events.loaded.register(function (obj) {
+ if (obj.extensionData && obj.extensionData.WFSCONFIDSTRING) {
+ var req = Mapbender.Ajax.Request({
+ parameters: {
+ wfsConfIdString: obj.extensionData.WFSCONFIDSTRING
+ reset(result);
+ req.send();
- $confTree.children().remove();
- $confTree.addClass('conftree');
- var $WFSConffolder = $('<li class="open wfsconf"><ul></ul></li>');
- $confTree.append($WFSConffolder);
var $wfsConfDialog = $("<div></div>").dialog({
width: 500,
height: 600,
@@ -27,50 +45,70 @@
- mb_ajax_json("../php/mod_wfs_gazetteer_server.php", {command:"getWfsConf",wfsConfIdString: wfsConfIdString }, function(json,status){
- aWFSConf = json;
+ $("button.toggle",$confTree).live('click', function(){
+ if($(this).parent().hasClass("open")){
+ $(this).parent().removeClass("open");
+ $(this).parent().addClass("closed");
+ }else{
+ $(this).parent().removeClass("closed");
+ $(this).parent().addClass("open");
+ var reset = function(aWFSConf){
+ wfsconfs = [];
+ $confTree.children().remove();
+ $confTree.append("<li class='emptymessage'>Keine WFSConf verfügbar</li>");
+ $confTree.addClass('conftree');
+ var $WFSConffolder = $('<li class="open wfsconf"><ul></ul></li>');
+ $confTree.append($WFSConffolder);
for(var i in aWFSConf){
+ // remove default "no wfs conf"message
+ if(i == 0){ $confTree.find(".emptymessage").remove();}
// group by featyretype
- $featuretypeFolder = $WFSConffolder.find("li.featuregroup_"+aWFSConf[i].featuretype_id);
+ $featuretypeFolder = $WFSConffolder.find("li.featuregroup_"+aWFSConf[i].featureTypeId);
+ wfsconfs.push(aWFSConf[i].id);
if($featuretypeFolder.size() == 0){
- $featuretypeFolder = $('<li class="open featuregroup_'+ aWFSConf[i].featuretype_id + '"><button class="toggle"></button>'+ aWFSConf[i].wfs_conf_abstract + '<ul></ul></li>');
+ $featuretypeFolder = $('<li class="open featuregroup_'+ aWFSConf[i].featureTypeId + '"><button class="toggle"></button>'+ aWFSConf[i].abstr + '<ul></ul></li>');
$WFSConffolder.find(" > ul").append($featuretypeFolder);
$featuretypeList = $featuretypeFolder.find("ul");
}else{
- switch(aWFSConf[i].wfs_conf_type){
+ //parseInt because one version of wfsConf creates this as a string, the other as an int
+ switch(parseInt(aWFSConf[i].type,10)){
/* search */
- case "0":
- $wfsconfEntry = $('<li class="search" ><img src="../img/gnome/icn_suchmodul.png" /><a href="#" class="meta">metadata</a><button class="remove">remove</button><a href="#" class="dialogopen">'+ aWFSConf[i].g_label +'</a></li>');
- //$wfsconfEntry = $('<li class="search" ><a href="#" class="meta">metadata</a><button class="remove">remove</button><a href="#" class="dialogopen">'+ aWFSConf[i].g_label +'</a></li>');
+ case 0:
+ $wfsconfEntry = $('<li class="search" ><img src="../img/gnome/icn_suchmodul.png" /><a href="#" class="meta">metadata</a><button class="remove">remove</button><a href="#" class="dialogopen">'+ aWFSConf[i].label +'</a></li>');
break;
/* digitize */
- case "1":
- $wfsconfEntry = $('<li class="digitize" ><img src="../img/gnome/document-save.png" /><a href="#" class="meta">medadata</a><button class="remove">remove</button><a href="#" class="dialogopen">'+ aWFSConf[i].g_label +'</a></li>');
+ case 1:
+ $wfsconfEntry = $('<li class="digitize" ><img src="../img/gnome/document-save.png" /><a href="#" class="meta">medadata</a><button class="remove">remove</button><a href="#" class="dialogopen">'+ aWFSConf[i].label +'</a></li>');
break;
/* download */
- case "2":
- $wfsconfEntry = $('<li class="download" ><img src="../img/gnome/accessories-text-editor.png" /><a href="#" class="meta">metadata</a><button class="remove">remove</button><a href="#" class="dialogopen">'+ aWFSConf[i].g_label +'</a></li>');
+ case 2:
+ $wfsconfEntry = $('<li class="download" ><img src="../img/gnome/accessories-text-editor.png" /><a href="#" class="meta">metadata</a><button class="remove">remove</button><a href="#" class="dialogopen">'+ aWFSConf[i].label +'</a></li>');
break;
+ $wfsconfEntry.data("wfsconfId",aWFSConf[i].id);
$featuretypeList.append($wfsconfEntry);
$wfsconfEntry.find("a.dialogopen").click((function(wfsConf){
return function(){
- var querystring = 'wfsConfId='+wfsConf.wfs_conf_id+'&e_id_css='+o.id+'&e_target='+o.target;
- switch(wfsConf.wfs_conf_type){
+ var querystring = 'wfsConfId='+wfsConf.id+'&e_id_css='+o.id+'&e_target='+o.target;
+ switch(parseInt(wfsConf.type,10)){
/* search */
- case "0":
+ case 0:
/* download */
- case "2":
+ case 2:
var $iframe = $('<iframe name="'+o.id+'_" style="width: 100%; height: 100%;" src="../javascripts/mod_wfsGazetteerEditor_client.php?'+querystring+'"></iframe>');
$wfsConfDialog.empty();
$wfsConfDialog.append($iframe);
@@ -78,7 +116,7 @@
break;
/* digitize */
- case "1":
+ case 1:
break;
@@ -86,30 +124,66 @@
})(aWFSConf[i]));
$wfsconfEntry.find("button.remove").click(function(){
+ var wfsconfId = $(this).parent().data("wfsconfId");
// if this was the last entry in the featuregroup, remove it completely ...
- if($(this).parent().siblings().size() == 0){
- $(this).parent().parent().parent().remove();
- }else{
- //.. otherwise just rmeove the entry
- $(this).parent().remove();
+// if($(this).parent().siblings().size() == 0){
+// $(this).parent().parent().parent().remove();
+// }else{
+// $(this).parent().remove();
+ var newWFSConf = [];
+ for (var i in currentWFSConf){
+ if(currentWFSConf[i].id != wfsconfId){
+ newWFSConf.push(currentWFSConf[i]);
+ reset(newWFSConf);
+ if(parent.Mapbender.modules.savewmc){
+ parent.Mapbender.modules.savewmc.setExtensionData({ WFSCONFIDSTRING: wfsconfs.join(',') });
+ parent.Mapbender.modules.savewmc.save({session: true});
- $("button.toggle",$confTree).live('click', function(){
- if($(this).parent().hasClass("open")){
- $(this).parent().removeClass("open");
- $(this).parent().addClass("closed");
- }else{
- $(this).parent().removeClass("closed");
- $(this).parent().addClass("open");
+ // need this so we have a reference to the currently active wfsConfs
+ currentWFSConf = aWFSConf;
+ parameters: {
+ wfsConfIdString: wfsConfIdString
+ console.debug("FROM GUI");
+ reset(result);
+ req.send();
+ // addFeaturetypeConf should take precedence
+ $('#body').bind('addFeaturetypeConfs',function(evt,obj){
+ parameters: {
+ wfsConfIdString: obj.wfsConfIdString
+ console.debug("FROM WMS");
+ reset(result);
+ req.send();
Mapbender.events.init.register(function(){
More information about the Mapbender_commits
