[Mapbender-commits] r7563 - in trunk/mapbender: http/html
http/javascripts http/plugins lib
svn_mapbender at osgeo.org
Fri Feb 11 07:19:50 EST 2011
Author: armin11
Date: 2011-02-11 04:19:49 -0800 (Fri, 11 Feb 2011)
New Revision: 7563
trunk/mapbender/http/html/mod_treefolderPlain.php
trunk/mapbender/http/javascripts/map_obj.js
trunk/mapbender/http/javascripts/mod_loadwmc.js
trunk/mapbender/http/javascripts/mod_tab.js
trunk/mapbender/http/javascripts/mod_tooltip.php
trunk/mapbender/http/plugins/mb_i18n.js
trunk/mapbender/lib/button.js
Fix of very big performance problems with sync of different ajax calls! Reduce the loading time of mapbender 2.7 to 30% - nearly the time it needs before.
Modified: trunk/mapbender/http/html/mod_treefolderPlain.php
--- trunk/mapbender/http/html/mod_treefolderPlain.php 2011-02-11 10:21:30 UTC (rev 7562)
+++ trunk/mapbender/http/html/mod_treefolderPlain.php 2011-02-11 12:19:49 UTC (rev 7563)
@@ -89,16 +89,18 @@
req.send();
eventInit.register(function () {
localizeTree();
-eventLocalize.register(function () {
- localizeTree();
+if (localizeTree == 1) {
+ eventLocalize.register(function () {
+ localizeTree();
var jst_container = "document.getElementById('treeContainer')";
var jst_image_folder = imagedir;
var jst_display_root = false;
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js 2011-02-11 10:21:30 UTC (rev 7562)
+++ trunk/mapbender/http/javascripts/map_obj.js 2011-02-11 12:19:49 UTC (rev 7563)
@@ -41,9 +41,9 @@
localizeMap();
- eventInit.register(function(){
+/* eventInit.register(function(){
localizeMap();
var localizeMap = function(){
$.post("../php/mod_map_messages.php", {
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js 2011-02-11 10:21:30 UTC (rev 7562)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js 2011-02-11 12:19:49 UTC (rev 7563)
@@ -67,7 +67,7 @@
var translatedI18nObject = Mapbender.cloneObject(originalI18nObject);
-if(Mapbender.modules.i18n){
+/*if(Mapbender.modules.i18n){
Mapbender.modules.i18n.queue(options.id, originalI18nObject, function (translatedObject) {
if (typeof translatedObject !== "object") {
return;
@@ -75,7 +75,7 @@
translatedI18nObject = translatedObject;
Mapbender.modules.i18n.localize(Mapbender.languageId);
var $loadWmc = $(this);
Modified: trunk/mapbender/http/javascripts/mod_tab.js
--- trunk/mapbender/http/javascripts/mod_tab.js 2011-02-11 10:21:30 UTC (rev 7562)
+++ trunk/mapbender/http/javascripts/mod_tab.js 2011-02-11 12:19:49 UTC (rev 7563)
@@ -21,7 +21,7 @@
tab_init();
- localizeTabs();
+// localizeTabs();
Modified: trunk/mapbender/http/javascripts/mod_tooltip.php
--- trunk/mapbender/http/javascripts/mod_tooltip.php 2011-02-11 10:21:30 UTC (rev 7562)
+++ trunk/mapbender/http/javascripts/mod_tooltip.php 2011-02-11 12:19:49 UTC (rev 7563)
@@ -93,7 +93,7 @@
-eventInit.register(mod_tooltipInit);
+eventInit.register(mod_tooltipInit); //initialize tooltips!
function mod_tooltip_run(point){
mouseMoves++;
@@ -428,4 +428,4 @@
resultHighlight.paint();
return true;
\ No newline at end of file
Modified: trunk/mapbender/http/plugins/mb_i18n.js
--- trunk/mapbender/http/plugins/mb_i18n.js 2011-02-11 10:21:30 UTC (rev 7562)
+++ trunk/mapbender/http/plugins/mb_i18n.js 2011-02-11 12:19:49 UTC (rev 7563)
@@ -76,7 +76,7 @@
translationObj = {};
- Mapbender.events.localize.trigger();
+ //Mapbender.events.localize.trigger();
req.send();
Modified: trunk/mapbender/lib/button.js
--- trunk/mapbender/lib/button.js 2011-02-11 10:21:30 UTC (rev 7562)
+++ trunk/mapbender/lib/button.js 2011-02-11 12:19:49 UTC (rev 7563)
@@ -226,7 +226,7 @@
mb_localizeButtons();
-Mapbender.events.init.register(function () {
+/*Mapbender.events.init.register(function () {
More information about the Mapbender_commits
