[Mapbender-commits] r7569 - trunk/mapbender/conf
svn_mapbender at osgeo.org
Fri Feb 11 10:57:44 EST 2011
Author: astrid_emde
Date: 2011-02-11 07:57:44 -0800 (Fri, 11 Feb 2011)
New Revision: 7569
trunk/mapbender/conf/mapbender.conf-dist
notive MAXLOGIN is not in use anymore
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist 2011-02-11 15:52:29 UTC (rev 7568)
+++ trunk/mapbender/conf/mapbender.conf-dist 2011-02-11 15:57:44 UTC (rev 7569)
@@ -36,8 +36,12 @@
# URL to login
define("LOGIN", "http://localhost/mapbender/frames/login.php");
-define("MAXLOGIN", 3);
$login = LOGIN;
+# MAXLOGIN - this parameter is not in use anymore, but still needed for compatibility
+define("MAXLOGIN", 3);
# URL to owsproxy
More information about the Mapbender_commits
