[Mapbender-commits] r7608 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Tue Feb 15 09:07:29 EST 2011
Author: kmq
Date: 2011-02-15 06:07:29 -0800 (Tue, 15 Feb 2011)
New Revision: 7608
trunk/mapbender/http/javascripts/mod_coordsLookup.php
add highlight to coordinateLookup
Modified: trunk/mapbender/http/javascripts/mod_coordsLookup.php
--- trunk/mapbender/http/javascripts/mod_coordsLookup.php 2011-02-15 11:04:27 UTC (rev 7607)
+++ trunk/mapbender/http/javascripts/mod_coordsLookup.php 2011-02-15 14:07:29 UTC (rev 7608)
@@ -70,6 +70,12 @@
+var standingHighlight = null;
+Mapbender.events.afterMapRequest.register( function(){
+ if(standingHighlight){
+ standingHighlight.paint();
var CoordsLookup = function() {
var that = this;
if(
@@ -212,6 +218,7 @@
parseFloat(this.coords.y) + parseFloat(this.coords.perimeter));
+ var that = this;
var req = new Mapbender.Ajax.Request({
url: "../php/mod_coordsLookup_server.php",
method: "transform",
@@ -224,13 +231,23 @@
var map = Mapbender.modules[options.target];
+ if(standingHighlight !== null){
+ standingHighlight.clean();
+ }else{
+ standingHighlight = new Highlight(
+ [options.target],
+ "standingHighlight",
+ {"position":"absolute", "top":"0px", "left":"0px", "z-index":100},
+ 2);
if (obj.points) {
if (obj.points.length === 1) {
- map.setCenter(new Point(
+ var point = new Point(
obj.points[0].x,
obj.points[0].y
+ map.setCenter(point);
else if (obj.points.length === 2) {
var newExtent = new Extent(
@@ -239,10 +256,22 @@
obj.points[1].x,
obj.points[1].y
+ var point0 = new Point(obj.points[0].x,obj.points[0].y);
+ var point1 = new Point(obj.points[1].x,obj.points[1].y);
+ var x = point0.x + (point1.x - point0.x)/2;
+ var y = point0.y + (point1.y - point0.y)/2;
+ var point = new Point(x,y);
map.calculateExtent(newExtent);
- map.setMapRequest();
+ var ga = new GeometryArray();
+ ga.importPoint({
+ coordinates:[x,y,null]
+ },that.coords.targetProjection)
+ var m = ga.get(-1,-1);
+ standingHighlight.add(m, "#ff0000");
+ map.setMapRequest();
More information about the Mapbender_commits
