[Mapbender-commits] r7629 - in trunk/mapbender: http/classes
http/plugins resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org
Sat Feb 19 05:01:17 EST 2011
Author: armin11
Date: 2011-02-19 02:01:17 -0800 (Sat, 19 Feb 2011)
New Revision: 7629
trunk/mapbender/http/classes/class_weldMaps2JPEG.php
trunk/mapbender/http/plugins/mb_metadata_wmcPreview.php
trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
Fix problems with firewalls who dismiss urls when trying to save previews for wmc
Modified: trunk/mapbender/http/classes/class_weldMaps2JPEG.php
--- trunk/mapbender/http/classes/class_weldMaps2JPEG.php 2011-02-19 09:26:43 UTC (rev 7628)
+++ trunk/mapbender/http/classes/class_weldMaps2JPEG.php 2011-02-19 10:01:17 UTC (rev 7629)
@@ -34,8 +34,12 @@
$e = new mb_exception("weldMaps2JPEG: no maprequests delivered");
$url = explode("___", $urls);
- $obj1 = new stripRequest($url[0]);
+ for($i=0; $i<count($url); $i++){
+ if ($url[$i] != false) {
+ $obj1 = new stripRequest($url[$i]);
+ break;
$width = $obj1->get("width");
$height = $obj1->get("height");
Modified: trunk/mapbender/http/plugins/mb_metadata_wmcPreview.php
--- trunk/mapbender/http/plugins/mb_metadata_wmcPreview.php 2011-02-19 09:26:43 UTC (rev 7628)
+++ trunk/mapbender/http/plugins/mb_metadata_wmcPreview.php 2011-02-19 10:01:17 UTC (rev 7629)
@@ -23,24 +23,43 @@
switch ($ajaxResponse->getMethod()) {
- case "saveWmcPreview":
+ case "saveWmcPreview":
+ //check if all urls have been send - sometimes only false is send - then delete this entry!
+ //loop
+ $mapUrlsNew = array();
+ $problemUrls = array();
+ for($i=0; $i<count($mapUrls); $i++){
+ if ($mapUrls[$i] != false) {
+ $mapUrlsNew[] = $mapUrls[$i];
+ } else {
+ $problemUrls[] = $i;
+ $listOfProblemUrls = implode($problemUrls,",");
+ $mapUrls = $mapUrlsNew;
$img = new weldMaps2JPEG(implode("___",$mapUrls), PREVIEW_DIR."/".$wmcId."_wmc_preview.jpg");
if(!$img) {
$ajaxResponse->setSuccess(false);
- $ajaxResponse->setMessage('Preview could not be created');
$ajaxResponse->send();
else {
- $ajaxResponse->setSuccess(true);
- $ajaxResponse->setMessage('Preview saved');
- $ajaxResponse->send();
+ if (count($problemUrls) > 0) {
+ $ajaxResponse->setSuccess(true);
+ $ajaxResponse->send();
+ } else {
+ $ajaxResponse->setMessage(_mb('Preview saved - but following service urls are not included cause the firewall prevent this!').": ".$listOfProblemUrls);
break;
default:
- $ajaxResponse->setMessage("invalid method");
+ $ajaxResponse->setMessage(_mb("invalid method"));
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2011-02-19 09:26:43 UTC (rev 7628)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2011-02-19 10:01:17 UTC (rev 7629)
@@ -2301,3 +2301,14 @@
msgid "The selected service is already activated in your application and will not be included again:"
msgstr "Der folgende Dienst befindet sich bereits unter 'Aktive Dienste', und wird nicht erneut hinzugefügt:"
+msgid "Preview saved"
+msgstr "Vorschau gespeichert"
+msgid "Preview saved - but following service urls are not included cause the firewall prevent this!"
+msgstr "Vorschau gespeichert - aber folgende Dienste fehlen, weil die Firewall sie rausschmeißt!"
+msgid "Preview could not be created"
+msgstr "Vorschau konnte nicht gespeichert werden"
More information about the Mapbender_commits
