[Mapbender-commits] r7634 - in trunk/mapbender: http/classes
http/javascripts http/php resources/locale/de_DE/LC_MESSAGES tools
svn_mapbender at osgeo.org
Tue Feb 22 11:57:49 EST 2011
Author: armin11
Date: 2011-02-22 08:57:49 -0800 (Tue, 22 Feb 2011)
New Revision: 7634
trunk/mapbender/http/classes/class_wmc.php
trunk/mapbender/http/javascripts/mod_loadwmc.js
trunk/mapbender/http/php/mod_wmc2ol.php
trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
trunk/mapbender/tools/mod_mailAbo.php
Bugfix for delete wmc problem, wmc2ol and script for mail subscribers.
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2011-02-21 21:56:11 UTC (rev 7633)
+++ trunk/mapbender/http/classes/class_wmc.php 2011-02-22 16:57:49 UTC (rev 7634)
@@ -281,6 +281,7 @@
$publicWmcIdArray = self::getPublicWmcIds();
$wmcIdArray = array_keys( array_flip(array_merge($wmcOwnerArray, $publicWmcIdArray)));
} else {
+ $publicWmcIdArray = array();
$wmcIdArray=$wmcOwnerArray;
// get WMC data
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js 2011-02-21 21:56:11 UTC (rev 7633)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js 2011-02-22 16:57:49 UTC (rev 7634)
@@ -53,7 +53,7 @@
"labelOpenLayersUrl": "Link",
"labelCurrentState": "currentState",
"labelDeleteWmc": "delete this WMC",
- "confirmDelete": "Do you really want to delete WMC '%s'?",
+ "confirmDelete": "Do you really want to delete WMC",
"labelLoadWmc": "load this WMC",
"labelMergeWmc": "merge this WMC",
"labelAppendWmc": "append WMC",
Modified: trunk/mapbender/http/php/mod_wmc2ol.php
--- trunk/mapbender/http/php/mod_wmc2ol.php 2011-02-21 21:56:11 UTC (rev 7633)
+++ trunk/mapbender/http/php/mod_wmc2ol.php 2011-02-22 16:57:49 UTC (rev 7634)
@@ -181,6 +181,14 @@
$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_serial_id = $1";
$res = db_prep_query($sql, array($wmc_id), array("s"));
$wmc = db_fetch_row($res);
+ //control if wmc was found else use old wmc_id
+ if (!$wmc[0]) {
+ $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1";
+ $res = db_prep_query($sql, array($wmc_id), array("s"));
+ $wmc = db_fetch_row($res);
+ //echo "Wmc with this id was not found in Database!<br>";
+ //die;
//Read out WMC into XML object
$xml=simplexml_load_string($wmc[0], "SimpleXMLElement", LIBXML_NOBLANKS);
if ($_REQUEST['withoutBody'] == '1') {
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2011-02-21 21:56:11 UTC (rev 7633)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2011-02-22 16:57:49 UTC (rev 7634)
@@ -2311,4 +2311,6 @@
msgid "Preview could not be created"
msgstr "Vorschau konnte nicht gespeichert werden"
+#:../tools/mod_mailAbo.php
+msgid "test1"
+msgstr "test2"
Modified: trunk/mapbender/tools/mod_mailAbo.php
--- trunk/mapbender/tools/mod_mailAbo.php 2011-02-21 21:56:11 UTC (rev 7633)
+++ trunk/mapbender/tools/mod_mailAbo.php 2011-02-22 16:57:49 UTC (rev 7634)
@@ -1,8 +1,4 @@
<?php
-# $Id: mod_monitorCapabilities_main.php 1240 2007-10-24 09:27:00Z baudson $
-# http://www.mapbender.org/index.php/Monitor_Capabilities
-# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2, or (at your option)
@@ -16,13 +12,10 @@
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require_once(dirname(__FILE__)."/../core/globalSettings.php");
require_once(dirname(__FILE__)."/../http/classes/class_administration.php");
require_once(dirname(__FILE__)."/../http/classes/class_user.php");
$admin = new administration();
function getRootLayerId ($wms_id) {
$sql = "SELECT layer_id FROM layer, wms " .
"WHERE wms.wms_id = layer.fkey_wms_id AND layer_pos='0' " .
@@ -33,11 +26,9 @@
$row=db_fetch_array($res);
return $row ? $row["layer_id"] : null;
-//Herauslesen der User die in der Tabelle mb_user_abo_ows eingetragen sind
+//Read out user which have subscribed some services (abo)
$sql = "SELECT DISTINCT fkey_mb_user_id FROM mb_user_abo_ows";
$res = db_query($sql);
$cnt = 0;
$user_id_all=array();
while($row = db_fetch_array($res)){
@@ -46,9 +37,7 @@
echo "User_id: ". $row["fkey_mb_user_id"] ."\n";
$cnt++;
$cnt=0;
$mail_user_topic = _mb("Mapbender subscribers notification"); // "GeoPortal.rlp Mitteilung WMS Abonennten"
$number_of_users_text = _mb("Number of users"); // "Zahl der eingetragenen User IDs"
$subscribed_wms_text = _mb("All WMS subscribed by this user"); // "Alle abonnierten WMS des Users"
@@ -72,49 +61,41 @@
// Ihnen beantragt. Diese E-Mail-Benachrichtigung können Sie jederzeit
// abbestellen, indem Sie das Abonnement über die Metadatenanzeige im
// GeoPortal.rlp deaktivieren.\n http://www.geoportal.rlp.de
echo "\n" . $number_of_users_text . ": " . count($user_id_all) . "\n";
for ($iz = 0; $iz < count($user_id_all); $iz++) {
$userid = $user_id_all[$iz];
echo "User: ".$userid."\n";
- //Herauslesen abonnierten Dienste aus Tabelle mb_user_abo_ows
+ //read out services from mb_user_abo_ows
$sql="SELECT fkey_wms_id FROM mb_user_abo_ows WHERE fkey_mb_user_id = $1";
$v=array($userid);
$t=array('i');
$res=db_prep_query($sql,$v,$t);
$cnt = 0;
- //Initialisieren des Arrays
+ //initialize array
$wms_id_all=array();
echo $subscribed_wms_text . ":\n";
- //Herauslesen der Ergebnisse
+ //read results
$wms_id_all[$cnt] = $row["fkey_wms_id"];
$cnt++;
echo "WMS: " . implode(",", $wms_id_all) . "\n";
$mailhead="";
$body="";
- //Auslesen der Monitoring Ergebnisse aus mb_monitor
+ //read results from mb_monitor
for ($iz2=0; $iz2<count($wms_id_all);$iz2++){
$wmsid = $wms_id_all[$iz2];
- #echo "WMS: ".$wmsid."\n";
$sql = "SELECT status, status_comment, to_timestamp(timestamp_end) " .
"AS timestamp_end FROM mb_monitor WHERE fkey_wms_id = $1 " .
"ORDER BY timestamp_end DESC LIMIT 1";
$v = array($wmsid);
$t = array('i');
+ //read results
$row = db_fetch_array($res);
$wms_monitor_status = $row["status"];
$wms_monitor_status_comment = $row["status_comment"];
$wms_monitor_timestamp_end = $row["timestamp_end"];
echo $wms_with_problems_text . ":\n";
#read wms_title
$sql="SELECT wms_title FROM wms WHERE wms_id = $1";
@@ -122,9 +103,7 @@
$t_wms_t = array('i');
$res_wms_t = db_prep_query($sql, $v_wms_t, $t_wms_t);
$row_wms_t = db_fetch_array($res_wms_t);
if ($wms_monitor_status == '-1') {
$metadataUrl = preg_replace(
"/(.*)frames\/login.php/",
"$1php/mod_layerMetadata.php?id=",
@@ -136,10 +115,9 @@
$metadata_text . ": " . $metadataUrl . getRootLayerId ($wmsid)."\n\n";
- //Absenden der Mail an einzelnen User (falls ein Dienst nicht erreichbar ist)
+ //send mail to subscribers (if a service (capabilities doc) is not available)
if ($body) {
$body .= "\n" . $body_text;
$time = strval(time()-2);
$error_msg = "";
if ($admin->getEmailByUserId($userid)) {
@@ -165,4 +143,4 @@
\ No newline at end of file
More information about the Mapbender_commits
