[Mapbender-commits] r7638 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Feb 23 05:13:28 EST 2011
Author: kmq
Date: 2011-02-23 02:13:28 -0800 (Wed, 23 Feb 2011)
New Revision: 7638
   trunk/mapbender/http/classes/class_wfs_1_0_factory.php
   trunk/mapbender/http/classes/class_wfs_1_1_factory.php
fix for ticket #778
Modified: trunk/mapbender/http/classes/class_wfs_1_0_factory.php
--- trunk/mapbender/http/classes/class_wfs_1_0_factory.php	2011-02-22 23:59:00 UTC (rev 7637)
+++ trunk/mapbender/http/classes/class_wfs_1_0_factory.php	2011-02-23 10:13:28 UTC (rev 7638)
@@ -44,37 +44,57 @@
 	protected function createFeatureTypeFromXml ($xml, $myWfs) {
 		$newFeatureType = new WfsFeatureType($myWfs);
-		$admin = new administration();
-		$values = $admin->parseXml($xml);
+		$doc = new DOMDocument();
+		$doc->loadXML($xml);
+		$xpath =  new DOMXpath($doc);
+		$xpath->registerNamespace("xs","http://www.w3.org/2001/XMLSchema");
-		foreach ($values as $element) {
-			if ($this->sepNameSpace($element[tag]) == "schema" && $element[type] == "open") {
-				$section = "namespace";
+		// populate a Namespaces Hastable where we can use thec namesopace as a lookup for the prefix
+		// and also keep a
+		$namespaces = array();
+		$namespaceList = $xpath->query("//namespace::*");
+		$targetNamespace = $doc->documentElement->getAttribute("targetNamespace");
+		$targetNamespaceNode = null;
+		foreach($namespaceList as $namespaceNode){
+			$namespaces[$namespaceNode->nodeValue] = $namespaceNode->localName;
+			if($namespaceNode->nodeValue == $targetNamespace){
+				$targetNamespaceNode = $namespaceNode;
-			if ($section == "namespace" && is_array($element[attributes])) {
-				while (list($k, $val) = each ($element[attributes])) {
-   					if (substr($k, 0, 5) == "xmlns") {
-   						$key = $this->sepNameSpace($k);
-						$newFeatureType->addNamespace($key, $val);
+			$newFeatureType->addNamespace($namespaceNode->localName, $namespaceNode->nodeValue);
+		list($ftLocalname,$ftTypePrefix) = array_reverse(explode(":",$featureTypeName));
+		// for the sake of simplicity we only care about top level elements. Seems to have worked so far
+		$query = sprintf("/xs:schema/xs:element[@name='%s']",$ftLocalname);
+		$elementList = $xpath->query($query);
+		foreach ($elementList as $elementNode){
+			$elementName = $elementNode->getAttribute("name");
+			$elementType = $elementNode->getAttribute("type");
+			// The elementType is now bound to a prefix e.g. topp:housType
+			// if the prefix is in the targetNamespace, changces are good it's defined in this very document
+			// if the prefiox is not in the targetNamespace, it's likely not defined here, and we bail
+			list($elementTypeLocalname,$elementTypePrefix) = array_reverse(explode(":",$elementType));
+			$elementTypeNamespace = $doc->lookupNamespaceURI($elementTypePrefix);
+			if($elementTypeNamespace !== $targetNamespaceNode->nodeValue){
+				$e = new mb_warning("Tried to parse FeatureTypeName $featureTypeName : $elementType is not in the targetNamespace");
+				break;
-			if($this->sepNameSpace($element[tag]) == "complexContent" && $element[type] == "open"){
-				$section = "complexcontent";
+			// Just querying for complexTypes containing a Sequence - good enough for Simple Features
+			$query = sprintf("//xs:complexType[@name='%s']//xs:element",$elementTypeLocalname);
+			$subElementList = $xpath->query($query);
+			$e = new mb_exception("NNN sub $query $subElementList->length");
+			foreach($subElementList as $subElement){
+				$newFeatureType->addElement($subElement->getAttribute('name'), $subElement->getAttribute('type'));
-			if($section == "complexcontent" && $this->sepNameSpace($element[tag]) == "element" && $element[attributes][name]){
-				$newFeatureType->addElement(
-					$element[attributes]["name"],
-					$this->sepNameSpace($element[attributes]["type"])
-			if($this->sepNameSpace($element[tag]) == "complexContent" && $element[type] == "close"){
-				$section = "";
-		return $newFeatureType;
+		return $newFeatureType;
@@ -203,4 +223,4 @@
 		return parent::createFromDb($id, $myWfs);
\ No newline at end of file
Modified: trunk/mapbender/http/classes/class_wfs_1_1_factory.php
--- trunk/mapbender/http/classes/class_wfs_1_1_factory.php	2011-02-22 23:59:00 UTC (rev 7637)
+++ trunk/mapbender/http/classes/class_wfs_1_1_factory.php	2011-02-23 10:13:28 UTC (rev 7638)
@@ -76,38 +76,64 @@
 		return $this->createFeatureTypeFromXml ($xml, $aWfs, $featureTypeName);
+	 * Given an XSD document (usually from a DescribefeatureType Operation)
+	 * @returns a WfsFeatureType
 	protected function createFeatureTypeFromXml ($xml, $myWfs, $featureTypeName) {
+				break;
-			if($this->sepNameSpace($element[tag]) == "complexType" && $element[type] == "open" && $element[attributes]["name"] === $featureTypeName . "Type"){
-				$section = "complexType";
-			if($section == "complexType" && $this->sepNameSpace($element[tag]) == "element" && $element[attributes][name]){
-			if($this->sepNameSpace($element[tag]) == "complexType" && $element[type] == "close"){
-				$section = "";
@@ -248,4 +274,4 @@
More information about the Mapbender_commits mailing list
