[Mapbender-commits] r7656 - in trunk/mapbender: http/classes
http/php http_auth/http owsproxy/http
svn_mapbender at osgeo.org
Sun Feb 27 07:32:08 EST 2011
Author: armin11
Date: 2011-02-27 04:32:08 -0800 (Sun, 27 Feb 2011)
New Revision: 7656
trunk/mapbender/http/classes/class_administration.php
trunk/mapbender/http/classes/class_connector.php
trunk/mapbender/http/php/wms.php
trunk/mapbender/http_auth/http/index.php
trunk/mapbender/owsproxy/http/index.php
Bugfixes from geoportal.rlp - concerning the http_auth, owsproxy and the connector class.
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php 2011-02-26 15:57:18 UTC (rev 7655)
+++ trunk/mapbender/http/classes/class_administration.php 2011-02-27 12:32:08 UTC (rev 7656)
@@ -1216,6 +1216,13 @@
// deprecated! use User->isLayerAccessible
function getLayerPermission($wms_id, $layer_name, $user_id){
+ //prohibit problems with layer names
+ $layer_name = urldecode($layer_name);
+ if (!is_int($layer_id)) {//TODO: do this also in User->isLayerAccessible
+ $e = new mb_exception("No id for the requested layer with name '".$layer_name."' found in database!");
+ return false;
$layer_id = $this->getLayerIdByLayerName($wms_id,$layer_name);
$array_guis = $this->getGuisByPermission($user_id,true);
$v = array();
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php 2011-02-26 15:57:18 UTC (rev 7655)
+++ trunk/mapbender/http/classes/class_connector.php 2011-02-27 12:32:08 UTC (rev 7656)
@@ -201,6 +201,8 @@
curl_setopt($ch, CURLOPT_BINARYTRANSFER, true); //for images
curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
+ //dont store and load cookies from previous sessions
+ curl_setopt($ch, CURLOPT_COOKIESESSION, true);
//allow https connections and handle certificates quite simply ;-)
curl_setopt($ch,CURLOPT_SSL_VERIFYHOST,0);
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0);
Modified: trunk/mapbender/http/php/wms.php
--- trunk/mapbender/http/php/wms.php 2011-02-26 15:57:18 UTC (rev 7655)
+++ trunk/mapbender/http/php/wms.php 2011-02-27 12:32:08 UTC (rev 7656)
@@ -19,23 +19,26 @@
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__)."/../classes/class_layer_monitor.php");
-ob_start();
+//ob_start(); //TODO why?
// make all parameters available as upper case
foreach($_GET as $key => $val) {
$_GET[strtoupper($key)] = $val;
$requestType = $_GET["REQUEST"];
$version = $_GET["VERSION"];
$service = strtoupper($_GET["SERVICE"]);
$layerId = $_GET["LAYER_ID"];
$updateSequence = intval($_GET["UPDATESEQUENCE"]);
-$mapbenderMetadataUrl = preg_replace("/(.*)frames\/login.php/", "$1php/mod_layerMetadata.php?id=", LOGIN);
+//$mapbenderMetadataUrl = preg_replace("/(.*)frames\/login.php/", "$1php/mod_showMetadata.php?resource=layer&id=", LOGIN);
+$mapbenderMetadaUrl = $_SERVER['HTTP_HOST']."/mapbender/php/mod_showMetadata.php?resource=layer&id=";
+if (isset($_SERVER["HTTPS"])){
+ $urlPrefix = "https://";
+} else {
+ $urlPrefix = "http://";
+$mapbenderMetadataUrl = $urlPrefix.$mapbenderMetadataUrl;
* Creates an XML Exception according to WMS 1.1.1
@@ -47,11 +50,9 @@
// see http://de2.php.net/manual/de/domimplementation.createdocumenttype.php
$imp = new DOMImplementation;
$dtd = $imp->createDocumentType("ServiceExceptionReport", "", "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd");
$doc = $imp->createDocument("", "", $dtd);
$doc->encoding = 'UTF-8';
$doc->standalone = false;
$el = $doc->createElement("ServiceExceptionReport");
$exc = $doc->createElement("ServiceException", $errorMessage);
if ($errorCode) {
@@ -59,10 +60,8 @@
$el->appendChild($exc);
$doc->appendChild($el);
return $doc->saveXML();
// check if service param is set
@@ -71,28 +70,23 @@
echo createExceptionXml("", "Parameter SERVICE invalid");
die;
// check if request param is set
if (!isset($requestType) || $requestType === "" ||
- ($service == "WMS" && $requestType != "GetCapabilities")) {
+ ($service == "WMS" && $requestType != "GetCapabilities")) {
header("Content-type: application/xhtml+xml; charset=UTF-8");
echo createExceptionXml("", "Parameter REQUEST invalid");
die;
// check if version param is set
if (!isset($version) || $version === "" ||
- ($service == "WMS" && $version != "1.1.1")) {
+ ($service == "WMS" && $version != "1.1.1")) {
// optional parameter, set to 1.1.1 if not set
$version = "1.1.1";
// check if layer id is set
@@ -105,7 +99,6 @@
die;
// check if layer is stored in database
@@ -115,7 +108,6 @@
$t = array("i");
$res_wms_sql = db_prep_query($wms_sql, $v, $t);
$wms_row = db_fetch_array($res_wms_sql);
if (!$wms_row["wms_id"]) {
// TO DO: create exception XML
@@ -125,12 +117,10 @@
die;
// check if update sequence is valid
$updateSequenceDb = intval($wms_row["wms_timestamp"]);
if ($updateSequence) {
if ($updateSequence > $updateSequenceDb) {
// Exception: code=InvalidUpdateSequence
@@ -145,24 +135,20 @@
die;
// increment layer count
$monitor = new Layer_load_count();
$monitor->increment($layerId);
// START TO CREATE CAPABILITIES DOC
// (return most recent Capabilities XML)
$doc = new DOMDocument('1.0');
#Check for existing content in database
#to be adopted TODO armin
function validate ($contactInformation_column) {
@@ -173,25 +159,20 @@
$contactinformationcheck = false;
return $contactinformationcheck;
#Creating the "WMT_MS_Capabilities" node
$wmt_ms_capabilities = $doc->createElement("WMT_MS_Capabilities");
$wmt_ms_capabilities->setAttribute("updateSequence", $wms_row["wms_timestamp"]);
$wmt_ms_capabilities = $doc->appendChild($wmt_ms_capabilities);
$wmt_ms_capabilities->setAttribute('version', '1.1.1');
#Creatig the "Service" node
$service = $doc->createElement("Service");
$service = $wmt_ms_capabilities->appendChild($service);
#Creating the "Name" Node
$name = $doc->createElement("Name");
$name = $service->appendChild($name);
$nameText = $doc->createTextNode("OGC:WMS");
$nameText = $name->appendChild($nameText);
#Creating the "Title" node
if($wms_row['wms_title'] <> "" AND $wms_row['wms_title'] <> NULL) {
$title = $doc->createElement("Title");
@@ -199,18 +180,16 @@
$titleText = $doc->createTextNode($wms_row['wms_title']);
$titleText = $title->appendChild($titleText);
#Creating the "Abstract" node
if($wms_row['wms_abstract'] <> "" AND $wms_row['wms_abstract'] <> NULL) {
$abstract = $doc->createElement("Abstract");
$abstract = $service->appendChild($abstract);
$abstractText = $doc->createTextNode($wms_row['wms_abstract']);
$abstractText = $abstract->appendChild($abstractText);
# switch URLs for OWSPROXY
if($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL) {
- $tmpOR = "http://".$_SERVER["HTTP_HOST"]."/owsproxy/".session_id()."/".$wms_row["wms_owsproxy"]."?";
+ $tmpOR = $urlPrefix.$_SERVER["HTTP_HOST"]."/owsproxy/".session_id()."/".$wms_row["wms_owsproxy"]."?";
$tmpOR = str_replace(SERVERIP, SERVERNAME, $tmpOR);
$wms_row['wms_getcapabilities'] = $tmpOR;
$wms_row['wms_getmap'] = $tmpOR;
@@ -233,9 +212,7 @@
$onlineResource->setAttribute("xlink:href", $onlRes);
$onlineResource->setAttribute("xlink:type", "simple");
#Insert contact information
#Creating "Contact Information" node
if (validate($wms_row['contactperson']) &&
validate($wms_row['contactorganization']) &&
@@ -250,14 +227,12 @@
$contactInformation = $doc->createElement("ContactInformation");
$contactInformation = $service->appendChild($contactInformation);
#Creating "Contact Person Primary" node
if(validate($wms_row['contactperson']) AND validate($wms_row['contactorganization']))
$contactPersonPrimary = $doc->createElement("ContactPersonPrimary");
$contactPersonPrimary = $contactInformation->appendChild($contactPersonPrimary);
#Creating the "ContactPerson" node
if(validate($wms_row['contactperson']))
@@ -266,7 +241,6 @@
$contactPersonText = $doc->createTextNode($wms_row['contactperson']);
$contactPersonText = $contactPerson->appendChild($contactPersonText);
#Creating the "ContactOrganization" node
if(validate($wms_row['contactorganization']))
@@ -275,8 +249,6 @@
$contactOrganizationText = $doc->createTextNode($wms_row['contactorganization']);
$contactOrganizationText = $contactOrganization->appendChild($contactOrganizationText);
#Creating the "ContactPosition" node
if(validate($wms_row['contactposition']))
@@ -285,29 +257,24 @@
$contactPositionText = $doc->createTextNode($wms_row['contactposition']);
$contactPositionText = $contactPosition->appendChild($contactPositionText);
#Creating "ContactAddress" node
if(validate($wms_row['address']) AND validate($wms_row['city']) AND validate($wms_row['stateorprovince']) AND validate($wms_row['postcode']) /*AND validate($wms_row['country'])*/)
$contactAddress = $doc->createElement("ContactAddress");
$contactAddress = $contactInformation->appendChild($contactAddress);
#Creating the "AddressType" and "Address" textnode
if(validate($wms_row['address']))
$addressType = $doc->createElement("AddressType");
$addressType = $contactAddress->appendChild($addressType);
$addresstypeText = $doc->createTextNode("postal");
$addresstypeText = $addressType->appendChild($addresstypeText);
$address = $doc->createElement("Address");
$address = $contactAddress->appendChild($address);
$addressText = $doc->createTextNode($wms_row['address']);
$addressText = $address->appendChild($addressText);
#Creatig the "City" node
if(validate($wms_row['city']))
@@ -325,7 +292,6 @@
$stateOrProvinceText = $doc->createTextNode($wms_row['stateorprovince']);
$stateOrProvinceText = $stateOrProvince->appendChild($stateOrProvinceText);
#Creatig the "PostCode" node
if(validate($wms_row['postcode']))
@@ -334,8 +300,6 @@
$postCodeText = $doc->createTextNode($wms_row['postcode']);
$postCodeText = $postCode->appendChild($postCodeText);
#Creatig the "Country" node
if(isset($wms_row['country']) AND validate($wms_row['country']))
@@ -344,7 +308,6 @@
$countryText = $doc->createTextNode($wms_row['country']);
$countryText = $country->appendChild($countryText);
#Creatig the "ContactVoiceTelephone" node
if(validate($wms_row['contactvoicetelephone']))
@@ -353,7 +316,6 @@
$contactVoiceTelephoneText = $doc->createTextNode($wms_row['contactvoicetelephone']);
$contactVoiceTelephoneText = $contactVoiceTelephone->appendChild($contactVoiceTelephoneText);
#Creatig the "ContactFacsimileTelephone" node
if(validate($wms_row['contactfacsimiletelephone']))
@@ -362,7 +324,6 @@
$contactFacsimileTelephoneText = $doc->createTextNode($wms_row['contactfacsimiletelephone']);
$contactFacsimileTelephoneText = $contactFacsimileTelephone->appendChild($contactFacsimileTelephoneText);
#Creatig the "ContactElectronicMailAddress" node
if(validate($wms_row['contactelectronicmailaddress']))
@@ -372,7 +333,6 @@
$contactElectronicMailAddressText = $contactElectronicMailAddress->appendChild($contactElectronicMailAddressText);
#Creatig the "Fees" node
if(validate($wms_row['fees']))
@@ -380,8 +340,7 @@
$fees = $service->appendChild($fees);
$feesText = $doc->createTextNode($wms_row['fees']);
$feesText = $fees->appendChild($feesText);
#Creating the "AccessConstraints" node
if(validate($wms_row['accessconstraints']))
@@ -390,22 +349,17 @@
$accessConstraintsText = $doc->createTextNode($wms_row['accessconstraints']);
$accessConstraintsText = $accessConstraints->appendChild($accessConstraintsText);
#Creatig the "Capability" node
$capability = $doc->createElement("Capability");
$capability = $wmt_ms_capabilities->appendChild($capability);
#Creatig the "Request" node
$request = $doc->createElement("Request");
$request = $capability->appendChild($request);
#GetCapabilities
#Creatig the "GetCapabilities" node
$getCapabilities = $doc->createElement("GetCapabilities");
$getCapabilities = $request->appendChild($getCapabilities);
#Creatig the "Format" node
$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'capability'";
$v = array($wms_row['wms_id']);
@@ -421,24 +375,17 @@
$format = $doc->createElement("Format");
$format = $getCapabilities->appendChild($format);
$formatText = $doc->createTextNode('application/vnd.ogc.wms_xml');
- $formatText = $format->appendChild($formatText);
+ $formatText = $format->appendChild($formatText);
#Creating the "DCPType" node
$DCPType = $doc->createElement("DCPType");
$DCPType = $getCapabilities->appendChild($DCPType);
#Creating the "HTTP" node
$HTTP = $doc->createElement("HTTP");
$HTTP = $DCPType->appendChild($HTTP);
#Creating the "Get" node
$get = $doc->createElement("Get");
$get = $HTTP->appendChild($get);
#Creating the "OnlineResource" node
//if ($wms_row['wms_getcapabilities'] <> "" AND $wms_row['wms_getcapabilities'] <> NULL) {
$onlineResource = $doc->createElement("OnlineResource");
$onlineResource = $get->appendChild($onlineResource);
@@ -454,11 +401,9 @@
#Creating the "Post" node
$post = $doc->createElement("Post");
$post = $HTTP->appendChild($post);
@@ -475,7 +420,6 @@
#GetMap
#Creatig the "GetMap" node
@@ -1092,5 +1036,5 @@
header("Content-type: application/xml; charset=UTF-8");
-echo $doc->saveXml();
+echo ltrim(" ",$doc->saveXml());
Modified: trunk/mapbender/http_auth/http/index.php
--- trunk/mapbender/http_auth/http/index.php 2011-02-26 15:57:18 UTC (rev 7655)
+++ trunk/mapbender/http_auth/http/index.php 2011-02-27 12:32:08 UTC (rev 7656)
@@ -68,13 +68,13 @@
//if we are here - authentication has been done well!
//let's do the proxy things (came from owsproxy.php):
-$postdata = $HTTP_RAW_POST_DATA;
-$layerId = $_REQUEST['layer_id'];
+$postdata = $HTTP_RAW_POST_DATA;
+$layerId = $_REQUEST['layer_id'];
$query = new QueryHandler();
-// an array with keys and values toLoserCase -> caseinsensitiv
+// an array with keys and values toLoserCase -> caseinsensitiv
$reqParams = $query->getRequestParams();
$n = new administration();
$wmsId = getWmsIdByLayerId($layerId);
@@ -94,44 +94,50 @@
//what the proxy does
switch (strtolower($reqParams['request'])) {
- case 'getcapabilities':
- $arrayOnlineresources = checkWmsPermission($wmsId,$userInformation[0]);
- $query->setOnlineResource($arrayOnlineresources['wms_getcapabilities']);
- $request = preg_replace("/(.*)frames\/login.php/", "$1php/wms.php?layer_id=".$layerId, LOGIN);
+ case 'getcapabilities':
+ $arrayOnlineresources = checkWmsPermission($wmsId,$userInformation[0]);
+ $query->setOnlineResource($arrayOnlineresources['wms_getcapabilities']);
+ //$request = preg_replace("/(.*)frames\/login.php/", "$1php/wms.php?layer_id=".$layerId, LOGIN);
+ if (isset($_SERVER["HTTPS"])){
+ } else {
+ $request = $urlPrefix.$_SERVER['HTTP_HOST']."/mapbender/php/wms.php?layer_id=".$layer_id;
$requestFull .= $request.'&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS';
- if(isset($auth)){
+ if(isset($auth)){
getCapabilities($request,$requestFull,$auth);
else {
getCapabilities($request,$requestFull);
- break;
- case 'getfeatureinfo':
+ break;
+ case 'getfeatureinfo':
$query->setOnlineResource($arrayOnlineresources['wms_getfeatureinfo']);
$layers = checkLayerPermission($wmsId,$reqParams['layers'],$userInformation[0]);
if ($layers == '' ) {
throwE("GetFeatureInfo permission denied on layer with id".$layerId);
die();
$request = $query->getRequest();
- if(isset($auth)){
+ if(isset($auth)){
getFeatureInfo($request,$auth);
else {
getFeatureInfo($request);
- break;
- case 'getmap':
- $query->setOnlineResource($arrayOnlineresources['wms_getmap']);
+ break;
+ case 'getmap':
+ $query->setOnlineResource($arrayOnlineresources['wms_getmap']);
throwE("GetMap permission denied on layer with id ".$layerId);
die();
- $query->setParam("layers",$layers);
+ $query->setParam("layers",urldecode($layers));
#log proxy requests
if($n->getWmsLogTag($wmsId)==1) {
@@ -141,7 +147,7 @@
$price=intval($n->getWmsPrice($wmsId));
$n->logWmsProxyRequest($wmsId,$userInformation[0],$request,$price);
- if(isset($auth)){
+ if(isset($auth)){
getImage($request,$auth);
else {
@@ -151,15 +157,15 @@
case 'getlegendgraphic':
$url = getLegendUrl($wmsId);
$e = new mb_exception("URL for getlegendgraphic: ");
- if(isset($auth)){
+ if(isset($auth)){
getImage($url,$auth);
else {
getImage($url);
break;
- default:
-echo 'Your are logged in as: <b>' .$requestHeaderArray['username'].'</b> and requested the layer with id=<b>'.$layerId.'</b> but your request is not a valid OWS request';
+ default:
+echo 'Your are logged in as: <b>' .$requestHeaderArray['username'].'</b> and requested the layer with id=<b>'.$layerId.'</b> but your request is not a valid OWS request';
//functions for http_auth
@@ -204,186 +210,186 @@
//functions of owsproxy/http/index.php
-function throwE($e){
+function throwE($e){
global $reqParams, $imageformats;
- if(in_array($reqParams['format'],$imageformats)){
- throwImage($e);
- else{
- throwText($e);
+ if(in_array($reqParams['format'],$imageformats)){
+ throwImage($e);
+ else{
+ throwText($e);
function throwImage($e){
global $reqParams;
if (!$reqParams['width'] || !$reqParams['height']) { //width or height are not set by ows request - maybe for legendgraphics
$width = 300;
$height = 20;
- $image = imagecreate($width,$height);
- $transparent = ImageColorAllocate($image,155,155,155);
- ImageFilledRectangle($image,0,0,$width,$height,$transparent);
- imagecolortransparent($image, $transparent);
- $text_color = ImageColorAllocate ($image, 233, 14, 91);
- for($i=0; $i<count($e); $i++){
- ImageString ($image, 3, 5, $i*20, $e[$i], $text_color);
- responseImage($image);
-function throwText($e){
- echo join(" ", $e);
-function responseImage($im){
- global $reqParams;
- $format = $reqParams['format'];
- if($format == 'image/png'){header("Content-Type: image/png");}
- if($format == 'image/jpeg' || $format == 'image/jpg'){header("Content-Type: image/jpeg");}
- if($format == 'image/gif'){header("Content-Type: image/gif");}
- if($format == 'image/png'){imagepng($im);}
- if($format == 'image/jpeg' || $format == 'image/jpg'){imagejpeg($im);}
- if($format == 'image/gif'){imagegif($im);}
-function completeURL($url){
- $mykeys = array_keys($reqParams);
- for($i=0; $i<count($mykeys);$i++){
- if($i > 0){ $url .= "&"; }
- $url .= $mykeys[$i]."=".urlencode($reqParams[$mykeys[$i]]);
- return $url;
+ $image = imagecreate($width,$height);
+ $transparent = ImageColorAllocate($image,155,155,155);
+ ImageFilledRectangle($image,0,0,$width,$height,$transparent);
+ imagecolortransparent($image, $transparent);
+ $text_color = ImageColorAllocate ($image, 233, 14, 91);
+ for($i=0; $i<count($e); $i++){
+ ImageString ($image, 3, 5, $i*20, $e[$i], $text_color);
+ responseImage($image);
+function throwText($e){
+ echo join(" ", $e);
+function responseImage($im){
+ global $reqParams;
+ $format = $reqParams['format'];
+ if($format == 'image/png'){header("Content-Type: image/png");}
+ if($format == 'image/jpeg' || $format == 'image/jpg'){header("Content-Type: image/jpeg");}
+ if($format == 'image/gif'){header("Content-Type: image/gif");}
+ if($format == 'image/png'){imagepng($im);}
+ if($format == 'image/jpeg' || $format == 'image/jpg'){imagejpeg($im);}
+ if($format == 'image/gif'){imagegif($im);}
+function completeURL($url){
+ $mykeys = array_keys($reqParams);
+ for($i=0; $i<count($mykeys);$i++){
+ if($i > 0){ $url .= "&"; }
+ $url .= $mykeys[$i]."=".urlencode($reqParams[$mykeys[$i]]);
+ return $url;
* fetch and returns an image to client
* @param string the original url of the image to send
-function getImage($or){
+function getImage($or){
header("Content-Type: ".$reqParams['format']);
if (func_num_args() == 2) { //new for HTTP Authentication
$auth = func_get_arg(1);
echo getDocumentContent($or,$auth);
else
echo getDocumentContent($or);
- * fetchs and returns the content of the FeatureInfo Response
- * @param string the url of the FeatureInfoRequest
- * @return string the content of the FeatureInfo document
-function getFeatureInfo($url){
- global $info_format;
- $e = new mb_exception("owsproxy: Try to fetch FeatureInfoRequest: ".$url);
+ * fetchs and returns the content of the FeatureInfo Response
+ * @param string the url of the FeatureInfoRequest
+ * @return string the content of the FeatureInfo document
+function getFeatureInfo($url){
+ global $info_format;
+ $e = new mb_exception("owsproxy: Try to fetch FeatureInfoRequest: ".$url);
header("Content-Type: ".$info_format);
echo getDocumentContent($url,$auth);
else
echo getDocumentContent($url);
-function matchUrls($content){
- if(!session_is_registered("owsproxyUrls")){
- $_SESSION["owsproxyUrls"] = array();
- $_SESSION["owsproxyUrls"]["id"] = array();
- $_SESSION["owsproxyUrls"]["url"] = array();
- $pattern = "/[\"|\'](https*:\/\/[^\"|^\']*)[\"|\']/";
- preg_match_all($pattern,$content,$matches);
- for($i=0; $i<count($matches[1]); $i++){
- $req = $matches[1][$i];
+function matchUrls($content){
+ if(!session_is_registered("owsproxyUrls")){
+ $_SESSION["owsproxyUrls"] = array();
+ $_SESSION["owsproxyUrls"]["id"] = array();
+ $_SESSION["owsproxyUrls"]["url"] = array();
+ $pattern = "/[\"|\'](https*:\/\/[^\"|^\']*)[\"|\']/";
+ preg_match_all($pattern,$content,$matches);
+ for($i=0; $i<count($matches[1]); $i++){
+ $req = $matches[1][$i];
$e = new mb_exception("Gefundene URL ".$i.": ".$req);
#$notice = new mb_notice("owsproxy id:".$req);
- $id = registerURL($req);
- $extReq = setExternalRequest($id);
+ $id = registerURL($req);
+ $extReq = setExternalRequest($id);
$e = new mb_exception("MD5 URL ".$id."-Externer Link: ".$extReq);
- $content = str_replace($req,$extReq,$content);
- return $content;
+ $content = str_replace($req,$extReq,$content);
+ return $content;
-function setExternalRequest($id){
- global $reqParams,$query;
- $extReq = "http://".$_SESSION['HTTP_HOST'] ."/owsproxy/". $reqParams['sid'] ."/".$id."?request=external";
- return $extReq;
-function getExternalRequest($id){
- for($i=0; $i<count($_SESSION["owsproxyUrls"]["url"]); $i++){
- if($id == $_SESSION["owsproxyUrls"]["id"][$i]){
- $cUrl = $_SESSION["owsproxyUrls"]["url"][$i];
- $query_string = removeOWSGetParams($_SERVER["QUERY_STRING"]);
- if($query_string != ''){
- $cUrl .= getConjunctionCharacter($cUrl).$query_string;
- $metainfo = get_headers($cUrl,1);
- // just for the stupid InternetExplorer
- header('Pragma: private');
- header('Cache-control: private, must-revalidate');
- header("Content-Type: ".$metainfo['Content-Type']);
- $content = getDocumentContent($cUrl,false);
- #$content = matchUrls($content); //In the case of http_auth - this is not possible cause we cannot save them in the header - maybe we could create a special session to do so later on?
- echo $content;
-function removeOWSGetParams($query_string){
- $r = preg_replace("/.*request=external&/","",$query_string);
- #return $r;
+function setExternalRequest($id){
+ global $reqParams,$query;
+ $extReq = "http://".$_SESSION['HTTP_HOST'] ."/owsproxy/". $reqParams['sid'] ."/".$id."?request=external";
+ return $extReq;
+function getExternalRequest($id){
+ for($i=0; $i<count($_SESSION["owsproxyUrls"]["url"]); $i++){
+ if($id == $_SESSION["owsproxyUrls"]["id"][$i]){
+ $cUrl = $_SESSION["owsproxyUrls"]["url"][$i];
+ $query_string = removeOWSGetParams($_SERVER["QUERY_STRING"]);
+ if($query_string != ''){
+ $cUrl .= getConjunctionCharacter($cUrl).$query_string;
+ $metainfo = get_headers($cUrl,1);
+ // just for the stupid InternetExplorer
+ header('Pragma: private');
+ header('Cache-control: private, must-revalidate');
+ header("Content-Type: ".$metainfo['Content-Type']);
+ $content = getDocumentContent($cUrl,false);
+ #$content = matchUrls($content); //In the case of http_auth - this is not possible cause we cannot save them in the header - maybe we could create a special session to do so later on?
+ echo $content;
+function removeOWSGetParams($query_string){
+ $r = preg_replace("/.*request=external&/","",$query_string);
+ #return $r;
return "";
-function getConjunctionCharacter($url){
- if(strpos($url,"?")){
- if(strpos($url,"?") == strlen($url)){
- $cchar = "";
- }else if(strpos($url,"&") == strlen($url)){
- $cchar = "";
- }else{
- $cchar = "&";
- if(strpos($url,"?") === false){
- $cchar = "?";
- return $cchar;
-function registerUrl($url){
- if(!in_array($url,$_SESSION["owsproxyUrls"]["url"])){
+function getConjunctionCharacter($url){
+ if(strpos($url,"?")){
+ if(strpos($url,"?") == strlen($url)){
+ $cchar = "";
+ }else if(strpos($url,"&") == strlen($url)){
+ $cchar = "";
+ }else{
+ $cchar = "&";
+ if(strpos($url,"?") === false){
+ $cchar = "?";
+ return $cchar;
+function registerUrl($url){
+ if(!in_array($url,$_SESSION["owsproxyUrls"]["url"])){
$e = new mb_exception("Is noch net drin!");
- $id = md5($url);
+ $id = md5($url);
$e = new mb_exception("ID: ".$id." URL: ".$url." will be written to session");
- array_push($_SESSION["owsproxyUrls"]["url"],$url);
- array_push($_SESSION["owsproxyUrls"]["id"], $id);
- else{
+ array_push($_SESSION["owsproxyUrls"]["url"],$url);
+ array_push($_SESSION["owsproxyUrls"]["id"], $id);
+ else{
$e = new mb_exception("It was found! Search content and return ID!");
$e = new mb_exception("Content ".$i." : proxyurl:".$_SESSION["owsproxyUrls"]["url"][$i]." - new: ".$url);
- if($url == $_SESSION["owsproxyUrls"]["url"][$i]){
+ if($url == $_SESSION["owsproxyUrls"]["url"][$i]){
$e = new mb_exception("Identical! ID:".$_SESSION["owsproxyUrls"]["id"][$i]." will be used");
- $id = $_SESSION["owsproxyUrls"]["id"][$i];
- return $id;
+ $id = $_SESSION["owsproxyUrls"]["id"][$i];
+ return $id;
-function getCapabilities($request,$requestFull){
+function getCapabilities($request,$requestFull){
global $arrayOnlineresources;
global $layerId;
header("Content-Type: application/xml");
@@ -405,8 +411,8 @@
$new = "href=\"".HTTP_AUTH_PROXY ."/". $layerId."?$1\"";
$pattern = "#href=\"".str_replace('?','\?',str_replace('/','\/',$request))."\"#";
$content = preg_replace($pattern,$new,$content);
- echo $content;
+ echo $content;
@@ -445,58 +451,58 @@
* @param wmsId integer, userId - integer
* @return array array with detailed information about requested wms
-function checkWmsPermission($wmsId,$userId){
+function checkWmsPermission($wmsId,$userId){
global $con, $n;
- $myguis = $n->getGuisByPermission($userId,true);
- $mywms = $n->getWmsByOwnGuis($myguis);
- $sql = "SELECT * FROM wms WHERE wms_id = $1";
- $v = array($wmsId);
- $t = array("s");
- $res = db_prep_query($sql, $v, $t);
- $service = array();
- if($row = db_fetch_array($res)){
- $service["wms_id"] = $row["wms_id"];
- $service["wms_getcapabilities"] = $row["wms_getcapabilities"];
- $service["wms_getmap"] = $row["wms_getmap"];
- $service["wms_getfeatureinfo"] = $row["wms_getfeatureinfo"];
- $service["wms_getcapabilities_doc"] = $row["wms_getcapabilities_doc"];
- if(!$row || count($mywms) == 0){
- throwE(array("No wms data available."));
- die();
- if(!in_array($service["wms_id"], $mywms)){
- throwE(array("Permission denied."," -> ".$service["wms_id"], implode(",", $mywms)));
- die();
- return $service;
+ $myguis = $n->getGuisByPermission($userId,true);
+ $mywms = $n->getWmsByOwnGuis($myguis);
+ $sql = "SELECT * FROM wms WHERE wms_id = $1";
+ $v = array($wmsId);
+ $t = array("s");
+ $res = db_prep_query($sql, $v, $t);
+ $service = array();
+ if($row = db_fetch_array($res)){
+ $service["wms_id"] = $row["wms_id"];
+ $service["wms_getcapabilities"] = $row["wms_getcapabilities"];
+ $service["wms_getmap"] = $row["wms_getmap"];
+ $service["wms_getfeatureinfo"] = $row["wms_getfeatureinfo"];
+ $service["wms_getcapabilities_doc"] = $row["wms_getcapabilities_doc"];
+ if(!$row || count($mywms) == 0){
+ throwE(array("No wms data available."));
+ die();
+ if(!in_array($service["wms_id"], $mywms)){
+ throwE(array("Permission denied."," -> ".$service["wms_id"], implode(",", $mywms)));
+ die();
+ return $service;
-function checkLayerPermission($wms_id,$l,$userId){
- global $n, $owsproxyService;
- $e = new mb_exception("owsproxy: checkLayerpermission: wms: ".$wms_id.", layer: ".$l.' user_id: '.$userId);
- $myl = split(",",$l);
- $r = array();
- foreach($myl as $mysl){
- if($n->getLayerPermission($wms_id, $mysl, $userId) === true){
- array_push($r, $mysl);
- $ret = implode(",",$r);
- return $ret;
+function checkLayerPermission($wms_id,$l,$userId){
+ global $n, $owsproxyService;
+ $e = new mb_exception("owsproxy: checkLayerpermission: wms: ".$wms_id.", layer: ".$l.' user_id: '.$userId);
+ $myl = split(",",$l);
+ $r = array();
+ foreach($myl as $mysl){
+ if($n->getLayerPermission($wms_id, $mysl, $userId) === true){
+ array_push($r, $mysl);
+ $ret = implode(",",$r);
+ return $ret;
function getDocumentContent($url){
$d = new connector($url, $auth);
- else {
+ else {
$d = new connector($url);
- return $d->file;
+ return $d->file;
//extra functions TODO: push them in class_administration.php
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php 2011-02-26 15:57:18 UTC (rev 7655)
+++ trunk/mapbender/owsproxy/http/index.php 2011-02-27 12:32:08 UTC (rev 7656)
@@ -100,7 +100,7 @@
throwE("Permission denied");
die();
+ $query->setParam("layers",urldecode($layers));//the decoding of layernames dont make problems - but not really good names will be requested also ;-)
#log proxy requests
if($n->getWmsLogTag($arrayOnlineresources['wms_id'])==1) {
@@ -126,7 +126,7 @@
die();
if(isset($auth)){
More information about the Mapbender_commits
