[Mapbender-commits] r7425 - in trunk/mapbender/http: classes
javascripts php
svn_mapbender at osgeo.org
Thu Jan 6 11:07:31 EST 2011
Author: armin11
Date: 2011-01-06 08:07:31 -0800 (Thu, 06 Jan 2011)
New Revision: 7425
trunk/mapbender/http/classes/class_wmc.php
trunk/mapbender/http/javascripts/initWmcObj.php
trunk/mapbender/http/php/mod_loadwmc_server.php
New functions to count the loading of public wmc documents. The load_count is stored in the mapbender database and the counting is done, when a wmc is loaded from loadWmc and if a wmc is given thru the GET API.
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2011-01-06 15:38:46 UTC (rev 7424)
+++ trunk/mapbender/http/classes/class_wmc.php 2011-01-06 16:07:31 UTC (rev 7425)
@@ -876,6 +876,64 @@
return true;
+ * increments the wmc_load_count if it has been set before
+ * @param $wmc_id wmc_serial_id
+ public function incrementWmcLoadCount() {
+ $wmcId = $this->wmc_id;
+ //check for public else return false
+ if ($this->isPublic()) {
+ //check if a load_count has been set before
+ //if not been set, set it to 1
+ //else increment it
+ $sql = "SELECT load_count FROM wmc_load_count where fkey_wmc_serial_id = $1;";
+ $v = array($wmcId);
+ $t = array("i");
+ $res = db_prep_query($sql,$v,$t);
+ if(db_error()) {
+ return false;
+ $row = db_fetch_array($res);
+ if ($row) {
+ $e = new mb_exception("class_wmc: incrementWmcLoadCount found entry increment should be performed");
+ $count = $row['load_count'];
+ $count++;
+ $sql = "UPDATE wmc_load_count SET load_count = $2 WHERE fkey_wmc_serial_id = $1;";
+ $v = array($wmcId,$count);
+ $t = array("i","i");
+ } else {
+ $e = new mb_exception("class_wmc: incrementWmcLoadCount dont found entry - new should be set to 1");
+ $sql = "INSERT INTO wmc_load_count (fkey_wmc_serial_id,load_count) VALUES ($1, $2);";
+ $v = array($wmcId,1);
+ return true;
+ return false;
+ * test if the given wmc is public
+ public function isPublic() {
+ $sql = "SELECT wmc_serial_id FROM mb_user_wmc ";
+ $sql .= "WHERE wmc_serial_id = $1 AND wmc_public = 1;";
+ $t = array("i");
+ if (isset($row['wmc_serial_id']) && $row['wmc_serial_id'] != '') {
+ $e = new mb_exception("class_wmc: isPublic is true");
+ return true;
+ $e = new mb_exception("class_wmc: isPublic is false");
+ return false;
// GETTER FUNCTIONS
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php 2011-01-06 15:38:46 UTC (rev 7424)
+++ trunk/mapbender/http/javascripts/initWmcObj.php 2011-01-06 16:07:31 UTC (rev 7425)
@@ -120,6 +120,8 @@
// just make it work for a single Wmc
try {
$wmcGetApi = WmcFactory::createFromDb($input["id"]);
+ //increment load count
+ $wmcGetApi->incrementWmcLoadCount();
catch (Exception $e) {
new mb_exception("Failed to load WMC from DB. Keeping original WMC.");
Modified: trunk/mapbender/http/php/mod_loadwmc_server.php
--- trunk/mapbender/http/php/mod_loadwmc_server.php 2011-01-06 15:38:46 UTC (rev 7424)
+++ trunk/mapbender/http/php/mod_loadwmc_server.php 2011-01-06 16:07:31 UTC (rev 7425)
@@ -57,7 +57,7 @@
$wmcId = $ajaxResponse->getParameter("id");
if ($wmc->createFromDb($wmcId)) {
$updatedWMC = $wmc->updateUrlsFromDb();
- $wmc->createFromXml($updatedWMC);
+ $wmc->createFromXml($updatedWMC);
$skipWms = $ajaxResponse->getParameter("skipWms");
if (is_array($skipWms)) {
@@ -68,6 +68,8 @@
if ($jsArray) {
$resultObj["javascript"] = $jsArray;
+ //increment load_count
+ $wmc->incrementWmcLoadCount();
$ajaxResponse->setResult($resultObj);
$ajaxResponse->setSuccess(true);
break;
@@ -88,8 +90,8 @@
$wmc->createFromXml($wmcDoc);
- $jsArray = $wmc->toJavaScript();
+ $jsArray = $wmc->toJavaScript();
if ($jsArray) {
More information about the Mapbender_commits
